    5. Blockly löst nur zum Teil aus
      Thomas Braun Most Active last edited by Thomas Braun
      Moin!
      Ich hab Probleme mit dem folgenden Blockly:
      on({id: 'nuki-extended.0.smartlocks.wohnungstür.state.lastAction', change: "any"}, async function (obj) {
        var value = obj.state.val;
        if (getState("nuki-extended.0.smartlocks.wohnungstür.state.lastAction").val == 3 && compareTime("7:00", "22:00", "not between")) {
          setState("alexa2.0.Echo-Devices.G0911B0592250842.Commands.speak-volume"/*Volume to use for speak commands*/, 60);
          setStateDelayed("alexa2.0.Echo-Devices.G0911B0592250842.Commands.speak"/*speak*/, 'Hallo Thomas, wie war dein Abend?', 5000, false);
          if (compareTime(getAstroDate("goldenHourEnd", undefined, 0), getAstroDate("sunsetStart", undefined, 0), "not between", null)) {
            getState("alexa2.0.Echo-Devices.G0911B0592250842.Routines.db9242b1-a8bb-4347-bbff-7c55cd8839c2", function (err, state) {
                setState("alexa2.0.Echo-Devices.G0911B0592250842.Routines.db9242b1-a8bb-4347-bbff-7c55cd8839c2"/*Gemutlichkeit*/, state ? !state.val : true);
        } else {
          if (getState("nuki-extended.0.smartlocks.wohnungstür.state.lastAction").val == 3) {
            setState("alexa2.0.Echo-Devices.G0911B0592250842.Commands.speak-volume"/*Volume to use for speak commands*/, 80);
            setStateDelayed("alexa2.0.Echo-Devices.G0911B0592250842.Commands.speak"/*speak*/, 'Hallo Thomas, willkommen zurück!', 5000, false);
            // WZ Fenster rechts
            setStateDelayed("tradfri.0.B-65557.blind.position"/*Blind position*/, 65, 4000, false);
            // WZ Fenster links
            setStateDelayed("tradfri.0.B-65558.blind.position"/*Blind position*/, 65, 2000, false);
            // Küche Fenster
            setState("tradfri.0.B-65572.blind.position"/*Blind position*/, 65);
            // Rollo Terrassentür
            setStateDelayed("tradfri.0.B-65576.blind.position"/*Blind position*/, 95, 6000, false);
            // Vorhänge Schlafzimmer
            setStateDelayed("switchbot-hub.0.D25BD616C204.slidePosition"/*only available for Curtain devices. the percentage of the distance between the calibrated open position and close position that a Curtain has moved to*/, 0, 6000, false);
            setStateDelayed("switchbot-hub.0.FED553380FAB.slidePosition"/*only available for Curtain devices. the percentage of the distance between the calibrated open position and close position that a Curtain has moved to*/, 0, 8000, false);
            if (compareTime(getAstroDate("sunriseEnd", undefined, 0), getAstroDate("goldenHour", undefined, 0), "not between", null)) {
      3;
      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
      Der Teil wo die Routine 'Gemütlichkeit' getoggelt werden soll wird nicht ausgeführt. Und ich verstehe nicht warum...
      Der Datenpunkt sieht so aus:
        "common": {
          "type": "boolean",
          "role": "indicator",
          "read": true,
          "write": true,
          "name": "Gemutlichkeit"
        "type": "state",
        "native": {},
        "from": "system.adapter.alexa2.0",
        "user": "system.user.admin",
        "ts": 1634939013369,
        "_id": "alexa2.0.Echo-Devices.G0911B0592250842.Routines.db9242b1-a8bb-4347-bbff-7c55cd8839c2",
        "acl": {
          "object": 1636,
          "state": 1636,
          "owner": "system.user.admin",
      Wenn ich den in den Objekten per Mausklick zwischen wahr und falsch umschalte wird die Routine immer ausgeführt.
      Wo ist mein Denkfehler?
        @thomas-braun ganzes Blockly Bild bitte!
        incl trigger
        @thomas-braun sagte in Blockly löst nur zum Teil aus:
          Thomas Braun Most Active @Homoran last edited by Thomas Braun
          Krieg ich nich drauf, Monitor zu klein...
          Mit zoom geht's:
            Homoran Global Moderator Administrators @Thomas Braun last edited by Homoran
            klingt wie ein Argument 😉
            wenn schalten in den Objekten wirkt, muss die Ursache in den Objektänderungen liegen
            Entweder werden die nicht geändert, oder der Trigger bekommt es nicht mit
            Edit:
            geh mal auf Blöcke prüfen, da hängt zumindest eine Mathe3 planlos rum
              @homoran sagte in Blockly löst nur zum Teil aus:
              Äh, wo mach ich das?
              Hab jetzt 'Blöcke aufgeräumt' und die heimatlose 3 gelöscht.
              • liv-in-sky
                liv-in-sky @Thomas Braun last edited by
                @thomas-braun wenn du vor dem umschalten gemutlichkeit ein debug reinschiebst - wird das im log immer angezeigt ?
                hast du mal steuere gemutlichkeit versucht - sind bei routinen nicht nur true's möglich ? eine routiine abschalten funktioniert ja nicht
                  Thomas Braun Most Active @liv-in-sky last edited by
                  @liv-in-sky
                  In den Objekten kann ich den Datenpunkt der Routine aber zwischen true und false umschalten, bei jeder Änderung wird auch die Routine gestartet. Deswegen scheint mir 'umschalten' an der Stelle richtig zu sein.
                  • liv-in-sky
                    @thomas-braun hast du es getestet ?
                      @liv-in-sky
                      Was? Das die Routine bei manuellem umschalten ausgelöst wird?
                      Ja, tut sie.
                      • liv-in-sky
                        nein - das sie steuert gemutlichkeit mit true
                        du könntest auch mal versuchen, die routine direkt im textcommand dp einzugeben anstatt umzuschalten-blockly
                        das wäre dann wie wenn du sagts: alexa gemutlichkeit (also so, wie die routine heißt - nur ohne "alexa"
                        ((( ich dachte immer, routinen müssen mindestens 2 wörter haben z.b. mache gemütlichkeit - aber anscheinend irre ich mih da )))
                        • liv-in-sky
                          liv-in-sky @Thomas Braun last edited by liv-in-sky
                          ich brauche rock - ist der name einer meiner routinen
                            @liv-in-sky sagte in Blockly löst nur zum Teil aus:
                            Wird sowohl mit true wie mit false losgetreten.
                            Ich glaube aber, die heimatlose 3 die @Homoran da mit seinen Adleraugen erspäht hat war es.
                            liv-in-sky crunchip 2 Replies Last reply Reply Quote 0
                            • liv-in-sky
                              dann is ja gut 🙂
                                @liv-in-sky
                                Ich mach das gar nicht mit textCommand, ich stups direkt die Routine an.
                                • liv-in-sky
                                  ich weiß - sollte ja nur ein test sein, ob es damit stabiler läuft
                                  • crunchip
                                    crunchip Forum Testing Most Active @Thomas Braun last edited by
                                    ne Routine, ist doch wie ein Taster, wird mit einem true ausgelöst, das steuern mit umschalten sollte also funktionieren, da dadurch die Routine kurz auf true springt und somit auslöst
                                      Thomas Braun Most Active @crunchip last edited by
                                      @crunchip
                                      Ja, sag ich ja.
                                        @crunchip @liv-in-sky @Homoran
                                        2021-10-25 20:35:53.795  - info: javascript.0 (781) script.js.common.wohnungstuer_entriegelt: Routine Gemuetlichkeit getriggert
                                        Ist aber nix gemütlich geworden. Mist.
                                        Ich kapiers aber auch nicht. Wenn ich den Trigger durch einen Datenpunkt 'Schalter' ersetze und von Hand auslöse wird das immer 'gemütlich' in der Bude.
                                        • crunchip
                                          @thomas-braun Wenn du im trigger mal anstatt "wurde aktualisierst" auf "ist grösser als" umstellst?
                                            Thomas Braun Most Active @crunchip last edited by Thomas Braun
                                            @crunchip
                                            Was ich nicht verstehe ist: Der ganze Kram davor (Rollos fahren; Vorhänge auf, den Herrn und Meister begrüßen) wird ja erledigt.
                                            Nur der letzte Block nicht.
                                            Ich hab jetzt mal im javaskript-Adapter die Astrozeiten von 'System' auf einen eigenen Eintrag geändert. Vielleicht hilft das ja.
                                            Homoran crunchip 2 Replies Last reply Reply Quote 0
                                            626
