    4. Node-Red
    5. Node-Red stoppt immer :-(
    • Olli_M
      Olli_M last edited by Olli_M
      ich hatte mir eine Flow hier aus dem Forum geladen und dann wieder gelöscht aber scheinbar hat er die Daten noch behalten und habe sogar schon den Adapter gelöscht und installiert und es kommen immer noch Fehlermeldungen und der Adapter stoppt die ganze Zeit 😞
      node-red.0	2021-11-05 10:45:19.076	error	(19042) Huejay: getaddrinfo ENOTFOUND 192.168.x.x
      node-red.0	2021-11-05 10:45:19.075	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      node-red.0	2021-11-05 10:45:19.075	error	at /opt/iobroker/iobroker-data/node-red/node_modules/huejay/lib/Transport.js:106:15
      node-red.0	2021-11-05 10:45:19.075	error	(19042) Error: Huejay: getaddrinfo ENOTFOUND 192.168.x.x
      node-red.0	2021-11-05 10:45:19.074	error	(19042) unhandled promise rejection: Huejay: getaddrinfo ENOTFOUND 192.168.x.x
      node-red.0	2021-11-05 10:45:19.074	error	(19042) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      node-red.0	2021-11-05 10:45:19.072	error	(19042) Huejay: getaddrinfo ENOTFOUND 192.168.x.x
      node-red.0	2021-11-05 10:45:19.071	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      node-red.0	2021-11-05 10:45:19.071	error	at /opt/iobroker/iobroker-data/node-red/node_modules/huejay/lib/Transport.js:106:15
      node-red.0	2021-11-05 10:45:19.071	error	(19042) Error: Huejay: getaddrinfo ENOTFOUND 192.168.x.x
      node-red.0	2021-11-05 10:45:19.070	error	(19042) unhandled promise rejection: Huejay: getaddrinfo ENOTFOUND 192.168.x.x
      node-red.0	2021-11-05 10:45:19.070	error	(19042) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      node-red.0	2021-11-05 10:45:19.067	error	(19042) Huejay: getaddrinfo ENOTFOUND 192.168.x.x
      node-red.0	2021-11-05 10:45:19.066	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      node-red.0	2021-11-05 10:45:19.066	error	at /opt/iobroker/iobroker-data/node-red/node_modules/huejay/lib/Transport.js:106:15
      node-red.0	2021-11-05 10:45:19.066	error	(19042) Error: Huejay: getaddrinfo ENOTFOUND 192.168.x.x
      node-red.0	2021-11-05 10:45:19.065	error	(19042) unhandled promise rejection: Huejay: getaddrinfo ENOTFOUND 192.168.x.x
      node-red.0	2021-11-05 10:45:19.062	error	(19042) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      MOD-Edit: Code in code-tags gesetzt!
      Was mach ich denn jetzt? Ist da irgendwo noch ein Cache den ich löschen muss? Wie gesagt das Flow was ich importiert hatte gibts nicht mehr..
      VG
      Thomas Braun mickym L 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Olli_M last edited by
        @olli_m
        Kannst du das bitte in </> CodeTags einbetten? Danke.
        • mickym
          mickym Most Active @Olli_M last edited by mickym
          @olli_m Für mich sieht das nicht nach einem Flow aus, den Du noch hast, sondern vielleicht hast Du zusätzliche Nodes installiert?
          Falls Du den Palettenmanger genutzt hast, hier halt die Nodes wieder deinstallieren, falls nicht ggf. aus der Adapterkonfig entfernen.
          Falls das alles nichts hilft, musst Du in das Verzeichnis /opt/iobroker/iobroker-data/node-red wechseln und mit npm uninstall huejay manuell deinstallieren oder dieses Verzeichnis /opt/iobroker/iobroker-data/node-red/node_modules/huejay komplett löschen.
            lessthanmore @Olli_M last edited by
            @olli_m Du hast eine node und einen flow installiert, der eine Konfig beinhaltet.
            Installiere die node erneut und lösche die Konfig aus der jeweiligen node. Danach node wieder deinstallieren.
            Olli_M 1 Reply Last reply Reply Quote 0
            • Olli_M
              Olli_M @lessthanmore last edited by
              @lessthanmore
              okay danke läuft wieder 🙂
              naja ist halt auch etwas strange wenn man hier einen Flow postet der dann auch gleich eine Konfiguration beinhaltet die dann alles zerschießt 🙂
