    4. Adapter löschen - gelöst
    • sissiwup
      sissiwup last edited by sissiwup
      ich habe eine Installation unter Linux Debian 11. Keine VM etc.
      Es sammeln sich immer mehr Adapter, die man nicht löschen kann.
      Als Beispiel der unifi Adapter.
      System it aktuell, Löschversuch siehe am Ende:
      root@zotac /opt/iobroker # iobroker stop && iobroker update && iobroker upgrade self && iobroker start
      Used repository: beta
      hash unchanged, use cached sources
      update done
      Adapter    "admin"         : 5.1.25   , installed 5.1.25
      Adapter    "backitup"      : 2.2.1    , installed 2.2.1
      Adapter    "broadlink2"    : 2.1.5    , installed 2.1.5
      Adapter    "devices"       : 1.0.9    , installed 1.0.9
      Adapter    "dwd"           : 2.7.7    , installed 2.7.7
      Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
      Adapter    "geofency"      : 1.0.3    , installed 1.0.3
      Adapter    "habpanel"      : 0.4.3    , installed 0.4.3
      Adapter    "hm-rega"       : 3.0.32   , installed 3.0.32
      Adapter    "hm-rpc"        : 1.14.45  , installed 1.14.45
      Adapter    "ical"          : 1.11.4   , installed 1.11.4
      Adapter    "icons-addictive-flavour-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
      Adapter    "icons-icons8"  : 0.0.1    , installed 0.0.1
      Adapter    "icons-material-png": 0.1.0   , installed 0.1.0
      Adapter    "icons-material-svg": 0.1.0   , installed 0.1.0
      Adapter    "icons-mfd-png" : 1.0.2    , installed 1.0.2
      Adapter    "icons-mfd-svg" : 1.0.2    , installed 1.0.2
      Adapter    "icons-open-icon-library-png": 0.1.2   , installed 0.1.3
      Adapter    "icons-ultimate-png": 1.0.1   , installed 1.0.1
      Adapter    "info"          : 1.9.10   , installed 1.9.10
      Adapter    "javascript"    : 5.2.13   , installed 5.2.13
      Controller "js-controller" : 3.3.18   , installed 3.3.18
      Adapter    "mqtt"          : 2.4.0    , installed 2.4.0
      Adapter    "ping"          : 1.5.0    , installed 1.5.0
      Adapter    "pushover"      : 2.0.5    , installed 2.0.5
      Adapter    "scenes"        : 2.3.8    , installed 2.3.8
      Adapter    "simple-api"    : 2.6.1    , installed 2.6.1
      Adapter    "socketio"      : 3.1.5    , installed 3.1.5
      Adapter    "sonoff"        : 2.4.5    , installed 2.4.5
      Adapter    "sql"           : 1.15.7   , installed 1.15.7
      Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
      Adapter    "telegram"      : 1.10.0   , installed 1.10.0
      Adapter    "trashschedule" : 1.3.0    , installed 1.3.0
      Adapter    "unifi"         : 0.5.10   , installed 0.5.10
      Adapter    "vis"           : 1.4.5    , installed 1.4.5
      Adapter    "vis-bars"      : 0.1.4    , installed 0.1.4
      Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
      Adapter    "vis-colorpicker": 1.2.0   , installed 1.2.0
      Adapter    "vis-fancyswitch": 1.1.0   , installed 1.1.0
      Adapter    "vis-history"   : 1.0.0    , installed 1.0.0
      Adapter    "vis-hqwidgets" : 1.1.9    , installed 1.1.9
      Adapter    "vis-inventwo"  : 3.2.5    , installed 3.2.5
      Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
      Adapter    "vis-justgage"  : 1.0.2    , installed 1.0.2
      Adapter    "vis-lcars"     : 1.0.4    , installed 1.0.4
      Adapter    "vis-map"       : 1.0.4    , installed 1.0.4
      Adapter    "vis-material"  : 0.1.3    , installed 0.1.3
      Adapter    "vis-material-advanced": 1.7.2   , installed 1.7.2
      Adapter    "vis-material-webfont": 0.0.3   , installed 0.0.3
      Adapter    "vis-materialdesign": 0.5.9   , installed 0.5.9
      Adapter    "vis-metro"     : 1.1.2    , installed 1.1.2
      Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
      Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
      Adapter    "vis-timeandweather": 1.1.7   , installed 1.1.7
      Adapter    "vis-weather"   : 2.5.4    , installed 2.5.4
      Adapter    "web"           : 3.4.13   , installed 3.4.13
      Adapter    "yahka"         : 0.13.1   , installed 0.13.1
      Host    "zotac"          is up to date.
      root@zotac /opt/iobroker # iobroker del unifi
      Delete adapter "unifi"
      host.zotac object unifi deleted
      host.zotac object unifi.admin deleted
      npm uninstall iobroker.unifi --loglevel error --prefix "/opt/iobroker" (System call)
      npm ERR! code ELOOP
      npm ERR! syscall open
      npm ERR! path /opt/iobroker/node_modules/iobroker.objects-redis/package.json
      npm ERR! errno -40
      npm ERR! ELOOP: too many symbolic links encountered, open '/opt/iobroker/node_modules/iobroker.objects-redis/package.json'
      npm ERR!     /home/iobroker/.npm/_logs/2021-11-06T08_01_55_296Z-debug.log
      Error deleting adapter unifi from disk: Error: host.zotac: Cannot uninstall iobroker.unifi: 216
      You might have to delete it yourself!
      root@zotac /opt/iobroker # node -v
      v14.17.0
      root@zotac /opt/iobroker # npm -v
      6.14.13
        Thomas Braun Most Active @sissiwup last edited by Thomas Braun
        @sissiwup
        root@zotac
        Lass den Mist bleiben!
        Da sind irgendwoher falsche Links (meist im Kreis auf die Datei selber) gesetzt. Schau dir die Rechte und die Dateiart an.
        sissiwup 1 Reply Last reply Reply Quote 0
        • sissiwup
          sissiwup @Thomas Braun last edited by
          @thomas-braun sagte in Adapter löschen:
          @sissiwup
          root@zotac
          ich mache das nur über die Konsole, wenn es anders nicht geht.
          Kannst du mir noch einen Tipp geben, wo ich genau schauen soll wegen der zirkulären Links?
          Thomas Braun sissiwup 2 Replies Last reply Reply Quote 0
            @sissiwup sagte in Adapter löschen:
            Das geht IMMER anders. Der root wird nicht genutzt, wird nicht genutzt, wird nicht genutzt! Gerade unter Debian, Ubuntu und Konsorten nicht.
            Zum Problem: Keine Ahnung. Und auch keine Lust mich mit einer per root shell zerrupften Installation zu beschäftigen.
            • sissiwup
              sissiwup @sissiwup last edited by sissiwup
              Hi, wenn du keine Ahnung hast, dann brauchst du nicht antworten.
              Ich habe nur über iobroker selbst installiert.
              Habe den Fehler jetzt aber gefunden:
              Zirkuläre Links kann man finden über
              find . -L >/dev/null
              Wenn hier Fehler kommen, den Link löschen.
              Bei mir war der "redis" da, obwohl ich das nicht verwende.
              Löschen in package.json hat geholfen.
              package.json:    "iobroker.objects-redis": "file:node_modules/iobroker.objects-redis",
              Danach ging es wieder aus dem Admin-Adapter.
              löschen
