    4. Zigbee Adapter stürzt ab bei Firmwareaktualisierung
      Ritter last edited by
      Wenn ich ein Firmware update von einer IKEA Fernbedienung starte z.B. Shortcut-Button will er anfangen geht dann aber sofort auf rot. Ist mit Zigbeeversion 1.63, 1.64 und 1.65 das selbe. Adapter läuft auf einem Raspberry als Multihost.
      zigbee.0
      2021-11-07 13:00:22.264	info	Zigbee started
      zigbee.0
      2021-11-07 13:00:22.262	info	0x84fd27fffed7b32f (addr 40960): GL-C-007P - Gledopto Zigbee LED Controller RGBW (pro) (Router)
      zigbee.0
      2021-11-07 13:00:22.258	info	0xcc86ecfffe1e783b (addr 34465): GL-C-007P - Gledopto Zigbee LED Controller RGBW (pro) (Router)
      zigbee.0
      2021-11-07 13:00:22.254	info	0xb4e3f9fffe67b85a (addr 39472): E1812 - IKEA TRADFRI shortcut button (EndDevice)
      zigbee.0
      2021-11-07 13:00:22.252	info	0xb4e3f9fffeb2fe12 (addr 21889): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
      zigbee.0
      2021-11-07 13:00:22.249	info	0xec1bbdfffe9d217b (addr 8204): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
      zigbee.0
      2021-11-07 13:00:22.245	info	0x00158d00038c251e (addr 55078): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.241	info	0x00158d0003475b7f (addr 53319): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.237	info	0x842e14fffe9077ee (addr 11007): E2001/E2002 - IKEA STYRBAR remote control N2 (EndDevice)
      zigbee.0
      2021-11-07 13:00:22.234	info	0x00158d00034719af (addr 18904): MLI-404011 - Müller Licht Tint remote control (EndDevice)
      zigbee.0
      2021-11-07 13:00:22.231	info	0x7cb03eaa00ae3d35 (addr 20892): AC03645 - OSRAM LIGHTIFY LED CLA60 E27 RGBW (Router)
      zigbee.0
      2021-11-07 13:00:22.227	info	0x00158d000362d9b3 (addr 48788): MLI-404011 - Müller Licht Tint remote control (EndDevice)
      zigbee.0
      2021-11-07 13:00:22.224	info	0x00158d0003f0fdfb (addr 3645): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
      zigbee.0
      2021-11-07 13:00:22.221	info	0x7cb03eaa00adbae1 (addr 1489): AC03645 - OSRAM LIGHTIFY LED CLA60 E27 RGBW (Router)
      zigbee.0
      2021-11-07 13:00:22.217	info	0xf0d1b8000010db7f (addr 26257): AC03647 - OSRAM SMART+ LED CLASSIC E27 RGBW (Router)
      zigbee.0
      2021-11-07 13:00:22.213	info	0x00124b000153768e (addr 40720): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
      zigbee.0
      2021-11-07 13:00:22.210	info	0x000d6ffffe3a783a (addr 13892): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
      zigbee.0
      2021-11-07 13:00:22.207	info	0x7cb03eaa0a06e9cc (addr 53518): AB3257001NJ - OSRAM Smart+ plug (Router)
      zigbee.0
      2021-11-07 13:00:22.205	info	0x00124b001efe44c1 (addr 44681): GL-C-007-1ID - Gledopto Zigbee LED Controller RGBW (1 ID) (Router)
      zigbee.0
      2021-11-07 13:00:22.200	info	0x00158d0002ca3fb0 (addr 36594): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.196	info	0x00158d0002c28084 (addr 16140): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.188	info	0x00158d0003570b8e (addr 19951): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.185	info	0x00158d00038c263c (addr 17413): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.182	info	0x00124b000fea77a5 (addr 61850): CC2530.ROUTER - Custom devices (DiY) [CC2530 router](http://ptvo.info/cc2530-based-zigbee-coordinator-and-router-112/) (Router)
      zigbee.0
      2021-11-07 13:00:22.180	info	0x00158d00038be21f (addr 36616): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.176	info	0x000d6ffffe8e848a (addr 46520): E1746 - IKEA TRADFRI signal repeater (Router)
      zigbee.0
      2021-11-07 13:00:22.171	info	0x000d6ffffe207e3f (addr 6796): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.168	info	0x00158d0002c27f6f (addr 9584): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.165	info	0x00158d0002c28090 (addr 48053): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.161	info	0x00158d0002c27f96 (addr 15937): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.158	info	0x90fd9ffffe6513bc (addr 19465): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.154	info	0x90fd9ffffe64ee9a (addr 57401): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.151	info	0x90fd9ffffe666304 (addr 21143): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.147	info	0x90fd9ffffe64e7ed (addr 21991): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.143	info	0x60a423fffebe16ee (addr 66): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.139	info	0x90fd9ffffe6363f8 (addr 17580): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.135	info	0x90fd9ffffe654212 (addr 37055): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.131	info	0x90fd9ffffe65394f (addr 31344): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.124	info	0x90fd9ffffe6548fd (addr 20699): 404000/404005/404012 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, color, opal white (Router)
      zigbee.0
      2021-11-07 13:00:22.004	info	Currently 38 devices are joined:
      zigbee.0
      2021-11-07 13:00:21.982	info	--> transmitPower : high
      zigbee.0
      2021-11-07 13:00:21.969	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
      zigbee.0
      2021-11-07 13:00:21.531	info	Installed Version: ioBroker/ioBroker.zigbee
      zigbee.0
      2021-11-07 13:00:20.575	info	Starting Zigbee npm ...
      zigbee.0
      2021-11-07 13:00:20.405	info	starting. Version 1.6.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.17.6, js-controller: 3.3.18
      zigbee.0
      2021-11-07 12:59:43.375	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      2021-11-07 12:59:43.371	info	terminating
      zigbee.0
      2021-11-07 12:59:43.039	info	Failed to check if update available for '0xb4e3f9fffe67b85a' (Device didn't respond to OTA request)
      zigbee.0
      2021-11-07 12:59:42.879	info	Zigbee: disabling joining new devices.
      zigbee.0
      2021-11-07 12:59:42.869	info	cleaned everything up...
      zigbee.0
      2021-11-07 12:59:42.844	error	Timeout - 11007 - 1 - null - 25 - 1 after 30000ms
      zigbee.0
      2021-11-07 12:59:42.843	error	Error: Timeout - 11007 - 1 - null - 25 - 1 after 30000ms at Timeout._onTimeout (/opt/iobroker/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35) at listOnTimeout (internal/timers.js:557:17) at processTimers (internal/timers.js:500:7)
      zigbee.0
      2021-11-07 12:59:42.827	error	unhandled promise rejection: Timeout - 11007 - 1 - null - 25 - 1 after 30000ms
      zigbee.0
      2021-11-07 12:59:42.825	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      2021-11-07 12:59:42.792	info	Failed to check if update available for '0x000d6ffffe3a783a' (Device didn't respond to OTA request)
      zigbee.0
      2021-11-07 12:59:40.187	warn	Failed to ping 0x7cb03eaa00ae3d35 CLA60 RGBW OSRAM
      zigbee.0
      2021-11-07 12:59:39.995	warn	Failed to ping 0x7cb03eaa00adbae1 CLA60 RGBW OSRAM
      zigbee.0
      2021-11-07 12:59:39.786	info	Update of '0xb4e3f9fffeb2fe12' at 0%
      zigbee.0
      2021-11-07 12:59:39.322	info	Failed to check if update available for '0x7cb03eaa00ae3d35' (Device didn't respond to OTA request)
      zigbee.0
      2021-11-07 12:59:39.048	info	Failed to check if update available for '0x7cb03eaa00adbae1' (Device didn't respond to OTA request)
      zigbee.0
      2021-11-07 12:59:31.330	info	Failed to check if update available for '0x84fd27fffed7b32f' (Device didn't respond to OTA request)
      zigbee.0
      2021-11-07 12:59:31.267	info	Failed to check if update available for '0xcc86ecfffe1e783b' (Device didn't respond to OTA request)
      zigbee.0
      2021-11-07 12:59:24.121	info	Start firmware update for 0xb4e3f9fffeb2fe12
      • crunchip
        crunchip Forum Testing Most Active @Ritter last edited by
        @ritter wäre dann wohl eher als Github issue angebracht, mit allen dazu nötigen Info`s
