    4. In der Nacht gingen Alle Lichter an
      A Former User last edited by
      Hallo
      2021-11-09 03:24:26.969 - info: info.0 (1080) Reading/updating systemdata.
      2021-11-09 03:24:27.457 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
      2021-11-09 03:24:27.484 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
      2021-11-09 03:24:27.529 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
      2021-11-09 03:24:27.533 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
      2021-11-09 03:24:27.536 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
      2021-11-09 03:24:27.682 - info: info.0 (1080) cpu Temp res = {"main":52.582,"cores":[],"max":52.582,"socket":[],"chipset":null}
      2021-11-09 03:47:32.096 - info: javascript.0 (976) Stop script script.js.SchlafBettLicht
      2021-11-09 03:47:32.122 - info: javascript.0 (976) Start javascript script.js.SchlafBettLicht
      2021-11-09 03:47:32.162 - info: javascript.0 (976) script.js.SchlafBettLicht: registered 1 subscription and 0 schedules
      2021-11-09 05:04:00.099 - info: telegram.0 (9020) Scheduled restart.
      2021-11-09 05:04:00.622 - info: telegram.0 (9020) terminating
      2021-11-09 05:04:00.624 - info: telegram.0 (9020) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      2021-11-09 05:04:01.236 - info: host.raspberrypi instance system.adapter.telegram.0 scheduled normal terminated and will be restarted on schedule.
      2021-11-09 05:04:01.250 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
      2021-11-09 05:04:02.309 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 20569
      2021-11-09 05:04:04.513 - info: telegram.0 (20569) starting. Version 1.10.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.3.18
      2021-11-09 10:17:00.887 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
      2021-11-09 10:18:57.238 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
      2021-11-09 10:19:03.228 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
      2021-11-09 10:37:14.241 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
      2021-11-09 13:28:55.719 - info: admin.0 (792) Adapter rating updated
      2021-11-09 13:30:22.985 - info: admin.0 (792) Request actual repository...
      2021-11-09 13:30:23.229 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2021-11-09 13:30:24.621 - info: admin.0 (792) Repository received successfully.
      Um 3:24 Uhr gingen bei usn die Lichter alle an. Und nicht so wie wir sie eingestellt haben, sondern auf 100% Helligkeit. also sehr grell.
      Was war der Auslöser?
      Was müssen wir tun?
      Glasfaser mickym 2 Replies Last reply Reply Quote 0
        @paul-ol
        im Logfile sieht man, dass das Script SchlafBettLicht um 3:47 Uhr gestoppt und wieder gestartet wurde.
        Das sollte im Normalfall nicht dazu fuehren, dass Lichter an gehen, es sei denn, es ist so programmiert, dass es das macht..???
        Hast du etwas programmiert, dass das Script stoppt?
        Ich wuerde an deiner Stelle erstmal die Scripte checken, da ist anscheinend was faul.. ??
        • Glasfaser
          Glasfaser @Guest last edited by Glasfaser
          @paul-ol sagte in In der Nacht gingen Alle Lichter an:
          Um 3:24 Uhr gingen
          und was ist vor "03:24:26.969" im Log !?
          und was heißt : ........Alle Lichter an
          Alle gleiche angesteuert , Zigbee , Homematic .... oder !?
          Um 3:24 Uhr gingen ----- Alle Lichter an ..... sondern auf 100% Helligkeit.
          oder ein Spaßvogel auf deinem System .
          • BananaJoe
            Wie steuerst du denn die Lichter an? Ich hatt so etwas ähnliches mal geschafft mit Tasmota. MQTT und das die States gespeichert sein sollen (oder so), da hat er nach einem Neustart allen Geräten den vermeintlich letzten Status neu übermittelt (und der war bei mir in der Regel aus)
            • mickym
              mickym Most Active @Guest last edited by
              @paul-ol Wenn das Zigbee und IKEA Lampen sind - dann musst Du das über Deine Logikmaschine prüfen - die gehen nämlich bei einem Stromausfall und anschließender Stromzufuhr alle an.
                Thomas Braun Most Active @mickym last edited by
                @mickym sagte in In der Nacht gingen Alle Lichter an:
                Wenn man es nicht anders einstellt. Kann man in der Tradfri-App machen.
                • mickym
                  mickym Most Active @Thomas Braun last edited by
                  @thomas-braun Ich habe aber keine App und laufen auch direkt auf dem Zigbee Adapter und nicht über das Gateway.
                    @mickym Du nicht.
                    Aber vielleicht @Paul-OL
                    • mickym
                      mickym Most Active @Thomas Braun last edited by mickym
                      @thomas-braun sagte in In der Nacht gingen Alle Lichter an:
                      @mickym Du nicht.
                      Ok soweit habe ich gar nicht gedacht - zudem ja noch nicht mal sicher sind, welche Lampen, Protokoll etc. es sich handelt. - Es geht ja erst mal darum, was für Ursachen die plötzliche Helligkeit in tiefster Nacht haben könnte. Dabei ist mir halt der Stromausfall eingefallen - und insbesondere die IKEA Lampen indem man es - wie Du schreibst nur in einer App konfigurieren kann.
                        A Former User @Guest last edited by A Former User
                        @ilovegym said in In der Nacht gingen Alle Lichter an:
                        @paul-ol
                        Das war ich mit der Hand. Dank unserer Kammera konten wir feststellen, dass es um 3:24 Uhr angegangen ist. Erst später bin ich wach geworden. Und dann habe ich selber versucht es zu deaktivieren. Schlaftrunken.
                        Nein, ich habe kein Programm was die Lichter alle anmacht.
                        Die Scripte wurden mehrere Monate nicht verändert. Es gibt vor allem eine besonderheit. Anstatt das das Licht Gelb ist, war es weiß.
                        @glasfaser said in In der Nacht gingen Alle Lichter an:
                        Um 3:24 Uhr gingen
                        Genau um 3:24 ist es ja angenagen. Das Licht. Davor steht nichts. Das ist das gesamte Log das ich geladen habe.
                        Mit alle, ahbe ich mich vershene. Es ist das Zigbee Innr LED Leiste angenagen. Diese ist unter dem bett. Nur dieses Licht. Aber dafür auch noch in Weiß. Helles 100% weiß.
                        Wie kann ich das sehen?
                        Stromausfall nur in einem Raum? Dan wäre die Kammera auch nicht möglich gewesen aufzuzeichnen. Alle anderen geräte scheinen nichts gemacht zu haben.
                        und das ist der Log vom vorherrigen tag.
                        Auch der beginnt um 3:24 Uhr. Wie es scheint, macht ioBroker da etwas und dann ging bei diesem Mal die Innr LEZ Stripe auf 100% an. Einfach so.
                        2021-11-08 03:24:26.968 - info: info.0 (1080) Reading/updating systemdata.
                        2021-11-08 03:24:27.443 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                        2021-11-08 03:24:27.536 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                        2021-11-08 03:24:27.590 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                        2021-11-08 03:24:27.595 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                        2021-11-08 03:24:27.601 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                        2021-11-08 03:24:27.759 - info: info.0 (1080) cpu Temp res = {"main":51.608,"cores":[],"max":51.608,"socket":[],"chipset":null}
                        2021-11-08 05:04:00.082 - info: telegram.0 (11736) Scheduled restart.
                        2021-11-08 05:04:00.603 - info: telegram.0 (11736) terminating
                        2021-11-08 05:04:00.605 - info: telegram.0 (11736) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2021-11-08 05:04:01.225 - info: host.raspberrypi instance system.adapter.telegram.0 scheduled normal terminated and will be restarted on schedule.
                        2021-11-08 05:04:01.239 - info: host.raspberrypi Restart adapter system.adapter.telegram.0 because enabled
                        2021-11-08 05:04:02.303 - info: host.raspberrypi instance system.adapter.telegram.0 started with pid 9020
                        2021-11-08 05:04:04.471 - info: telegram.0 (9020) starting. Version 1.10.0 in /opt/iobroker/node_modules/iobroker.telegram, node: v12.22.1, js-controller: 3.3.18
                        2021-11-08 13:28:55.453 - info: admin.0 (792) Adapter rating updated
                        2021-11-08 13:30:20.840 - info: admin.0 (792) Request actual repository...
                        2021-11-08 13:30:21.153 - info: host.raspberrypi Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                        2021-11-08 13:30:22.735 - info: admin.0 (792) Repository received successfully.
                        2021-11-08 15:24:26.969 - info: info.0 (1080) Reading/updating systemdata.
                        2021-11-08 15:24:27.506 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.speed" has to be type "string" but received type "number"
                        2021-11-08 15:24:27.546 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l1d" has to be type "number" but received type "string"
                        2021-11-08 15:24:27.554 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l1i" has to be type "number" but received type "string"
                        2021-11-08 15:24:27.560 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l2" has to be type "number" but received type "string"
                        2021-11-08 15:24:27.564 - info: info.0 (1080) State value to set for "info.0.sysinfo.cpu.info.cache-l3" has to be type "number" but received type "string"
                        2021-11-08 15:24:27.678 - info: info.0 (1080) cpu Temp res = {"main":54.043,"cores":[],"max":54.043,"socket":[],"chipset":null}
                        2021-11-08 16:19:24.658 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.smartlocks.wohnungstür.state.batteryCharge" has to be type "string" but received type "number"
                        2021-11-08 17:18:58.775 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
                        2021-11-08 17:20:38.665 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
                        2021-11-08 17:20:45.200 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
                        2021-11-08 17:39:12.323 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
                        2021-11-08 19:39:21.613 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
                        2021-11-08 19:40:35.699 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
                        2021-11-08 19:40:40.589 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
                        2021-11-08 19:59:35.046 - info: nuki-extended.0 (24187) State value to set for "nuki-extended.0.openers.opener.state.lastStateUpdate" has to be type "string" but received type "number"
                        ? Glasfaser 2 Replies Last reply Reply Quote 0
                          @paul-ol
                          das logfile sagt nichts bestimmtes, ausser dass der info Adapter da was macht, der aber eigentlich nur Systemdaten ausliest.. schau da mal in die Konfig..?!
                          Wenn das die eine Zigbee Leuchte war, die anging, und sonst keine.. kann ja auch ein Wackelkontakt am Kabel sein..etc.. wie die anderen hier schon schrieben, bei Stromausfall gehen die Dinger gerne mal an.. es sei denn, es ist ausdruecklich anders konfiguriert.
                          Also Konfig im iobroker checken, logfiles checken, mal den info Adapter vielleicht stoppen ( braucht man den? ) und nochmal bei der Leuchte unterm Bett n Stromausfall simulieren.. dann sieht man ja, was passiert..
                          Alles andere ist fuer die Glaskugel.. 🙂
                          • Glasfaser
                            Nur dieses Licht.
                            Und dann so ein Aufschrei wegen einer Lampe !? 🤔
                            Da es vorher noch nie war und einmalig aufgetreten ist ..... eher ein Zufall ..... um 03:24 Uhr ..
                            332
