    4. Backitup speichert unterschiedliches lokal und online
      Blackbox last edited by Blackbox
      Ich habe gerade Backitup eingerichtet. Als speicherort dienen USB stick an Fritzbox und googledrive.
      Mittlerweile funktioniert es auch, allerdings habe ich unterschiedliche dateien an den speicherorten.
      Lokal, kein influxdb:
      googledrive kein grafana:
      Übersehe ich etwas? Ist das normal?
      Das spuckt der adapter aus:
      Started iobroker ...
      [DEBUG] [mount] - noserverino option: false
      [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Backup,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.178.1/FRITZ.NAS/BACKUP/Backup /opt/iobroker/backups"
      [DEBUG] [mount] - mount successfully completed
      [DEBUG] [mount] - done
      [DEBUG] [iobroker] - host.raspberrypi 756 states saved
      [DEBUG] [iobroker] - host.raspberrypi 961 objects saved
      [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_11_14-20_33_06_backupiobroker.tar.gz
      [DEBUG] [iobroker] - done
      [DEBUG] [influxDB] - InfluxDB-Backup started ...
      [DEBUG] [influxDB] - Start InfluxDB Backup ...
      [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
      [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
      [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
      [ERROR] [influxDB] - [IGNORED] Error: Command failed: influxd backup -portable -database iobroker "/opt/iobroker/backups/influxDB_2021_11_14-20_33_11_backupiobroker"
      backup: copy: read /opt/iobroker/backups/influxDB_2021_11_14-20_33_11_backupiobroker/meta.00: input/output error
      [DEBUG] [grafana] - Start Grafana Backup ...
      [DEBUG] [grafana] - Try deleting the old grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
      [DEBUG] [grafana] - old grafana_tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
      [DEBUG] [grafana] - Created grafana_tmp directory
      [DEBUG] [grafana] - Created dashboard directory
      [DEBUG] [grafana] - Created dashboards_manually_restore directory
      [DEBUG] [grafana] - Created datasource directory
      [DEBUG] [grafana] - start Grafana request ...
      [DEBUG] [grafana] - Grafana is available ... Status: 200
      [DEBUG] [grafana] - Error on Grafana Datasource Request
      [DEBUG] [grafana] - found Dashboard: 1
      [DEBUG] [grafana] - start Grafana backup compress ...
      [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
      [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" cannot deleted ... Error: EACCES: permission denied, unlink '/opt/iobroker/backups/grafana_tmp/dashboards/1.json'
      [DEBUG] [grafana] - cannot found Grafana Backup files
      [DEBUG] [grafana] - done
      [DEBUG] [javascripts] - Created javascript_tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - Try deleting the Javascript tmp directory: "/opt/iobroker/backups/tmpScripts"
      [DEBUG] [javascripts] - Javascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted
      [DEBUG] [javascripts] - Backup created: /opt/iobroker/backups/javascripts_2021_11_14-20_33_16_backupiobroker.tar.gz
      [DEBUG] [javascripts] - done
      [DEBUG] [cifs] - done
      [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_11_14-20_33_06_backupiobroker.tar.gz...
      [ERROR] [googledrive] - Google Drive: Error: EIO: i/o error, read
      [ERROR] [googledrive] - Google Drive: Error: <!DOCTYPE html>
      <html lang=en>
        <meta charset=utf-8>
        <meta name=viewport content="initial-scale=1, minimum-scale=1, width=device-width">
        <title>Error 408 (Request Timeout)!!1</title>
        <style>
          *{margin:0;padding:0}html,code{font:15px/22px arial,sans-serif}html{background:#fff;color:#222;padding:15px}body{margin:7% auto 0;max-width:390px;min-height:180px;padding:30px 0 15px}* > body{background:url(//www.google.com/images/errors/robot.png) 100% 5px no-repeat;padding-right:205px}p{margin:11px 0 22px;overflow:hidden}ins{color:#777;text-decoration:none}a img{border:0}@media screen and (max-width:772px){body{background:none;margin-top:0;max-width:none;padding-right:0}}#logo{background:url(//www.google.com/images/branding/googlelogo/1x/googlelogo_color_150x54dp.png) no-repeat;margin-left:-5px}@media only screen and (min-resolution:192dpi){#logo{background:url(//www.google.com/images/branding/googlelogo/2x/googlelogo_color_150x54dp.png) no-repeat 0% 0%/100% 100%;-moz-border-image:url(//www.google.com/images/branding/googlelogo/2x/googlelogo_color_150x54dp.png) 0}}@media only screen and (-webkit-min-device-pixel-ratio:2){#logo{background:url(//www.google.com/images/branding/googlelogo/2x/googlelogo_color_150x54dp.png) no-repeat;-webkit-background-size:100% 100%}}#logo{display:inline-block;height:54px;width:150px}
        </style>
        <a href=//www.google.com/><span id=logo aria-label=Google></span></a>
        <p><b>408.</b> <ins>That’s an error.</ins>
        <p>Your client has taken too long to issue its request.  <ins>That’s all we know.</ins>
      [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/influxDB_2021_11_14-20_33_11_backupiobroker.tar.gz" not found
      [DEBUG] [googledrive] - Google Drive: Copy javascripts_2021_11_14-20_33_16_backupiobroker.tar.gz...
      <html lang=en>
        <style>
        </style>
      [DEBUG] [googledrive] - done
      [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
      [DEBUG] [clean] - done
      [DEBUG] [historyHTML] - new history html values created
      [DEBUG] [historyHTML] - done
      [DEBUG] [historyJSON] - new history json values created
      [DEBUG] [historyJSON] - done
      [DEBUG] [umount] - mount activ, umount is started ...
      [DEBUG] [umount] - umount successfully completed
      [DEBUG] [umount] - done
      [EXIT] 0
        Thomas Braun Most Active @Blackbox last edited by
        @blackbox sagte in Backitup speichert unterschiedliches lokal und online:
        Auf true setzen.
        Weiter wollte ich nicht lesen, setz den Konsolenoutput in CodeTags.
          Blackbox @Thomas Braun last edited by
          Codetags gesetzt, danke für den tip.
          Wie setze ich "noserverino" auf true?
          Sollte vielleicht erwähnen das ich anfänger bin.
            @blackbox
            In den Einstellungen der Instanz des Backitup-Adapters.
            Da kannst du gleich auch Mal die smb-Version auf 3.1.1 setzen. (Aktuelle Firmware >7.20 der Fritzbox vorausgesetzt)
              Blackbox @Thomas Braun last edited by Blackbox
              @thomas-braun said in Backitup speichert unterschiedliches lokal und online:
              Done.
              Jetzt verschwindet der grafana ordner auf der fritzbox. Allerdings bleibt kein backup. Weder fritz noch googledrive.
              [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
              Hab mal den api key neu gemacht. Editor sollte richtig sein? funktioniert immer noch nicht. Admin api auch getestet.
                Thomas Braun Most Active @Blackbox last edited by Thomas Braun
                @blackbox
                Zeig mal die Einstellungen der einzelnen Backup-Verfahren.
                Und der Mountpunkt /opt/iobroker/backups ist auch leer, wenn die Freigabe nicht gemountet ist?
                  Hat ein bischen länger gedauert, leider viel los hier in der familie.
                  ?? Hier verstehe ich nur bahnhof
                  Einstellungen:
                  crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                  • crunchip
                    crunchip Forum Testing Most Active @Blackbox last edited by crunchip
                    @blackbox im ersten bild sieht man deinen Pfad nicht
                    ansonsten, gibt es doch so einen schöne Beschreibung
                    @thomas-braun sagte in Backitup speichert unterschiedliches lokal und online:
                    bist du 'Lokal' unterwegs.
                    wäre ja richtig, wenn influx auf dem selben Server läuft
                      @blackbox
                      Im zweiten Bild bist du 'Lokal' unterwegs.
                        Blackbox @crunchip last edited by
                        @crunchip
                        Funtioniert auch alles, außer grafana backup.
                          ist das ein problem? Die datenbank wird ja gesichert.
                            @blackbox
                            Aber du willst doch das Backup extern haben. Und auch von extern wieder einspielen.
                              ist doch die quellenangabe nicht der ort an dem gesichert wird?
                              Also ich verstehe das so das hier angegeben wird wo sich das zu sichernde objekt befindet.
                              Die Datenbank wird ja auch problemlos gesichert.
                                @blackbox
                                Richtig, auf dem ersten Bild agierst du aber nicht lokal sondern auf einer smb-Freigabe.
                                  Wow, bist du schnell. Hab meinen letzten post angepasst.
                                  erstes bild ist ja auch ziel der sicherung.
                                    Blackbox @Blackbox last edited by
                                    @blackbox
                                    Kann natürlich auch sein das ich etwas fundamental missverstehe. Bin absoluter laie.
                                      @blackbox
                                      Gebe ich bei grafana lokal an, findet er die instanz nicht. Gebe ich die ip an, bekomme ich diesen output.
                                      Er findet also die instanz, versucht ein backup, aber danach sind keine files da. ??
                                      [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                      [DEBUG] [grafana] - found Dashboard: pc-verbrauch-and-pi-temperatur
                                      [DEBUG] [grafana] - found Dashboard: waschmaschine-and-trockner-verbrauch
                                        @blackbox said in Backitup speichert unterschiedliches lokal und online:
                                        Warum?
                                          @blackbox
                                          Ich habe zwar weder grafana noch influx im Einsatz, aber grundsätzlich sollte das so ablaufen:
                                          Das Dateisystem auf der Fritzbox wird in /opt/iobroker/backups
                                          eingehängt/gemountet. Dazu sollte der Ordner zuvor leer sein. Dann werden die Backups dort zusammengeschraubt und dann wird der Kram ins Google Drive geschoben. Abschließend wird das Dateisystem der Fritzbox wieder rausgerollt und zurück bleibt der leere Mountpunkt. Da sollte also keine Diskrepanz zwischen der Fritzbox und Google Drive und Lokal entstehen können.
                                            Diese einstellung scheint doch unter NAS
                                            und Google Drive
                                            auch zu passen. Alles andere als Grafana wird ja auch gespeichert.
                                            crunchip simatec 2 Replies Last reply Reply Quote 0
                                            909
