    4. LOG quillt mit javascript Fehler über.
      hertob81 last edited by Homoran
      mein LOG quillt mit den folgenden Meldungen über.
      Ich bin noch Laie, alles was ich vor ein paar Tagen gemacht habe war, die Adapter so zu aktuallisieren:
      sudo iobroker stop
      sudo iobroker update
      sudo iobroker upgrade self
      sudo iobroker start
      Könnt ihr mir helfen?
      2021-11-23 18:46:23.598  - warn: javascript.0 (29184) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:46:23.601  - warn: javascript.0 (29184)     at Object.<anonymous> (script.js.Beleuchtung.Film_Ab:125:7)
      2021-11-23 18:46:23.601  - warn: javascript.0 (29184)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
      2021-11-23 18:46:23.601  - warn: javascript.0 (29184)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
      2021-11-23 18:46:23.602  - warn: javascript.0 (29184)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
      2021-11-23 18:46:23.602  - warn: javascript.0 (29184)     at processImmediate (internal/timers.js:461:21)
      2021-11-23 18:46:23.603  - warn: javascript.0 (29184) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:46:23.604  - warn: javascript.0 (29184)     at Object.<anonymous> (script.js.Energieüberwachung.Trockner:125:7)
      2021-11-23 18:46:23.605  - warn: javascript.0 (29184)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
      2021-11-23 18:46:23.605  - warn: javascript.0 (29184)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
      2021-11-23 18:46:23.605  - warn: javascript.0 (29184)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
      2021-11-23 18:46:23.606  - warn: javascript.0 (29184)     at processImmediate (internal/timers.js:461:21)
      2021-11-23 18:46:23.606  - warn: javascript.0 (29184) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:46:23.608  - warn: javascript.0 (29184)     at Object.<anonymous> (script.js.Energieüberwachung.Waschmaschine:125:7)
      2021-11-23 18:46:23.608  - warn: javascript.0 (29184)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
      2021-11-23 18:46:23.608  - warn: javascript.0 (29184)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
      2021-11-23 18:46:23.609  - warn: javascript.0 (29184)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
      2021-11-23 18:46:23.609  - warn: javascript.0 (29184)     at processImmediate (internal/timers.js:461:21)
      2021-11-23 18:46:28.030  - warn: meross.0 (9860) Can not get Abilities for Device 1909127140323125186448e1e9038373: Error: Timeout / undefined
      2021-11-23 18:46:46.231  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
      2021-11-23 18:46:46.248  - info: javascript.0 (29184) Got terminate signal TERMINATE_YOURSELF
      2021-11-23 18:46:46.249  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
      2021-11-23 18:46:46.251  - info: javascript.0 (29184) Stop script script.js.Beleuchtung.Film_Ab
      2021-11-23 18:46:46.253  - info: javascript.0 (29184) Stop script script.js.Energieüberwachung.Trockner
      2021-11-23 18:46:46.253  - info: javascript.0 (29184) Stop script script.js.Energieüberwachung.Waschmaschine
      2021-11-23 18:46:46.258  - info: javascript.0 (29184) terminating
      2021-11-23 18:46:46.260  - info: javascript.0 (29184) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-11-23 18:46:46.895  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-11-23 18:46:49.491  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 29478
      2021-11-23 18:46:52.615  - info: javascript.0 (29478) starting. Version 5.2.13 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.7, js-controller: 3.3.19
      2021-11-23 18:46:52.745  - info: javascript.0 (29478) requesting all states
      2021-11-23 18:46:52.747  - info: javascript.0 (29478) requesting all objects
      2021-11-23 18:46:54.048  - info: javascript.0 (29478) received all objects
      2021-11-23 18:46:54.102  - info: javascript.0 (29478) received all states
      2021-11-23 18:47:04.027  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
      2021-11-23 18:47:04.060  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
      2021-11-23 18:47:04.233  - info: javascript.0 (29478) Start javascript script.js.Beleuchtung.Film_Ab
      2021-11-23 18:47:04.337  - warn: javascript.0 (29478) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:04.347  - warn: javascript.0 (29478)     at script.js.Beleuchtung.Film_Ab:57:10
      2021-11-23 18:47:04.348  - warn: javascript.0 (29478)     at script.js.Beleuchtung.Film_Ab:15:3
      2021-11-23 18:47:04.348  - info: javascript.0 (29478) script.js.Beleuchtung.Film_Ab: registered 7 subscriptions and 2 schedules
      2021-11-23 18:47:04.357  - info: javascript.0 (29478) Start javascript script.js.Energieüberwachung.Trockner
      2021-11-23 18:47:04.376  - warn: javascript.0 (29478) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:04.378  - warn: javascript.0 (29478)     at script.js.Energieüberwachung.Trockner:57:10
      2021-11-23 18:47:04.378  - warn: javascript.0 (29478)     at script.js.Energieüberwachung.Trockner:16:3
      2021-11-23 18:47:04.380  - info: javascript.0 (29478) script.js.Energieüberwachung.Trockner: registered 7 subscriptions and 2 schedules
      2021-11-23 18:47:04.381  - info: javascript.0 (29478) Start javascript script.js.Energieüberwachung.Waschmaschine
      2021-11-23 18:47:04.406  - warn: javascript.0 (29478) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:04.408  - warn: javascript.0 (29478)     at script.js.Energieüberwachung.Waschmaschine:57:10
      2021-11-23 18:47:04.408  - warn: javascript.0 (29478)     at script.js.Energieüberwachung.Waschmaschine:16:3
      2021-11-23 18:47:04.409  - info: javascript.0 (29478) script.js.Energieüberwachung.Waschmaschine: registered 7 subscriptions and 2 schedules
      2021-11-23 18:47:04.414  - info: javascript.0 (29478) Got terminate signal TERMINATE_YOURSELF
      2021-11-23 18:47:04.416  - info: javascript.0 (29478) Stop script script.js.Beleuchtung.Film_Ab
      2021-11-23 18:47:04.417  - info: javascript.0 (29478) Stop script script.js.Energieüberwachung.Trockner
      2021-11-23 18:47:04.418  - info: javascript.0 (29478) Stop script script.js.Energieüberwachung.Waschmaschine
      2021-11-23 18:47:04.428  - info: javascript.0 (29478) terminating
      2021-11-23 18:47:04.430  - info: javascript.0 (29478) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-11-23 18:47:05.064  - info: host.raspberrypi stopInstance system.adapter.javascript.0 killing pid 29478
      2021-11-23 18:47:05.186  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-11-23 18:47:07.188  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 29597
      2021-11-23 18:47:07.732  - warn: meross.0 (9860) Can not get Abilities for Device 1909127140323125186448e1e9038373: Error: Timeout / undefined
      2021-11-23 18:47:10.103  - info: javascript.0 (29597) starting. Version 5.2.13 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.7, js-controller: 3.3.19
      2021-11-23 18:47:10.223  - info: javascript.0 (29597) requesting all states
      2021-11-23 18:47:10.225  - info: javascript.0 (29597) requesting all objects
      2021-11-23 18:47:11.602  - info: javascript.0 (29597) received all objects
      2021-11-23 18:47:11.658  - info: javascript.0 (29597) received all states
      2021-11-23 18:47:21.341  - info: javascript.0 (29597) Start javascript script.js.Beleuchtung.Film_Ab
      2021-11-23 18:47:21.434  - warn: javascript.0 (29597) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:21.444  - warn: javascript.0 (29597)     at script.js.Beleuchtung.Film_Ab:57:10
      2021-11-23 18:47:21.444  - warn: javascript.0 (29597)     at script.js.Beleuchtung.Film_Ab:15:3
      2021-11-23 18:47:21.445  - info: javascript.0 (29597) script.js.Beleuchtung.Film_Ab: registered 7 subscriptions and 2 schedules
      2021-11-23 18:47:21.449  - info: javascript.0 (29597) Start javascript script.js.Energieüberwachung.Trockner
      2021-11-23 18:47:21.469  - warn: javascript.0 (29597) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:21.470  - warn: javascript.0 (29597)     at script.js.Energieüberwachung.Trockner:57:10
      2021-11-23 18:47:21.471  - warn: javascript.0 (29597)     at script.js.Energieüberwachung.Trockner:16:3
      2021-11-23 18:47:21.473  - info: javascript.0 (29597) script.js.Energieüberwachung.Trockner: registered 7 subscriptions and 2 schedules
      2021-11-23 18:47:21.473  - info: javascript.0 (29597) Start javascript script.js.Energieüberwachung.Waschmaschine
      2021-11-23 18:47:21.490  - warn: javascript.0 (29597) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:21.492  - warn: javascript.0 (29597)     at script.js.Energieüberwachung.Waschmaschine:57:10
      2021-11-23 18:47:21.492  - warn: javascript.0 (29597)     at script.js.Energieüberwachung.Waschmaschine:16:3
      2021-11-23 18:47:21.493  - info: javascript.0 (29597) script.js.Energieüberwachung.Waschmaschine: registered 7 subscriptions and 2 schedules
      2021-11-23 18:47:27.110  - info: web.0 (10070) <==Disconnect system.user.admin from ::ffff:192.168.0.108 flot
      2021-11-23 18:47:27.850  - info: host.raspberrypi stopInstance system.adapter.javascript.0 (force=false, process=true)
      2021-11-23 18:47:27.859  - info: javascript.0 (29597) Got terminate signal TERMINATE_YOURSELF
      2021-11-23 18:47:27.859  - info: host.raspberrypi stopInstance system.adapter.javascript.0 send kill signal
      2021-11-23 18:47:27.862  - info: javascript.0 (29597) Stop script script.js.Beleuchtung.Film_Ab
      2021-11-23 18:47:27.864  - info: javascript.0 (29597) Stop script script.js.Energieüberwachung.Trockner
      2021-11-23 18:47:27.865  - info: javascript.0 (29597) Stop script script.js.Energieüberwachung.Waschmaschine
      2021-11-23 18:47:27.872  - info: javascript.0 (29597) terminating
      2021-11-23 18:47:27.876  - info: javascript.0 (29597) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2021-11-23 18:47:28.492  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2021-11-23 18:47:29.032  - info: web.0 (10070) ==>Connected system.user.admin from ::ffff:192.168.0.108
      2021-11-23 18:47:31.028  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 29681
      2021-11-23 18:47:34.390  - info: javascript.0 (29681) starting. Version 5.2.13 in /opt/iobroker/node_modules/iobroker.javascript, node: v12.22.7, js-controller: 3.3.19
      2021-11-23 18:47:34.505  - info: javascript.0 (29681) requesting all states
      2021-11-23 18:47:34.506  - info: javascript.0 (29681) requesting all objects
      2021-11-23 18:47:35.727  - info: javascript.0 (29681) received all objects
      2021-11-23 18:47:35.783  - info: javascript.0 (29681) received all states
      2021-11-23 18:47:45.810  - info: javascript.0 (29681) Start javascript script.js.Beleuchtung.Film_Ab
      2021-11-23 18:47:45.906  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:45.917  - warn: javascript.0 (29681)     at script.js.Beleuchtung.Film_Ab:57:10
      2021-11-23 18:47:45.917  - warn: javascript.0 (29681)     at script.js.Beleuchtung.Film_Ab:15:3
      2021-11-23 18:47:45.918  - info: javascript.0 (29681) script.js.Beleuchtung.Film_Ab: registered 7 subscriptions and 2 schedules
      2021-11-23 18:47:45.925  - info: javascript.0 (29681) Start javascript script.js.Energieüberwachung.Trockner
      2021-11-23 18:47:45.953  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:45.955  - warn: javascript.0 (29681)     at script.js.Energieüberwachung.Trockner:57:10
      2021-11-23 18:47:45.955  - warn: javascript.0 (29681)     at script.js.Energieüberwachung.Trockner:16:3
      2021-11-23 18:47:45.957  - info: javascript.0 (29681) script.js.Energieüberwachung.Trockner: registered 7 subscriptions and 2 schedules
      2021-11-23 18:47:45.958  - info: javascript.0 (29681) Start javascript script.js.Energieüberwachung.Waschmaschine
      2021-11-23 18:47:46.007  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:46.011  - warn: javascript.0 (29681)     at script.js.Energieüberwachung.Waschmaschine:57:10
      2021-11-23 18:47:46.011  - warn: javascript.0 (29681)     at script.js.Energieüberwachung.Waschmaschine:16:3
      2021-11-23 18:47:46.012  - info: javascript.0 (29681) script.js.Energieüberwachung.Waschmaschine: registered 7 subscriptions and 2 schedules
      2021-11-23 18:47:48.032  - warn: meross.0 (9860) Can not get Abilities for Device 1909127140323125186448e1e9038373: Error: Timeout / undefined
      2021-11-23 18:47:48.335  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:48.346  - warn: javascript.0 (29681)     at Object.<anonymous> (script.js.Beleuchtung.Film_Ab:125:7)
      2021-11-23 18:47:48.346  - warn: javascript.0 (29681)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
      2021-11-23 18:47:48.347  - warn: javascript.0 (29681)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
      2021-11-23 18:47:48.347  - warn: javascript.0 (29681)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
      2021-11-23 18:47:48.347  - warn: javascript.0 (29681)     at processImmediate (internal/timers.js:461:21)
      2021-11-23 18:47:48.348  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:48.349  - warn: javascript.0 (29681)     at Object.<anonymous> (script.js.Energieüberwachung.Trockner:125:7)
      2021-11-23 18:47:48.349  - warn: javascript.0 (29681)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
      2021-11-23 18:47:48.350  - warn: javascript.0 (29681)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
      2021-11-23 18:47:48.350  - warn: javascript.0 (29681)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
      2021-11-23 18:47:48.350  - warn: javascript.0 (29681)     at processImmediate (internal/timers.js:461:21)
      2021-11-23 18:47:48.351  - warn: javascript.0 (29681) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
      2021-11-23 18:47:48.352  - warn: javascript.0 (29681)     at Object.<anonymous> (script.js.Energieüberwachung.Waschmaschine:125:7)
      2021-11-23 18:47:48.352  - warn: javascript.0 (29681)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
      2021-11-23 18:47:48.352  - warn: javascript.0 (29681)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
      2021-11-23 18:47:48.353  - warn: javascript.0 (29681)     at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
      2021-11-23 18:47:48.353  - warn: javascript.0 (29681)     at processImmediate (internal/timers.js:461:21)
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC/Pi3/etc.
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Ubuntu/Windows/Mac
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link Hallo zusammen,
      sudo iobroker stop
      sudo iobroker start
        Thomas Braun Most Active @hertob81 last edited by
        @hertob81
        iobroker stop
        iobroker fix
        iobroker start
        Und gewöhn die das sudo an der Stelle ab, der iobroker wird ohne sudo angepackt.
          Hallo Thomas,
          Danke für die Info.
          Magst mir noch verraten, was da dann im Hintergrund passiert?
          VG Tobias
            @hertob81
            Das richtet die mutmaßlich verbogenen Rechte.
              hertob81 @Thomas Braun last edited by
              Muss mir das Sorgen machen?
              Oder anders gefragt:
              Be welchen "Warnungen" herrscht den Handlungsbedarf?
              Danke Dir!
              javascript.0	2021-11-24 19:31:54.938	warn	(22274) at processImmediate (internal/timers.js:461:21)
              javascript.0	2021-11-24 19:31:54.938	warn	(22274) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
              javascript.0	2021-11-24 19:31:54.938	warn	(22274) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
              javascript.0	2021-11-24 19:31:54.938	warn	(22274) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
              javascript.0	2021-11-24 19:31:54.937	warn	(22274) at Object.<anonymous> (script.js.Energieüberwachung.Waschmaschine:138:7)
              javascript.0	2021-11-24 19:31:54.936	warn	(22274) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
              javascript.0	2021-11-24 19:31:54.935	warn	(22274) at processImmediate (internal/timers.js:461:21)
              javascript.0	2021-11-24 19:31:54.935	warn	(22274) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
              javascript.0	2021-11-24 19:31:54.935	warn	(22274) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
              javascript.0	2021-11-24 19:31:54.935	warn	(22274) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
              javascript.0	2021-11-24 19:31:54.934	warn	(22274) at Object.<anonymous> (script.js.Energieüberwachung.Trockner:138:7)
              javascript.0	2021-11-24 19:31:54.933	warn	(22274) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
              javascript.0	2021-11-24 19:31:54.933	warn	(22274) at processImmediate (internal/timers.js:461:21)
              javascript.0	2021-11-24 19:31:54.933	warn	(22274) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:5706:41)
              javascript.0	2021-11-24 19:31:54.932	warn	(22274) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
              javascript.0	2021-11-24 19:31:54.932	warn	(22274) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1087:38)
              javascript.0	2021-11-24 19:31:54.932	warn	(22274) at Object.<anonymous> (script.js.Beleuchtung.Film_Ab:138:7)
              javascript.0	2021-11-24 19:31:54.930	warn	(22274) getState "zigbee.0.00158d0006d6892c.opened" not found (3)
              host.raspberrypi	2021-11-24 19:31:17.256	warn	Requested repository "latest" does not exist in config.
                paul53 @hertob81 last edited by
                @hertob81 sagte:
                Das wird in 3 Skripten immer in Zeile 138 angemeckert. Gibt es diesen Datenpunkt nicht mehr oder hat er sich geändert?
                  hertob81 @paul53 last edited by
                  Ja, das ist mein Fenster-Sensor der aktuell ausgestiegen ist, da das Zigbee-Signal nicht immer reicht.
                  Das sollte aber ab morgen mit den Osram-Steckdosen erledigt haben...
                  Oder sollte ich den besser rausschmeißen?
                  Danke!
