    4. Luxtronik Adapter Fehler
      TimoWald last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC/Pi3/etc.
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Ubuntu/Windows/Mac
      Node-Version: 10.x.x
      Nodejs-Version: 10.x.x
      NPM-Version: 6.x.x
      Image genutzt: Ja/Nein
      Ort/Name der Imagedatei: Link
        TimoWald @TimoWald last edited by
        luxtronik1.0
        2021-11-28 12:02:52.667 warn Adapter wird neu gestartet
        luxtronik1.0
        2021-11-28 12:02:52.665 warn Achtung, mehrfach unvollständiger Datensatz 1800
        luxtronik1.0
        2021-11-28 10:58:03.159 warn 3501 connection error: Error: This socket has been ended by the other party
        luxtronik1.0
        2021-11-28 10:58:01.161 warn 3501 connection error: Error: This socket has been ended by the other party
        luxtronik1.0
        2021-11-28 10:57:51.149 info ack is not set!
        luxtronik1.0
        2021-11-28 10:54:50.636 info [START] Starting luxtronik adapter
        luxtronik1.0
        2021-11-28 10:54:50.565 info starting. Version 0.3.4 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v12.22.6, js-controller: 3.3.18
        host.raspberrypi
        2021-11-28 10:54:47.280 info instance system.adapter.luxtronik1.0 started with pid 13883
        host.raspberrypi
        2021-11-28 10:54:44.745 info instance system.adapter.luxtronik1.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        host.raspberrypi
        2021-11-28 10:54:44.207 info stopInstance system.adapter.luxtronik1.0 send kill signal
        luxtronik1.0
        2021-11-28 10:54:44.165 info Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        luxtronik1.0
        2021-11-28 10:54:44.164 info terminating
        luxtronik1.0
        2021-11-28 10:54:44.163 info [END] Stopping luxtronik adapter...
        luxtronik1.0
        2021-11-28 10:54:44.162 info Got terminate signal TERMINATE_YOURSELF
        host.raspberrypi
        2021-11-28 10:54:44.153 info stopInstance system.adapter.luxtronik1.0 (force=false, process=true)
          Kann mir bei diesem Fehler jemand helfen?
            Thomas Braun Most Active @TimoWald last edited by
            @timowald sagte in Luxtronik Adapter Fehler:
            Mit den fehlenden CodeTags?
            Ja, </> - Icon anklicken, LogFile zwischen die Steuerzeichen kopieren. Fertig.
              TimoWald @Thomas Braun last edited by
              2021-11-28 09:49:34.606 - warn: luxtronik1.0 (13377) Achtung, mehrfach unvollständiger Datensatz 1800
              2021-11-28 09:49:34.607 - warn: luxtronik1.0 (13377) Adapter wird neu gestartet
              2021-11-28 09:49:34.691 - info: host.raspberrypi stopInstance system.adapter.luxtronik1.0 (force=false, process=true)
              2021-11-28 09:49:34.705 - info: luxtronik1.0 (13377) Got terminate signal TERMINATE_YOURSELF
              2021-11-28 09:49:34.706 - info: host.raspberrypi stopInstance system.adapter.luxtronik1.0 send kill signal
              2021-11-28 09:49:34.707 - info: luxtronik1.0 (13377) [END] Stopping luxtronik adapter...
              2021-11-28 09:49:34.708 - info: luxtronik1.0 (13377) terminating
              2021-11-28 09:49:34.709 - info: luxtronik1.0 (13377) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              2021-11-28 09:49:35.308 - info: host.raspberrypi instance system.adapter.luxtronik1.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
              2021-11-28 09:49:37.784 - info: host.raspberrypi instance system.adapter.luxtronik1.0 started with pid 13447
              2021-11-28 09:49:41.048 - info: luxtronik1.0 (13447) starting. Version 0.3.4 in /opt/iobroker/node_modules/iobroker.luxtronik1, node: v12.22.6, js-controller: 3.3.18
              2021-11-28 09:49:41.122 - info: luxtronik1.0 (13447) [START] Starting luxtronik adapter
              2021-11-28 09:52:41.588 - info: luxtronik1.0 (13447) ack is not set!
                Kann mir einer sagen was ich ändern muss? Die Verbindung wird immer in gleichen Abständen abgebrochen.
