    4. Fehlermeldung nach dem Update auf node.js 14.18.2
    • G
      glitzi last edited by glitzi
      Re: Daten Seriell von Paradigma Solaranlage lesen
      heute habe ich auf nodejs non 12 auf 14.18.2 Upgedatet, jetzt kommt folgende Fehlermeldung
      19:11:20.628	error	javascript.0 (3623) script.js.Paradigma.Paradigma_Variablen_parsen: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
      19:11:20.636	error	javascript.0 (3623) at script.js.Paradigma.Paradigma_Variablen_parsen:237:21
      19:11:20.637	error	javascript.0 (3623) at script.js.Paradigma.Paradigma_Variablen_parsen:249:3
      19:11:20.638	info	javascript.0 (3623) script.js.Paradigma.Paradigma_Variablen_parsen: registered 0 subscriptions and 0 schedules
      19:11:20.640	error	javascript.0 (3623) script.js.Paradigma.Paradigma_Variablen_parsen: TypeError: SerialPort is not a constructor
      19:11:20.640	error	javascript.0 (3623) at script.js.Paradigma.Paradigma_Variablen_parsen:240:14
      19:11:20.641	error	javascript.0 (3623) at script.js.Paradigma.Paradigma_Variablen_parsen:249:3
      Thomas Braun G 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @glitzi last edited by
        @glitzi
        sudo ln -s /usr/bin/node /usr/bin/nodejs
        which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
        sagt?
        • G
          glitzi @glitzi last edited by glitzi
          @glitzi
          pi@raspberrypi4:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
          ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
          pi@raspberrypi4:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v14.18.2
          v14.18.2
          6.14.15
          OK:1 http://archive.raspberrypi.org/debian buster InRelease
          Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
          OK:3 https://repos.influxdata.com/debian buster InRelease
          OK:4 https://deb.nodesource.com/node_14.x buster InRelease
          OK:5 https://packages.grafana.com/oss/deb stable InRelease
          Es wurden 15,0 kB in 2 s geholt (8.853 B/s).
          Abhängigkeitsbaum wird aufgebaut.
          Statusinformationen werden eingelesen.... Fertig
          Alle Pakete sind aktuell.
          OK:2 https://repos.influxdata.com/debian buster InRelease
          OK:3 https://packages.grafana.com/oss/deb stable InRelease
          OK:5 http://raspbian.raspberrypi.org/raspbian buster InRelease
          nodejs:
            Installiert:           14.18.2-deb-1nodesource1
            Installationskandidat: 14.18.2-deb-1nodesource1
            Versionstabelle:
           *** 14.18.2-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                  100 /var/lib/dpkg/status
               10.24.0~dfsg-1~deb10u1 500
          pi@raspberrypi4:~ $
            @glitzi dir hats den serialport zerhauen
            versuchmal
            cd /opt/iobroker/node_modules/@serialport/
            npm rebuild
            • G
              glitzi @arteck last edited by glitzi
              @arteck
              Bestes Forum!!!
              DANKE es geht wieder.
              Ich sehe gerade das ich einen neuen Thread aufgemacht habe, eigentlich sollte es in diesen "Daten Seriell von Paradigma Solaranlage lesen"
