    4. Script Konvertierung HSV <==> Hex
    • Dutchman
      Dutchman Developer Most Active Administrators last edited by Dutchman
      Hi all,
      Auf anfrage und. z.b. praktisch fuer Yahka, hier ein script zum konvertieren von HEX nach HSV und umgekehrt :
      // ######### DutchmanNL #########
      // ###### HSV Color to HEX ######
      // ############ V1.0 ############
      // Add the state containing HEX values here :
      const zigbeeDevice = [
          'zigbee.0.group_2.color',     // Bank
          'zigbee.0.group_3.color'     // Vensterbank
      // ## Don't change anything from here ##
      // Prepare variables
      const mySubscription = {}, debounceTimer = {};
      // Create Folder structure
      extendObjectAsync(`0_userdata.0.HEXtoHSL` , {
          "type": "folder",
          "common": {
          "name": 'Convert HEX to HSL color',
              "role": "",
              "icon": "",
          "native": {},
      // Read all array objects, create new state in javascript instance and subscribe on changes
      for (const device in zigbeeDevice) {
          // Define folder structure in userdata directory
          const statePrepare = zigbeeDevice[device].split('.');
      	const deviceName = `0_userdata.0.HEXtoHSL.${statePrepare[0]}_${statePrepare[1]}_${statePrepare[2]}`
          // Create Device Structure
          extendObjectAsync(deviceName , {
              "type": "device",
              "common": {
              "name": statePrepare[2],
                  "role": "",
                  "icon": "",
              "native": {},
          // States to cover Hue and Sat values
      	createState(`${deviceName}.hue` , {
      		'name': `Hue of ${statePrepare[2]}`,
      		'role': 'level.color.hue',
      		'type': 'number'
      	// @ts-ignore
      	createState(`${deviceName}.sat`, {
      		'name': `Sat of ${statePrepare[2]}`,
      		'role': 'level.color.sat',
      		'type': 'number'
      	// Subscribe on state changes for HUE and Saturation
      	// @ts-ignore
      	mySubscription[`${deviceName}.hue`] = on(
              [`${deviceName}.hue`,
              `${deviceName}.sat`
              ], (data) => {
              // DebounceTimer
              // Reset timer (if running) and start new one for next watchdog interval
      		if (debounceTimer[zigbeeDevice[device]]) {
      			clearTimeout(debounceTimer[zigbeeDevice[device]]);
      			debounceTimer[zigbeeDevice[device]] = null;
      		debounceTimer[zigbeeDevice[device]] = setTimeout(() => {
                  if (!data.state.ack){
                      const h = getState(`${deviceName}.hue`).val / 360;
                      const s = getState(`${deviceName}.sat`).val / 100;
                      const v = 1;
                      const colorRGB = hsvTOrgb(h,s,v)
                      const colorHEX = rgbTOhex(colorRGB)
                      console.log(`HSV value : ${h}, ${s}, ${v}`);
                      setState(`${zigbeeDevice[device]}`, colorHEX);
                      // setState(`${deviceName}.hue`, h * 360, true)
                      // setState(`${deviceName}.sat`, h * 100, true)
              }, (500));
          // Subscribe on state changes for HEX surce
              ], (data) => {
                  console.log(`Device change detected : ${JSON.stringify(data.id)} value : ${data.state.val} | ack : ${data.state.ack}`);
              // DebounceTimer
                      const colorHEX = data.state.val;
                      const colorRGB = hexTOrgb(colorHEX)
                      const colorHSV = rgbTOhsv(colorRGB)
                      const h = roundDigit(colorHSV[0]);
                      console.log(colorHSV);
                      const s = roundDigit(colorHSV[1]);
                      setState(`${deviceName}.sat`, s, true);
                      setState(`${deviceName}.hue`, h, true);
              }, (500));
      ////////////////Funktionen////////////////
       * Coonvert HSV to RGB
       * @param {number} h - HUE value
       * @param {number} s - Saturation value
       * @param {number} v - Brightness value
      function hsvTOrgb(h, s, v) {
                  var r, g, b, i, f, p, q, t;
                  i = Math.floor(h * 6);
                  f = h * 6 - i;
                  p = v * (1 - s);
                  q = v * (1 - f * s);
                  t = v * (1 - (1 - f) * s);
                  switch (i % 6) {
                      case 0: r = v, g = t, b = p; break;
                      case 1: r = q, g = v, b = p; break;
                      case 2: r = p, g = v, b = t; break;
                      case 3: r = p, g = q, b = v; break;
                      case 4: r = t, g = p, b = v; break;
                      case 5: r = v, g = p, b = q; break;
                  console.log(`${r} ${g} ${b}`)
                  r=Math.round(255 * r);
                  g=Math.round(255 * g);
                  b=Math.round(255 * b);
                  return [r,g,b];
      function rgbTOhsv(rgb) {
      	let rdif;
      	let gdif;
      	let bdif;
      	let h;
      	let s;
      	const r = rgb[0] / 255;
      	const g = rgb[1] / 255;
      	const b = rgb[2] / 255;
      	const v = Math.max(r, g, b);
      	const diff = v - Math.min(r, g, b);
      	const diffc = function (c) {
      		return (v - c) / 6 / diff + 1 / 2;
      	if (diff === 0) {
      		h = 0;
      		s = 0;
      	} else {
      		s = diff / v;
      		rdif = diffc(r);
      		gdif = diffc(g);
      		bdif = diffc(b);
      		if (r === v) {
      			h = bdif - gdif;
      		} else if (g === v) {
      			h = (1 / 3) + rdif - bdif;
      		} else if (b === v) {
      			h = (2 / 3) + gdif - rdif;
      		if (h < 0) {
      			h += 1;
      		} else if (h > 1) {
      			h -= 1;
      	return [
      		h * 360,
      		s * 100,
      		v * 100
      function rgbTOhex (args) {
      	const integer = ((Math.round(args[0]) & 0xFF) << 16)
      		+ ((Math.round(args[1]) & 0xFF) << 8)
      		+ (Math.round(args[2]) & 0xFF);
      	const string = integer.toString(16).toUpperCase();
      	return '000000'.substring(string.length) + string;
      //In HEX konvertieren
      function toHex(number) {
          if (number < 0) number = 0xFFFFFFFF + number + 1;
          var n = number.toString(16).toUpperCase();
          if (n.length == 1) {
              n = '0' + n;
          return n;
      // Function to convert HEX to RGB
      function hexTOrgb(args) {
          const match = args.toString(16).match(/[a-f0-9]{6}|[a-f0-9]{3}/i);
          if (!match) {
              return [0, 0, 0];
          let colorString = match[0];
          if (match[0].length === 3) {
              colorString = colorString.split('').map(char => {
                  return char + char;
              }).join('');
          const integer = parseInt(colorString, 16);
          const r = (integer >> 16) & 0xFF;
          const g = (integer >> 8) & 0xFF;
          const b = integer & 0xFF;
          return [r, g, b];
      // Function to convert RGB to HSL
      function rgbTOhsl (rgb) {
      	const min = Math.min(r, g, b);
      	const max = Math.max(r, g, b);
      	const delta = max - min;
      	let h;
      	let s;
      	if (max === min) {
      		h = 0;
      	} else if (r === max) {
      		h = (g - b) / delta;
      	} else if (g === max) {
      		h = 2 + (b - r) / delta;
      	} else if (b === max) {
      		h = 4 + (r - g) / delta;
      	h = Math.min(h * 60, 360);
      	if (h < 0) {
      		h += 360;
      	const l = (min + max) / 2;
      	if (max === min) {
      		s = 0;
      	} else if (l <= 0.5) {
      		s = delta / (max + min);
      	} else {
      		s = delta / (2 - max - min);
      	return [h, s * 100, l * 100];
      // Funtion to round digits properly
      function roundDigit(num){
          // return Math.round((num + Number.EPSILON) * 100) / 100
          return Math.round((num + Number.EPSILON));
      paul53 S 2 Replies Last reply Reply Quote 3
        paul53 @Dutchman last edited by
        @dutchman
        Markiere bitte das Thema gemäß den Forum Rules als [Vorlage].
          stan23 @Dutchman last edited by
          Statt dieser Schleife for-in
              // pick device from array using index
              myDevice = zigbeeDevice[device];
          kann man auch for-of benutzen, sofern man den Index nicht braucht.
          for (const device of zigbeeDevice) {
              // no need to pick from array, because 'of' returns the element and not the index
              myDevice = device;
          Hab ich aus JavaScript-Tutorials gelernt 😉
            tklein last edited by
            hi,
            sorry stehe momentan a bissl auf dem Schlauch: wie kann ich das Script nutzen/konfigurieren?
            Werden Datenpunkte angelegt?
            Thomas
            javascript
