    4. Error bei Adapter Updates: /bin/sh: 1: cmake: not foundmake:
    • wendy2702
      wendy2702 last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Core I7
      Arbeitsspeicher: 16GB
      Festplattenart: SSD
      Betriebssystem: Debian Buster
      Node-Version: 14.18.2
      Nodejs-Version: 14.18.2
      NPM-Version: 6.14.15
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      hatte eben 3 Adapter updates-
      Ical verlief ohne Probleme:
      2021-12-20 09:41:44.689  - info: host.iobroker iobroker upgrade ical@1.11.6
      2021-12-20 09:41:45.969  - info: host.iobroker iobroker Update ical from @1.11.5 to @1.11.6
      2021-12-20 09:41:46.353  - info: host.iobroker iobroker NPM version: 6.14.15
      2021-12-20 09:41:46.354  - info: host.iobroker iobroker npm install iobroker.ical@1.11.6 --loglevel error --prefix "/opt/iobroker" (System call)
      2021-12-20 09:42:00.276  - info: linux-control.0 (22579) getting data from VIS-EG (192.168.178.216:22)
      2021-12-20 09:42:01.069  - info: host.iobroker iobroker upload [4] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
      2021-12-20 09:42:01.169  - info: host.iobroker iobroker Update "system.adapter.ical.0"
      2021-12-20 09:42:01.173  - info: host.iobroker iobroker Update "system.adapter.ical.1"
      2021-12-20 09:42:01.219  - info: host.iobroker iobroker Update "system.adapter.ical.2"
      2021-12-20 09:42:01.224  - info: host.iobroker stopInstance system.adapter.ical.0 (force=false, process=false)
      2021-12-20 09:42:01.224  - info: host.iobroker stopInstance canceled schedule system.adapter.ical.0
      2021-12-20 09:42:01.491  - info: host.iobroker stopInstance system.adapter.ical.1 (force=false, process=false)
      2021-12-20 09:42:01.494  - info: host.iobroker stopInstance canceled schedule system.adapter.ical.1
      2021-12-20 09:42:01.511  - info: host.iobroker stopInstance system.adapter.ical.2 (force=false, process=false)
      2021-12-20 09:42:01.511  - info: host.iobroker stopInstance canceled schedule system.adapter.ical.2
      2021-12-20 09:42:01.595  - info: host.iobroker iobroker upload [3] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
      2021-12-20 09:42:01.655  - info: host.iobroker iobroker upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index.html index.html text/html
      2021-12-20 09:42:01.715  - info: host.iobroker iobroker upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/img/info-big.png img/info-big.png image/png
      2021-12-20 09:42:01.775  - info: host.iobroker iobroker upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/ical.png ical.png image/png
      2021-12-20 09:42:01.830  - info: host.iobroker iobroker Adapter "ical" updated
      2021-12-20 09:42:02.845  - info: host.iobroker iobroker exit 0
      Danach dann Linux Control mit dem in der Überschrift genannten "Fehler":
      $ iobroker upgrade linux-control@1.1.4
      Update linux-control from @1.1.3 to @1.1.4
      npm install iobroker.linux-control@1.1.4 --loglevel error --prefix "/opt/iobroker" (System call)
      make: *** [config_deps.target.mk:13: /opt/iobroker/node_modules/cpu-features/deps/cpu_features/build/Makefile] Error 127gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.4.60-1-pvegyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/cpu-featuresgyp ERR! node -v v14.18.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      In file included from ../src/binding.cc:6:/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:787:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/14.18.2/include/node/node.h:821:3: note: in expansion of macro 'NODE_MODULE_X' NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/binding.cc:2003:1: note: in expansion of macro 'NODE_MODULE' NODE_MODULE(sshcrypto, init) ^~~~~~~~~~~
      upload [20] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/words.js words.js application/javascript
      Update "system.adapter.linux-control.0"
      upload [19] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/style.css style.css text/css
      upload [18] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/linux-control.png linux-control.png image/png
      upload [17] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/updates.json lib/updates.json application/json
      upload [16] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/services.json lib/services.json application/json
      upload [15] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/needrestart.json lib/needrestart.json application/json
      upload [14] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/jquery.fancytree.dnd5.js lib/jquery.fancytree.dnd5.js application/javascript
      upload [13] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/info.json lib/info.json application/json
      upload [12] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/distribution.json lib/distribution.json application/json
      upload [11] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/lib/control.json lib/control.json application/json
      upload [10] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/index_m.js index_m.js application/javascript
      upload [9] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/index_m.html index_m.html text/html
      upload [8] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/state.png img/state.png image/png
      upload [7] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/menu_right.svg img/menu_right.svg image/svg+xml
      upload [6] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/menu_down.svg img/menu_down.svg image/svg+xml
      upload [5] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/info-big.png img/info-big.png image/png
      upload [4] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/folder.png img/folder.png image/png
      upload [3] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox_marked.svg img/checkbox_marked.svg image/svg+xml
      upload [2] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox_intermediate.svg img/checkbox_intermediate.svg image/svg+xml
      upload [1] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/img/checkbox.svg img/checkbox.svg image/svg+xml
      upload [0] linux-control.admin /opt/iobroker/node_modules/iobroker.linux-control/admin/admin.d.ts admin.d.ts video/mp2t
      Adapter "linux-control" updated
      Process exited with code 0
      Und auch iQontrol:
      $ iobroker upgrade iqontrol@1.11.0
      Update iqontrol from @1.10.0 to @1.11.0
      npm install iobroker.iqontrol@1.11.0 --loglevel error --prefix "/opt/iobroker" (System call)
      /bin/sh: 1: cmake: not foundmake: *** [config_deps.target.mk:13: /opt/iobroker/node_modules/cpu-features/deps/cpu_features/build/Makefile] Error 127gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack at ChildProcess.emit (events.js:400:28)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)gyp ERR! System Linux 5.4.60-1-pvegyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/cpu-featuresgyp ERR! node -v v14.18.2gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      upload [650] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/plugins/jquery.pressure.min.js jquery/plugins/jquery.pressure.min.js application/javascript
      upload [350] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/fancytree/react/state.pdn fancytree/react/state.pdn null
      upload [600] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-svg/user-black.svg jquery/images/icons-svg/user-black.svg image/svg+xml
      upload [300] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/theme/icecoder.css codemirror/theme/icecoder.css text/css
      upload [550] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-svg/comment-black.svg jquery/images/icons-svg/comment-black.svg image/svg+xml
      upload [250] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/src/input/movement.js codemirror/src/input/movement.js application/javascript
      upload [500] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-png/user-black.png jquery/images/icons-png/user-black.png image/png
      upload [200] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/mode/vue/vue.js codemirror/mode/vue/vue.js application/javascript
      upload [450] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/jquery/images/icons-png/comment-black.png jquery/images/icons-png/comment-black.png image/png
      upload [150] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/mode/perl/perl.js codemirror/mode/perl/perl.js application/javascript
      upload [400] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/index.js index.js application/javascript
      upload [100] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/mode/diff/diff.js codemirror/mode/diff/diff.js application/javascript
      upload [90] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/mode/clojure/clojure.js codemirror/mode/clojure/clojure.js application/javascript
      upload [80] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/keymap/sublime.js codemirror/keymap/sublime.js application/javascript
      upload [70] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/selection/mark-selection.js codemirror/addon/selection/mark-selection.js application/javascript
      upload [60] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/scroll/scrollpastend.js codemirror/addon/scroll/scrollpastend.js application/javascript
      upload [350] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/symbols/media_stop.png images/symbols/media_stop.png image/png
      upload [50] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/mode/loadmode.js codemirror/addon/mode/loadmode.js application/javascript
      upload [40] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/lint/coffeescript-lint.js codemirror/addon/lint/coffeescript-lint.js application/javascript
      upload [30] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/fold/markdown-fold.js codemirror/addon/fold/markdown-fold.js application/javascript
      upload [20] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/edit/continuelist.js codemirror/addon/edit/continuelist.js application/javascript
      upload [19] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/edit/closetag.js codemirror/addon/edit/closetag.js application/javascript
      upload [18] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/edit/closebrackets.js codemirror/addon/edit/closebrackets.js application/javascript
      upload [17] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/display/rulers.js codemirror/addon/display/rulers.js application/javascript
      upload [16] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/display/placeholder.js codemirror/addon/display/placeholder.js application/javascript
      upload [15] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/display/panel.js codemirror/addon/display/panel.js application/javascript
      upload [14] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/display/fullscreen.js codemirror/addon/display/fullscreen.js application/javascript
      upload [13] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/display/fullscreen.css codemirror/addon/display/fullscreen.css text/css
      upload [12] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/display/autorefresh.js codemirror/addon/display/autorefresh.js application/javascript
      upload [11] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/dialog/dialog.js codemirror/addon/dialog/dialog.js application/javascript
      upload [10] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/dialog/dialog.css codemirror/addon/dialog/dialog.css text/css
      upload [9] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/comment/continuecomment.js codemirror/addon/comment/continuecomment.js application/javascript
      upload [8] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/addon/comment/comment.js codemirror/addon/comment/comment.js application/javascript
      upload [7] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/README.md codemirror/README.md text/markdown
      upload [6] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/LICENSE codemirror/LICENSE null
      upload [5] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/CONTRIBUTING.md codemirror/CONTRIBUTING.md text/markdownupload [300] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/maximize.png images/maximize.png image/png
      upload [4] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/CHANGELOG.md codemirror/CHANGELOG.md text/markdown
      upload [3] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/codemirror/AUTHORS codemirror/AUTHORS null
      upload [2] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/blockly.js blockly.js application/javascript
      upload [1] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/background_and_overlay.png background_and_overlay.png image/png
      upload [0] iqontrol.admin /opt/iobroker/node_modules/iobroker.iqontrol/admin/admin.d.ts admin.d.ts video/mp2t
      upload [250] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/panic_off.png images/icons/panic_off.png image/png
      upload [200] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/fluent/fluent_widget_on.png images/icons/fluent/fluent_widget_on.png image/png
      upload [150] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/fluent/fluent_light_lampshade_on.png images/icons/fluent/fluent_light_lampshade_on.png image/png
      upload [100] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/fluent/fluent_bell_ringing_on.png images/icons/fluent/fluent_bell_ringing_on.png image/png
      upload [90] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/fluent/fluent_battery_10.png images/icons/fluent/fluent_battery_10.png image/png
      upload [80] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/flood_on.png images/icons/flood_on.png image/png
      upload [70] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/file_html.png images/icons/file_html.png image/png
      upload [60] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/door_closed.png images/icons/door_closed.png image/png
      upload [50] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/blind_opening.png images/icons/blind_opening.png image/png
      upload [40] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/bell_off.png images/icons/bell_off.png image/png
      upload [30] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/icons/alarm_on.png images/icons/alarm_on.png image/png
      upload [20] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/error.png images/error.png image/png
      upload [19] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/ct_invert.png images/ct_invert.png image/png
      upload [18] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/ct.png images/ct.png image/png
      upload [17] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/battery.png images/battery.png image/png
      upload [16] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/backward.png images/backward.png image/png
      upload [15] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/images/background.png images/background.png image/png
      upload [14] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [13] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [12] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [11] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [10] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [9] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [7] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/es/translations.json i18n/es/translations.json application/json
      upload [6] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/en/translations.json i18n/en/translations.json application/json
      upload [5] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/i18n/de/translations.json i18n/de/translations.json application/json
      upload [4] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/favicon_big.png favicon_big.png image/png
      upload [3] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/favicon.png favicon.png image/png
      upload [2] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [1] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/conn.js conn.js application/javascript
      upload [0] iqontrol /opt/iobroker/node_modules/iobroker.iqontrol/www/cache.manifest cache.manifest text/cache-manifest
      Update "system.adapter.iqontrol.0"
      Adapter "iqontrol" updated
      Jemand ne Idee was das ist und wie ich es beseitigen kann?
      Danke und Gruß
      Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @wendy2702 last edited by
        @wendy2702 sagte in Error bei Adapter Updates: /bin/sh: 1: cmake: not foundmake::
        cmake: not found
        cmake nachinstallieren...
        • Glasfaser
          Glasfaser @wendy2702 last edited by Glasfaser
          @wendy2702
          sudo apt update
          sudo apt install cmake
          • wendy2702
            Ist das denn neu das es jetzt benötigt wird?
            Hatte vorgestern ca. 15 Updates bei denen die Meldung nicht kam.
            Und hat das jetzt einen negativen einfluß auf meine beiden Updates?
            Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
            • Glasfaser
              Eigentlich nicht .... bei vielen fehlte es .
              Du bist der erste dem das Auffällt , währe die Frage ab welchen Update es gekommen ist .
                @wendy2702
                Das Modul
                benötigt das wohl. Hab ich aber nicht in meinem System, keine Ahnung welcher Adapter damit angeschleppt kommt.
                • Glasfaser
                  Glasfaser last edited by
                  @Wen
                  z.B . das JS Modul SSH benötigt es
                  https://forum.iobroker.net/topic/47576/adapter-updates-fehler-cmake-not-found?_=1631190453457
                  • wendy2702
                    OK.
                    Danke euch beiden.
                    Habe es mal nach installiert und muss jetzt auf die nächsten Adapter Updates warten.
                    • crunchip
                      crunchip Forum Testing Most Active @Glasfaser last edited by
                      @glasfaser sagte in Error bei Adapter Updates: /bin/sh: 1: cmake: not foundmake::
                      da ich den Thread gerade sehe...ist mir vorhin auch aufgefallen, gestern sah ich das noch nicht bei dem ein oder anderen update
                      @thomas-braun sagte in Error bei Adapter Updates: /bin/sh: 1: cmake: not foundmake::
                      Info Adapter?
                        Thomas Braun Most Active @crunchip last edited by
                        @crunchip sagte in Error bei Adapter Updates: /bin/sh: 1: cmake: not foundmake::
                        Info Adapter?
                        Nö, den hab ich drauf, aber node_modules/cpu-features nicht. Kann also keine Dependency sein.
                        • wendy2702
                          Ich würde mal auf Linux-Control tippen.
                          345
