    4. Java Scrip Modul
    Java Scrip Modul
      Lucascoco last edited by
      Systemdata arm4
      Hardwaresystem: PI4.
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Ubuntu
      Node-Version: 14.18.2
      Nodejs-Version: 10.x.x
      NPM-Version: 6.14.15
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      nach dem Update auf die neue NPM Version kommt immer folgender Fehler
      2021-12-31 12:30:52.501 - info: host.IpBrokerPi4 instance system.adapter.javascript.0 started with pid 5243
      2021-12-31 12:30:52.977 - error: host.IpBrokerPi4 Caught by controller[0]: internal/modules/cjs/loader.js:905
      2021-12-31 12:30:52.977 - error: host.IpBrokerPi4 Caught by controller[0]: throw err;
      2021-12-31 12:30:52.977 - error: host.IpBrokerPi4 Caught by controller[0]: ^
      2021-12-31 12:30:52.977 - error: host.IpBrokerPi4 Caught by controller[0]: Error: Cannot find module 'typescript'
      2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: Require stack:
      2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/server.js
      2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: - /opt/iobroker/node_modules/virtual-tsc/build/index.js
      2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
      2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:902:15)
      2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:746:27)
      2021-12-31 12:30:52.978 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
      2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/virtual-tsc/build/server.js:4:10)
      2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      2021-12-31 12:30:52.979 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      2021-12-31 12:30:52.980 - error: host.IpBrokerPi4 Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
      2021-12-31 12:30:52.980 - error: host.IpBrokerPi4 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/virtual-tsc/build/index.js:8:16)
      2021-12-31 12:30:52.980 - error: host.IpBrokerPi4 Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      2021-12-31 12:30:52.980 - error: host.IpBrokerPi4 Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      2021-12-31 12:30:52.980 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:974:19)
      2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at require (internal/modules/cjs/helpers.js:93:18)
      2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
      2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1085:14)
      2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
      2021-12-31 12:30:52.981 - error: host.IpBrokerPi4 Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:950:32)
      2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:790:12)
      2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:76:12)
      2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: at internal/main/run_main_module.js:17:47
      2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: {
      2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: requireStack: [
      2021-12-31 12:30:52.982 - error: host.IpBrokerPi4 Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/server.js',
      2021-12-31 12:30:52.983 - error: host.IpBrokerPi4 Caught by controller[0]: '/opt/iobroker/node_modules/virtual-tsc/build/index.js',
      2021-12-31 12:30:52.983 - error: host.IpBrokerPi4 Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
      2021-12-31 12:30:52.983 - error: host.IpBrokerPi4 Caught by controller[0]: ]
      2021-12-31 12:30:52.983 - error: host.IpBrokerPi4 Caught by controller[0]: }
      2021-12-31 12:30:52.983 - error: host.IpBrokerPi4 instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      2021-12-31 12:30:52.983 - info: host.IpBrokerPi4 Restart adapter system.adapter.javascript.0 because enabled
        Thomas Braun Most Active @Lucascoco last edited by
        @lucascoco
        NodeJS ist sauber im System? Wenn du von npm alleine sprichst schwant mir da schon wieder was.
          Wie erkenne ich denn, ob es sauber im System ist ?
            @lucascoco
            Das sagt dir die Ausgabe von
            which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
              Das kam raus
              v14.18.2
              v14.18.2
              6.14.15
                @lucascoco
                Nicht nacherzählen, vollständige Ein- und Ausgaben. Da kam hofffentlich noch mehr ums Eck.
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v14.18.2
                  v14.18.2
                  6.14.15
                  OK:1 http://archive.raspberrypi.org/debian buster InRelease
                  OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                  OK:3 https://deb.nodesource.com/node_14.x buster InRelease
                  Abhängigkeitsbaum wird aufgebaut.
                  Statusinformationen werden eingelesen.... Fertig
                  Aktualisierung für 129 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                  nodejs:
                    Installiert:           14.18.2-deb-1nodesource1
                    Installationskandidat: 14.18.2-deb-1nodesource1
                    Versionstabelle:
                   *** 14.18.2-deb-1nodesource1 500
                          500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                          100 /var/lib/dpkg/status
                       10.24.0~dfsg-1~deb10u1 500
                    @lucascoco sagte in Java Scrip Modul:
                    Die node-Installation ist okay, der Rest hängt schwer hinterher:
                    sudo apt update
                    sudo apt full-upgrade
                    sudo reboot
                    • AlCalzone
                      Scheinbar zufällige
                      Cannot find module
                      hab ich bisher immer dann gesehen, wenn jemand manuell einzelne Module in /opt/iobroker nachinstalliert hat. Wäre also ein Versuch wert, sich mal /opt/iobroker/package.json anzuschauen, ob da nicht ein unnötiges typescript drin auftaucht.
                        @alcalzone said in Java Scrip Modul:
                        typescript
                        nein ist nicht mit drin
                        Full upgrade ist System wurde gemacht, Fehler ist immer noch da
                        Thomas Braun AlCalzone 2 Replies Last reply Reply Quote 0
                          War auch nicht anders zu erwarten. Ich schau mir aber lieber voll durchpatchte Systeme an.
                          cd /opt/iobroker
                          npm list
                          • AlCalzone
                            AlCalzone Developer @Lucascoco last edited by
                            ggf. was anderes - zeig doch mal den Inhalt
                              npm ERR! missing: @types/node@14.18.0, required by iobroker.javascript@5.2.13
                              npm ERR! peer dep missing: typescript@>=2.0.0, required by virtual-tsc@0.6.1
                              npm ERR! missing: @types/node@14.18.0, required by @types/iobroker@3.3.4
                              Die Ausgabe ist zu lang, habe mal das Ende angefügt
                                "name": "iobroker.inst",
                                "version": "2.0.3",
                                "private": true,
                                "description": "Automation platform in node.js",
                                "scripts": {
                                  "install": "node lib/checkVersions.js",
                                  "postinstall": "node lib/install.js",
                                  "test": "node node_modules/mocha/bin/mocha --exit"
                                "dependencies": {
                                  "colors": "^1.3.3",
                                  "fs-extra": "^7.0.1",
                                  "iobroker": "^2.0.3",
                                  "iobroker.admin": "^5.2.3",
                                  "iobroker.alexa2": "^3.11.2",
                                  "iobroker.backitup": "^2.2.2",
                                  "iobroker.devices": "^1.0.9",
                                  "iobroker.discovery": "^2.7.3",
                                  "iobroker.email": "^1.0.10",
                                  "iobroker.flot": "^1.10.7",
                                  "iobroker.history": "^1.9.14",
                                  "iobroker.hm-rega": "^3.0.33",
                                  "iobroker.hm-rpc": "^1.14.50",
                                  "iobroker.hue-extended": "^2.0.0",
                                  "iobroker.info": "^1.9.8",
                                  "iobroker.javascript": "^5.2.13",
                                  "iobroker.js-controller": "^3.3.22",
                                  "iobroker.rpi2": "^1.3.1",
                                  "iobroker.shelly": "^4.0.7",
                                  "iobroker.simple-api": "^2.6.1",
                                  "iobroker.sonoff": "^2.4.5",
                                  "iobroker.tahoma": "github:Excodibur/ioBroker.tahoma",
                                  "iobroker.telegram": "^1.10.0",
                                  "iobroker.viessmannapi": "^2.0.6",
                                  "iobroker.web": "^3.4.9",
                                  "iobroker.yahka": "^0.13.1",
                                  "semver": "^5.6.0",
                                  "yargs": "^7.0.2"
                              • AlCalzone
                                @lucascoco Ok in package.json ist wirklich nix auffälliges dabei... Ggf. nochmal iobroker.javascript drüber installieren, aber ansonsten bin ich raus.
                                  Homoran Global Moderator Administrators @AlCalzone last edited by
                                  @alcalzone sagte in Java Scrip Modul:
                                  und in package-lock.json vielleicht?
                                    Ich glaube das hat geholfen
                                    npm install iobroker.javascript
                                    681
