    4. Node-Red
    5. (Gelöst)Fehlermeldung Node Red CCU
      Lafgoh last edited by Lafgoh
      Hallo und ein gutes neues Jahr nochmal...
      Ich habe seit einiger Zeit ein Problem mit ständigen Fehlermeldungen im Log. Es scheint zwar alles ohne Probleme zu laufen, nervt aber doch ziemlich.
      :8181
      node-red.0
      2022-01-02 10:53:22.830	error	2 Jan 10:53:22 - [error] [ccu-connection:localhost] getRegaVariables Error: connect ECONNREFUSED 127.0.0.1:8181
      node-red.0
      2022-01-02 10:52:52.824	error	2 Jan 10:52:52 - [error] [ccu-connection:localhost] getRegaPrograms Error: connect ECONNREFUSED 127.0.0.1:8181
      node-red.0
      2022-01-02 10:52:52.822	error	2 Jan 10:52:52 - [error] [ccu-connection:localhost] getRegaVariables Error: connect ECONNREFUSED 127.0.0.1:8181
      node-red.0
      2022-01-02 10:52:22.807	error	2 Jan 10:52:22 - [error] [ccu-connection:localhost] getRegaPrograms Error: connect ECONNREFUSED 127.0.0.1:8181
      node-red.0
      2022-01-02 10:52:22.804	error	2 Jan 10:52:22 - [error] [ccu-connection:localhost] getRegaVariables Error: connect ECONNREFUSED 127.0.0.1:8181
      node-red.0
      2022-01-02 10:51:52.795	error	2 Jan 10:51:52 - [error] [ccu-connection:localhost] getRegaPrograms Error: connect ECONNREFUSED 127.0.0.1:8181
      node-red.0
      2022-01-02 10:51:52.793	error	2 Jan 10:51:52 - [error] [ccu-connection:localhost] getRegaVariables Error: connect ECONNREFUSED 127.0.0.1:8181
      node-red.0
      2022-01-02 10:51:22.776	error	2 Jan 10:51:22 - [error] [ccu-connection:localhost] getRegaPrograms Error: connect ECONNREFUSED 127.0.0.1:8181
      node-red.0
      2022-01-02 10:51:22.659	error	2 Jan 10:51:22 - [error] [ccu-connection:localhost] getRegaVariables Error: connect ECONNREFUSED 127.0.0.1:8181
      node-red.0
      2022-01-02 10:51:22.554	error	2 Jan 10:51:22 - [error] [ccu-connection:localhost] < VirtualDevices init Error: connect ECONNREFUSED 127.0.0.1:92922 Jan 10:51:22 - [error] [ccu-connection:localhost] init VirtualDevices Error: connect ECONNREFUSED 127.0.0.1:92922 Jan 10:51:22 - [info] [ccu-connection:localhost] Interface VirtualDevices disconnected
      node-red.0
      2022-01-02 10:51:22.554	error	2 Jan 10:51:22 - [error] [ccu-connection:localhost] init HmIP-RF Error: connect ECONNREFUSED 127.0.0.1:20102 Jan 10:51:22 - [info] [ccu-connection:localhost] Interface HmIP-RF disconnected
      node-red.0
      2022-01-02 10:51:22.554	error	2 Jan 10:51:22 - [error] [ccu-connection:localhost] init BidCos-RF Error: connect ECONNREFUSED 127.0.0.1:20012 Jan 10:51:22 - [info] [ccu-connection:localhost] Interface BidCos-RF disconnected2 Jan 10:51:22 - [error] [ccu-connection:localhost] < HmIP-RF init Error: connect ECONNREFUSED 127.0.0.1:2010
      node-red.0
      2022-01-02 10:51:22.554	error	2 Jan 10:51:22 - [error] [ccu-connection:localhost] < BidCos-RF init Error: connect ECONNREFUSED 127.0.0.1:2001
      node-red.0
      2022-01-02 10:51:22.485	error	2 Jan 10:51:22 - [error] [ccu-connection:localhost] Error: rega getChannels connect ECONNREFUSED 127.0.0.1:8181
      hat vielleicht jemand eine Idee, wie ich das los werde? Ports und Ip Adressen sind - eigentlich- alles in der CCU Firewall eingetragen
      Danke in Voraus
      Plattform
      Windows
      Betriebssystem
      win32
      Architektur
      x64
      CPUs
      12
      Geschwindigkeit
      3194 MHz
      Modell
      AMD Ryzen 5 1600 Six-Core Processor
      RAM
      15.95 GB
      System-Betriebszeit
      2 T. 11:17:12
      Node.js
      v14.18.2
      NPM
      6.14.15
      Datenträgergröße
      232.31 GB
      freier Festplattenspeicher
      146.44 GB
      Anzahl der Adapter
      362
      Betriebszeit
      2 T. 03:27:19
      Aktive Instanzen
      29
      location
      C:\Program Files\iobroker
      Hostname
      Server2020
        paul53 @Lafgoh last edited by
        @lafgoh sagte: ECONNREFUSED 127.0.0.1:8181
        Die CCU wird wohl kaum unter der lokalen IP-Adresse erreichbar sein.
          Lafgoh @paul53 last edited by
          @paul53 Node-RED : 192.168.168.90 2022-01-02 11-29-59.jpg
          Habe ich da was falsch eingetragen? CCU hat .111 als IP
            jauntyjosef @Lafgoh last edited by
            @lafgoh Und Wie hast du das Problem gelöst? Ich habe nämlich seit einiger Zeit die gleichen Fehlermeldungen.
