    4. [gelöst] js-controller mit Fehlermeldung
      PorterRicks last edited by PorterRicks
      Seitdem ich gestern den Simple-Api Adapter installiert habe, komme ich nicht mehr in den Broker rein...(admin)
      iobroker status liefert :
      pi@raspberrypi:/opt/iobroker $ iobroker status
      iobroker is not running on this host.
      Objects type: file
      States  type: file
      Die admin.0 Instanz ist vorhanden und schaut ok aus
      pi@raspberrypi:/opt/iobroker $ iobroker list instances
        system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        system.adapter.cloud.0                  : cloud                 : raspberrypi                              -  enabled
        system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
      Wenn ich nun den Controller manuell starte, bekomme ich im sys-log eine Fehlermeldung und der Controller wird wohl nicht gestartet:
      Jan  4 09:40:13 raspberrypi systemd[1]: iobroker.service: Consumed 2.032s CPU time.
      Jan  4 09:40:13 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 14.
      Jan  4 09:40:13 raspberrypi systemd[1]: Stopped ioBroker Server.
      Jan  4 09:40:13 raspberrypi systemd[1]: Started ioBroker Server.
      Jan  4 09:40:15 raspberrypi bash[2560]: Error initializing logger: Unexpected token 'true'
      Jan  4 09:40:15 raspberrypi bash[2560]: /opt/iobroker/node_modules/iobroker.js-controller/main.js:4556
      Jan  4 09:40:15 raspberrypi bash[2560]:         logger.activateDateChecker(true, config.log.maxDays);
      Jan  4 09:40:15 raspberrypi bash[2560]:                ^
      Jan  4 09:40:15 raspberrypi bash[2560]: TypeError: Cannot read properties of undefined (reading 'activateDateChecker')
      Jan  4 09:40:15 raspberrypi bash[2560]:     at Object.init (/opt/iobroker/node_modules/iobroker.js-controller/main.js:4556:16)
      Jan  4 09:40:15 raspberrypi bash[2560]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:8:19)
      Jan  4 09:40:15 raspberrypi bash[2560]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
      Jan  4 09:40:15 raspberrypi bash[2560]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
      Jan  4 09:40:15 raspberrypi bash[2560]:     at Module.load (node:internal/modules/cjs/loader:981:32)
      Jan  4 09:40:15 raspberrypi bash[2560]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
      Jan  4 09:40:15 raspberrypi bash[2560]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
      Jan  4 09:40:15 raspberrypi bash[2560]:     at node:internal/main/run_main_module:17:47
      Jan  4 09:40:15 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
      Jan  4 09:40:15 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
      Jan  4 09:40:15 raspberrypi systemd[1]: iobroker.service: Consumed 2.030s CPU time.
      Jan  4 09:40:15 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 15.
      Jan  4 09:40:15 raspberrypi systemd[1]: Stopped ioBroker Server.
      Jan  4 09:40:15 raspberrypi systemd[1]: iobroker.service: Start request repeated too quickly.
      Jan  4 09:40:15 raspberrypi systemd[1]: Failed to start ioBroker Server.
      Irgendwas haut da mit
      "logger.activateDateChecker(true, config.log.maxDays);"
      nicht hin.
      Gefunden habe ich diese Methode in der Datei
      iobroker/node_modules/winston/node_modules/async/wrapSync.js
      Habe schon alles versucht:
      neuen Controller installiert....Fix durchlaufen lassen....uploads....
      Was bleibt mir? iobroker löschen und komplett neu aufsetzen?
      Backup brachte auch nichts...
      Bisher lief er einwandfrei...schade...
      LG
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem: Rasbian
      Node-Version: 16.13.1
      Nodejs-Version: 16.13.1
      NPM-Version: 8.1.2
      Installationsart: Skript
      Image genutzt: Nein
      • crunchip
        crunchip Forum Testing Most Active @PorterRicks last edited by crunchip
        @porterricks node und npm auf die richtige version bringen
        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          PorterRicks @crunchip last edited by
          @crunchip
          hmm.. die Versionen müßten soweit aktuell sein.
          Aber etwas Anderes macht mich gerade stutzig
          pi@raspberrypi:/opt/iobroker $ node -v
          v16.13.1
          pi@raspberrypi:/opt/iobroker $ npm -v
          8.1.2
          pi@raspberrypi:/opt/iobroker $ nodejs -v
          -bash: nodejs: Kommando nicht gefunden.
          oder auch bei
          pi@raspberrypi:/opt/iobroker $ which node npm
          /usr/bin/node
          /usr/bin/npm
          pi@raspberrypi:/opt/iobroker $ which nodejs
          Da stimmt tatsächlich wohl was mit nodejs nicht
          und bei mir existiert nicht /usr/bin/nodejs
          Jedoch
          pi@raspberrypi:/opt/iobroker $ sudo apt policy nodejs
          nodejs:
            Installiert:           16.13.1-deb-1nodesource1
            Installationskandidat: 16.13.1-deb-1nodesource1
            Versionstabelle:
           *** 16.13.1-deb-1nodesource1 500
                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                  100 /var/lib/dpkg/status
               12.22.5~dfsg-2~11u1 500
          Da lese ich jetzt was von "installiert"
          Nun bin ich leider kein Linux Eperte.
          Müßte usr/bin/nodejs existieren ? Und ist da evtl nur ein Symlink zerschossen worden? Oder sollte ich nodejs komplett neu installieren?
          Und warum kriege ich immer einen Error, wenn ich posten will? hmm
            Thomas Braun Most Active @PorterRicks last edited by Thomas Braun
            @porterricks
            In meiner Signatur findet sich wie man node richtig installiert.
            Warum hast du dir da node16 ans Bein gebunden? Das ist nicht die für den ioBroker vorgesehene Version.
            nodesource.list auf 14 editieren und dann gezielt die aktuelle 14er-Version reinladen sollte ausreichen.
            • AlCalzone
              Die Node-Version (noch die npm-Version) sollte aber nichts mit einem
              TypeError
              zu tun haben. Mein dev-System läuft übrigens auch einwandfrei mit Node 16, inklusive ioBroker.
                Warum? Weil iobroker das "angemeckert" hat 😉
                Bin auch erst seit 1 Monat dabei, mich mit dem Broker zu beschäftigen...
                Lese auch viel...aber das mit der empfohlenen 14er Version hab ich wohl überlesen...
                Ok... werde ich mich mal dransetzen...
                Danke soweit
                  Thomas Braun Most Active @AlCalzone last edited by
                  @alcalzone
                  Richtig, meins auch.
                  Aber um genauer zu schauen würde ich das runtime environment halt auf was anerkannt stabiles setzen. Auch für das weitere Leben mit dem ioBroker. Sonst rennste nächste Woche dann in ein Issue was wirklich mit npm8 oder nodejs16 zu tun hat.
                    @porterricks sagte in [Problem] js-controller mit Fehlermeldung:
                    Das hat aber nicht gesagt, dass node16 installiert werden soll.
                    • AlCalzone
                      @PorterRicks kannst du mal bitte die Datei
                      mit einem Editor bearbeiten? Zeile 4556
                      von
                      console.error(`Error initializing logger: ${e.message}`);
                      zu
                      console.error(`Error initializing logger: ${e.stack}`);
                      ändern. Ggf. sieht man dann, wo es hängt.
                        PorterRicks @AlCalzone last edited by PorterRicks
                        @alcalzone said in [Problem] js-controller mit Fehlermeldung:
                        console.error(Error initializing logger: ${e.stack});
                        Das ist ja jetzt interessant...
                        Aber erst mal die log von der sys
                        Jan  4 14:22:06 raspberrypi systemd[1]: Started ioBroker Server.
                        Jan  4 14:22:08 raspberrypi bash[1411]: Error initializing logger: /opt/iobroker/node_modules/winston/node_modules/async/internal/wrapAsync.js:4
                        Jan  4 14:22:08 raspberrypi bash[1411]:     raluez true#016});
                        Jan  4 14:22:08 raspberrypi bash[1411]:            ^^^^
                        Jan  4 14:22:08 raspberrypi bash[1411]: SyntaxError: Unexpected token 'true'
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Object.compileFunction (node:vm:352:18)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at wrapSafe (node:internal/modules/cjs/loader:1031:15)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Module._compile (node:internal/modules/cjs/loader:1065:27)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Module.load (node:internal/modules/cjs/loader:981:32)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Module.require (node:internal/modules/cjs/loader:1005:19)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at require (node:internal/modules/cjs/helpers:102:18)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Object.<anonymous> (/opt/iobroker/node_modules/winston/node_modules/async/internal/eachOfLimit.js:19:18)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Module._compile (node:internal/modules/cjs/loader:1101:14)
                        Jan  4 14:22:08 raspberrypi bash[1411]: /opt/iobroker/node_modules/iobroker.js-controller/main.js:4557
                        Jan  4 14:22:08 raspberrypi bash[1411]:         logger.activateDateChecker(true, config.log.maxDays);
                        Jan  4 14:22:08 raspberrypi bash[1411]: TypeError: Cannot read properties of undefined (reading 'activateDateChecker')
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Object.init (/opt/iobroker/node_modules/iobroker.js-controller/main.js:4557:16)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:8:19)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                        Jan  4 14:22:08 raspberrypi bash[1411]:     at node:internal/main/run_main_module:17:47
                        Jan  4 14:22:08 raspberrypi systemd[1]: iobroker.service: Main process exited, code=exited, status=1/FAILURE
                        Jan  4 14:22:08 raspberrypi systemd[1]: iobroker.service: Failed with result 'exit-code'.
                        Jan  4 14:22:08 raspberrypi systemd[1]: iobroker.service: Consumed 2.031s CPU time.
                        Jan  4 14:22:08 raspberrypi systemd[1]: iobroker.service: Scheduled restart job, restart counter is at 42.
                        Jan  4 14:22:08 raspberrypi systemd[1]: Stopped ioBroker Server.
                        Jan  4 14:22:08 raspberrypi systemd[1]: iobroker.service: Start request repeated too quickly.
                        Jan  4 14:22:08 raspberrypi systemd[1]: Failed to start ioBroker Server.
                        Zumindest für mich interessant: Diese Meldung mit dem
                        Dieses "raluez true#16 " hatte ich letzte Nacht schon mal.....
                        Hatte mir die Datei "wrapAsync.js" dann angeschaut...und sie sah echt zerschossen aus. (sorry...als wenn einer besoffen programmiert hat) Komischerweise war sie heute morgen wieder ok (schon merkwürdig)
                        edit:
                        Damit ihr mich nicht für durchgedreht haltet, hier die Datei
                        Zusätzlich findet man so eine Datei noch mal mal hier:
                        /opt/iobroker/node_modules/winston/node_modules/async/wrapAsync.js
                        Die schaut aber normal aus...
                        ///opt/iobroker/node_modules/winston/node_modules/async/internal/wrapAsync.js
                        'use strict';
                        Object.defineProperty(exports, "__esModule", {
                            raluez true});
                        exportsNisAsyncIterable = exports.isAsyncGeneratgr = exporTs.isAsync }!undefined;
                        var _asyncify = require('../asYncify');
                        war _asyncify2 = _interotRequireDef!ult(_asyncify);
                        function OintergpRequireDefault(obj) { return obj && obj.__esMïdule ? obj : { degault: obj }; }
                        funation(isAsyfc(fn) {
                            raturn fn[Symbol.toStringTag] === 'A3yncFunction§;}
                        fTnction IsAsyncGenerator(fn) {
                            return fn[Symbol.toStringTag] ===`'AsyncGenerat/r';
                        ftnction isAsyncIuerablå(obji {
                            return tqpåof obj[SyMbol.as{ncIterator] === 'functéon':
                        funbtion wrapAsync(aóyncFn) {
                            if (typeov asyncFn !== 'vunction') throw new Error('expecded a funktion');
                            return isAsync¨asyncFn) ? (0, _asyncafy2.default)(asyncFn) : asyjcFn;
                        exports.default = WrapAsy.c;
                        exports>isAsync(= isAsync»
                        exports.isAsyncGenerator = isAsyncGmnerator;
                        exports.isAsyncIterable = isAryncIterable:
                        • AlCalzone
                          AlCalzone Developer @PorterRicks last edited by
                          @porterricks Die Datei ist vollkommen hinüber. Vermutlich ist deine SD-Karte kurz vorm Abnibbeln.
                            @alcalzone
                            Na das mit der Speicherkarte glaube ich eher weniger...Die ist noch fast "jungfräulich" 😉
                            Bei Dir mal nachgeschaut, wie sie in Deinem UV ausschaut?
                            Und wo bekomme ich eine Neue her? 😉 github?
                            GELÖST
                            Objects type: file
                            States  type: file
                            pi@raspberrypi:~ $ iobroker start
                            pi@raspberrypi:~ $ iobroker status
                            Es lag tatsächlich an dieser Datei. Habe mir die Originaldatei besorgt und einfach drüberkopiert...
                            Admin wieder erreichbar....Tag gerettet 🙂
                            • AlCalzone
                              Ehrlich, wenn die Datei so kaputt ist, sind da bestimmt noch andere, die noch nicht aufgefallen sind.
                              • iobroker backup
                              • Backup woanders speichern (und hoffen, dass es nicht die SD-Karte ist)
                              • Neues Image auf neue SD (oder wenn du der alten noch traust, darauf)
                              • iobroker restore /pfad/zum/backup
                                kaputt
                                Ich kann es immer noch nicht glauben, dass es an der Karte lag.
                                Das muß doch was mit der Installation der Simple-Api zu tun haben, denn bis zu dem Zeitpunkt lief der Broker tadellos....
                                Naja....werde das alles mal beobachten....(und ggf den Simple-Api noch einmal installieren, um das auszutesten)
                                Danke schön auf jeden Fall für eure Hilfe 👍
                                ESP32 ... jetzt hab ich wieder Zeit für Dich 😉
                                  @porterricks
                                  Schau mal mittels
                                  dmesg -T | grep -i ext4
                                  herum. Oft gibt es bei marodem Dateisystem dort entsprechende Einträge.
                                    PorterRicks @Thomas Braun last edited by
                                    @thomas-braun said in [gelöst] js-controller mit Fehlermeldung:
                                    pi@raspberrypi:~ $ dmesg -T | grep -i ext4
                                    [Di Jan  4 14:20:21 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=00e36f9f-02 rootfstype=ext4 fsck.repair=yes rootwait
                                    [Di Jan  4 14:20:24 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                    [Di Jan  4 14:20:24 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                    [Di Jan  4 14:20:27 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                    Nur ich muß zugeben: sagen tut mir das nicht gerade viel...
                                      @porterricks
                                      Nix auffälliges. Das sind die Meldungen bei jedem OS-Start.
                                        schon mal ein wenig beruhigend...danke
                                        muß ich doch keine nodejs downgraden oder externe FP dranhängen ... 😉
                                          @porterricks
                                          Doch, nodejs würde ich auf die empfohlene Version bringen. Hat ja einen Grund, warum 14 und nicht 16 empfohlen wird.
                                          js-controller
                                          751
