    4. [[GELÖST]] HM-REGA HM-RPC
      muckel last edited by
      Hallo IoBroker Spezialisten
      Ich habe seit heute seltsame Abstürze des IoBroker.
      Sagt euch dieses log etwas?
      Danach ist alles eingefrohren. kein zugriff per web oder SSH mehr möglich.
      am raspi 2 leuchtet nur die HDD LED permanent.
      danke im voraus
      lg.
      host.iobroker	2017-02-27 19:26:57.025	info	Restart adapter system.adapter.hm-rega.0 because enabled
      host.iobroker	2017-02-27 19:26:57.024	error	instance system.adapter.hm-rega.0 terminated with code 0 (OK)
      hm-rega.0	2017-02-27 19:26:56.960	info	terminating
      hm-rega.0	2017-02-27 19:26:56.929	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:322:16)
      hm-rega.0	2017-02-27 19:26:56.929	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:246:12)
      hm-rega.0	2017-02-27 19:26:56.929	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      hm-rega.0	2017-02-27 19:26:56.929	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      hm-rega.0	2017-02-27 19:26:56.929	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
      hm-rega.0	2017-02-27 19:26:56.929	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      hm-rega.0	2017-02-27 19:26:56.929	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      hm-rega.0	2017-02-27 19:26:56.929	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
      hm-rega.0	2017-02-27 19:26:56.929	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
      hm-rega.0	2017-02-27 19:26:56.929	error	at Socket. (/opt/iobroker/node_modules/iobroker.hm-rega/hm-rega.js:1353:39)
      hm-rega.0	2017-02-27 19:26:56.929	error	TypeError: Cannot set property 'hm-rpc.0.info' of null
      hm-rega.0	2017-02-27 19:26:56.909	error	uncaught exception: Cannot set property 'hm-rpc.0.info' of null
      • apollon77
        apollon77 last edited by
        Einmalig oder mehrfach passiert? Läuft es wieder wenn Du alles neu startest?
          Hallo Apollon77!
          es passiert immer wieder; aber nur wenn ich meine Skripte laufen habe mit SayIt Ausgabe auf Sonos.
          Das Skript funktioniert aber. Manchmal hängt die Sprachausgabe.
          Dann frisst das System Speicher bis nur noch wenige MB übrig sind und dann hängt er sich auf.
          Diesen Speicherfresser-Prozess kann ich auch nicht mehr stoppen, wenn ich alle Adapter deaktiviere.
          RAM Verbraucht 384 / RAM Frei 520 Normal
          RAM Verbraucht 384 / RAM Frei 9 dann hängt er.
          2 Skripte gleich aufgebaut 1 x Trockner und 1 x Waschmaschine
          Mit Blockly gebaut:
          Hast eine Idee ??? :roll:
          var Intervall;
          on({id: 'hm-rega.0.1422', change: "any"}, function (obj) {
            var value = obj.state.val;
            if (getState("hm-rega.0.1422").val == true) {
              setState("sayit.0.tts.text", "de-DE_CLOUD_Female;70;" + 'Der Trockner ist eingeschaltet');
              console.log("sayIt[de-DE_CLOUD_Female][Volume - 70]: " + 'Der Trockner ist eingeschaltet');
            if (getState("hm-rega.0.1422").val == false) {
              Intervall = setInterval(function () {
                while (!(getState("hm-rpc.0.0001D3C996146A.6.CURRENT").val == 0)) {
                  setState("sayit.0.tts.text", "de-DE_CLOUD_Female;70;" + 'Der Trockner ist fertig');
                  console.log("sayIt[de-DE_CLOUD_Female][Volume - 70]: " + 'Der Trockner ist fertig');
              }, 600000);
          • apollon77
            Dann update hm-rega mal vom Github… dann ggf hm-rega neu starten und dann sag mal obs noch passiert
              Hallo Apollon77
              seit 1.4.4 stürzt er nicht mehr ab! 😄
              Thank You!
              • apollon77
                super, schreibst Du bitte noch ein "gelöst" in den Thread titel?! Danke
                Kommt dann offiziell ins npm
                81.0k
