    4. Problem mit automatischem testen in Github
    • OliverIO
      OliverIO last edited by
      Bei einem heutigen Commit/Push nach Github lief die test and release action los und brach in allen versionen mit dem folgenden Fehler ab
      Ausschnit ab ca Zeile 440
      > ursa-optional@0.9.10 install /tmp/test-iobroker.tvprogram/node_modules/ursa-optional
      > node rebuild.js
      ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
      > iobroker.js-controller@4.0.0-alpha.42-20220108-6954bae6 install /tmp/test-iobroker.tvprogram/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      undefined
      undefined
      undefined
                                         !             H|H|H|H|H           H__________________________________             H|§|§|§|H           H|* * * * * *|---------------------|             H|§|∞|§|H           H| * * * * * |---------------------|             H|§|§|§|H           H|* * * * * *|---------------------|             H|H|H|H|H           H| * * * * * |---------------------|             H|H|H|H|H           H|---------------------------------|          ===============        H|---------------------------------|            /| _   _ |          H|---------------------------------|            (| O   O |)          H|---------------------------------|            /|   U   |          H-----------------------------------             |  =/  |           H              _..._/            H              _|I/|_            H      _______/| H |/_______    H     /           / /          H    |          | | /         |  H    |          ||o||          |  H    |    |     ||o||     |    |  H    |    |     ||o||     |    |  H   Carl Pilcher
      .......ganz viele Unicode Zeichen, die aber hier im Forum ganz blöd angezeigt werden.....
      danach ganz viele Unicode-Zeichen, dann ab ca Zeile 600
      FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
      .......diverse Unicode zeichen, die aber hier im Forum ganz blöd angezeigt werden.....
      <--- Last few GCs --->
      [2100:0x2f58f20]    59810 ms: Scavenge 2031.5 (2044.0) -> 2029.0 (2045.2) MB, 21.0 / 0.0 ms  (average mu = 0.079, current mu = 0.018) allocation failure
       1: 0xa1a5d0 node::Abort() [node]
      [2100:0x2f58f20]    59840 ms: Scavenge 2032.9 (2045.2) -> 2031.1 (2063.7) MB, 19.0 / 0.0 ms  (average mu = 0.079, current mu = 0.018) allocation failure
      <--- JS stacktrace --->
      ==== JS stack trace =========================================
          0: ExitFrame [pc: 0x140db59]
       2: 0xa1a9dc node::OnFatalError(char const*, char const*) [node]
      Security context: 0x312f6f0008d1 <JSObject>
          1: /* anonymous */ [0x2033b71fffa9] [/tmp/test-iobroker.tvprogram/node_modules/colors/safe.js:~1] [pc=0x143a765a6594](this=0x053e8407fd41 <Object map = 0x3de3aa6c0439>,0x053e8407fd41 <Object map = 0x3de3aa6c0439>,0x053e8407fd01 <JSFunction require (sfi = 0x3091842ed291)>,0x053e8407fca9 <Module map = 0x2e6b548829b9>,0x2033b71fabe1 <String[#56]: /tmp/test-iobro...
       3: 0xb9a55e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node]
       4: 0xb9a8d9 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node]
       5: 0xd57b55  [node]
       6: 0xd581e6 v8::internal::Heap::RecomputeLimits(v8::internal::GarbageCollector) [node]
       7: 0xd64aa5 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [node]
       8: 0xd65955 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node]
       9: 0xd66fff v8::internal::Heap::HandleGCRequest() [node]
      10: 0xd15a65 v8::internal::StackGuard::HandleInterrupts() [node]
      11: 0x10710a6 v8::internal::Runtime_StackGuard(int, unsigned long*, v8::internal::Isolate*) [node]
      12: 0x140db59  [node]
      Error: The operation was canceled.
      Wenn mehr Informationen benötigt werden, dann gerne.
      Das Ergebnis habe ich bei 2 repos gesehen, bei anderen Repos habe ich diese Actions noch nicht eingerichtet.
      Gestern lief die Action noch ohne Fehler
      AlCalzone apollon77 2 Replies Last reply Reply Quote 0
      • AlCalzone
        AlCalzone Developer @OliverIO last edited by
        @oliverio Habs mal weitergegeben
        • OliverIO
          OliverIO @AlCalzone last edited by
          @alcalzone
          danke, habe gerade gesehen @foxriver76 hat da commited
          foxriver76 1 Reply Last reply Reply Quote 0
          • apollon77
            apollon77 @OliverIO last edited by
            @oliverio Link?? Also ich wüste nichts was wir geändert haben was das verursachen könnte
            • OliverIO
              OliverIO @apollon77 last edited by OliverIO
              @apollon77
              die letzte version die korrekt lief, war, bevor das log-chaos ausbrach war
              > iobroker.js-controller@4.0.0-alpha.41-20220107-d0505f94 install /tmp/test-iobroker.tvprogram/node_modules/iobroker.js-controller
              bei der action mit fehler wurde an der gleichen Stelle das folgende aufgerufen.
              danach steht im action log, das was ich oben schon gepostet habe
              > iobroker.js-controller@4.0.0-alpha.42-20220108-6954bae6 install /private/var/folders/24/8k48jl6d249_n_qfxwsl6xvm0000gn/T/test-iobroker.tvprogram/node_modules/iobroker.js-controller
              dann müsste es die letzten 3 commits umfassen.
              da dort, wie ich sehe wieder auf tags in anderen packages verwiesen wird, kann natürlich auch da der fehler liegen.
              https://github.com/ioBroker/ioBroker.js-controller/commits/master
              evtl war auch die letzte korrekt laufende action bei mir schon vor 2 tagen gewesen.
              hier der link zum fehlerhaften action-protokoll
              https://github.com/oweitman/ioBroker.tvprogram/runs/4755064733?check_suite_focus=true
              und hier das was noch gut lief
              https://github.com/oweitman/ioBroker.tvprogram/runs/4744650059?check_suite_focus=true
              • apollon77
                WTF 🙂
                Also bei mir laufen tests durch ... auch mit der .42 ... bei mehreren Adaptern. haben jetzt einen zweiten Report im Telegram wo es scheinbar bei einer clean Neuinstallation (damit controller 3.3.22) passiert ... also mit der Info kann es an sich nur irgendein Dep Package sein was ein update bekommen hat und jetzt gezogen wird. Aber warum es manchmal knallt ist ne gute frage
                Ok weiter gesucht ... Google ist super
                https://github.com/aws/aws-cdk/issues/18329
                Scheinbar ist color.js kaputt
                blimmer created this issue in aws/aws-cdk
                closed (cli): replace colors.js with chalk #18329
                • apollon77
                  Update: https://github.com/Marak/colors.js/issues/289 ... Müssen nachdenken
                  Und ja meine tests gehen auch nimmer
                  die "colors" 1.4.0 tut ... 1.4.1 und 1.4.2 is broken
                  dhilt created this issue in Marak/colors.js
                  closed v1.4.2 is broken #289
                  • apollon77
                    Ok habe als schnelle reaktion mal https://github.com/flatiron/prompt/issues/220 angelegt was zumindestens bei mir die herkunft von colors ist. winston hat für winston und logform vor 1h schon eine neue Version released und es auf die 1.4.0 gepinnt. Das waren die anderen zwei "herkünfte"
                    Apollon77 created this issue in flatiron/prompt
                    closed URGENT!!!! colos 1.4.x is broken! YOur dependency will get this version! #220
                      Thomas Braun Most Active @apollon77 last edited by Thomas Braun
                      Und genau deswegen angelt man ja auch keinen Code aus GitHub sondern bleibt bei den Default oder Beta-Repos. Aus GitHub / 'über die Katze' nur wenn der Entwickler euch dazu auffordert das zu tun!
                      Oh...
                      ☺️ Sorry, ich konnte nicht widerstehen... 😀
                      apollon77 foxriver76 2 Replies Last reply Reply Quote 0
                      • foxriver76
                        foxriver76 Developer @OliverIO last edited by
                        @oliverio sagte in Problem mit automatischem testen in Github:
                        @alcalzone
                        Der hat keinen Einfluss darauf so viele Pakete zu zerstören.
                        • apollon77
                          apollon77 @Thomas Braun last edited by
                          @thomas-braun Er ist der Entwickler :-))) Ggf sollte man das Posting eher ins Entwickler forum schieben 🙂
                          @OliverIO restart testing ... bei mir geht es wieder ... scheinbar hat es gereicht das winstom die Pakete pinnt ... mal weiter schauen
                          • foxriver76
                            foxriver76 Developer @Thomas Braun last edited by
                            @thomas-braun allgemein ja, leider tut das auch normale Installationen betreffen und war mehr oder minder böswillige Absicht.
                            Neue Minor Version einer Dep die sehr viele Projekte nutzen mit einer infinity loop bestückt. 😉
                            apollon77 sigi234 2 Replies Last reply Reply Quote 0
                            • apollon77
                              apollon77 @foxriver76 last edited by
                              @foxriver76 sagte in Problem mit automatischem testen in Github:
                              sogar nur neue patch Version
                              • apollon77
                                apollon77 last edited by apollon77
                                Ok, aktueller Stand ist das ioBroker wieder installiert. Pot betroffen sind noch zwei CLI Funktionen: setup multihost und setup User via CLI. Das braucht noch https://github.com/flatiron/prompt/pull/219
                                micalevisk created this issue in flatiron/prompt
                                closed fix: pin the version of `colors` dependency #219
                                • OliverIO
                                  @apollon77
                                  Interessanter Artikel zum aktuellen problem.
                                  Bin ja mal gespannt was da noch rauskommt
                                  https://www.theverge.com/2022/1/9/22874949/developer-corrupts-open-source-libraries-projects-affected
                                    Thomas Braun Most Active @OliverIO last edited by
                                    @oliverio
                                    Dann muss der ioBroker auch kostenpflichtig werden? Sonst werden wilde Dinge mit der Heizung und der Beleuchtung angestellt? 😄
                                    • apollon77
                                      @thomas-braun Nicht so hilfreich 😉 Ich glaube eine Endlosschleife ist kein Angriffsszenario ... es ist "nur ne Denial of Service"
                                      H OliverIO 2 Replies Last reply Reply Quote 0
                                        Hansi1234 @apollon77 last edited by
                                        @apollon77 golem hat auch etwas dazu geschrieben link
                                        • sigi234
                                          sigi234 Forum Testing Most Active @foxriver76 last edited by
                                          Warum macht das ein Entwickler?😞
                                          • OliverIO
                                            @apollon77
                                            Ich glaube das geht noch etwas weiter als: da hat der Entwickler einen Fehler gemacht.
                                            Was ich rausgelesen habe ist, der Entwickler selber hat keinen Zugriff mehr auf githubNPM, von daher ist nicht ganz klar, ob er das selber committed hat oder jemand anderes.
                                            Darüber hinaus ist auch noch ein weiteres Repository (faker.js) betroffen, das eine ähnliche Reichweite hat.
                                            1305
