    4. Meldung: "ADAPTER_ALREADY_RUNNING" nach Neustart
    • surfer09
      surfer09 last edited by
      mir ist vor Kurzem aufgefallen, das nach einem Systemneustart immer diese Meldung ("ADAPTER_ALREADY_RUNNING") bei fast allen Adaptern auftaucht:
      Hier mal ein kurzer Auszug aus dem LOG:
      2022-01-15 08:36:58.697 - info: host.IO-Broker-Server instance system.adapter.info.0 started with pid 11744
      2022-01-15 08:36:59.776 - error: info.0 (11744) info.0 already running
      2022-01-15 08:36:59.777 - warn: info.0 (11744) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-01-15 08:37:00.314 - error: host.IO-Broker-Server instance system.adapter.info.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-01-15 08:37:00.314 - info: host.IO-Broker-Server Restart adapter system.adapter.info.0 because enabled
      2022-01-15 08:37:01.798 - info: host.IO-Broker-Server instance system.adapter.hm-rpc.1 started with pid 2232
      2022-01-15 08:37:02.514 - info: hm-rpc.1 (2232) starting. Version 1.15.0 in I:/iobroker/node_modules/iobroker.hm-rpc, node: v14.18.1, js-controller: 3.3.22
      2022-01-15 08:37:02.568 - info: hm-rpc.1 (2232) xmlrpc server is trying to listen on 0.0.0.0:2010
      2022-01-15 08:37:02.568 - info: hm-rpc.1 (2232) xmlrpc client is trying to connect to 192.168.1.100:2010/ with ["http://192.168.1.14:2010","IO-Broker-Server:hm-rpc.1"]
      2022-01-15 08:37:02.603 - info: hm-rpc.1 (2232) Connected
      2022-01-15 08:37:02.638 - info: hm-rpc.1 (2232) xmlrpc <- listDevices ["IO-Broker-Server:hm-rpc.1"]
      2022-01-15 08:37:02.679 - info: hm-rpc.1 (2232) xmlrpc -> 0 devices
      2022-01-15 08:37:02.689 - info: host.IO-Broker-Server instance system.adapter.hs100.0 started with pid 11964
      2022-01-15 08:37:02.993 - info: hm-rpc.1 (2232) xmlrpc <- newDevices 264
      2022-01-15 08:37:03.029 - info: hm-rpc.1 (2232) new HMIP devices/channels after filter: 0
      2022-01-15 08:37:03.202 - error: hs100.0 (11964) hs100.0 already running
      2022-01-15 08:37:03.203 - warn: hs100.0 (11964) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-01-15 08:37:03.758 - error: host.IO-Broker-Server instance system.adapter.hs100.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-01-15 08:37:03.758 - info: host.IO-Broker-Server Restart adapter system.adapter.hs100.0 because enabled
      2022-01-15 08:37:05.984 - info: host.IO-Broker-Server instance system.adapter.ping.0 started with pid 3520
      2022-01-15 08:37:06.674 - info: ping.0 (3520) starting. Version 1.5.0 in I:/iobroker/node_modules/iobroker.ping, node: v14.18.1, js-controller: 3.3.22
      2022-01-15 08:37:06.685 - info: host.IO-Broker-Server instance system.adapter.simple-api.0 started with pid 4368
      2022-01-15 08:37:07.136 - error: simple-api.0 (4368) simple-api.0 already running
      2022-01-15 08:37:07.137 - warn: simple-api.0 (4368) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-01-15 08:37:07.689 - error: host.IO-Broker-Server instance system.adapter.simple-api.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-01-15 08:37:07.689 - info: host.IO-Broker-Server Restart adapter system.adapter.simple-api.0 because enabled
      2022-01-15 08:37:08.710 - info: host.IO-Broker-Server instance system.adapter.simple-api.0 started with pid 11468
      2022-01-15 08:37:09.378 - info: simple-api.0 (11468) starting. Version 2.6.2 in I:/iobroker/node_modules/iobroker.simple-api, node: v14.18.1, js-controller: 3.3.22
      2022-01-15 08:37:09.429 - info: simple-api.0 (11468) simpleAPI server listening on port 8087
      2022-01-15 08:37:09.429 - info: simple-api.0 (11468) Allow states only when user is owner: false
      2022-01-15 08:37:09.430 - info: simple-api.0 (11468) http server listening on port 8087
      2022-01-15 08:37:10.702 - info: host.IO-Broker-Server instance system.adapter.deconz.0 started with pid 3008
      2022-01-15 08:37:11.185 - error: deconz.0 (3008) deconz.0 already running
      2022-01-15 08:37:11.743 - error: host.IO-Broker-Server instance system.adapter.deconz.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-01-15 08:37:11.743 - info: host.IO-Broker-Server Restart adapter system.adapter.deconz.0 because enabled
      2022-01-15 08:37:14.280 - info: host.IO-Broker-Server instance system.adapter.mihome-vacuum.0 started with pid 11200
      2022-01-15 08:37:14.700 - info: host.IO-Broker-Server instance system.adapter.squeezeboxrpc.0 started with pid 3620
      2022-01-15 08:37:15.418 - error: squeezeboxrpc.0 (3620) squeezeboxrpc.0 already running
      2022-01-15 08:37:15.419 - warn: squeezeboxrpc.0 (3620) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-01-15 08:37:15.972 - error: host.IO-Broker-Server instance system.adapter.squeezeboxrpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-01-15 08:37:15.972 - info: host.IO-Broker-Server Restart adapter system.adapter.squeezeboxrpc.0 because enabled
      2022-01-15 08:37:18.699 - info: host.IO-Broker-Server instance system.adapter.upnp.0 started with pid 4160
      2022-01-15 08:37:19.334 - error: upnp.0 (4160) upnp.0 already running
      2022-01-15 08:37:19.335 - warn: upnp.0 (4160) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-01-15 08:37:19.983 - error: host.IO-Broker-Server instance system.adapter.upnp.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-01-15 08:37:19.983 - info: host.IO-Broker-Server Restart adapter system.adapter.upnp.0 because enabled
      2022-01-15 08:37:21.798 - info: host.IO-Broker-Server instance system.adapter.web.0 started with pid 10204
      2022-01-15 08:37:22.527 - info: web.0 (10204) starting. Version 3.4.16 in I:/iobroker/node_modules/iobroker.web, node: v14.18.1, js-controller: 3.3.22
      2022-01-15 08:37:22.655 - info: web.0 (10204) socket.io server listening on port 8082
      2022-01-15 08:37:22.657 - info: web.0 (10204) http server listening on port 8082
      2022-01-15 08:37:22.667 - info: host.IO-Broker-Server instance system.adapter.yahka.0 started with pid 11636
      2022-01-15 08:37:23.390 - error: yahka.0 (11636) yahka.0 already running
      2022-01-15 08:37:23.391 - warn: yahka.0 (11636) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-01-15 08:37:23.942 - error: host.IO-Broker-Server instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-01-15 08:37:23.943 - info: host.IO-Broker-Server Restart adapter system.adapter.yahka.0 because enabled
      2022-01-15 08:37:26.683 - info: host.IO-Broker-Server instance system.adapter.yahka.2 started with pid 9348
      2022-01-15 08:37:27.282 - error: yahka.2 (9348) yahka.2 already running
      2022-01-15 08:37:27.282 - warn: yahka.2 (9348) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-01-15 08:37:27.826 - error: host.IO-Broker-Server instance system.adapter.yahka.2 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-01-15 08:37:27.826 - info: host.IO-Broker-Server Restart adapter system.adapter.yahka.2 because enabled
      2022-01-15 08:37:30.342 - info: host.IO-Broker-Server instance system.adapter.info.0 started with pid 7240
      2022-01-15 08:37:30.695 - info: host.IO-Broker-Server instance scheduled system.adapter.coronavirus-statistics.0 30 6 * * *
      2022-01-15 08:37:30.698 - info: host.IO-Broker-Server instance system.adapter.coronavirus-statistics.0 started with pid 12212
      2022-01-15 08:37:31.494 - info: coronavirus-statistics.0 (12212) starting. Version 0.8.7 in I:/iobroker/node_modules/iobroker.coronavirus-statistics, node: v14.18.1, js-controller: 3.3.22
      2022-01-15 08:37:33.769 - info: host.IO-Broker-Server instance system.adapter.hs100.0 started with pid 12192
      2022-01-15 08:37:34.533 - info: sql.0 (11496) enabled logging of hs100.0.192_168_1_188.power, Alias=false
      2022-01-15 08:37:34.677 - info: host.IO-Broker-Server instance system.adapter.fritzbox.0 started with pid 9404
      Ich habe mir zuerst nichts dabei gedacht, wollte jedoch mal einmal nachfragen, ob das so okay ist. Das System an sich macht so keine Probleme - nur halt nach dem Neustart erscheinen immer wieder diese Hinweise im LOG.
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: 12GB
      Festplattenart: SSD
      Betriebssystem: Windows 10
      Nodejs-Version: 14.18.1
      NPM-Version: 6.14.15
      Installationsart: Manuell
        Homoran Global Moderator Administrators @surfer09 last edited by Homoran
        @surfer09 sagte in Meldung: "ADAPTER_ALREADY_RUNNING" nach Neustart:
        • was ist ein "Systemstart"?
          • wie führst du den aus?
        • wirklich immer?
          • das deutet darauf hin, dass bei dem Systemstart" iobroker nicht beendet wird
          • oder dein ioB startet doppelt????
        • surfer09
          surfer09 @Homoran last edited by
          @homoran: Mit Systemneustart meine ich einen kompletten Neustart vom Windows und somit logischerweise auch vom IOBroker.
          Wo kann ich denn nachsehen, ob der IOBroker doppelt startet? Wenn ich den Windows Dienst stoppe, dann komme ich auch nicht mehr auf die Weboberfläche, somit gehe ich davon aus, dass dort nicht noch eine 2. Geschichte irgendwo im Hintergrund läuft. "iobroker status" liefert dann auch die Info, dass er nicht mehr läuft.
            vom Windows
            da kann ich nichts zu beitragen - Sorry
            already running log-eintrag windows 10
