    2. English
    3. Scripting / Logic
    5. Enable DOM objects for javascript and typescript [gelöst]
    • E
      Ethernet-Fellow last edited by Ethernet-Fellow
      The simple type- and javascript statement
      document.getElementById('xxx')
      returns a syntax error: 'document' unknown.
      On Google I found that the DOM objects are not enabled by default in typescript.
      To enable it the typescript configuration file 'tsconfig.json' file must contain the line
      "lib": ["DOM", "ES2017"],
      to enable the DOM objects for typescript (and also for javascript).
      I inserted that line in /opt/iobroker/node_modules/@iobroker/plugin-base/tsconfig.json
      without success. On my Raspi there are about 20 more such file.
      So my question, does anyone know how to enable the DOM objects for type- and javascript in iobroker.
      Thanks a lot
      • Jey Cee
        That doesn't make sense.
        DOM objects are only available on web pages, ioBroker is complete server side based and uses nodejs.
        So it useless there.
        If you wan't this feature anyway you have to include a third party module.
        • E
          Thanks Jey Cee,
          I didn't find an editable table. So I tried to implement it by Typescript.
          • liv-in-sky
            liv-in-sky @Ethernet-Fellow last edited by
            @ethernet-fellow the DOM elements are only available in the vis.
            to use it you have to write scripts in the vis editor or in the e.g. html standard widget
            do I misunderstand your question ?
            what you want to do
            • E
              Hi liv-in-sky,
              I tried to make a table in VIS using HTML and typescript, but the typescript does not know DOM elements.
              • liv-in-sky
                @ethernet-fellow I only use javascript - it is working
                example: a script which builds the html und jquery - in the vis you have to use the binding for the datapoint
                https://forum.iobroker.net/topic/51217/html-tabelle-für-zigbee-devices-vis-übersicht
                or this exampleis in the script-tab in the vis-editor:
                https://forum.iobroker.net/topic/48663/howto-skripte-im-vis-editor-mit-jquery
                • E
                  Thanks a lot liv-in-sky,
                  that's what I missed.
                  liv-in-sky 1 Reply Last reply Reply Quote 1
                  • liv-in-sky
                    @ethernet-fellow
                    you're welcome
                    by the way - for example : fast tables for vis:
                    https://forum.iobroker.net/topic/48130/howto-schnell-erstellte-html-tabelle-für-vis
                    javascript
