    4. HMIP-Adapter: Cannot read property 'home' of undefined
    • O
      oFbEQnpoLKKl6mbY5e13 last edited by oFbEQnpoLKKl6mbY5e13
      @apollon77
      Darf der Fehler kommen, wenn die Cloud mal wieder down ist, oder sollte das nicht passieren?
      2022-01-20 12:05:36.578  - warn: hmip.0 (256) ws connection closed (0) - code: 1006 - reason:
      2022-01-20 12:05:46.925  - warn: hmip.0 (256) ws connection error (0): Error: connect ECONNREFUSED 81.14.202.238:8888
      2022-01-20 12:05:46.926  - warn: hmip.0 (256) ws connection closed (1) - code: 1006 - reason:
      2022-01-20 12:05:58.688  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:05:58.705  - warn: hmip.0 (256) ws connection closed (2) - code: 1000 - reason:
      2022-01-20 12:06:10.395  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:06:10.401  - warn: hmip.0 (256) ws connection closed (3) - code: 1000 - reason:
      2022-01-20 12:06:22.026  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:06:22.033  - warn: hmip.0 (256) ws connection closed (4) - code: 1000 - reason:
      2022-01-20 12:06:33.891  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:06:33.936  - warn: hmip.0 (256) ws connection closed (5) - code: 1000 - reason:
      2022-01-20 12:06:45.717  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:06:45.762  - warn: hmip.0 (256) ws connection closed (6) - code: 1000 - reason:
      2022-01-20 12:06:57.369  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:06:57.386  - warn: hmip.0 (256) ws connection closed (7) - code: 1000 - reason:
      2022-01-20 12:07:09.068  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:07:09.078  - warn: hmip.0 (256) ws connection closed (8) - code: 1000 - reason:
      2022-01-20 12:07:20.752  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:07:20.758  - warn: hmip.0 (256) ws connection closed (9) - code: 1000 - reason:
      2022-01-20 12:07:32.467  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:07:32.487  - warn: hmip.0 (256) ws connection closed (10) - code: 1000 - reason:
      2022-01-20 12:07:43.933  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:07:43.943  - warn: hmip.0 (256) ws connection closed (11) - code: 1000 - reason:
      2022-01-20 12:07:44.233  - warn: hmip.0 (256) Request error: StatusCodeError: 418 - {"errorCode":"INVALID_REQUEST"}
      2022-01-20 12:07:45.439  - warn: hmip.0 (256) Request error: StatusCodeError: 403 - {"errorCode":"INVALID_AUTHORIZATION"}
      2022-01-20 12:07:45.510  - error: hmip.0 (256) error starting homematic: TypeError: Cannot read property 'home' of undefined
      2022-01-20 12:07:45.510  - error: hmip.0 (256) Try reconnect in 30s
      2022-01-20 12:07:45.512  - info: hmip.0 (256) hmip adapter connected and ready
      2022-01-20 12:08:29.186  - info: hmip.0 (256) ws connection opened
      2022-01-20 12:08:39.297  - info: hmip.0 (256) hmip adapter connected and ready
      v1.15.2
      • apollon77
        apollon77 @oFbEQnpoLKKl6mbY5e13 last edited by
        @ofbeqnpolkkl6mby5e13 Jupp hatte ich auch heute. Wird mit nächster Version gefixt sein
        • O
          oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by
          @apollon77
          Soll ich trotzdem ein issue aufmachen?
          • apollon77
            @ofbeqnpolkkl6mby5e13 Ne in dem Fall mal ausnahmsweise nicht 🙂
            O 1 Reply Last reply Reply Quote 1
            • O
              oFbEQnpoLKKl6mbY5e13 @apollon77 last edited by oFbEQnpoLKKl6mbY5e13
              @apollon77
              Du scheinst ja zumindest auch einen Access Point laufen zu haben. Hattest du auch Reconnects gestern gegen 13:50 Uhr?
              2022-04-07 13:38:19.983  - info: hmip.0 (363) ws connection opened
              2022-04-07 13:38:20.017  - warn: hmip.0 (363) ws connection closed (2) - code: 1000 - reason:
              2022-04-07 13:38:32.498  - info: hmip.0 (363) ws connection opened
              2022-04-07 13:38:32.502  - warn: hmip.0 (363) ws connection closed (3) - code: 1000 - reason:
              2022-04-07 13:38:46.340  - info: hmip.0 (363) ws connection opened
              2022-04-07 13:38:46.345  - warn: hmip.0 (363) ws connection closed (4) - code: 1000 - reason:
              2022-04-07 13:38:59.756  - info: hmip.0 (363) ws connection opened
              2022-04-07 13:38:59.766  - warn: hmip.0 (363) ws connection closed (5) - code: 1000 - reason:
              2022-04-07 13:39:11.669  - info: hmip.0 (363) ws connection opened
              2022-04-07 13:39:11.676  - warn: hmip.0 (363) ws connection closed (6) - code: 1000 - reason:
              2022-04-07 13:39:23.598  - info: hmip.0 (363) ws connection opened
              2022-04-07 13:39:23.604  - warn: hmip.0 (363) ws connection closed (7) - code: 1000 - reason:
              2022-04-07 13:39:24.343  - warn: hmip.0 (363) Request error: StatusCodeError: 418 - {"errorCode":"INVALID_REQUEST"}
              2022-04-07 13:39:24.724  - warn: hmip.0 (363) Request error: StatusCodeError: 403 - {"errorCode":"INVALID_AUTHORIZATION"}
              2022-04-07 13:39:24.725  - error: hmip.0 (363) error starting homematic: Error: No current State received
              2022-04-07 13:39:24.725  - error: hmip.0 (363) Try reconnect in 30s
              2022-04-07 13:39:24.747  - info: hmip.0 (363) hmip adapter connected and ready
              2022-04-07 13:40:03.740  - info: hmip.0 (363) ws connection opened
              2022-04-07 13:40:07.108  - info: hmip.0 (363) hmip adapter connected and ready
              2022-04-07 13:42:03.592  - warn: hmip.0 (363) State "hmip.0.devices.3014F711****.channels.3.functionalChannelType" has no existing object, this might lead to an error in future versions
              2022-04-07 13:42:03.593  - warn: hmip.0 (363) State "hmip.0.devices.3014F711****.channels.4.functionalChannelType" has no existing object, this might lead to an error in future versions
              2022-04-07 13:42:03.593  - warn: hmip.0 (363) State "hmip.0.devices.3014F711****.channels.5.functionalChannelType" has no existing object, this might lead to an error in future versions
              2022-04-07 13:42:03.627  - info: hmip.0 (363) New devices or channels detected ... reinitialize in 5s... 3014F711****
              2022-04-07 13:42:03.704  - warn: hmip.0 (363) ws connection closed (7) - code: 1005 - reason:
              2022-04-07 13:42:14.601  - info: hmip.0 (363) ws connection opened
              2022-04-07 13:42:17.830  - info: hmip.0 (363) ws connection opened
              2022-04-07 13:42:17.837  - warn: hmip.0 (363) ws connection closed (8) - code: 1000 - reason:
              2022-04-07 13:42:17.954  - warn: hmip.0 (363) ws connection closed (9) - code: 1005 - reason:
              2022-04-07 13:42:29.299  - info: hmip.0 (363) hmip adapter connected and ready
              2022-04-07 14:13:05.206  - warn: hmip.0 (363) Request error: StatusCodeError: 429 - undefined
              2022-04-07 14:13:05.207  - error: hmip.0 (363) error starting homematic: Error: No current State received
              2022-04-07 14:13:05.207  - error: hmip.0 (363) Try reconnect in 30s
              2022-04-07 14:13:05.209  - info: hmip.0 (363) hmip adapter connected and ready
              2022-04-07 14:13:15.043  - info: hmip.0 (363) hmip adapter connected and ready
              2022-04-07 14:13:15.064  - info: hmip.0 (363) hmip adapter connected and ready
              2022-04-07 14:13:15.514  - info: hmip.0 (363) ws connection opened
              2022-04-07 14:13:18.693  - info: hmip.0 (363) hmip adapter connected and ready
              2022-04-07 14:13:35.513  - warn: hmip.0 (363) Request error: StatusCodeError: 429 - undefined
              2022-04-07 14:13:35.514  - error: hmip.0 (363) error starting homematic: Error: No current State received
              Das ging so, bis ich das gegen 14:50 Uhr bemerkte. Ich habe dann die Instanz etwa 10 Minuten gestoppt. Danach war die Verbindung wieder möglich. EQ-3 hatte mich wegen dieser Geschichte gedrosselt. Die haben übrigens dazugelernt. Statt komplett zu blocken wird man gedrosselt und in der App wird dies sogar angezeigt. Sogar, dass es um REST geht.
              Anzumerken ist hier auch, dass der Adapter meint, dass ein bestehender Fußbodenheizungsaktor als neu zu erkennen ist.
              • apollon77
                Also ja, ich hatte auch einen Reconnect, aber - weiss ja nicht welche Version Du einsetzt, die aktuellsten Versionen des Adapter haben das sehr optimiert.
                • O
                  @apollon77
                  v1.15.5
                  • apollon77
                    @ofbeqnpolkkl6mby5e13 Bist Du dir da gaaaanz sicher???
                    Bitte github issue mit vollständigem Log
                    • O
                      @apollon77
                      Ja.
                      https://github.com/iobroker-community-adapters/ioBroker.hmip/issues/368
                      RP70DP created this issue in iobroker-community-adapters/ioBroker.hmip
                      closed Reconnection issue #368
