    4. JeeLink flashen?
    JeeLink flashen?
      Marcolotti last edited by
      habe heute meinen JeeLink 868 erhalten. Muss man den vorher noch flashen? Irgendwas hab ich mit F H E M gelesen.
      Im Log steht seit 5 Stunden:
      jeelink.0	2017-03-03 17:20:11.100	info	data received: A i1 g210 @ 868 MHz q1
      jeelink.0	2017-03-03 17:20:11.097	info	data received: Current configuration:
      jeelink.0	2017-03-03 17:20:11.090	info	data received: 123z - total power down, needs a reset to start up again
      jeelink.0	2017-03-03 17:20:11.079	info	data received: - 1: hex, 3: hex+ascii)
      jeelink.0	2017-03-03 17:20:11.073	info	data received: x - set reporting format (0: decimal, 2: decimal+ascii
      jeelink.0	2017-03-03 17:20:11.063	info	data received: q - set quiet mode (1 = don't report bad packets)
      jeelink.0	2017-03-03 17:20:11.052	info	data received: sent with its next ack. Group number becomes sticky
      jeelink.0	2017-03-03 17:20:11.040	info	data received: ,,p post semaphore for node , group to be
      jeelink.0	2017-03-03 17:20:11.029	info	data received: ...,m - add message string to ram, see p command
      jeelink.0	2017-03-03 17:20:11.019	info	data received: l - turn activity LED on PB1 on or off
      jeelink.0	2017-03-03 17:20:11.011	info	data received: n - set group as sticky. Group 0 only, see p command
      jeelink.0	2017-03-03 17:20:11.000	info	data received: ,n - remove group/node index number entry from eeprom
      jeelink.0	2017-03-03 17:20:10.988	info	data received: ... - Space character is a valid delimiter
      jeelink.0	2017-03-03 17:20:10.979	info	data received: ...,s - send data packet to node , no ack
      jeelink.0	2017-03-03 17:20:10.971	info	data received: if using group 0 then sticky group number is used
      jeelink.0	2017-03-03 17:20:10.961	info	data received: ...,a - send data packet to node , request ack
      jeelink.0	2017-03-03 17:20:10.949	info	data received: t - broadcast max-size test packet, request ack
      jeelink.0	2017-03-03 17:20:10.939	info	data received: c - set collect mode (advanced, normally 0)
      jeelink.0	2017-03-03 17:20:10.930	info	data received: g - set network group (RFM12 only allows 212, 0 = any)
      jeelink.0	2017-03-03 17:20:10.919	info	data received: 96..3903 is the range supported by the RFM12B
      jeelink.0	2017-03-03 17:20:10.913	info	data received: o - change frequency offset within the band (default 1600)
      jeelink.0	2017-03-03 17:20:10.908	info	data received: b - set MHz band (4 = 433, 8 = 868, 9 = 915)
      jeelink.0	2017-03-03 17:20:10.894	info	data received: i - set node ID (standard node ids are 1..30)
      jeelink.0	2017-03-03 17:20:10.894	info	data received: Available commands:
      jeelink.0	2017-03-03 17:20:10.892	info	data received:
      jeelink.0	2017-03-03 17:20:10.874	info	data received: [RF12demo.13] A i1 g210 @ 868 MHz q1
      jeelink.0	2017-03-03 17:20:10.858	info	data received:
      jeelink.0	2017-03-03 17:20:09.321	info	open
      jeelink.0	2017-03-03 17:20:09.282	info	RFM12B setting up object = LaCrosse 2
      jeelink.0	2017-03-03 17:20:09.280	info	RFM12B setting up object = emonTH1
      jeelink.0	2017-03-03 17:20:09.270	info	entered ready
      jeelink.0	2017-03-03 17:20:09.253	info	starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.jeelink, node: v6.10.0
      Gruß Marco
        photographix last edited by
        Hallo Marcolotti,
        ja du musst den Jeelink vorher mit einer Software betanken. Aktuell ist nur ein Demo Sketch drauf. Wenn du Technoline DTH Sensoren abfragen willst musst du im Netz mal nach Lacrosse Sketch suchen. Im Homematic Forum gibt es auch Links zum Download (Link gerade nicht zur Hand). Je nach System brauchst du dann noch eine Software zum flashen des Jeelinks. Ich habe für den Mac die IDE für Arduino im Einsatz. Damit geht dies problemlos.
          simpixo last edited by
          Also ich habe meine von hier
          https://sourceforge.net/p/fhem/code/HEA … Reader.zip
          Einfach das ZIP Downloaden/ entpacken und auf den Jeelink draufpacken
          Adrian
          Gesendet von iPhone mit Tapatalk Pro
