    4. Update / Upgrade Fehler
      firstfreak last edited by
      Mein ioBroker läuft nun seit Wochen auf einem ESXi Server und das sehr gut, besser als vorher bei Windows
      Nun wollte ich mal ein paar Adapter updaten, aber das funktioniert gar nicht.
      Weder harmony, noch RPC, Rega, iCal nix.
      Weder im Interface noch in SSH, iobroker an oder aus, nicht mit –unsafe-perm
      nix
      Ich brauch dabei mal Hilfe. Vielen Dank
      $ ./iobroker upgrade ical
      npm install iobroker.ical --production --prefix "/opt/iobroker" (System call)
      npm
       WARN
      deprecated node-uuid@1.4.7: use uuid module instead
      npm
      WARN
      optional Skipping failed optional dependency /noble/xpc-connection:npm
       WARN notsup Not compatible with your operating system or architecture: xpc-connection@0.1.4
      npm
       WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/ical/package.json'
      npm
       WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
      npm
      ERR! Linux 4.4.0-64-genericnpm
       ERR! argv
       "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.ical" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.2.6
      npm ERR! npm  v3.5.2
      npm ERR! path /opt/iobroker/node_modules/ical/node_modules/.bin/uuidnpm
       ERR! code EEXIST
      npm
       ERR! Refusing to delete /opt/iobroker/node_modules/ical/node_modules/.bin/uuid: containing path /opt/iobroker/node_modules/ical/node_modules/node-uuid isn't under npm's controlnpm ERR! File exists: /opt/iobroker/node_modules/ical/node_modules/.bin/uuid
      npm
       ERR! Move it away, and try again.
      npm
       ERR! Please include the following file with any support request:
      npm ERR!     /opt/npm-debug.log
      ERROR: host.iobroker Cannot install iobroker.ical: 1
      ERROR: process exited with code 25
      und im Log:
      iobroker	2017-03-06 03:01:18.871	info	npm
      iobroker	2017-03-06 03:01:18.864	info
      iobroker	2017-03-06 03:01:18.703	info	ERR! Move it away, and try again.
      iobroker	2017-03-06 03:01:18.693	info	npm
      iobroker	2017-03-06 03:01:18.693	info	ERR! Refusing to delete /opt/iobroker/node_modules/ical/node_modules/.bin/uuid: containing path /opt/iobroker/node_modules/ical/node_modules/node-uuid isn't under npm's controlnpm ERR! File exists:
      iobroker	2017-03-06 03:01:18.687	info	npm
      iobroker	2017-03-06 03:01:18.687	info	ERR! code EEXIST
      iobroker	2017-03-06 03:01:18.679	info	npm ERR! path /opt/iobroker/node_modules/ical/node_modules/.bin/uuidnpm
      iobroker	2017-03-06 03:01:18.676	info	npm ERR! npm v3.5.2
      iobroker	2017-03-06 03:01:18.673	info	"/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.ical" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.2.6
      iobroker	2017-03-06 03:01:18.667	info	ERR! argv
      iobroker	2017-03-06 03:01:18.665	info	ERR! Linux 4.4.0-64-genericnpm
      iobroker	2017-03-06 03:01:18.663	info
      iobroker	2017-03-06 03:01:18.659	info	npm
      iobroker	2017-03-06 03:01:18.643	info	WARN babel-eslint@5.0.4 requires a peer of eslint@<2.3.0 but none was installed.
      iobroker	2017-03-06 03:01:18.637	info	npm
      iobroker	2017-03-06 03:01:18.633	info	WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/ical/package.json'
      iobroker	2017-03-06 03:01:18.629	info	npm
      iobroker	2017-03-06 03:01:18.624	info	WARN notsup Not compatible with your operating system or architecture: xpc-connection@0.1.4
      iobroker	2017-03-06 03:01:18.614	info	optional Skipping failed optional dependency /noble/xpc-connection:npm
      iobroker	2017-03-06 03:01:18.609	info	WARN
      iobroker	2017-03-06 03:01:18.604	info
      iobroker	2017-03-06 03:01:18.598	info	npm
        Marcolotti last edited by
        Guten Morgen,
        als was bist du angemeldet? Hast du es mal mit sudo versucht?
        Gruß Marco
        • eric2905
          eric2905 last edited by
          Moin,
          noch eine Frage:
          Welches OS hast Du denn für die VM in Einsatz?
          Windows oder Linux (welches)?
          Gruß,
          Eric
          Von unterwegs getippert
            Angemeldet bin ich als root.
            Ubuntu 16.04.2 LTS
            Ich habe alles per Hand installiert, neu installiert inkl iobroker. da ging auch noch alles
            • Thisoft
              Thisoft last edited by
              > Nun wollte ich mal ein paar Adapter updaten, aber das funktioniert gar nicht. :!: :?: :mrgreen:
              Nix für ungut - will hier auch kein Spam produzieren - konnten mir das nur gerade nich ganz verkneifen "duck und weg"
              • Thisoft
                So und jetzt der Versuch einer wirklichen Hilfe 😉 :
                Ich würde dunkel vermuten dass mit deine npm-Installation was nicht stimmt. Google hat mir z.B. das ausgespuckt
                ` > npm uninstall –save node-uuid
                npm install --save uuid
                The old node-uuid module is deprecated and won't be maintained moving forward. The module is still published in NPM for backward compatibility (with the deprecation notice). If you need the source, clone this repo then git checkout v1.4.7. `
                Wäre vielleicht einen Versuch wert…
                • apollon77
                  apollon77 last edited by
                  Würde ich nicht machen. Diese Warning kommt gerade überall.
                  Er sagt doch
                  mach das doch mal!
                  Bzw wenn DU den Adapter eh neu installierst scheiss das ganze /opt/iobroker/node_modules/ical/ weg.
                  Welche node-Version nimmst Du ?
                    @Thisoft:
                    Wäre vielleicht einen Versuch wert… `
                    ERGEBNIS :
                    root@iobroker:~# npm uninstall --save node-uuid
                    npm ERR! Linux 4.4.0-65-generic
                    npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "uninstall" "--save" "node-uuid"
                    npm ERR! npm  v3.5.2
                    npm ERR! code EMISSINGARG
                    npm ERR! typeerror Error: Missing required argument #3
                    npm ERR! typeerror     at replaceModule (/usr/share/npm/lib/install/deps.js:438:                       3)
                    npm ERR! typeerror     at /usr/share/npm/lib/install/deps.js:234:7
                    npm ERR! typeerror     at Array.forEach (native)
                    npm ERR! typeerror     at exports.removeDeps (/usr/share/npm/lib/install/deps.js                       :230:8)
                    npm ERR! typeerror     at Array. <anonymous>(/usr/share/npm/node_modules/slide/l                       ib/bind-actor.js:15:8)
                    npm ERR! typeerror     at LOOP (/usr/share/npm/node_modules/slide/lib/chain.js:1                       5:14)
                    npm ERR! typeerror     at chain (/usr/share/npm/node_modules/slide/lib/chain.js:                       20:5)
                    npm ERR! typeerror     at Uninstaller.loadAllDepsIntoIdealTree (/usr/share/npm/l                       ib/uninstall.js:72:3)
                    npm ERR! typeerror This is an error with npm itself. Please report this error at                       :
                    npm ERR! typeerror     <http: github.com/npm/issues="">npm ERR! Please include the following file with any support request:
                    npm ERR!     /root/npm-debug.log</http:></anonymous></anonymous>
                    NODE:
                    root@iobroker:~# node -v
                    v4.2.6
                    • Thisoft
                      War ja auch nur von Dr.Google "abgeschrieben"… Bin kein Linux-Kenner...
                      Appollon hatte ja auch schon davon abgeraten.
                      Hast Du auch schon mal versucht das ganze angemeckerte Verzeichnis wegzuschmeißen wie Appollon geraten hatte?
                      • Y
                        ykuendig last edited by
                        Oder für die nicht Linuxianer (wie mich)
                        sudo rm /opt/iobroker/node_modules/ical/node_modules/.bin/uuid
                        ````oder so
                          @ykuendig:
                          ````oder so `
                          Hab ich gemacht, bringt aber nichts.
                          auch die anderen Adapter lassen sich nicht updaten.
                          Ich überlege am Wochenende nochmal alles neu auf zusetzten, ev mit debian, vielleicht ist das besser.
                          Gibt da eine gute Anleitung hier ?
                          • Y
                            Ich habs ca. nach der hier - in einer xen-server vm gemacht.
                            http://www.iobroker.net/docu/?page_id=5358&lang=de
                            Aber vom Prinzip her ist das Wurst ob virtuell oder physisch.
                              @ykuendig:
                              Aber vom Prinzip her ist das Wurst ob virtuell oder physisch. `
                              Vielen Dank, super Anleitung
                              2723
