    4. KNX Adapter läuft nicht
      Rookie 0 last edited by
      Hallo Zusammen,
      ich habe iobroker installiert und den knx adapter installiert. Dieser möchte jedoch nicht seinen Dienst aufnehmen. Siehe screenshot.
        Thomas Braun Most Active @Rookie 0 last edited by
        @rookie-0 sagte in KNX Adapter läuft nicht:
        Was kann ich tun?
        Den Start des Adapters nicht per nichtssagendem Screenshot sondern aus dem LogFile heraus dokumentieren.
        iobroker logs --watch
        Dann den Adapter (neu)starten, Ausgaben in CodeTags (KEIN Screenshot!) als Text hier rein.
          pi@raspberrypi:~ $ pi@raspberrypi:~ $ iobroker logs --watch
          2022-01-31 17:36:42.377  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
          2022-01-31 17:36:42.386  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
          2022-01-31 17:36:42.389  - info: knx.1 (4737) Got terminate signal TERMINATE_YOURSELF
          2022-01-31 17:36:42.401  - info: knx.1 (4737) terminating
          2022-01-31 17:36:42.404  - info: knx.1 (4737) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-01-31 17:36:42.958  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-01-31 17:36:45.458  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4752
          2022-01-31 17:36:48.672  - info: knx.1 (4752) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
          2022-01-31 17:36:48.765  - warn: knx.1 (4752) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
          2022-01-31 17:36:48.770  - info: knx.1 (4752) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
          2022-01-31 17:36:48.938  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
          2022-01-31 17:36:48.949  - info: knx.1 (4752) Got terminate signal TERMINATE_YOURSELF
          2022-01-31 17:36:48.961  - info: knx.1 (4752) terminating
          2022-01-31 17:36:48.964  - info: knx.1 (4752) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-01-31 17:36:48.994  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
          2022-01-31 17:36:49.532  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-01-31 17:36:52.056  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4767
          2022-01-31 17:36:55.253  - info: knx.1 (4767) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
          2022-01-31 17:36:55.368  - warn: knx.1 (4767) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
          2022-01-31 17:36:55.373  - info: knx.1 (4767) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
          2022-01-31 17:36:55.473  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
          2022-01-31 17:36:55.484  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
          2022-01-31 17:36:55.512  - info: knx.1 (4767) Got terminate signal TERMINATE_YOURSELF
          2022-01-31 17:36:55.522  - info: knx.1 (4767) terminating
          2022-01-31 17:36:55.525  - info: knx.1 (4767) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-01-31 17:36:56.085  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-01-31 17:36:58.556  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4782
          2022-01-31 17:37:01.748  - info: knx.1 (4782) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
          2022-01-31 17:37:01.870  - warn: knx.1 (4782) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
          2022-01-31 17:37:01.874  - info: knx.1 (4782) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
          2022-01-31 17:37:01.968  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
          2022-01-31 17:37:01.995  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
          2022-01-31 17:37:02.026  - info: knx.1 (4782) Got terminate signal TERMINATE_YOURSELF
          2022-01-31 17:37:02.036  - info: knx.1 (4782) terminating
          2022-01-31 17:37:02.039  - info: knx.1 (4782) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-01-31 17:37:02.598  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-01-31 17:37:05.054  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4797
          2022-01-31 17:37:08.236  - info: knx.1 (4797) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
          2022-01-31 17:37:08.328  - warn: knx.1 (4797) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
          2022-01-31 17:37:08.333  - info: knx.1 (4797) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
          2022-01-31 17:37:08.806  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
          2022-01-31 17:37:08.818  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
          2022-01-31 17:37:08.818  - info: knx.1 (4797) Got terminate signal TERMINATE_YOURSELF
          2022-01-31 17:37:08.833  - info: knx.1 (4797) terminating
          2022-01-31 17:37:08.837  - info: knx.1 (4797) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-01-31 17:37:09.436  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-01-31 17:37:11.880  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4812
          2022-01-31 17:37:15.049  - info: knx.1 (4812) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
          2022-01-31 17:37:15.179  - warn: knx.1 (4812) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
          2022-01-31 17:37:15.184  - info: knx.1 (4812) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
          2022-01-31 17:37:15.623  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
          2022-01-31 17:37:15.631  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
          2022-01-31 17:37:15.631  - info: knx.1 (4812) Got terminate signal TERMINATE_YOURSELF
          2022-01-31 17:37:15.642  - info: knx.1 (4812) terminating
          2022-01-31 17:37:15.645  - info: knx.1 (4812) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2022-01-31 17:37:16.277  - info: host.raspberrypi instance system.adapter.knx.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2022-01-31 17:37:18.698  - info: host.raspberrypi instance system.adapter.knx.1 started with pid 4827
          2022-01-31 17:37:21.936  - info: knx.1 (4827) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.knx, node: v14.18.3, js-controller: 3.3.22
          2022-01-31 17:37:22.034  - warn: knx.1 (4827) No license found for knx. You can use 500DP for free or you can get a license on https://iobroker.net/accountLicenses !
          2022-01-31 17:37:22.040  - info: knx.1 (4827) Connecting to knx GW: 127.0.0.1:3674 with phy. Adr: 1.1.0
          2022-01-31 17:37:22.453  - info: host.raspberrypi stopInstance system.adapter.knx.1 (force=false, process=true)
          2022-01-31 17:37:22.462  - info: host.raspberrypi stopInstance system.adapter.knx.1 send kill signal
          2022-01-31 17:51:23.128  - info: host.raspberrypi stopInstance system.adapter.knx.2 send kill signalocess=true)x, node: v14.18.3, js-controller: 3.3.225) not possible because of cancelled connection.D : 0 SeqCntIN : 0 SeqCntOUT : 0  msgC
            Rookie 0 @Rookie 0 last edited by
            ist das so ok?
            Danke schonmal!
            Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
              @rookie-0
              Deine Systemzeit steht offenbar auf London-Zeit. Stell das auf Berlin/MEZ um
              • Glasfaser
                Glasfaser @Rookie 0 last edited by
                @rookie-0
                Oben im Screenshot ist die Instanz knx.2
                und im Log knx.1 !?
                Wieviel instanzen hast du !?
                  Rookie 0 @Glasfaser last edited by
                  Eine Instanz. Der Rest ist eigentlich raus gelöscht...
                    System Zeit hatte ich eigentlich schon auf berlin gesetzt.
                    Geht doch über rasperry-config oder?
                      Thomas Braun Most Active @Rookie 0 last edited by Thomas Braun
                      @rookie-0 Ja. Die geloggten Zeitstempel deuten aber auf eine Stunde Differenz hin.
                      date && date -u
                      liefert?
                        @rookie-0
                        iobroker list instances
                        iobroker update -i
                          Rookie 0 @Thomas Braun last edited by
                          Mon 31 Jan 20:08:12 CET 2022
                          Mon 31 Jan 19:08:12 UTC 2022
                            • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                            • system.adapter.discovery.0 : discovery : raspberrypi - enabled
                              system.adapter.knx.1 : knx : raspberrypi - disabled, bind: 127.0.0.1
                            • system.adapter.knx.2 : knx : raspberrypi - enabled, bind: 192.168.178.37
                            • instance is alive
                              Rookie 0 @Rookie 0 last edited by Rookie 0
                              R
                              Rookie 0
                              32 minutes ago
                              pi@raspberrypi:~ $ iobroker update -i
                              Used repository: default
                              hash changed or no sources cached => force download of new sources
                              update done
                              Adapter "admin" : 5.2.3 , installed 5.2.3
                              Adapter "backitup" : 2.2.3 , installed 2.2.3
                              Adapter "discovery" : 2.7.3 , installed 2.7.3
                              Controller "js-controller" : 3.3.22 , installed 3.3.22
                              Adapter "knx" : 2.0.5 , installed 2.0.5
                              R Thomas Braun 2 Replies Last reply Reply Quote 0
                                kann es an einer verkehrten physikalischen adresse liegen?
                                  @rookie-0
                                  Bitte in CodeTags setzen. Danke.
                                    hiermit geschehen...
                                    Thomas Braun T 2 Replies Last reply Reply Quote 0
                                      @rookie-0
                                      Nö, noch nicht geschehen.
                                      Ist meist falsch. Lös das Binding auf.
                                        tombox @Rookie 0 last edited by
                                        @rookie-0
                                        Also sicherstellen das nur eine instance läuft.
                                        Dann die IP und Physikalische adresse des gateways doppelt checken
                                        OpenKnx Adapter ausprobieren.
                                          Rookie 0 @tombox last edited by
                                          Ich habe es endlich hinbekommen.
                                          Die IP des Gateway war falsch...
                                          Danke an Alle!
                                            Jetzt würde ich gerne eine Visu installieren.
                                            Ich bekomme jedoch eine rote Meldung, wenn ich den Adapter hinzufügen möchte.
                                            Keine Versionsinfo für web
                                            Steht dann da und Hinzufügen ist ausgegraut.
                                            Was mache ich jetzt schon wieder verkehrt?
                                            1038
