    2. English
    3. Scripting / Logic
    5. time of the last change of a data point.
      franzda last edited by
      is there a way in javascript (for node-red) to query the time of the last change of a data point.
      The system "knows" this because the time is displayed in the object list.
      paul53 OliverIO 2 Replies Last reply Reply Quote 0
        paul53 @franzda last edited by
        @franzda
        let lc = getState(id).lc;
        // Trigger:
        on(id, function(dp) {
           let lc = dp.state.lc;
        F 2 Replies Last reply Reply Quote 0
          franzda @paul53 last edited by
          @paul53 Hi Paul thank you for very quick response. The question ist how can I access to the ts property. I mien ts is the value I am looking for.
            @franzda sagte: how can I access to the ts property.
            .ts instead of .lc.
            • OliverIO
              OliverIO @franzda last edited by
              @franzda
              1. you insert a node "iobroker in"
              2. select your datapoint as topic
              3. select object in payload
              4. then you select a function node with the following code
              msg.payload=msg.payload.lc; //or msg.payload.ts
              return msg;
              5 for testing purpose you can connect the function node with a debug node
                franzda @OliverIO last edited by
                @oliverio Hi Oliver Thank you for quick response. it works
                  franzda @franzda last edited by
                  @franzda said in time of the last change of a data point.:
                  this is my code thank you for helping: (two different formats for testing)
                    sensor.neulcT = (new Date(msg.payload[i].lc)).toLocaleTimeString();
                    sensor.neulc =  (new Date(msg.payload[i].lc)).toLocaleString();
                    @oliverio
                      @paul53 hi Paul Thank you for quick response. it works
