    4. GELÖST ZigBee Adapter bleibt gelb
      BLRD last edited by BLRD
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Architektur x64
      CPUs 4
      Geschwindigkeit 2300 MHz
      Modell Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Bullseye
      Node-Version: 14.18.2
      Nodejs-Version: 14.18.2
      NPM-Version: 6.14.15
      Installationsart: Manuell
      Image genutzt: Nein
      Ort/Name der Imagedatei: none
      leider bin ich mit einem Problem, welchen den ZigBeeAdapter (zigbee.0
      v1.6.14) nicht weiterkommen. Dieser beleibt trotz vielen lesen und probieren gelb.
      Log anbei:
      2022-02-11 11:25:58.924  - #[32minfo#[39m: host.iob instance system.adapter.zigbee.0 started with pid 231269
      2022-02-11 11:26:01.381  - #[34mdebug#[39m: zigbee.0 (231269) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2022-02-11 11:26:01.443  - #[34mdebug#[39m: zigbee.0 (231269) Objects client ready ... initialize now
      2022-02-11 11:26:01.457  - #[34mdebug#[39m: zigbee.0 (231269) Objects create System PubSub Client
      2022-02-11 11:26:01.458  - #[34mdebug#[39m: zigbee.0 (231269) Objects create User PubSub Client
      2022-02-11 11:26:01.567  - #[34mdebug#[39m: zigbee.0 (231269) Objects client initialize lua scripts
      2022-02-11 11:26:01.580  - #[34mdebug#[39m: zigbee.0 (231269) Objects connected to redis: 127.0.0.1:9001
      2022-02-11 11:26:01.583  - #[35msilly#[39m: zigbee.0 (231269) redis psubscribe cfg.o.system.user.*
      2022-02-11 11:26:01.626  - #[35msilly#[39m: zigbee.0 (231269) redis psubscribe cfg.o.enum.*
      2022-02-11 11:26:01.631  - #[35msilly#[39m: zigbee.0 (231269) objectDB connected
      2022-02-11 11:26:01.633  - #[34mdebug#[39m: zigbee.0 (231269) Redis States: Use Redis connection: 127.0.0.1:9000
      2022-02-11 11:26:01.667  - #[34mdebug#[39m: zigbee.0 (231269) States create System PubSub Client
      2022-02-11 11:26:01.668  - #[34mdebug#[39m: zigbee.0 (231269) States create User PubSub Client
      2022-02-11 11:26:01.720  - #[34mdebug#[39m: zigbee.0 (231269) States connected to redis: 127.0.0.1:9000
      2022-02-11 11:26:01.721  - #[35msilly#[39m: zigbee.0 (231269) statesDB connected
      2022-02-11 11:26:01.940  - #[34mdebug#[39m: zigbee.0 (231269) Plugin sentry Initialize Plugin (enabled=true)
      2022-02-11 11:26:02.659  - #[32minfo#[39m: zigbee.0 (231269) starting. Version 1.6.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.18.2, js-controller: 4.0.7
      2022-02-11 11:26:02.700  - #[34mdebug#[39m: zigbee.0 (231269) Using zigbee-herdsman with settings: {"network":{"panID":6754,"extendedPanID":[32,221,221,221,221,221,221,221],"channelList":[11],"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":true}}
      2022-02-11 11:26:02.759  - #[32minfo#[39m: zigbee.0 (231269) Starting Zigbee  npm ...
      2022-02-11 11:26:02.760  - #[34mdebug#[39m: zigbee.0 (231269) Starting zigbee-herdsman...
      2022-02-11 11:26:03.076  - #[35msilly#[39m: zigbee.0 (231269) States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1644575162926,"q":0,"from":"system.adapter.zigbee.0","lc":1643205476682}
      2022-02-11 11:26:03.173  - #[34mdebug#[39m: zigbee.0 (231269) zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[32,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
      2022-02-11 11:26:03.174  - #[34mdebug#[39m: zigbee.0 (231269) zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyACM0 and {"baudRate":115200,"rtscts":false,"autoOpen":false}
      2022-02-11 11:26:03.181  - #[34mdebug#[39m: zigbee.0 (231269) Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_02_11-11_26_02.tar.gz success
      2022-02-11 11:26:03.242  - #[31merror#[39m: zigbee.0 (231269) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Operation not permitted, cannot open /dev/ttyACM0'"
      2022-02-11 11:26:03.243  - #[31merror#[39m: zigbee.0 (231269) Failed to start Zigbee
      2022-02-11 11:26:03.243  - #[31merror#[39m: zigbee.0 (231269) Error herdsman start
      2022-02-11 11:26:03.245  - #[32minfo#[39m: zigbee.0 (231269) Installed Version: iobroker.zigbee@1.6.14
      2022-02-11 11:26:03.254  - #[35msilly#[39m: zigbee.0 (231269) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1644575163247,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1630856270636}
      2022-02-11 11:26:03.314  - #[35msilly#[39m: zigbee.0 (231269) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Error while opening serialport 'Error: Error: Operation not permitted, cannot open /dev/ttyACM0'\". undefined","ack":true,"ts":1644575163311,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1643225935906}
      2022-02-11 11:26:03.317  - #[35msilly#[39m: zigbee.0 (231269) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1644575163311,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1630856270636}
      2022-02-11 11:26:13.246  - #[32minfo#[39m: zigbee.0 (231269) Try to reconnect. 1 attempts left
      2022-02-11 11:26:13.247  - #[32minfo#[39m: zigbee.0 (231269) Starting Zigbee  npm ...
      2022-02-11 11:26:13.248  - #[34mdebug#[39m: zigbee.0 (231269) Starting zigbee-herdsman...
      2022-02-11 11:26:13.269  - #[32minfo#[39m: zigbee.0 (231269) Installed Version: iobroker.zigbee@1.6.14
      2022-02-11 11:26:13.448  - #[34mdebug#[39m: zigbee.0 (231269) zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[32,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","adapter":{"disableLED":false,"forceStartWithInconsistentAdapterConfiguration":true},"acceptJoiningDeviceHandler":null}'
      2022-02-11 11:26:13.449  - #[34mdebug#[39m: zigbee.0 (231269) zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyACM0 and {"baudRate":115200,"rtscts":false,"autoOpen":false}
      2022-02-11 11:26:13.459  - #[31merror#[39m: zigbee.0 (231269) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Operation not permitted, cannot open /dev/ttyACM0'"
      2022-02-11 11:26:13.460  - #[31merror#[39m: zigbee.0 (231269) Failed to start Zigbee
      2022-02-11 11:26:13.460  - #[31merror#[39m: zigbee.0 (231269) Error herdsman start
      2022-02-11 11:26:13.475  - #[35msilly#[39m: zigbee.0 (231269) States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Error while opening serialport 'Error: Error: Operation not permitted, cannot open /dev/ttyACM0'\". undefined","ack":true,"ts":1644575173473,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1643225935906}
      2022-02-11 11:26:13.477  - #[35msilly#[39m: zigbee.0 (231269) States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1644575173474,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1630856270636}
      Ich bitte um Hilfe / Anregungen was ich noch machen kann!?
      Danke.
      VG
      BLRD
      • Asgothian
        Asgothian Developer @BLRD last edited by
        @blrd sagte in ZigBee Adapter bleibt gelb:
        Du kannst/musst dafür sorgen das der Benutzer der den ioBroker laufen lässt die serielle Schnittstelle öffnen darf. Darf er aktuell nicht:
          BLRD @Asgothian last edited by BLRD
          @asgothian
          Danke für die Rückmeldung.
          Wie mache ich dies ? Meinst du den Anmeldnamen bei IoBroker mit PW?
          Achso über die Konsole des NUC oder soll ich per Putty rein?
          • Asgothian
            @blrd Die frage kann ich dir so nicht beantworten.
            • Du hast oben geschrieben das du den ioBroker "manuell" installiert hast.. was genau heisst das ?
            • unter welchem Benutzer läuft der ioBroker ?
            • wie sind die rechte auf der seriellen Schnittstelle (ls -al /dev/ttyACM0)
            A.
              @asgothian sagte in ZigBee Adapter bleibt gelb:
              Du hast oben geschrieben das du den ioBroker "manuell" installiert hast.. was genau heisst das ? Also ich habe dies über die Konsole des NUC mit dem Eingabebefehl für IOB erledigt - Technikram- Installations-Skript den ioBroker installieren können. Das macht ihr mit dem Befehl: curl -sL https://raw.githubusercontent.com/ioBroker/ioBroker/stable-installer/installer.sh | bash
              unter welchem Benutzer läuft der ioBroker ? [Mit meinen Initalien und PW, allerdings in der Konsole des Nuc so -root@iob:/opt/iobroker# -.]
              wie sind die rechte auf der seriellen Schnittstelle (ls -al /dev/ttyACM0)!
              • Asgothian
                • bitte den ls Befehl in der Konsole ausführen und das Ergebnis als Text posten - dabei nicht als root angemeldet sein !. Der Screenshot zeigt ziemlich sicher nicht. Bitte zusätzlich die Ausgabe von ls -al /dev/serial/by-id
                • ich hoffe inständig das der ioBroker nicht als root läuft. Ich gehe davon aus das es der Benutzer iobroker ist. Heraus finden kannst du es mit dem Befehl ps -axu | grep -e iobroker
                A.
                  crw-rw-rw- 1 root dialout 166, 0 Feb 9 11:45 /dev/ttyACM0 dazu ls -al /dev/serial/by-id ls: cannot access '/dev/serial/by-id': No such file or directory]] D. h. wohl ich laufe auf root Mist!
                  $ ps -axu | grep -e iobroker
                  iobroker  219573 18.8  8.7 1199172 365544 ?      Rsl  09:41  32:53 iobroker.js-controller
                  iobroker  219591  1.2  3.5 1029852 148056 ?      Sl   09:41   2:09 io.admin.0
                  iobroker  219606  0.0  1.5 681856 64660 ?        Sl   09:41   0:09 io.email.0
                  iobroker  219621  0.1  1.8 704460 78988 ?        Sl   09:41   0:20 io.history.0
                  iobroker  219636  3.9  4.1 785084 173572 ?       Sl   09:41   6:57 io.javascript.0
                  iobroker  219651  0.0  1.5 663536 66552 ?        Sl   09:41   0:10 io.node-red.0
                  iobroker  219666  0.1  1.8 944472 78832 ?        Sl   09:41   0:19 io.telegram.0
                  iobroker  219673  0.2  3.0 986440 125952 ?       Sl   09:41   0:30 node-red
                  iobroker  219718  0.3  1.8 960456 78808 ?        Sl   09:41   0:32 io.homee.0
                  iobroker  219744  0.1  1.5 926024 64964 ?        Sl   09:41   0:11 io.netatmo.0
                  iobroker  219763  0.1  1.8 956520 79472 ?        Sl   09:41   0:18 io.alexa2.0
                  iobroker  219774  0.6  1.7 691456 74448 ?        Sl   09:41   1:07 io.ping.0
                  iobroker  219796  0.6  2.3 714256 96656 ?        Sl   09:41   1:07 io.shelly.0
                  iobroker  219816  3.2  2.4 783284 102764 ?       Sl   09:41   5:33 io.sonoff.0
                  iobroker  219852  1.7  2.0 702572 87968 ?        Sl   09:42   3:01 io.synology.0
                  iobroker  219867  0.4  2.1 700000 88832 ?        Sl   09:42   0:44 io.tr-064.0
                  iobroker  219912  0.0  1.7 683384 74480 ?        Sl   09:42   0:09 io.backitup.0
                  iobroker  219982  0.0  1.5 681800 64620 ?        Sl   09:42   0:09 io.discovery.0
                  iobroker  220022  0.0  1.3 656740 55948 ?        Sl   09:42   0:08 io.egigeozone.0
                  iobroker  220045  0.4  1.6 799692 68112 ?        Sl   09:42   0:42 io.enigma2.0
                  iobroker  220066  0.3  1.6 733028 67888 ?        Sl   09:42   0:38 io.enigma2.1
                  iobroker  220081  1.0  2.2 809424 93620 ?        Sl   09:42   1:49 io.fb-checkpresence.0
                  iobroker  220096  0.1  1.4 725268 59120 ?        Sl   09:42   0:18 io.fritzbox.0
                  iobroker  220114  0.1  1.5 664944 65152 ?        Sl   09:42   0:16 io.fritzdect.0
                  iobroker  220197  0.1  2.3 913488 97716 ?        Sl   09:43   0:20 io.iot.0
                  iobroker  220442  0.0  1.6 683656 67468 ?        Sl   09:43   0:09 io.iqontrol.0
                  iobroker  220479  0.1  1.3 662032 57892 ?        Sl   09:43   0:13 io.lgtv.0
                  iobroker  220601  0.0  1.5 925760 63884 ?        Sl   09:43   0:10 io.nina.0
                  iobroker  220630  0.1  1.7 690700 72472 ?        Sl   09:43   0:18 io.octoprint.0
                  iobroker  220645  0.1  1.3 658560 57868 ?        Sl   09:43   0:11 io.paw.0
                  iobroker  220660  0.7  1.8 648100 75952 ?        Sl   09:43   1:14 io.pi-hole.0
                  iobroker  220675  0.1  1.6 751780 68984 ?        Sl   09:43   0:10 io.pollenflug.0
                  iobroker  220693  0.2  1.4 662228 61796 ?        Sl   09:43   0:22 io.samsung.0
                  iobroker  220717  0.1  1.4 659704 59772 ?        Sl   09:43   0:12 io.snmp.0
                  iobroker  220739  0.1  1.8 962200 78620 ?        Sl   09:43   0:13 io.statistics.0
                  iobroker  220769  0.1  1.6 931396 69396 ?        Sl   09:43   0:16 io.tankerkoenig.0
                  iobroker  220788  0.2  1.7 672412 73112 ?        Sl   09:44   0:21 io.upnp.0
                  iobroker  220835  0.1  1.6 692568 71100 ?        Sl   09:44   0:10 io.web.0
                  iobroker  220851  0.6  1.8 678736 77316 ?        Sl   09:44   1:08 io.proxmox.0
                  iobroker  220884  0.0  1.4 665500 61256 ?        Sl   09:44   0:08 io.terminal.0
                  iobroker  222862  0.1  1.8 889448 76628 ?        Sl   10:01   0:17 io.info.0
                  iobroker  225185  0.1  1.8 957140 77160 ?        Sl   10:22   0:13 io.discovergy.0
                  iobroker  228399  0.1  1.8 1021700 77056 ?       Sl   10:55   0:09 io.mihome-vacuum.0
                  iobroker  231269  0.2  2.1 901084 90548 ?        Sl   11:25   0:08 io.zigbee.0
                  iobroker  237840  0.0  0.0   4132   868 ?        S    12:35   0:00 /bin/ping -n -w 500 -c 1 192.168.178.90
                  dr        237842  0.0  0.0   3312   724 pts/1    S+   12:35   0:00 grep -e iobroker```
                  Nachtrag wenn ich über den Knoten - dortige shell gehe, dort geht es nur als root, kommt dies:
                  root@pve:~# ls -al /dev/serial/by-id
                  total 0
                  drwxr-xr-x 2 root root 60 Feb  9 11:45 .
                  drwxr-xr-x 4 root root 80 Feb  9 11:45 ..
                  lrwxrwxrwx 1 root root 13 Feb  9 11:45 usb-Texas_Instruments_CC2538_USB_CDC-if00 -> ../../ttyACM0
                  Und Sorry wenn ich nerve oder so, da ich in Linux noch Anfänger bin.
                  • Asgothian
                    Alles gut. Es fehlt noch die Ausgabe von
                    ls -al /dev/ttyACM0
                    Ansonsten läuft dein ioBroker nicht als root. Und auf der Konsole solltest du dich genau so wie auch mit putty mit deinem Benutzernamen anmelden können.
                    Im übrigen darfst du gerne wenn ich Konsole schreibe statt dessen Putty und deinen Benutzer nutzen. Die Ausgaben sollten vergleichbar sein, und du arbeitest da (hoffentlich) nicht als root.
                    A.
                    B 2 Replies Last reply Reply Quote 0
                      @asgothian
                      Hi, muss ich dies auf der Konsole des Containers machen
                      oder
                      am Knoten in der shell?
                      • Asgothian
                        @blrd Wieso container ?
                        Du schriebst doch:
                        Betriebsssytem Bullseye
                        Installation Manuell per Skript
                          @asgothian
                          Knoten:
                          root@pve:~# ls -al /dev/ttyACM0
                          root@pve:~#
                          Container:
                          ls -al /dev/ttyACM0
                          sh: 3: root@pve:~#: not found
                            @asgothian
                            In den Systemdata habe ich NUC geschrieben und IoBroker läuft im Container.
                            Sorry
                            Und nochmal Sorry, ich habe dies:
                            root@iob:/opt/iobroker# lsb_release -a
                            No LSB modules are available.
                            Distributor ID: Ubuntu
                            Description: Ubuntu 20.04.3 LTS
                            Release: 20.04
                            Codename: focal
                            • Asgothian
                              Asgothian Developer @BLRD last edited by Asgothian
                              @blrd der Nuc ist auch nur ein Rechner. Das du da mit Containern arbeitest war so nicht zu sehen
                              In diesem Fall musst du die Konfiguration deines Containers verifizieren - es scheint das die serielle Schnittstelle des USB Sticks nicht an den Container weiter gegeben wird.
                              Da bin ich dann auch raus. Mit Containern kenn ich mich nicht im Detail aus.
                              A.
                                @asgothian OK, dannn Sorry und Danke!
                                Und hoffentlich kann mir dazu jemand helfen.
                                VG
                                amg_666 1 Reply Last reply Reply Quote 0
                                • amg_666
                                  amg_666 @BLRD last edited by
                                  @blrd Debian11 ist das Betriebssystem, wenn du sagst, dass du einen Container für iob hast, was ist das für eine Umgebung: Docker? Proxmox?
                                    BLRD @amg_666 last edited by
                                    @amg_666
                                    Proxmox.
                                    • amg_666
                                      @blrd Also nach dieser Anleitung habe ich es hinbekommen.
                                      Das machst du alles in der "proxmox" Konsole (shell), nicht in der iobroker Konsole.
                                        @amg_666
                                        Sorry, dass ich mich jetzt erst zurückmelde.
                                        Freu der Adapter geht wieder. Diese Anleitung wie genannt kannte ich und hatte ich auch schon des öfteren genutzt, ohne Erfolg.
                                        Jetzt hae ich den NUC samt Promox neuinstalliert und es geht.
                                        Was ich eingrenzen konnte ist, dass dies nur mit einem unpreviliegierten LXC geht (warum auch immer)!? Kennt jemand dies?
                                        Des Weiteren habe ich jetzt noch ei Problem mit dem Synology- und Backituo-Adapter!? Hat dies ggf. auch damit zu tun? Beim Backitup (mit FritzBox kommt dies
                                        Error: Command failed: sudo mount -t cifs -o username=biu,password=****,noserverino,rw,file_mode=0777,dir_mode=0777 //192.168.178.111/fbfr/NAS_FB_FR/biuiob /opt/iobroker/backupsmount error(1): Operation not permittedRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                                        Danke und wenn jeman noch zum Syn bzw. Backitup was sagen kann, gerne her damit.
                                        Danke.
                                        VG
                                        BLRD
                                          arteck Developer Most Active @BLRD last edited by
                                          @blrd mach dafür einen extra Beitrag auf.. vermische nicht 2 themen..und setzt dieses auf Gelöst
                                            BLRD @arteck last edited by
                                            @arteck
                                            Ok Sorry hast recht.
                                            VG
                                            1002
