    4. Update Javascript auf 5.2.21 - Fehler im Log
    • Samson71
      Samson71 Global Moderator last edited by Samson71
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Syno/Docker
      Habe heute JS aktualisiert von 5.2.13 auf 5.2.21 und habe folgende Fehler im Protokoll, aus denen ich aber (für mich) kein ToDo ableiten kann. Grundsätzlich scheint aber erstmal alles zu funktionieren.
      javascript.0	2022-02-16 15:31:49.636	info	(24753) received all objects
      javascript.0	2022-02-16 15:31:48.813	info	(24753) received all states
      javascript.0	2022-02-16 15:31:45.905	info	(24753) requesting all objects
      javascript.0	2022-02-16 15:31:45.904	info	(24753) requesting all states
      javascript.0	2022-02-16 15:31:45.820	info	(24753) found 0 vulnerabilities
      javascript.0	2022-02-16 15:31:45.819	info	run `npm fund` for details
      javascript.0	2022-02-16 15:31:45.819	info	8 packages are looking for funding
      javascript.0	2022-02-16 15:31:45.819	info	(24753)
      javascript.0	2022-02-16 15:31:45.680	info	added 9 packages from 11 contributors and audited 78 packages in 12.587s
      javascript.0	2022-02-16 15:31:45.680	info	(24753) + node-ssh@12.0.3
      javascript.0	2022-02-16 15:31:45.676	error	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      javascript.0	2022-02-16 15:31:45.676	error	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: cpu-features@0.0.2 install: `node-gyp rebuild`
      javascript.0	2022-02-16 15:31:45.676	error	(24753) WARN optional SKIPPING OPTIONAL DEPENDENCY: cpu-features@0.0.2 (node_modules/cpu-features):
      javascript.0	2022-02-16 15:31:45.675	error	(24753) npm
      javascript.0	2022-02-16 15:31:45.362	info	(24753) Succeeded in building optional crypto binding
      javascript.0	2022-02-16 15:31:45.343	info	(24753) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
      javascript.0	2022-02-16 15:31:45.188	info	(24753) COPY Release/sshcrypto.node
      javascript.0	2022-02-16 15:31:44.559	info	(24753) SOLINK_MODULE(target) Release/obj.target/sshcrypto.node
      javascript.0	2022-02-16 15:31:41.390	error	| ^~~~~~~~~~~
      javascript.0	2022-02-16 15:31:41.390	error	2003 | NODE_MODULE(sshcrypto, init)
      javascript.0	2022-02-16 15:31:41.390	error	../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’
      javascript.0	2022-02-16 15:31:41.390	error	| ^~~~~~~~~~~~~
      javascript.0	2022-02-16 15:31:41.390	error	770 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
      javascript.0	2022-02-16 15:31:41.390	error	/opt/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:770:3: note: in expansion of macro ‘NODE_MODULE_X’
      javascript.0	2022-02-16 15:31:41.390	error	| ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      javascript.0	2022-02-16 15:31:41.390	error	736 | (node::addon_register_func) (regfunc), \
      javascript.0	2022-02-16 15:31:41.390	error	/opt/iobroker/.cache/node-gyp/12.22.7/include/node/node.h:736:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::
      javascript.0	2022-02-16 15:31:41.390	error	(24753) In file included from ../src/binding.cc:6:
      javascript.0	2022-02-16 15:31:38.461	info	(24753) CXX(target) Release/obj.target/sshcrypto/src/binding.o
      javascript.0	2022-02-16 15:31:38.460	info	(24753) make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
      javascript.0	2022-02-16 15:31:37.370	info	> node install.js
      javascript.0	2022-02-16 15:31:37.370	info	> ssh2@1.6.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
      javascript.0	2022-02-16 15:31:37.370	info	(24753)
      javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! not ok
      javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! node-gyp -v v5.1.0
      javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! node -v v12.22.7
      javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
      javascript.0	2022-02-16 15:31:37.347	error	gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      javascript.0	2022-02-16 15:31:37.347	error	(24753) gyp ERR! System Linux 4.4.59+
      javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
      javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack at ChildProcess.emit (events.js:314:20)
      javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      javascript.0	2022-02-16 15:31:37.345	error	gyp ERR! stack Error: `make` failed with exit code: 2
      javascript.0	2022-02-16 15:31:37.345	error	(24753) gyp ERR! build error
      javascript.0	2022-02-16 15:31:37.343	info	(24753) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build'
      javascript.0	2022-02-16 15:31:37.342	error	(24753) make: *** [config_deps.target.mk:13: /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build/Makefile] Error 127
      javascript.0	2022-02-16 15:31:37.341	error	(24753) /bin/sh: 1: cmake: not found
      javascript.0	2022-02-16 15:31:37.334	info	(24753) ACTION Configuring dependencies /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build/Makefile
      javascript.0	2022-02-16 15:31:37.333	info	(24753) make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build'
      host.iobroker	2022-02-16 15:31:36.358	info	iobroker exit 0
      javascript.0	2022-02-16 15:31:36.037	info	> node-gyp rebuild
      javascript.0	2022-02-16 15:31:36.037	info	> cpu-features@0.0.2 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
      javascript.0	2022-02-16 15:31:36.037	info	(24753)
        @samson71
        cmake: not found
        cmake nachinstallieren.
        Samson71 1 Reply Last reply Reply Quote 1
        • Samson71
          Samson71 Global Moderator @Thomas Braun last edited by
          Danke für die schnelle Rückmeldung. Dann muss ich mir das unter Docker mal näher ansehen. Habe ich ehrlich gesagt (noch) keinen Plan wie.
            Thomas Braun Most Active @Samson71 last edited by
            @samson71
            In nativen Debian-Umgebungen halt wie üblich:
            sudo apt update
            sudo apt install cmake
            Ob das eingedost anders gemacht werden muss hab ich keine Ahnung von.
            • Namrenner
              Namrenner last edited by
              bekomme leider diesen Fehler:
              D:\Iobroker\SmartHome>npm install "cmake"
              > cmake@0.0.4 install D:\Iobroker\SmartHome\node_modules\cmake
              > make
              Der Befehl "make" ist entweder falsch geschrieben oder
              konnte nicht gefunden werden.
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! cmake@0.0.4 install: `make`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the cmake@0.0.4 install script.
              npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
              Thomas Braun apollon77 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @Namrenner last edited by Thomas Braun
                @namrenner
                Windows...
                Hab ich keine Aktien drin. Vielleicht gibt es cmake nicht dafür.
                Namrenner 1 Reply Last reply Reply Quote 0
                • Namrenner
                  Namrenner @Thomas Braun last edited by
                  @thomas-braun ok, wir bekomme ich den Update v5.2.21 drauf, andere Updates gehen, nur dieser nicht?
                  liv-in-sky Thomas Braun 2 Replies Last reply Reply Quote 0
                  • liv-in-sky
                    liv-in-sky @Namrenner last edited by liv-in-sky
                    @namrenner
                    EDIT: war falsch - kann ihn auch nicht installieren
                      @namrenner sagte in Update Javascript auf 5.2.21 - Fehler im Log:
                      Mit welchen Meldungen?
                      Namrenner liv-in-sky 2 Replies Last reply Reply Quote 0
                      • Namrenner
                        @thomas-braun ```
                        $ iobroker upgrade javascript@5.2.21
                        Update javascript from @5.2.13 to @5.2.21
                        host.TV Adapter "system.adapter.javascript.0" is stopped.
                        NPM version: 6.14.16
                        Installing iobroker.javascript@5.2.21... (System call)
                        host.TV Cannot install iobroker.javascript@5.2.21: 4294963214
                        ERROR: Process exited with code 25
                        • liv-in-sky
                          liv-in-sky @Thomas Braun last edited by
                          @thomas-braun bei mir:
                          host.iobroker59
                          2022-02-26 11:11:00.509	error	iobroker (node:27388) Warning: Accessing non-existent property 'findOne' of module exports inside circular dependency(node:27388) Warning: Accessing non-existent property 'remove' of module exports inside circular dependency(node:27388) Warning: Accessing non-existent property 'updateOne' of module exports inside circular dependency
                          host.iobroker59
                          2022-02-26 11:11:00.505	error	iobroker (node:27388) Warning: Accessing non-existent property 'count' of module exports inside circular dependency(Use `node --trace-warnings ...` to show where the warning was created)
                          danach werden instanzen neugestartet
                          • apollon77
                            apollon77 @liv-in-sky last edited by
                            @liv-in-sky wie im Anderen thread. Gesagt. Mongodb lib ist buggy in alter Version und ab nodejs 14 wird das angemeckert. FAQ vom Controller 4 thread sagt was zu tun ist.
                            Aber nur wegen der Meldung sollte nichts neu starten. Die Meldungen nerven nur 😉
                            • apollon77
                              apollon77 @Namrenner last edited by
                              @namrenner Windows oder Linux? Bitte mal das Upgrade Kommando an der Shell ausführen. Ich tippe das dann Fehlermeldungen kommen mit permissions.
                              Also wenn Linux dann „iob fix“ nutzen. Bei Windows bitte mal iobroker komplett beenden und update manuell machen. Auch schauen ob visentwo als Adapter installiert ist und latest updaten. Der hatte es kaputtes drin was auf Windows komische permission Effekte hatte
                              • apollon77
                                @namrenner gute Frage. Ja das liegt übrigens an der ssh2 Library die du bestimmt manuell als JavaScript Adapter Modul dabei hast.
                                Am Ende ggf mal hier durcharbeiten?? https://github.com/mscdex/cpu-features/issues/3
                                somanuell created this issue in mscdex/cpu-features
                                closed Can't build on Windows #3
                                • liv-in-sky
                                  @apollon77 sagte in Update Javascript auf 5.2.21 - Fehler im Log:
                                  Warning: Accessing non-existent property '...' of module exports inside circular dependency
                                  danke - habe ich gemacht
                                  • javascript update läuft durch, wird aber nicht upgedatet - version in adapter tab:
                                  Update javascript from @5.2.18 to @5.2.21
                                  NPM version: 6.14.16Installing iobroker.javascript@5.2.21... (System call)
                                  upload [103] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                  upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                                  upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.wav google-blockly/media/delete.wav audio/wav
                                  upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote1.png google-blockly/media/quote1.png image/png
                                  upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pt.js google-blockly/msg/js/pt.js application/javascript
                                  upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_time.js google-blockly/own/blocks_time.js application/javascript
                                  upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
                                  upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/plugins/bundle.js plugins/bundle.js application/javascript
                                  upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.02a8da94.js static/js/runtime-main.02a8da94.js application/javascript
                                  upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
                                  upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
                                  upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                                  upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                                  upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                                  upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                                  upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                                  upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                  upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                  upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                  upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                  upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                  upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                  upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                  upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                  upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                  upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                  upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                  upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                  upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                  upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                  Process exited with code 0
                                  am ende steht wieder:
                                  • apollon77
                                    @liv-in-sky Reloade mal ... Es gab mal Refresh issues im Admin ... vllt ist da nich so eins? Also wenn Admin 5.3.1 dann bitte github issue im admin anlegen
                                    • Namrenner
                                      Namrenner @apollon77 last edited by
                                      @apollon77
                                      D:\Iobroker\SmartHome>iobroker update
                                      D:\Iobroker\SmartHome>node node_modules/iobroker.js-controller/iobroker.js update
                                      Used repository: stable
                                      Adapter    "admin"        : 5.3.1    , installed 5.3.1
                                      Adapter    "alexa2"       : 3.11.2   , installed 3.11.2
                                      Adapter    "backitup"     : 2.3.3    , installed 2.3.3
                                      Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
                                      Adapter    "countdown"    : 1.2.5    , installed 1.2.5
                                      Adapter    "discovery"    : 2.7.5    , installed 2.7.5
                                      Adapter    "echarts"      : 1.0.3    , installed 1.0.3
                                      Adapter    "flot"         : 1.10.7   , installed 1.10.7
                                      Adapter    "history"      : 1.10.5   , installed 1.10.5
                                      Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
                                      Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
                                      Adapter    "info"         : 1.9.8    , installed 1.9.18
                                      Adapter    "iot"          : 1.8.24   , installed 1.8.24
                                      Adapter    "javascript"   : 5.2.21   , installed 5.2.13 [Updatable]
                                      Controller "js-controller": 4.0.15   , installed 4.0.15
                                      Adapter    "material"     : 1.1.2    , installed 1.1.2
                                      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                      Adapter    "modbus"       : 3.4.17   , installed 3.4.17
                                      Adapter    "mqtt"         : 2.4.1    , installed 2.4.1
                                      Adapter    "musiccast"    : 0.1.5    , installed 0.1.5
                                      Adapter    "net-tools"    : 0.1.7    , installed 0.1.7
                                      Adapter    "node-red"     : 2.4.2    , installed 2.4.2
                                      Adapter    "parser"       : 1.0.7    , installed 1.0.7
                                      Adapter    "ping"         : 1.5.0    , installed 1.5.0
                                      Adapter    "scenes"       : 2.3.8    , installed 2.3.8
                                      Adapter    "simple-api"   : 2.6.2    , installed 2.6.2
                                      Adapter    "smartmeter"   : 3.2.1    , installed 3.2.1
                                      Adapter    "socketio"     : 3.1.5    , installed 3.1.5
                                      Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
                                      Adapter    "telegram"     : 1.11.1   , installed 1.11.1
                                      Adapter    "text2command" : 2.1.1    , installed 2.1.1
                                      Adapter    "vis"          : 1.4.5    , installed 1.4.5
                                      Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                      Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
                                      Adapter    "vis-inventwo" : 3.2.8    , installed 3.2.8
                                      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
                                      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                                      Adapter    "vis-metro"    : 1.1.2    , installed 1.1.2
                                      Adapter    "web"          : 3.4.16   , installed 3.4.16
                                      Would you like to upgrade javascript from @5.2.13 to @5.2.21 now? [(y)es, (n)o]: y
                                      • apollon77
                                        apollon77 @Namrenner last edited by apollon77
                                        @namrenner naja dann machen wir mal
                                        „iobroker upgrade javascript --debug“
                                        Was sagt die Ausgabe? Und mal versuchen wenn iobroker komplett gestoppt ist.
                                        Ps: und nochmal die Frage: hast du Vis-icontwo als Adapter installiert????
                                        • Namrenner
                                          Namrenner @apollon77 last edited by Namrenner
                                          @apollon77
                                          Vis-icontwo denke nicht, in der Liste habe es nicht, sehe Nachricht davor, dort sind alle Adapter aufgelistet, danke.
                                          npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                          npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
                                          npm WARN rollback Rolling back iobroker.javascript@5.2.21 failed (this is probably harmless): EBUSY: resource busy or locked, rmdir 'D:\Iobroker\SmartHome\node_modules\iobroker.javascript'
                                          npm ERR! code EBUSY
                                          npm ERR! syscall rename
                                          npm ERR! path D:\Iobroker\SmartHome\node_modules\iobroker.javascript
                                          npm ERR! dest D:\Iobroker\SmartHome\node_modules\.iobroker.javascript.DELETE
                                          npm ERR! errno -4082
                                          npm ERR! EBUSY: resource busy or locked, rename 'D:\Iobroker\SmartHome\node_modules\iobroker.javascript' -> 'D:\Iobroker\SmartHome\node_modules\.iobroker.javascript.DELETE'
                                          npm ERR!     C:\Users\Hans\AppData\Roaming\npm-cache\_logs\2022-02-26T13_36_10_444Z-debug.log
                                          • apollon77
                                            @namrenner ebusy ist mal wieder so ne Windows Nummer. Bitte alles beenden und dann das Update machen. Scheinbar lockt Windows irgendwelche files die das Update Bzw npm dann nicht austauschen kann.
                                            Wir stoppen zwar auf Windows seit Controller 4 immer die Instanzen des Adapters was das Update bekommt aber manchmal scheint das bei Windows nicht zu reichen 😞
                                            3003
