    4. [gelöst] Admin Adapter läuft nach Update nicht mehr
      MichaelJaD last edited by
      Ich kann meine Admin Instanz leide nicht mehr öffnen.
      Der Adapter läuft auch nicht
      ` > root@ioBroker:/opt/iobroker# iobroker list instances
      system.adapter.flot.0 : flot - enabled
      system.adapter.javascript.0 : javascript - disabled
      system.adapter.mobile.0 : mobile - disabled
      system.adapter.mpd.0 : mpd - enabled, port: 6600
      system.adapter.node-red.0 : node-red - enabled, port: 1880
      system.adapter.rpi2.0 : rpi2 - enabled
      system.adapter.s7.0 : s7 - enabled
      system.adapter.socketio.0 : socketio - enabled, port: 8084, bind: 0.0.0.0, run as: admin
      system.adapter.sql.0 : sql - enabled, port: 0
      system.adapter.vis-beta.0 : vis-beta - enabled
      system.adapter.vis.0 : vis - enabled
      system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin `
      Ich kann dieses auch nicht upgraden
      ` > root@ioBroker:/opt/iobroker# iobroker install admin
      adapter "admin" yet installed. Use "upgrade" to install newer version.
      root@ioBroker:/opt/iobroker# iobroker upgrade admin
      module.js:590
      throw err;
      SyntaxError: /opt/iobroker/node_modules/iobroker.admin/io-package.json: Unexpected end of JSON input
      at Object.parse (native)
      at Object.Module._extensions..json (module.js:587:27)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.require (module.js:497:17)
      at require (internal/module.js:20:19)
      at Upgrade.upgradeAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:178:27)
      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:108:22
      at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2528:33)</anonymous> `
      Löschen ist auch nicht möglich:
      ` > root@ioBroker:/opt/iobroker# iobroker del admin
      module.js:590
      throw err;
      at Install.deleteAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:1137:26)
      at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:843:29
      at Object.connected (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:2653:70) `
      Ein Update des js.controller habe ich auch durchgeführt.
      ` > root@ioBroker:/opt/iobroker# npm install iobroker.js-controller
      iobroker.js-controller@0.16.2 install /opt/iobroker/node_modules/iobroker.js-controller
      node lib/setup.js setup first
      iobroker.core@0.1.0 /opt/iobroker
      └─┬ iobroker.js-controller@0.16.2
      ├── greenlock@2.1.12
      ├─┬ jszip@3.1.3
      │ └── lie@3.1.1
      ├─┬ socket.io@1.7.3
      │ └─┬ engine.io@1.8.3
      │ └── ws@1.1.2
      ├─┬ socket.io-client@1.7.3
      │ └─┬ engine.io-client@1.8.3
      │ └── ws@1.1.2
      └── winston-daily-rotate-file@1.4.5 `
      Ein Admin Instanz hinzufügen geht leider auch nicht:
      ` > root@ioBroker:/opt/iobroker# iobroker add admin –port 8089
      host.ioBroker install adapter admin
      host.ioBroker error: reading io-package.json SyntaxError: Unexpected end of JSON input `
      Was kann ich nun noch machen?
        Hallo Michel und Willkommen im Forum!
        @MichaelJaD:
        Was kann ich nun noch machen? `
        Das bekommen wir schon hin!
        @MichaelJaD:
        Ein Update des js.controller habe ich auch durchgeführt. `
        Aber wahrscheinlich nicht als erstes, oder?
        Dan versuche mal
        cd /opt/iobroker
        sudo iobroker stop admin
        sudo iobroker upload admin
        sudo iobroker start admin
        Und dann nochmal auf <ip>:8081
        Rainer</ip>
        • G
          Graf Allrad last edited by
          Hat sich erledigt… läuft bei mir wieder.
            @Graf Allrad:
            Das gleiche bei mir. `
            @Graf Allrad:
            Was tun ? `
            Das gleiche 😉
            @MichaelJaD:
            Ein Update des js.controller `
            und dann:
            @Homoran:
            Dann versuche mal
            cd /opt/iobroker
            Und dann nochmal auf <ip>:8081</ip> `
            • G
              Jo Danke !!! :lol:
              Auch im Panikmode hilft "Zuerst Lesen" lach
                ` > Dan versuche mal
                cd /opt/iobroker
                Rainer</ip> `
                Das habe ich gemacht aber dann passiert das:
                ` > root@ioBroker:~# cd /opt/iobroker
                root@ioBroker:/opt/iobroker# sudo iobroker stop admin
                Cannot find any instances of "admin"
                root@ioBroker:/opt/iobroker# sudo iobroker upload admin
                got /opt/iobroker/node_modules/iobroker.admin/admin
                upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
                upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.htm l index.html text/html
                upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                Cannot find io-package.json in /opt/iobroker/node_modules/iobroker.admin
                module.js:590
                throw err;
                SyntaxError: /opt/iobroker/node_modules/iobroker.admin/io-package.json: Unexpect ed end of JSON input
                at Upload.uploadAdapter (/opt/iobroker/node_modules/iobroker.js-controller/l ib/setup/setupUpload.js:214:23)
                at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:776:48
                at Upload.upgradeAdapterObjects (/opt/iobroker/node_modules/iobroker.js-cont roller/lib/setup/setupUpload.js:431:13)
                root@ioBroker:/opt/iobroker# sudo iobroker start admin
                root@ioBroker:/opt/iobroker# `
                Admin Modul ist installiert aber irgendwie auch nicht?
                  Dann hilft nur drüberinstallieren:
                  cd /opt/iobroker
                  sudo iobroker stop
                  sudo npm cache clean
                  sudo npm install iobroker.admin
                  sudo iobroker start
                    Hilft leider auch nicht.
                    iobroker controller daemon is not running
                    root@ioBroker:/opt/iobroker# sudo npm cache clean
                    root@ioBroker:/opt/iobroker# sudo npm install iobroker.admin
                    └── (empty)
                    [b]npm ERR! code 1[/b]
                    Starting iobroker controller daemon...
                    iobroker controller daemon started. PID: 12674
                      Nachdem ich ich nochmal etwas versucht habe ging es aufeinmal wieder einen Admin Instanz hinzuzufügen!
                      [b]root@ioBroker:/opt/iobroker# sudo iobroker stop[/b]
                      Stopping iobroker controller daemon...
                      iobroker controller daemon stopped.
                      Exit code for "killall.sh": 0
                      [b]root@ioBroker:/opt/iobroker# sudo npm install iobroker.admin --production[/b]
                      └── (empty)
                      npm ERR! code 1
                      [b]root@ioBroker:/opt/iobroker# sudo npm install iobroker.js-controller --production[/b]
                      └── iobroker.js-controller@0.16.2
                      └── (empty)
                      npm ERR! code 1
                      root@ioBroker:/opt/iobroker# ^C
                      [b]root@ioBroker:/opt/iobroker# iobroker add admin --port 8089[/b]
                      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.admin"
                      upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
                      host.ioBroker object system.adapter.admin created
                      host.ioBroker create instance admin
                      host.ioBroker object admin.0.info created
                      host.ioBroker object system.adapter.admin.upload created
                      host.ioBroker object system.adapter.admin.0.outputCount created
                      host.ioBroker object system.adapter.admin.0.inputCount created
                      host.ioBroker object system.adapter.admin.0.uptime created
                      host.ioBroker object system.adapter.admin.0.memRss created
                      host.ioBroker object system.adapter.admin.0.memHeapTotal created
                      host.ioBroker object system.adapter.admin.0.memHeapUsed created
                      host.ioBroker object system.adapter.admin.0.connected created
                      host.ioBroker object system.adapter.admin.0.alive created
                      host.ioBroker object system.adapter.admin.0 created
                      system.adapter.admin.0                 : admin       -  enabled, port: 8089, bind: 0.0.0.0, run as: admin
                      iobroker controller daemon started. PID: 13635
