    4. Installation
    5. RPi Version Node.js
    RPi Version Node.js
      Broker Tester last edited by
      Hallo...
      bin am installieren des ioBrokers auf meinem PI.
      Welche Node.js Version wird denn unterstützt? Die 10.24. anscheinend nicht.
      Wie bekomme ich die richtige Version installiert??
      pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      /usr/bin/nodejs
      /usr/bin/node
      /usr/local/bin/npm
      v10.24.0
      v10.24.0
      npm does not support Node.js v10.24.0
      You should probably upgrade to a newer version of node as we
      can't make any promises that npm will work with this version.
      You can find the latest version at https://nodejs.org/
      /usr/local/lib/node_modules/npm/lib/npm.js:32
        #unloaded = false
      SyntaxError: Invalid or unexpected token
          at Module._compile (internal/modules/cjs/loader.js:723:23)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          at Module.require (internal/modules/cjs/loader.js:692:17)
          at require (internal/modules/cjs/helpers.js:25:18)
          at module.exports (/usr/local/lib/node_modules/npm/lib/cli.js:22:15)
          at Object.<anonymous> (/usr/local/lib/node_modules/npm/bin/npm-cli.js:2:25)
          at Module._compile (internal/modules/cjs/loader.js:778:30)
      pi@raspberrypi:~ $
      pi@raspberrypi:~ $ sudo curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
      ## Installing the NodeSource Node.js 14.x repo...
      ## Populating apt-get cache...
      + apt-get update
      OK:1 http://archive.raspberrypi.org/debian buster InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Ign:3 https://pi4j.com/download v1 InRelease
      Fehl:4 https://pi4j.com/download v1 Release
        Certificate verification failed: The certificate is NOT trusted. The certificate chain uses expired certificate.  Could not handshake: Error in the certificate verification. [IP: 185.199.108.153 443]
      E: Das Depot »https://pi4j.com/download v1 Release« enthält keine Release-Datei.
      N: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
      N: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
      Error executing command, exiting
      pi@raspberrypi:~ $ sudo apt install nodejs
      Abhängigkeitsbaum wird aufgebaut.
      Statusinformationen werden eingelesen.... Fertig
      nodejs ist schon die neueste Version (10.24.0~dfsg-1~deb10u1).
      Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
        gyp libjs-inherits libjs-is-typedarray libnode-dev libssl-dev libuv1-dev
      Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
      0 aktualisiert, 0 neu installiert, 0 zu entfernen und 367 nicht aktualisiert.
      pi@raspberrypi:~ $ node -v
      v10.24.0
        Homoran Global Moderator Administrators @Broker Tester last edited by
        @broker-tester sagte in RPi Version Node.js:
        wie?
        Die momentan empfohlene Version ist node 14.x; bei anderen gewünschten Versionen in Schritt 4.1. die “14.x” gegen Y.x” austauschen.
        Quelle: https://www.iobroker.net/#de/documentation/install/linux.md
        nein, die ist viel zu alt.
        die 14 würde mit dem einfachen Einzeiler automatisch mit installiert, wenn noch kein node drauf ist.
        Ansonsten nach der verlinkten Anleitung vorgehen
          Thomas Braun Most Active @Broker Tester last edited by
          Das ist aber keine futschneue Installation da, oder?
          Da ist irgendwas 'komisches' noch mit installiert.
          Jedenfalls ist
          eine Quelle die ich noch nie gesehen habe. (Und auch falsch aufgesetzt ist, sonst gäbe es die Fehlermeldung nicht).
          Offenbar ist da auch die sog. dfsg-Version von nodejs installiert. Die ist etwas schwierig zu bändigen.
          Zuerst musst du mal schauen, wo die Quelle mit pi4j.com herkommt.
          Müsste entweder in der Datei
          /etc/apt/sources.list
          oder in einer der NAME.list-Dateien im Verzeichnis
          /etc/apt/sources.list.d/
          zu finden sein.
            Broker Tester @Thomas Braun last edited by
            @thomas-braun said in RPi Version Node.js:
            Nein, keine neue Installation. Arbeite schon damit.
            Das ist ein Paket, welches ich für Python brauche.
              @broker-tester
              Dann musst du das zunächst reparieren. Sonst wird dein Paketmanager nicht funktionieren.
                @broker-tester
                Wie kann ich das denn reparieren?
                  @broker-tester
                  Ich vermute, da ist halt eine krumme .list-Datei von
                  reingerutscht. Da ich aber nicht weiß, was das ist oder woher das kommt kann ich da auch nichts konkretes zu raten.
                  Hast du denn mal in dem Verzeichnis das ich oben genannt habe rumgeschaut?
                    @broker-tester
                    ja die Datei steht da drin. Screenshot geht leider nicht.
                    Das pi4j Paket hab ich schon deinstalliert. bekomme ich die pi4j.list irgendwie gelöscht?
                      Thomas Braun Most Active @Broker Tester last edited by Thomas Braun
                      @broker-tester
                      Leg die erstmal auf Eis.
                      Mach aus der krummen Zeile einen Kommentar. Einfach ein Hashtag in die erste Spalte eintragen. So ungefähr:
                      # ich bin ein Kommentar und werde vom Paketmanager überlesen
                        @broker-tester
                        habe keine Berechtigung zum Speichern.
                          Warum nicht?
                          sudo nano /pfad/zur/datei
                          funktioniert nicht?
                            Warum nicht?
                            funktioniert nicht?
                            Wenn man weiß wie, dann schon.....👍
                              @broker-tester
                              sudo apt update
                              liefert?
                                @broker-tester
                                sudo apt update
                                liefert?
                                sudo apt update jetzt lief es durch.
                                node -v
                                und
                                nodejs -v
                                liefern jetzt die 14.19.0
                                ich versuche jetzt mit der ioBroker Installation fortzufahren... Danke schon mal
                                  node -v
                                  und
                                  nodejs -v
                                  ein sudo apt update ändert niemals die node-Version von 10.x in 14.x
                                  Was hast du gemacht?
                                    @broker-tester
                                    Dann nochmal den kompletten Sermon:
                                      Broker Tester @Homoran last edited by
                                      @homoran said in RPi Version Node.js:
                                      node -v
                                      und
                                      nodejs -v
                                      ich habe gemacht:
                                      sudo apt-get update && sudo apt-get upgrade
                                      sudo apt install -y nodejs
                                      sudo reboot
                                        Broker Tester @Broker Tester last edited by
                                        @broker-tester
                                        die Installation lief jetzt durch.
                                        Allerdings ließ sich die Website nicht öffnen.
                                        Bin dann auf einen Workaround gestoßen:
                                        cd /opt/iobroker
                                        iobroker stop
                                        npm install iobroker.js-controller
                                        iobroker setup
                                        iobroker add admin
                                        iobroker start
                                        und was soll ich sagen, es läuft jetzt. Danke
                                        1704
