    4. auf einmal Probleme mit Lupus und Web
      decnet last edited by wendy2702
      nach der ersten Installation habe ich einige Adapter eingebunden, u.a. Lupus und Web. Jetzt kommen auf einmal ständig Fehler, das ganze System ist irgendwie sehr langsam.
      Die Adapter stehen auf grün.
      Im Anhang das Protokoll. Wo kommen die Fehler her?
      2022-02-18 15:32:35.824 - info: web.0 (1384) <==Disconnect system.user.admin from ::ffff:192.168.178.110
      2022-02-18 15:32:36.836 - warn: web.0 (1384) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
      2022-02-18 15:33:48.771 - info: web.0 (1384) <==Disconnect system.user.admin from ::ffff:192.168.178.110
      2022-02-18 15:33:49.783 - warn: web.0 (1384) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
      2022-02-18 15:36:48.533 - error: lupusec.0 (6712) Cannot find search "folder" in "system"
      2022-02-18 15:36:54.917 - error: lupusec.0 (6712) Cannot find search "folder" in "system"
      2022-02-18 15:37:05.234 - error: lupusec.0 (6712) Cannot find search "folder" in "system"
      2022-02-18 15:39:30.429 - info: host.DESKTOP-ACJ5M6C(SmartHome) stopInstance system.adapter.lupusec.0 (force=false, process=true)
      2022-02-18 15:39:30.435 - info: lupusec.0 (6712) Got terminate signal TERMINATE_YOURSELF
      2022-02-18 15:39:30.435 - info: lupusec.0 (6712) terminating
      2022-02-18 15:39:30.436 - info: lupusec.0 (6712) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-02-18 15:39:30.447 - info: host.DESKTOP-ACJ5M6C(SmartHome) stopInstance system.adapter.lupusec.0 send kill signal
      2022-02-18 15:39:30.999 - info: host.DESKTOP-ACJ5M6C(SmartHome) instance system.adapter.lupusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-02-18 15:39:33.556 - info: host.DESKTOP-ACJ5M6C(SmartHome) instance system.adapter.lupusec.0 started with pid 8256
      2022-02-18 15:39:34.937 - info: lupusec.0 (8256) starting. Version 1.3.6 in C:/iobroker/SmartHome/node_modules/iobroker.lupusec, node: v14.18.3, js-controller: 3.3.22
      2022-02-18 15:39:34.946 - info: lupusec.0 (8256) Starting Adapter lupusec.0 in version 1.3.6
      2022-02-18 15:39:34.956 - info: lupusec.0 (8256) Changed LocalLink to https://192.168.178.111:80
      2022-02-18 15:39:34.965 - info: host.DESKTOP-ACJ5M6C(SmartHome) stopInstance system.adapter.lupusec.0 (force=false, process=true)
      2022-02-18 15:39:34.967 - info: host.DESKTOP-ACJ5M6C(SmartHome) stopInstance system.adapter.lupusec.0 send kill signal
      2022-02-18 15:39:34.988 - info: lupusec.0 (8256) Got terminate signal TERMINATE_YOURSELF
      2022-02-18 15:39:34.989 - info: lupusec.0 (8256) terminating
      2022-02-18 15:39:34.990 - info: lupusec.0 (8256) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-02-18 15:39:35.045 - info: lupusec.0 (8256) Lupusec Alarmsystem 192.168.178.111 is alive
      2022-02-18 15:39:35.046 - info: lupusec.0 (8256) Checking the ioBroker Lupusec configuration
      2022-02-18 15:39:35.048 - error: lupusec.0 (8256) Cannot find search "folder" in "system"
      2022-02-18 15:39:35.234 - info: lupusec.0 (8256) Connecting to Lupusec with https://192.168.178.111:80
      2022-02-18 15:39:35.234 - info: lupusec.0 (8256) Polltime 1 sec.
      2022-02-18 15:39:35.273 - error: lupusec.0 (8256) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:39:35.273 - error: lupusec.0 (8256) Poll rythmus chnaged to 15 seconds because of error!
      2022-02-18 15:39:35.552 - info: host.DESKTOP-ACJ5M6C(SmartHome) instance system.adapter.lupusec.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-02-18 15:39:38.004 - info: host.DESKTOP-ACJ5M6C(SmartHome) instance system.adapter.lupusec.0 started with pid 8400
      2022-02-18 15:39:39.498 - info: lupusec.0 (8400) starting. Version 1.3.6 in C:/iobroker/SmartHome/node_modules/iobroker.lupusec, node: v14.18.3, js-controller: 3.3.22
      2022-02-18 15:39:39.507 - info: lupusec.0 (8400) Starting Adapter lupusec.0 in version 1.3.6
      2022-02-18 15:39:39.566 - info: lupusec.0 (8400) Lupusec Alarmsystem 192.168.178.111 is alive
      2022-02-18 15:39:39.567 - info: lupusec.0 (8400) Checking the ioBroker Lupusec configuration
      2022-02-18 15:39:39.569 - error: lupusec.0 (8400) Cannot find search "folder" in "system"
      2022-02-18 15:39:39.751 - info: lupusec.0 (8400) Connecting to Lupusec with https://192.168.178.111:80
      2022-02-18 15:39:39.752 - info: lupusec.0 (8400) Polltime 1 sec.
      2022-02-18 15:39:39.789 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:39:39.790 - error: lupusec.0 (8400) Poll rythmus chnaged to 15 seconds because of error!
      2022-02-18 15:39:54.125 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:39:54.126 - error: lupusec.0 (8400) Poll rythmus chnaged to 30 seconds because of error!
      2022-02-18 15:40:25.001 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:40:25.002 - error: lupusec.0 (8400) Poll rythmus chnaged to 45 seconds because of error!
      2022-02-18 15:41:10.894 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:41:10.894 - error: lupusec.0 (8400) Poll rythmus chnaged to 60 seconds because of error!
      2022-02-18 15:41:27.643 - warn: info.0 (7728) State "info.0.uuid" has no existing object, this might lead to an error in future versions
      2022-02-18 15:42:10.216 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:42:10.216 - error: lupusec.0 (8400) Poll rythmus chnaged to 75 seconds because of error!
      2022-02-18 15:43:02.066 - info: host.DESKTOP-ACJ5M6C(SmartHome) Updating repository "default" under "http://download.iobroker.net/sources-dist.json"
      2022-02-18 15:43:25.706 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:43:25.706 - error: lupusec.0 (8400) Poll rythmus chnaged to 90 seconds because of error!
      2022-02-18 15:44:55.237 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:44:55.237 - error: lupusec.0 (8400) Poll rythmus chnaged to 105 seconds because of error!
      2022-02-18 15:46:40.451 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:46:40.451 - error: lupusec.0 (8400) Poll rythmus chnaged to 120 seconds because of error!
      2022-02-18 15:48:40.976 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:48:40.976 - error: lupusec.0 (8400) Poll rythmus chnaged to 135 seconds because of error!
      2022-02-18 15:50:55.761 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:50:55.761 - error: lupusec.0 (8400) Poll rythmus chnaged to 150 seconds because of error!
      2022-02-18 15:52:23.923 - info: web.0 (1384) ==>Connected system.user.admin from ::ffff:192.168.178.110
      2022-02-18 15:52:24.924 - warn: web.0 (1384) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
      2022-02-18 15:52:41.999 - info: web.0 (1384) ==>Connected system.user.admin from ::ffff:192.168.178.110
      2022-02-18 15:52:43.001 - warn: web.0 (1384) State "web.0.info.connection" has no existing object, this might lead to an error in future versions
      2022-02-18 15:52:45.613 - warn: web.0 (1384) State "dev3" has no existing object, this might lead to an error in future versions
      2022-02-18 15:52:46.616 - warn: web.0 (1384) State "dev3" has no existing object, this might lead to an error in future versions
      2022-02-18 15:52:47.044 - warn: web.0 (1384) State "dev3" has no existing object, this might lead to an error in future versions
      2022-02-18 15:53:25.608 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:53:25.608 - error: lupusec.0 (8400) Poll rythmus chnaged to 165 seconds because of error!
      2022-02-18 15:56:10.844 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:56:10.844 - error: lupusec.0 (8400) Poll rythmus chnaged to 180 seconds because of error!
      2022-02-18 15:59:10.494 - error: lupusec.0 (8400) Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
      2022-02-18 15:59:10.495 - error: lupusec.0 (8400) Poll rythmus chnaged to 195 seconds because of error!
      LG
      Lutz
      MOD EDIT: Log in Code Tags gesetzt
        Thomas Braun Most Active @decnet last edited by
        @decnet
        LogFile als Text in CodeTags setzen. Danke.
        • wendy2702
          wendy2702 last edited by
          @decnet sagte in auf einmal Probleme mit Lupus und Web:
          Lupusec sieht nach verbindungsproblem aus.
          Um genaueres sagen zu können fehlen uns leider nähere Infos zu deiner Installation und HW setup.
            decnet @wendy2702 last edited by
            Bis jetzt lief das System eigentlich problemlos. Die Lupus funktioniert problemlos ohne Fehlermeldungen, seht auch im Status grün, die einzelnen Objekte der Lupus sind vorhanden und werden scheinbar aktualisiert.
            Der web-Adapter steht auf 3.4.9 und lässt sich nicht aktualisieren auf 3.4.9 .
            Das ist mein System.
                Plattform: Windows
                Betriebssystem: win32
                Architektur: x64
                CPUs: 4
                Geschwindigkeit: 1995 MHz
                Modell: Intel(R) Core(TM) i5-4590T CPU @ 2.00GHz
                RAM: 7.8 GB
                System-Betriebszeit: 00:00:00
                Node.js: v14.18.3
                NPM: 6.14.15
                Adapter-Anzahl: 396
                Datenträgergröße: 118.6 GB
                Festplatte frei: 70.7 GB
                Betriebszeit: 01:39:20
                Aktive Instanzen: 23
                Pfad: C:\iobroker\SmartHome\
            und die Fehlemeldungen von eben:
            lupusec.0
            	2022-02-18 16:58:26.165	error	Poll rythmus chnaged to 315 seconds because of error!
            lupusec.0
            	2022-02-18 16:58:26.165	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
            lupusec.0
            	2022-02-18 16:53:11.060	error	Poll rythmus chnaged to 315 seconds because of error!
            lupusec.0
            	2022-02-18 16:53:11.060	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
            lupusec.0
            	2022-02-18 16:47:55.592	error	Poll rythmus chnaged to 315 seconds because of error!
            lupusec.0
            	2022-02-18 16:47:55.592	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
            lupusec.0
            	2022-02-18 16:42:40.722	error	Poll rythmus chnaged to 315 seconds because of error!
            lupusec.0
            	2022-02-18 16:42:40.722	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
            info.0
            	2022-02-18 16:41:27.646	warn	State "info.0.uuid" has no existing object, this might lead to an error in future versions
            lupusec.0
            	2022-02-18 16:37:25.842	error	Poll rythmus chnaged to 315 seconds because of error!
            lupusec.0
            	2022-02-18 16:37:25.842	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
            lupusec.0
            	2022-02-18 16:32:10.804	error	Poll rythmus chnaged to 315 seconds because of error!
            lupusec.0
            	2022-02-18 16:32:10.804	error	Error: Error in deviceGenericGet (/action/deviceListGet) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
            lupusec.0
            	2022-02-18 16:27:10.065	error	Poll rythmus chnaged to 300 seconds because of error!
            lupusec.0
            	2022-02-18 16:27:10.065	error	Error: Error in deviceGenericPost (/action/deviceEditThermoGet - ZS:1b8801) : RequestError: Error: Client network socket disconnected before secure TLS connection was established
            LG
            Lutz
