    4. install" "iobroker.js-controller ERR 1
      Jonnyhottub last edited by wendy2702
      I have a windows 10 iobroker system that has been working perfectly for over 1 year.
      Recently I updated adaptors etc
      node -v 17.5.0
      npm -v 8.5.1
      cannot install iobroker.js-controller@3.3.22
      C:\Program Files\iobroker\BarnLoxone>npm install iobroker.js-controller
      npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm WARN deprecated tough-cookie@1.2.0: ReDoS vulnerability parsing Set-Cookie https://nodesecurity.io/advisories/130
      npm ERR! code 1
      npm ERR! path C:\Program Files\iobroker\BarnLoxone\node_modules\iobroker.vis
      npm ERR! command failed
      npm ERR! command C:\WINDOWS\system32\cmd.exe /d /s /c node main.js --install
      npm ERR! node:internal/modules/cjs/loader:936
      npm ERR!   throw err;
      npm ERR!   ^
      npm ERR!
      npm ERR! Error: Cannot find module 'C:\Program Files\iobroker\BarnLoxone\node_modules\iobroker.js-controller\lib\exitCodes'
      npm ERR! Require stack:
      npm ERR! - C:\Program Files\iobroker\BarnLoxone\node_modules\@iobroker\adapter-core\build\index.js
      npm ERR! - C:\Program Files\iobroker\BarnLoxone\node_modules\iobroker.vis\main.js
      npm ERR!     at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)
      npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:778:27)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:999:19)
      npm ERR!     at require (node:internal/modules/cjs/helpers:102:18)
      npm ERR!     at Object.<anonymous> (C:\Program Files\iobroker\BarnLoxone\node_modules\@iobroker\adapter-core\build\index.js:37:54)
      npm ERR!     at Module._compile (node:internal/modules/cjs/loader:1097:14)
      npm ERR!     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1151:10)
      npm ERR!     at Module.load (node:internal/modules/cjs/loader:975:32)
      npm ERR!     at Function.Module._load (node:internal/modules/cjs/loader:822:12)
      npm ERR!     at Module.require (node:internal/modules/cjs/loader:999:19) {
      npm ERR!   code: 'MODULE_NOT_FOUND',
      npm ERR!   requireStack: [
      npm ERR!     'C:\\Program Files\\iobroker\\BarnLoxone\\node_modules\\@iobroker\\adapter-core\\build\\index.js',
      npm ERR!     'C:\\Program Files\\iobroker\\BarnLoxone\\node_modules\\iobroker.vis\\main.js'
      npm ERR!   ]
      npm ERR! }
      npm ERR!
      npm ERR! Node.js v17.5.0
      npm ERR!     C:\Users\jonat\AppData\Local\npm-cache\_logs\2022-02-20T10_08_53_514Z-debug-0.log
      ioboker admin is not available
      and I am going around in circles
      MOD EDIT: Put logfile into Code Tags
      Qix- created this issue in visionmedia/debug
      closed ReDos Vulnerability Regression Visibility Notice #797
      • wendy2702
        wendy2702 @Jonnyhottub last edited by
        @jonnyhottub sagte in install" "iobroker.js-controller ERR 1:
        node -v 17.5.0
        npm -v 8.5.1
        These Versions are not supported.
        With JS3.x the recommendation is NodeJS 14 and NPM 6
