    4. Node-Red
    5. Mit amazon-echo tuya lokal steuern
      kla960 last edited by
      Bin schon relativ weit.
      Nutze
      • node-red-contrib-amazon-echo für die Lokale Echo integration
      • node-red-contrib-color-convert für RGB nach HSV, da der hue wert aus amazon-echo mir nicht so zusagt
        zwei tuya rgb LED Strips Datenpunkt sind im ioBroker eingelesen
      An/aus ist jetzt nicht so das Problem.
      Farben setzt man über z.B. für rot 100% Helligkeit:
      color_data 000003e803e8
      hue 0000 möglicher Bereich 0 - 360
      sat 03e8 möglicher Bereich 0 - 1000
      value 03e8 möglicher Bereich0 - 1000
      kann schon mal die Ausgabe aus dem echo node in die Bereiche bringen
              "id": "c898591b.0e6fe8",
              "type": "tab",
              "label": "Test Tuya",
              "disabled": false,
              "info": ""
              "id": "32ab7202.1284ee",
              "type": "debug",
              "z": "c898591b.0e6fe8",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "targetType": "full",
              "statusVal": "",
              "statusType": "auto",
              "x": 250,
              "y": 440,
              "wires": []
              "id": "b7ed32a5.e1d11",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "move",
                      "p": "rgb",
                      "pt": "msg",
                      "to": "payload",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 240,
              "y": 220,
              "wires": [
                      "d84bff51.26272"
              "id": "6fb8b57d.2a653c",
              "type": "link in",
              "name": "Test Tuya",
              "links": [
                  "d06fcf08.164fd"
              "x": 115,
              "y": 220,
              "wires": [
                      "32ab7202.1284ee",
                      "b7ed32a5.e1d11"
              "id": "d84bff51.26272",
              "type": "color-convert",
              "input": "rgb",
              "output": "hsv",
              "outputType": "object",
              "scaleInput": false,
              "x": 410,
              "y": 220,
              "wires": [
                      "cd2bfe21.53877"
              "id": "b4f125ae.2dfb88",
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "false",
              "statusVal": "",
              "x": 910,
              "y": 220,
              "wires": []
              "id": "cd2bfe21.53877",
              "type": "range",
              "minin": "0",
              "maxin": "100",
              "minout": "0",
              "maxout": "1000",
              "action": "scale",
              "round": true,
              "property": "payload.saturation",
              "name": "saturation",
              "x": 580,
              "y": 220,
              "wires": [
                      "5fe5b78e.4c1578"
              "id": "5fe5b78e.4c1578",
              "type": "range",
              "minin": "0",
              "maxin": "100",
              "minout": "0",
              "maxout": "1000",
              "action": "scale",
              "round": true,
              "property": "payload.value",
              "name": "value",
              "x": 750,
              "y": 220,
              "wires": [
                      "b4f125ae.2dfb88"
      muss jetzt aber noch die payload z.B. für rot
      {"hue":0,"saturation":1000,"value":1000}
      in das Tuya color_data 000003e803e8 sting bringen.
      Werde dann mal googlen. Wenn Ihr Ideen habt, nur zu 😊
        kla960 @kla960 last edited by
        So geht es. In der Alexa bekommt sogar Änderungen bei IR Fernbedienung mit.
                "type": "tab",
                "label": "Lena Tuya",
                "disabled": false,
                "info": ""
                "type": "link in",
                "links": [
                    "d06fcf08.164fd"
                "x": 115,
                "y": 280,
                "wires": [
                        "24745777.87ea88",
                        "2d3cb289.c9ceae"
                "id": "24745777.87ea88",
                "type": "switch",
                "name": "colormode",
                "property": "colormode",
                "propertyType": "msg",
                "rules": [
                        "t": "eq",
                        "v": "hs",
                        "vt": "str"
                        "t": "eq",
                        "v": "ct",
                        "vt": "str"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 250,
                "y": 220,
                "wires": [
                        "5efba10b.dce29"
                        "8f00528b.9763d"
                "id": "5efba10b.dce29",
                "type": "range",
                "minin": "0",
                "maxin": "254",
                "minout": "0",
                "maxout": "1000",
                "action": "scale",
                "round": true,
                "property": "sat",
                "x": 480,
                "y": 180,
                "wires": [
                        "7bc350fb.2de61"
                "id": "7bc350fb.2de61",
                "type": "range",
                "minin": "0",
                "maxin": "254",
                "minout": "0",
                "maxout": "1000",
                "action": "scale",
                "round": true,
                "property": "bri",
                "name": "value",
                "x": 630,
                "y": 180,
                "wires": [
                        "e2b9d916.379268"
                "id": "e2b9d916.379268",
                "type": "range",
                "minin": "0",
                "maxin": "65563",
                "minout": "0",
                "maxout": "360",
                "action": "scale",
                "round": true,
                "property": "hue",
                "name": "hue",
                "x": 770,
                "y": 180,
                "wires": [
                        "86ddc18c.0f5cd"
                "id": "86ddc18c.0f5cd",
                "type": "function",
                "name": "joinToHexString",
                "func": "msg.bri = toHex(msg.bri)\nmsg.sat = toHex(msg.sat)\nmsg.hue = toHex(msg.hue)\n\nlet arr = [msg.hue, msg.sat, msg.bri];\nmsg.payload = arr.join(\"\");\nreturn msg;\n\nfunction toHex(decimal) { // This converts a number to a string Hex AND adds padding zeros to a set number of characters.\n    return (decimal + Math.pow(16, 4)).toString(16).slice(-4)\n}\n",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 940,
                "y": 180,
                "wires": [
                        "68a011f.1c0b6f"
                "id": "8f00528b.9763d",
                "type": "range",
                "minin": "0",
                "maxin": "254",
                "minout": "0",
                "maxout": "1000",
                "action": "scale",
                "round": true,
                "property": "bri",
                "name": "value",
                "x": 470,
                "y": 260,
                "wires": [
                        "1cb5e65b.c81d1a"
                "id": "1cb5e65b.c81d1a",
                "type": "function",
                "func": "msg.bri = toHex(msg.bri)\nmsg.sat = \"0000\"\nmsg.hue = \"0000\"\n\nlet arr = [msg.hue, msg.sat, msg.bri];\nmsg.payload = arr.join(\"\");\nreturn msg;\n\nfunction toHex(decimal) { // This converts a number to a string Hex AND adds padding zeros to a set number of characters.\n    return (decimal + Math.pow(16, 4)).toString(16).slice(-4)\n}\n",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 940,
                "y": 260,
                "wires": [
                        "68a011f.1c0b6f"
                "id": "2d3cb289.c9ceae",
                "type": "switch",
                "name": "on/off",
                "property": "payload",
                "rules": [
                        "t": "eq",
                        "v": "on",
                        "vt": "str"
                        "t": "eq",
                        "v": "off",
                        "vt": "str"
                "checkall": "true",
                "repair": false,
                "outputs": 2,
                "x": 230,
                "y": 340,
                "wires": [
                        "7478ffb4.d10b8"
                        "e6f736ec.004098"
                "id": "7478ffb4.d10b8",
                "type": "change",
                "name": "true",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "true",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 390,
                "y": 320,
                "wires": [
                        "4be3cd26.926364"
                "id": "e6f736ec.004098",
                "type": "change",
                "name": "flase",
                "rules": [
                        "t": "set",
                        "p": "payload",
                        "pt": "msg",
                        "to": "false",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 390,
                "y": 360,
                "wires": [
                        "4be3cd26.926364"
                "id": "4be3cd26.926364",
                "type": "ioBroker out",
                "name": "Lena Tuya LED Strip switch_led",
                "topic": "tuya.0.08200118e868e759568a.20",
                "ack": "false",
                "autoCreate": "false",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 990,
                "y": 360,
                "wires": []
                "id": "68a011f.1c0b6f",
                "name": "Lena Tuya LED Strip color_data",
                "topic": "tuya.0.08200118e868e759568a.24",
                "ack": "false",
                "stateName": "",
                "role": "",
                "payloadType": "",
                "readonly": "",
                "stateUnit": "",
                "stateMin": "",
                "stateMax": "",
                "x": 1190,
                "y": 220,
                "wires": []
                "id": "b766d64f.558e38",
                "type": "ioBroker in",
                "name": "color_mode",
                "payloadType": "value",
                "onlyack": true,
                "func": "all",
                "gap": "",
                "fireOnStart": "false",
                "x": 250,
                "y": 780,
                "wires": [
                        "a3eb0958.b769e8"
                "id": "52f07af3.8b1f44",
                "name": "switch_led",
                "onlyack": true,
                "func": "all",
                "gap": "",
                "x": 240,
                "y": 600,
                "wires": [
                        "c275b713.8d6788"
                "id": "c275b713.8d6788",
                "type": "change",
                "name": "on",
                "rules": [
                        "t": "move",
                        "p": "payload",
                        "pt": "msg",
                        "to": "payload.on",
                        "tot": "msg"
                        "t": "set",
                        "p": "payload.nodeid",
                        "pt": "msg",
                        "to": "6db05f00.c9783",
                        "tot": "str"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 690,
                "y": 600,
                "wires": [
                        "81e46aff.74a0d8"
                "id": "a3eb0958.b769e8",
                "type": "split",
                "name": "",
                "splt": "4",
                "spltType": "len",
                "arraySplt": "1",
                "arraySpltType": "len",
                "stream": false,
                "addname": "",
                "x": 390,
                "y": 780,
                "wires": [
                        "5177cbe7.485ab4"
                "id": "5177cbe7.485ab4",
                "type": "join",
                "name": "",
                "mode": "custom",
                "build": "array",
                "key": "topic",
                "joiner": "\\n",
                "joinerType": "str",
                "accumulate": false,
                "timeout": "",
                "count": "3",
                "reduceRight": false,
                "reduceExp": "",
                "reduceInit": "",
                "reduceInitType": "num",
                "reduceFixup": "",
                "x": 510,
                "y": 780,
                "wires": [
                        "92af89f0.547b48"
                "id": "92af89f0.547b48",
                "type": "change",
                "name": "",
                "rules": [
                        "t": "move",
                        "p": "payload.0",
                        "pt": "msg",
                        "to": "hue",
                        "tot": "msg"
                        "t": "move",
                        "p": "payload.1",
                        "pt": "msg",
                        "to": "sat",
                        "tot": "msg"
                        "t": "move",
                        "p": "payload.2",
                        "pt": "msg",
                        "to": "bri",
                        "tot": "msg"
                        "t": "delete",
                        "p": "payload",
                        "pt": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 670,
                "y": 780,
                "wires": [
                        "4e112b70.633bc4"
                "id": "8eb7f14.6ee0c1",
                "type": "comment",
                "name": "set Tuya",
                "info": "",
                "x": 240,
                "y": 100,
                "wires": []
                "id": "cfb4977b.415fd8",
                "type": "comment",
                "name": "get Tuya",
                "info": "",
                "x": 240,
                "y": 480,
                "wires": []
                "id": "9826af61.305f2",
                "type": "range",
                "minin": "0",
                "maxin": "360",
                "minout": "0",
                "maxout": "65563",
                "action": "scale",
                "round": true,
                "property": "hue",
                "name": "hue",
                "x": 250,
                "y": 680,
                "wires": [
                        "a3add1ea.138f1"
                "id": "4e112b70.633bc4",
                "type": "function",
                "name": "",
                "func": "msg.hue = parseInt(msg.hue,16);\nmsg.sat = parseInt(msg.sat,16);\nmsg.bri = parseInt(msg.bri,16)\nreturn msg;",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "libs": [],
                "x": 860,
                "y": 780,
                "wires": [
                        "9826af61.305f2"
                "id": "a3add1ea.138f1",
                "type": "range",
                "minin": "0",
                "maxin": "1000",
                "minout": "0",
                "maxout": "254",
                "action": "scale",
                "round": true,
                "property": "sat",
                "x": 380,
                "y": 680,
                "wires": [
                        "81962849.8fc1f8"
                "id": "81962849.8fc1f8",
                "type": "range",
                "minin": "0",
                "maxin": "1000",
                "minout": "0",
                "maxout": "254",
                "action": "scale",
                "round": true,
                "property": "bri",
                "name": "value",
                "x": 510,
                "y": 680,
                "wires": [
                        "b5006a27.98cc48"
                "id": "81e46aff.74a0d8",
                "type": "link out",
                "name": "Lena Tuya in",
                "links": [
                    "4ec4c5f2.23c2dc"
                "x": 895,
                "y": 640,
                "wires": []
                "id": "b5006a27.98cc48",
                "type": "change",
                "name": "on",
                "rules": [
                        "t": "set",
                        "pt": "msg",
                        "tot": "str"
                        "t": "move",
                        "p": "bri",
                        "pt": "msg",
                        "to": "payload.bri",
                        "tot": "msg"
                        "t": "move",
                        "p": "hue",
                        "pt": "msg",
                        "to": "payload.hue",
                        "tot": "msg"
                        "t": "move",
                        "p": "sat",
                        "pt": "msg",
                        "to": "payload.sat",
                        "tot": "msg"
                "action": "",
                "property": "",
                "from": "",
                "to": "",
                "reg": false,
                "x": 690,
                "y": 680,
                "wires": [
                        "81e46aff.74a0d8"
        1.0k
