    5. (SOLVED) Create Alias in TypeScript
    • U
      uwe72 last edited by uwe72
      Hallo, kann mir jemand diese funktionierende JS-Function in TypeScript zu übersetzen? Ich kriege es nicht hin:
      const idAlias = "test12345";
      const idOrigin = "deconz.1.Lights.2.on";
      function createAlias(idSrc, idDst, typeAlias) {
         if(!getObject(idDst)) {
            var obj = {};
            obj.type = 'state';
            obj.common = getObject(idSrc).common;
            if(typeAlias) obj.common.type = typeAlias;
            obj.common.alias = {};
            obj.common.alias.id = idSrc;
            setObject(idDst, obj);
         } //else log ("Alias schon vorhanden: " + idDst, 'warn');
      createAlias(idOrigin, idAlias, 'boolean');
      DANKE !!!!
      javascript.0 (4416) script.js.common.#RGB#.CreateAliase: TypeScript compilation failed: obj.type = 'state'; ^ ERROR: Property 'type' does not exist on type '{}'. obj.common = getObject(idSrc).common; ^ ERROR: Property 'common' does not exist on type '{}'. obj.common.type = typeAlias; ^ ERROR: Property 'common' does not exist on type '{}'. obj.common.alias = {}; ^ ERROR: Property 'common' does not exist on type '{}'. obj.common.alias.id = idSrc; ^ ERROR: Property 'common' does not exist on type '{}'. setObject(idDst, obj); ^ ERROR: Argument of type '{}' is not assignable to parameter of type '(Omit<StateObject, "acl" | "_id"> & { _id?: string; acl?: StateACL; }) | (Omit<InstanceObject, "acl" | "_id"> & { _id?: string; acl?: ObjectACL; }) | ... 10 more ... | (Omit<...> & { ...; })'. Type '{}' is not assignable to type 'Omit<OtherObject, "acl" | "_id"> & { _id?: string; acl?: ObjectACL; }'. Type '{}' is missing the following properties from type 'Omit<OtherObject, "acl" | "_id">': common, type, native
        CruziX last edited by CruziX
        @uwe72
        type TAlias = {
        type TCommon = {
         type?: string;
         alias?: TAlias;
        type TCustomObject ={
         type: string;
         common: TCommon;
        function createAlias(idSrc: string, idDst: string, typeAlias: string) {
              var obj: TCustomObject = {
         type: 'state',
         common: {
        type: '',
        alias: {
        Kurz mitm Handy getippt, vielleicht hilfts ja
        • U
          uwe72 @CruziX last edited by uwe72
          @cruzix bin dir so dankbar, dass Du mein Problem angeschaut hast!!
          Leider gibts noch irgendwie ein "Cast-Problem":
            "_id": "alias.0.Light.Device_1.WORKING",
            "type": "state",
            "common": {
              "alias": {
                "id": "admin.0.connected"
              "name": "WORKING",
              "role": "indicator.working",
              "type": "boolean"
            "native": {}
          type TAlias = {
          type TCommon = {
              type: string;
              alias: TAlias;
              type: string;
              common: TCommon;
              if (!getObject(idDst)) {
                      type: '',
                      common: {
                          type: '',
                          alias: {
                  obj.type = 'state';
          Den ersten Fehler gibts an dieser Stelle (Zeile 44):
          Type '{ [x: string]: any; [x: number]: any; }' is missing the following properties from type 'TCommon': type, alias(2739)
          (property) common: TCommon
            CruziX @uwe72 last edited by CruziX
            @uwe72 ja, verstehe was das Problem ist, habe in meinem vorherigen Post den Common type mit optionalen Properties ergänzt und die zeile entfernt wo alias mit {} gesetzt wird. Sollte nun klappen
            • U
              @cruzix
              Danke dir!! Das TypeScript passt nun, irgendwie akzeptiert die setObject Methode noch nicht den Parameter:
              type TAlias = {
              type TCommon = {
               type?: string;
               alias?: TAlias;
               type: string;
               common: TCommon;
                       type: 'state',
                      common: {
                      type: '',
                      alias: {
              //createAlias("deconz.1.Lights.6.on", "alias.0.rgb.Z005.on", "boolean");
              Argument of type 'TCustomObject' is not assignable to parameter of type '(Omit<StateObject, "acl" | "_id"> & { _id?: string; acl?: StateACL; }) | (Omit<InstanceObject, "acl" | "_id"> & { _id?: string; acl?: ObjectACL; }) | ... 10 more ... | (Omit<...> & { ...; })'.
                Type 'TCustomObject' is not assignable to type 'Omit<OtherObject, "acl" | "_id"> & { _id?: string; acl?: ObjectACL; }'.
                  Property 'native' is missing in type 'TCustomObject' but required in type 'Omit<OtherObject, "acl" | "_id">'.(2345)
              (local var) obj: TCustomObject
              • U
                uwe72 @uwe72 last edited by uwe72
                Gibts wirklich niemand von den ioBroker-Profis wo dieses Thema lösen können, eigentlich sollte es ja nur eine Kleinigkeit sein?
                Wäre wirklich sehr dankbar!
                LG
                • U
                  OK i think i have a working solution now:
                  function createAlias(originalDatenpunkt, aliasDatenpunkt) {
                      setObject(aliasDatenpunkt, {
                          type: 'state',
                              common: {
                              type: getObject(originalDatenpunkt).common.type,
                              unit: getObject(originalDatenpunkt).common.unit,
                              read: true,
                              write: true,
                              role: getObject(originalDatenpunkt).common.role,
                              alias: {
                          native: {}
                  var originalDatenpunkt = "deconz.1.Lights.2.on";
                  var aliasDatenpunkt = "alias.0.test.mytest12_new2_NG";
                  createAlias(originalDatenpunkt, aliasDatenpunkt);
                  • AlCalzone
                    AlCalzone Developer @uwe72 last edited by
                    @uwe72 sagte in (SOLVED) Create Alias in TypeScript:
                    Ja, stand auch in der von dir zitierten Fehlermeldung 🙂
                    Property 'native' is missing in type 'TCustomObject' but required [...]
                    • U
                      uwe72 @AlCalzone last edited by
                      @alcalzone
                      Wie ist deine Meinung dann zu
                      https://forum.iobroker.net/topic/57264/typescript-kompilierfehler-setobject/5
                      Da gibts auch eine Fehlermeldung, für die "ich" eigentlich nicht verantwortlich sein kann?
