    4. Log Fehler gelöst
    Log Fehler gelöst
    • O
      Opa75+ last edited by Opa75+
      Habe Fehler im Log aufgezeigt bekommen. Wie kann man diese Fehler beseitigen?
      Ich bitte um Hilfe.
      Log Fehler 3-3-2022.pages
      Thomas Braun O 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Opa75+ last edited by
        @opa75
        Den Anhang kann man nicht lesen.
        Auszüge aus dem LogFile bitte als Text in CodeTags posten.
        O 1 Reply Last reply Reply Quote 1
        • O
          Opa75+ @Opa75+ last edited by
          @opa75 Nun Log-File im txt-Format
          Log-Fehler 3-3-2022.rtf
          • O
            Opa75+ @Thomas Braun last edited by
            @thomas-braun passt das so?
            2022-03-03 10:31:30.845 - info: javascript.0 (552) Start javascript script.js.common.Trash-Kalender
            2022-03-03 10:31:30.851 - error: javascript.0 (552) script.js.common.Trash-Kalender compile failed:
            at script.js.common.Trash-Kalender:24
            2022-03-03 10:31:30.853 - error: javascript.0 (552)
            2022-03-03 10:31:30.854 - error: javascript.0 (552) ^
            2022-03-03 10:31:30.854 - error: javascript.0 (552) SyntaxError: Unexpected token '<'
            2022-03-03 10:31:30.855 - error: javascript.0 (552) at new Script (vm.js:102:7)
            2022-03-03 10:31:30.855 - error: javascript.0 (552) at Object.createScript (vm.js:262:10)
            2022-03-03 10:31:30.856 - error: javascript.0 (552) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1520:28)
            2022-03-03 10:31:30.856 - error: javascript.0 (552) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1769:37)
            2022-03-03 10:31:30.856 - error: javascript.0 (552) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1870:17
            2022-03-03 10:31:30.857 - error: javascript.0 (552) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1345:17)
            2022-03-03 10:31:30.857 - error: javascript.0 (552) at processImmediate (internal/timers.js:466:21)
            2022-03-03 10:33:06.088 - info: javascript.0 (552) Stop script script.js.common.Trash-Kalender
            2022-03-03 10:33:06.107 - info: javascript.0 (552) Start javascript script.js.common.Trash-Kalender
            2022-03-03 10:33:06.119 - error: javascript.0 (552) script.js.common.Trash-Kalender compile failed:
            2022-03-03 10:33:06.120 - error: javascript.0 (552)
            2022-03-03 10:33:06.122 - error: javascript.0 (552) ^
            2022-03-03 10:33:06.122 - error: javascript.0 (552) SyntaxError: Unexpected token '<'
            2022-03-03 10:33:06.123 - error: javascript.0 (552) at new Script (vm.js:102:7)
            2022-03-03 10:33:06.125 - error: javascript.0 (552) at Object.createScript (vm.js:262:10)
            2022-03-03 10:33:06.126 - error: javascript.0 (552) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1520:28)
            2022-03-03 10:33:06.126 - error: javascript.0 (552) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1769:37)
            2022-03-03 10:33:06.127 - error: javascript.0 (552) at /opt/iobroker/node_modules/iobroker.javascript/main.js:1870:17
            2022-03-03 10:33:06.128 - error: javascript.0 (552) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1345:17)
            2022-03-03 10:33:06.129 - error: javascript.0 (552) at processImmediate (internal/timers.js:466:21)
            2022-03-03 10:34:27.485 - info: web.0 (20355) <== Disconnect system.user.admin from ::ffff:192.168.1.173 iqontrol.0
              @opa75
              In dem skript Trash-Kalender ist offenbar ein Fehler.
                in zeile 24
                • O
                  @thomas-braun Dann werde ich diesen neu installieren.
                  Danke für die Info
                    Homoran Global Moderator Administrators @Opa75+ last edited by
                    @opa75 sagte in Log Fehler:
                    NEIN!
                    nicht der Adapter hat ein Problem.
                    Du hast ein Script mit Namen trashkalender
                    dort ist in Zeile 24 ein Fehler
                    • O
                      @opa75 Was bedeutet denn dieser Log-Fehler:
                      Adapter Hue => "Could not poll all: read ECONNRESET"
                        arteck Developer Most Active @Opa75+ last edited by
                        @opa75 die hue bridge ist nicht erreichbar
                        • O
                          Opa75+ @Homoran last edited by
                          @homoran Fehler war, so glaube ich, dass die Tagesvorschau auf 30 eingestellt war. Habe auf 31 erhöht.
                          495
