    4. Openuv killt sich regelmässig
    • Neues Video auf YouTube
    • Negalein
      Hi
      Bei mir killt sich regelmäßig der OpenUV-Adapter.
      Sieht jemand warum das so ist?
          at Request._callback (/opt/iobroker/node_modules/iobroker.openuv/main.js:175:50)
          at Request.self.callback (/opt/iobroker/node_modules/iobroker.openuv/node_modules/request/request.js:185:22)
          at Request.<anonymous> (/opt/iobroker/node_modules/iobroker.openuv/node_modules/request/request.js:1154:10)
          at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.openuv/node_modules/request/request.js:1076:12)
      2022-03-03 23:26:35.256  - error: openuv.0 (1471593) Cannot read property 'uv' of undefined
      2022-03-03 23:26:35.258  - info: openuv.0 (1471593) cleaned everything up...
      2022-03-03 23:26:35.259  - info: openuv.0 (1471593) terminating
      2022-03-03 23:26:35.259  - warn: openuv.0 (1471593) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-03-03 23:26:35.882  - error: host.ioBroker instance system.adapter.openuv.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-03-03 23:26:35.883  - info: host.ioBroker Restart adapter system.adapter.openuv.0 because enabled
      2022-03-03 23:27:06.068  - info: host.ioBroker instance system.adapter.openuv.0 started with pid 1471624
      2022-03-03 23:27:06.427  - debug: openuv.0 (1471624) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2022-03-03 23:27:06.448  - debug: openuv.0 (1471624) Objects client ready ... initialize now
      2022-03-03 23:27:06.448  - debug: openuv.0 (1471624) Objects create System PubSub Client
      2022-03-03 23:27:06.449  - debug: openuv.0 (1471624) Objects create User PubSub Client
      2022-03-03 23:27:06.449  - debug: openuv.0 (1471624) Objects client initialize lua scripts
      2022-03-03 23:27:06.460  - debug: openuv.0 (1471624) Objects connected to redis: 0.0.0.0:9001
      2022-03-03 23:27:06.463  - debug: openuv.0 (1471624) objectDB connected
      2022-03-03 23:27:06.464  - debug: openuv.0 (1471624) Redis States: Use Redis connection: 0.0.0.0:9000
      2022-03-03 23:27:06.470  - debug: openuv.0 (1471624) States create System PubSub Client
      2022-03-03 23:27:06.471  - debug: openuv.0 (1471624) States create User PubSub Client
      2022-03-03 23:27:06.481  - debug: openuv.0 (1471624) States connected to redis: 0.0.0.0:9000
      2022-03-03 23:27:06.481  - debug: openuv.0 (1471624) statesDB connected
      2022-03-03 23:27:06.707  - info: openuv.0 (1471624) starting. Version 0.0.5 in /opt/iobroker/node_modules/iobroker.openuv, node: v14.17.1, js-controller: 3.3.22
      2022-03-03 23:27:06.816  - info: openuv.0 (1471624) state openuv.0.UV changed: 0 (ack = true)
      2022-03-03 23:27:06.821  - info: openuv.0 (1471624) state openuv.0.UV_Max changed: 0 (ack = true)
      2022-03-03 23:27:07.344  - error: openuv.0 (1471624) uncaught exception: Cannot read property 'uv' of undefined
      2022-03-03 23:27:07.344  - error: openuv.0 (1471624) TypeError: Cannot read property 'uv' of undefined
      2022-03-03 23:27:07.344  - error: openuv.0 (1471624) Cannot read property 'uv' of undefined
      2022-03-03 23:27:07.347  - info: openuv.0 (1471624) cleaned everything up...
      2022-03-03 23:27:07.347  - info: openuv.0 (1471624) terminating
      2022-03-03 23:27:07.347  - warn: openuv.0 (1471624) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2022-03-03 23:27:08.055  - error: host.ioBroker instance system.adapter.openuv.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2022-03-03 23:27:08.056  - info: host.ioBroker Restart adapter system.adapter.openuv.0 because enabled
      2022-03-03 23:27:08.056  - warn: host.ioBroker Do not restart adapter system.adapter.openuv.0 because restart loop detected
      • simatec
        simatec Developer Most Active @Negalein last edited by
        @negalein Der Adapter wird nicht gepflegt.
        Ich habe dafür den uv-protect Adapter geschrieben. Der ist aktuell und in der Repo
        Negalein 1 Reply Last reply Reply Quote 1
        • Negalein
          Negalein Global Moderator @simatec last edited by
          @simatec sagte in Openuv killt sich regelmässig:
          Merci
          werd ich gleich installieren.
