    4. Installation
    5. [erledigt] Fehlermeldungen und Tab-Benutzer bring Absturz
      TT-Tom last edited by TT-Tom
      ich habe die Installation auf einen Raspi 4 8Gb nach der Anleitung "Einfacher geht's nicht" durchgeführt. Als OS habe ich Bullseye 64 bit Lite genutzt. Anschliessend gleich aktualisiert und neu gebootet. Danach den Einzeiler und es kamen diverse Warnungen bei der Installation von IoBroker.
      In file included from ../../nan/nan.h:58,
                       from ../src/main.cpp:3:
      /home/pi/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
        793 |       (node::addon_register_func) (regfunc),                          \
      /home/pi/.cache/node-gyp/14.19.0/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
        827 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
      ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’
         42 | NODE_MODULE(diskusage, Init)
                       from ../src/unix_dgram.cc:5:
      ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’
        404 | NODE_MODULE(unix_dgram, Initialize)
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:78:51: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:135:53: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:175:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:215:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:271:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        271 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:316:50: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        316 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:366:58: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        366 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
      ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../src/serialport.cpp:412:52: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
        412 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
      ../src/serialport.cpp: At global scope:
      ../src/serialport.cpp:433:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
        433 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
      ../src/serialport.cpp:452:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
        452 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
      In file included from ../../../nan/nan.h:58,
                       from ../src/./serialport.h:13,
                       from ../src/serialport.cpp:1:
      /home/pi/.cache/node-gyp/14.19.0/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
      ../src/serialport.cpp:486:1: note: in expansion of macro ‘NODE_MODULE’
        486 | NODE_MODULE(serialport, init);
      ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:
      ../src/serialport_unix.cpp:179:82: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=]
        179 |     snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path);
      ../src/serialport_unix.cpp:179:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024
      ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:
      ../src/serialport_unix.cpp:89:84: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=]
         89 |     snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path);
      ../src/serialport_unix.cpp:89:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024
      nach der Installation kam trotzdem die Fertigmeldung zum Einloggen im Browser.
      Dort habe ich das Willkommensetup durchgeführt und bin auf die Oberfläche gekommen. Jetzt kommt aber beim klicken auf Tab "Benutzer" es zum Absturz
      den Rest in IoBroker kann ich aber bedienen. Bevor ich jetzt weiter mache, wie kann ich dieses Problem lösen.
      Eine komplette Neuinstallation habe ich schon durchgeführt, wieder das gleiche Bild.
      Danke für eure Hilfe
      Gruß Tom
      • wendy2702
        wendy2702 @TT-Tom last edited by
        @tt-tom Mach es bitte so wie es im Screenshot steht: Issue beim Admin auf GitHub öffnen.
          TT-Tom @wendy2702 last edited by
          @wendy2702 ich habe noch kein Account bei GitHub. Muss ich mich erstmal belesen. Ich habe jetzt doch schon angefangen und Adapter installiert. Der Fehler ist jetzt nicht mehr reproduzierbar. Werde aber bei erneuten auftreten bei GitHub ein Issues erstellen.
          Eine Frage noch zu den Meldungen bei der Installation, soll ich diese bei Github posten. Wenn ja wo bzw. wem?
          Gruß Tom
          wendy2702 haus-automatisierung 2 Replies Last reply Reply Quote 0
          • wendy2702
            @tt-tom Die Meldungen bei der Installation sind normal.
              @wendy2702 Danke für deine Rückmeldung.
              • haus-automatisierung
                haus-automatisierung Developer Most Active @TT-Tom last edited by
                @tt-tom sagte in [erledigt] Fehlermeldungen und Tab-Benutzer bring Absturz:
                Gibts schon: https://github.com/ioBroker/ioBroker.admin/issues/1331
                KanzuTachiba created this issue in ioBroker/ioBroker.admin
                closed #tab-users not working #1331
                absturz installationsprobleme tab benutzer
