    4. [Fixed] Frisches ioBroker, Installation homekit2 schlägt fehl
    • G
      Gorg last edited by
      habe letzte Woche nach einem SD-Karten Problem den Raspi neu installiert und iobroker (tolles Projekt) ebenfalls ganz frisch installiert.
      Als letztes wollte ich das Homekit2 nachziehen, aber leider bekomme ich folgende Fehlermeldung.
      Wie gesagt, alles frisch installiert !?
      Eine Idee ?
      Gorg
      $ ./iobroker add homekit2
      npm install iobroker.homekit2 --production --prefix "/opt/iobroker" (System call)
      In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: No such file or directory
       #include <dns_sd.h>
      compilation terminated.
      make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Error 1
      gyp
      ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack     at emitTwo (events.js:87:13)
      gyp ERR! stack     at ChildProcess.emit (events.js:172:7)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
      gyp ERR! System Linux 4.4.38-v7+gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/mdns
      gyp ERR! node -v v4.8.0
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      npm
       ERR! Linux 4.4.38-v7+
      npm
       ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit2" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.0
      npm ERR! npm  v2.15.11
      npm ERR! code ELIFECYCLE
      npm ERR! mdns@2.3.3 install: `node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the mdns@2.3.3 install script 'node-gyp rebuild'.
      npm ERR! This is most likely a problem with the mdns package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node-gyp rebuild
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs mdns
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR!     npm owner ls mdns
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:npm ERR!     /opt/npm-debug.log
      ERROR: host.raspberrypi Cannot install iobroker.homekit2: 1
      ERROR: process exited with code 25</dns_sd.h>
      geändert: Code in Code-Tags; Homoran (Mod)
        Da fehlt noch: libavahi-compat-libdnssd-dev
        So installieren:
        sudo apt-get install libavahi-compat-libdnssd-dev
        Ist hier zu finden:
        https://github.com/jensweigele/ioBroker … stallation
        • G
          Gorg last edited by
          Super, das war es …..
          Vielen Dank !
          Gorg
          81.0k
