    4. [gelöst] PhantomJs auf VIS
      homecineplexx last edited by homecineplexx
      Hallo funktioniert ein PhantomJs Aufruf auf eine eigene VIS Seite bei euch?
      PhantomJs Version: 1.1.2
      VIS version: 1.4.5
      script.js.used-Scripts.Phantomjs-Test: viewportSize: {"height":600,"width":800} clipRect: {"height":600,"left":0,"top":0,"width":800} paperSize: {} scrollPosition: {"left":0,"top":0} URL: http://192.168.1.8:8082/vis/index.html#Heizung_Temp output: /opt/iobroker/node_modules/iobroker.phantomjs/picture.png zoom: 1 ERROR: ReferenceError: Can't find variable: vis TRACE: -> http://192.168.1.8:8082/vis/widgets/basic/js/table.js: 42 (in function "global code") phantomjs://code/rasterize.js:209 in onError ERROR: ReferenceError: Can't find variable: vis TRACE: -> http://192.168.1.8:8082/vis/index.html#Heizung_Temp: 59 (in function "global code") phantomjs://code/rasterize.js:209 in onError ERROR: ReferenceError: Can't find variable: vis TRACE: -> http://192.168.1.8:8082/vis/index.html#Heizung_Temp: 3342 (in function "global code") phantomjs://code/rasterize.js:209 in onError ERROR: ReferenceError: Can't find variable: vis TRACE: -> http://192.168.1.8:8082/vis/index.html#Heizung_Temp: 3523 (in function "global code") phantomjs://code/rasterize.js:209 in onError ERROR: ReferenceError: Can't find variable: vis TRACE: -> http://192.168.1.8:8082/vis/index.html#Heizung_Temp: 5537 (in function "global code") phantomjs://code/rasterize.js:209 in onError ERROR: ReferenceError: Can't find variable: vis TRACE: -> http://192.168.1.8:8082/vis/index.html#Heizung_Temp: 5784 (in function "global code") phantomjs://code/rasterize.js:209 in onError```
        @homecineplexx mit VIS Version 1.4.4 bzw der neuesten 1.4.12 geht das wieder
