    4. Von BETA zurück auf STABLE
    • sissiwup
      sissiwup last edited by
      ich wollte mein System von beta wieder zurück auf STABLE stellen.
      Ich habe das mal in den Einstellungen gemacht und habe mich gewundert, dass z.B. der js-controller im stable noch in der Version 3.2.16 angegeben wird.
      Wie ist hier der beste Weg ohne alles neu zu installieren?
      Used repository: stable
      Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
      Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
      Adapter    "admin"        : 4.2.1    , installed 5.3.1
      Adapter    "backitup"     : 2.1.6    , installed 2.3.5
      Adapter    "broadlink2"   : 2.0.3    , installed 2.1.5
      Adapter    "coronavirus-statistics": 0.6.3, installed 0.8.7
      Adapter    "devices"      : 0.3.16   , installed 1.0.10
      Adapter    "dwd"          : 2.7.5    , installed 2.7.7
      Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
      Adapter    "geofency"     : 1.0.3    , installed 1.1.0
      Adapter    "habpanel"     : 0.4.3    , installed 0.5.0
      Adapter    "hm-rega"      : 3.0.16   , installed 3.0.37
      Adapter    "hm-rpc"       : 1.14.37  , installed 1.15.8
      Adapter    "ical"         : 1.7.4    , installed 1.11.6
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-mfd-png": 1.0.2    , installed 1.0.2
      Adapter    "icons-mfd-svg": 1.0.2    , installed 1.0.2
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "info"         : 1.7.14   , installed 1.9.19
      Adapter    "javascript"   : 5.1.3    , installed 5.3.3
      Controller "js-controller": 3.2.16   , installed 4.0.19
      Adapter    "mqtt"         : 2.3.5    , installed 2.7.3
      Adapter    "ping"         : 1.4.12   , installed 1.5.3
      Adapter    "pushover"     : 2.0.3    , installed 2.1.0
      Adapter    "scenes"       : 2.3.6    , installed 2.3.9
      Adapter    "simple-api"   : 2.5.3    , installed 2.6.3
      Adapter    "socketio"     : 3.1.4    , installed 4.1.4
      Adapter    "sonoff"       : 2.4.0    , installed 2.4.7
      Adapter    "sql"          : 1.15.5   , installed 1.16.2
      Adapter    "tankerkoenig" : 2.0.5    , installed 2.1.1
      Adapter    "telegram"     : 1.8.1    , installed 1.11.1
      Adapter    "trashschedule": 1.1.1    , installed 1.4.3
      Adapter    "vis"          : 1.3.8    , installed 1.4.12
      Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.1.7    , installed 1.1.9
      Adapter    "vis-icontwo"  : 0.67.0   , installed 0.87.0
      Adapter    "vis-inventwo" : 2.8.3    , installed 3.3.1
      Adapter    "vis-justgage" : 1.0.2    , installed 1.0.2
      Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-material-advanced": 1.7.0, installed 1.7.2
      Adapter    "vis-metro"    : 1.1.2    , installed 1.2.0
      Adapter    "vis-timeandweather": 1.1.7, installed 1.1.7
      Adapter    "vis-weather"  : 2.5.3    , installed 2.5.5
      Adapter    "web"          : 3.4.0    , installed 4.2.0
      Adapter    "yahka"        : 0.12.0   , installed 0.13.1
      Host    "zotac"          is up to date.
      All adapters are up to date
      Was bedeuten die beiden Timeouts am Anfang?
      Kritisch sehe ich admin, js-controller und web.
      Probieren ist kein Problem, da ich ein funktionierendes Backup habe
      (nicht backitup, das läuft nur so mit)
        Thomas Braun Most Active @sissiwup last edited by
        @sissiwup
        iobroker repo list
        sagt?
        echad@chet:/opt/iobroker $ iobroker repo list
        live-beta     : http://iobroker.live/repo/sources-dist-latest.json
        live-stable   : http://iobroker.live/repo/sources-dist.json
        Active repo(s): live-beta
        Mit den live-Servern habe ich eigentlich nie Probleme.
        iobroker update
        sagt?
        sissiwup D 2 Replies Last reply Reply Quote 0
        • sissiwup
          sissiwup @Thomas Braun last edited by
          nie was geändert:
          iobroker repo list
          <input type="text" id="repo_1_name" name="name" role="textbox" class="editable" style="width: 98%;">: <input type="text" id="repo_1_link" name="link" role="textbox" class="editable" style="width: 98%;">
          online        : https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json
          fast-online   : http://download.iobroker.net/sources-dist.json
            @sissiwup
            Die Ausgabe sieht komisch aus. Da ist irgendwas krummes eingetragen.
            iobroker repo list
            Sauber ist es wie oben von mir gepostet.
            sissiwup Segway 2 Replies Last reply Reply Quote 0
              Homoran Global Moderator Administrators @sissiwup last edited by
              @sissiwup sagte in Von BETA zurück auf STABLE:
              dass die aktuellen Inhalte der Repos nicht gelesen werden können
              die sind ja deshalb auch uralt
              • sissiwup
                sissiwup @Thomas Braun last edited by sissiwup
                Ok, ich benutze aber nur die beiden unteren
                beta und stable
                Ist live jetzt das aktuelle?
                Habs angepasst:
                iobroker repo list
                Live-beta hat zumindest keine Timeouts mehr.
                  nie was geändert:
                  dann lösch zumindest die beiden ersten mal.
                  beta und stable sollten auf live weitergeleitet werden
                  ggf. gibt es da bei dir ein Problem
                    @sissiwup
                    Nein, das ist eine Alternative. Versuchs halt mal damit und wird den anderen Kram 'online' und 'fast-online' und den komischen Code-Kram raus
                    sissiwup 1 Reply Last reply Reply Quote 0
                    • sissiwup
                      live bringt im beta keine Timeouts. Probiere jetzt mal stable. Danke für den Tipp
                      • sissiwup
                        sissiwup @sissiwup last edited by
                        @sissiwup
                        Sieht viel besser aus:
                        iobroker stop && iobroker update && iobroker upgrade self && iobroker upgrade && iobroker start
                        Used repository: live-stable
                        Adapter    "admin"        : 5.3.1    , installed 5.3.1
                        Adapter    "backitup"     : 2.3.3    , installed 2.3.5
                        Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                        Adapter    "coronavirus-statistics": 0.8.7, installed 0.8.7
                        Adapter    "devices"      : 1.0.9    , installed 1.0.10
                        Adapter    "dwd"          : 2.7.7    , installed 2.7.7
                        Adapter    "hm-rega"      : 3.0.35   , installed 3.0.37
                        Adapter    "hm-rpc"       : 1.15.0   , installed 1.15.8
                        Adapter    "ical"         : 1.11.4   , installed 1.11.6
                        Adapter    "info"         : 1.9.8    , installed 1.9.19
                        Adapter    "javascript"   : 5.2.21   , installed 5.3.3
                        Controller "js-controller": 4.0.19   , installed 4.0.19
                        Adapter    "mqtt"         : 2.4.1    , installed 2.7.3
                        Adapter    "ping"         : 1.5.0    , installed 1.5.3
                        Adapter    "pushover"     : 2.0.5    , installed 2.1.0
                        Adapter    "scenes"       : 2.3.8    , installed 2.3.9
                        Adapter    "simple-api"   : 2.6.2    , installed 2.6.3
                        Adapter    "socketio"     : 3.1.5    , installed 4.1.4
                        Adapter    "sonoff"       : 2.4.7    , installed 2.4.7
                        Adapter    "sql"          : 1.16.1   , installed 1.16.2
                        Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
                        Adapter    "telegram"     : 1.11.1   , installed 1.11.1
                        Adapter    "trashschedule": 1.4.1    , installed 1.4.3
                        Adapter    "vis"          : 1.4.5    , installed 1.4.12
                        Adapter    "vis-hqwidgets": 1.1.9    , installed 1.1.9
                        Adapter    "vis-icontwo"  : 0.87.0   , installed 0.87.0
                        Adapter    "vis-inventwo" : 3.2.8    , installed 3.3.1
                        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
                        Adapter    "web"          : 3.4.16   , installed 4.2.0
                        Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                        Jetzt muss ich nur noch die "zu neuen" zurück drehen ...
                        Geht das auch per cmdline?
                          @sissiwup
                          iobroker upgrade ADAPTERNAME@Versionsnummer
                          Wenn es stabil mit den jetzigen Versionen funktioniert würde ich da aber gar nix fummeln. Die Versionen werden irgendwann von den stabilen Versionen überschrieben, wenn die Versionsnummer entsprechend die jetzige übersteigt.
                          • sissiwup
                            Hallo, du hast Recht. Ich schaue mir das erstmal so an. Danke.
                              Mit solchen Verkettungen würde ich nicht arbeiten:
                              Besser einzeln eingeben. Dann kann man besser auf Rückmeldungen reagieren.
                              • sissiwup
                                @thomas-braun sagte in Von BETA zurück auf STABLE:
                                Ich dachte durch die && hält er an, sobald es einen Fehler gibt.
                                Mache ich eigentlich schon Jahrelang so. Bisher ohne Probleme ...
                                  Das stimmt. Aber nicht jede ungewollte Folgeaktion wirft einen Fehler / Return Code <>0.
                                    daruse @Thomas Braun last edited by
                                    Hallo, das Thema ist zwar schon länger her, aber vllt könnt ihr mir auf die Sprünge helfen.
                                    Ich hatte erst die VIS-2 beta installiert dann auf VIS-2 gewechselt. Aber irgendwie nicht über die Adapter, sprich ich kann aktuell nicht einfach auf die neueste Version mit update/upgrade hochziehen.
                                    iobroker repo list:
                                    Active repo(s): stable
                                    iobroker update:
                                    Adapter    "admin"        : 6.12.0   , installed 6.12.2
                                    Adapter    "backitup"     : 2.9.8    , installed 2.9.8
                                    Adapter    "evcc"         : 0.0.10   , installed 0.0.10
                                    Adapter    "influxdb"     : 3.2.0    , installed 3.2.0
                                    Adapter    "javascript"   : 7.1.6    , installed 7.1.6
                                    Controller "js-controller": 5.0.17   , installed 5.0.17
                                    Adapter    "modbus"       : 6.0.1    , installed 6.0.1
                                    Adapter    "ocpp"         : 0.12.5   , installed 0.12.5
                                    Adapter    "pushover"     : 3.0.6    , installed 3.0.6
                                    Adapter    "rpi2"         : 1.3.2    , installed 1.3.2
                                    Adapter    "shelly"       : 6.6.1    , installed 6.6.1
                                    Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                                    Adapter    "web"          : 6.1.10   , installed 6.1.10
                                    Adapter    "ws"           : 2.5.8    , installed 2.5.8
                                    Könnt ihr mir Bitte sagen wie ich auf die "offizielle" stabile VIS-2 Version komme?
                                    Danke und viele Grüße,
                                    daruse
                                      Thomas Braun Most Active @daruse last edited by
                                      @daruse sagte in Von BETA zurück auf STABLE:
                                      Es gibt keine. Nur eine Beta-Version, die über den Reiter npm oder über das Beta-Repo zu beziehen ist.
                                        Homoran Global Moderator Administrators @daruse last edited by
                                        Die gibt es nicht!
                                        vis2 ist beta
                                          Ok Danke das war mir so nicht bewusst.
                                          Ich habe aktuell die Version 2.3.5 installiert und im Änderungsprotokoll hab ich bereits die 2.9.8 gesehen. Wie wäre der saubere Weg dies manuell zu updaten?
                                            Über den Reiter 'npm'
                                            beta repository
                                            1554
