    4. Skript: TypeError: Converting circular structure to JSON
      abcklaus last edited by abcklaus
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: 4GB
      Festplattenart: HDD
      Betriebssystem: Ubuntu / Docker
      Node-Version: 10.x.x
      Nodejs-Version: 14.18.3
      NPM-Version: 6.14.15
      Installationsart: Docker
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      Zur Steuerung meines AV Receivers nutze ich dieses Skript.
      var host, port, message;
      let socketClient;
      host = '10.10.21.14';
      port = 84;
      // PowerON
      on({id: 'fakeroku.0.lyngdorf.keys.Select', change: "any"}, async function (obj) {
        var value = obj.state.val;
        if (getState("fakeroku.0.lyngdorf.keys.Select").val) {
          await Send_mesage_via_TCP(host, port, '!POWERONMAIN\r');
      // PowerOFF
      on({id: 'fakeroku.0.lyngdorf.keys.Home', change: "any"}, async function (obj) {
        if (getState("fakeroku.0.lyngdorf.keys.Home").val) {
          await Send_mesage_via_TCP(host, port, '!POWEROFFMAIN\r');
      // Vol+
      on({id: 'fakeroku.0.lyngdorf.keys.Up', change: "any"}, async function (obj) {
        if (getState("fakeroku.0.lyngdorf.keys.Up").val) {
          await Send_mesage_via_TCP(host, port, '!VOL+\r!VOL+\r');
      // Vol-
      on({id: 'fakeroku.0.lyngdorf.keys.Down', change: "any"}, async function (obj) {
        if (getState("fakeroku.0.lyngdorf.keys.Down").val) {
          await Send_mesage_via_TCP(host, port, '!VOL-\r!VOL-\r');
      async function Send_mesage_via_TCP(host, port, message) {
          // Create the socket client if it was not already created
          if (!socketClient) {
              console.log('create new connection.');
              var net = require('net');
              socketClient = net.connect({ host: host, port: port });
              // On disconnect
              socketClient.on("end", () => {
                  console.log("Disconnected from API");
                  socketClient.destroy();
                  socketClient = null;
              // Wait until connection is established
              await once(socketClient, "connect");
          // Send the message
          socketClient.write(message);
          // Listen for the response
          const data = await once(socketClient, "data");
          //const response = JSON.parse(data).result;
      Das Skript steuert den AV Receiver via TCP Befehlen. Das klappt soweit seit Monaten bestens. Seit einigen Tagen erhalte ich im Log diese Fehler:
      2022-03-13 19:33:30.286  - info: javascript.0 (135) script.js.common.Lyngdorf.Fernbedienung: getState(id=fakeroku.0.lyngdorf.keys.Down, timerId=undefined) => {"val":true,"ack":true,"ts":1647196410285,"q":0,"from":"system.adapter.fakeroku.0","user":"system.user.admin","lc":1647196410285}
      2022-03-13 19:33:30.287  - error: javascript.0 (135) script.js.common.Lyngdorf.Fernbedienung: TypeError: Converting circular structure to JSON
      2022-03-13 19:33:30.287  - error: javascript.0 (135)     --> starting at object with constructor 'Socket'
      2022-03-13 19:33:30.287  - error: javascript.0 (135)     |     property '_writableState' -> object with constructor 'WritableState'
      2022-03-13 19:33:30.287  - error: javascript.0 (135)     |     property 'afterWriteTickInfo' -> object with constructor 'Object'
      2022-03-13 19:33:30.287  - error: javascript.0 (135)     --- property 'stream' closes the circle
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at JSON.stringify (<anonymous>)
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Object.subscribe (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1109:65)
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at _once (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1191:46)
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1199:47
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at new Promise (<anonymous>)
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at once (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1199:24)
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Send_mesage_via_TCP (script.js.common.Lyngdorf.Fernbedienung:155:24)
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Object.<anonymous> (script.js.common.Lyngdorf.Fernbedienung:39:11)
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1082:38)
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
      2022-03-13 19:33:30.288  - error: javascript.0 (135)     at processImmediate (internal/timers.js:464:21)
      Ich kann es nicht mit Gewissheit sagen. Ich denke aber, dass Fehler erstmalig mit dem Update auf js-controller 4 aufgetreten ist. Sicher bin ich aber nicht.
      Der Fehler im Log wird mit jedem Lauf des Skripts geschrieben. Hat jemand eine Idee?
      Ergänzung: Ich habe noch etwas getestet und festgestellt, dass die Fehlermeldung mit der "verbose" Option im Skript Editor im Zusammenhang steht. Ist diese aktiviert, erscheinen die Fehler im Protokoll.
      Danke und Grüße
      Michael
      Sokomoto OliverIO 2 Replies Last reply Reply Quote 0
      • Sokomoto
        Sokomoto @abcklaus last edited by
        @abcklaus sagte in Skript: TypeError: Converting circular structure to JSON:
        Die Option verbose, erweitert nur die Log Ausgabe. Ich denke der meckert über die doppelte VAR Deklaration.
        Einmal am Anfang:
        var host, port, message;  // Die VAR message ist hier überflüssig
        und bei :
        Das sind unterschiedliche Variablen auch wenn sie gleich heißen.
        Du kannst das auch so schreiben:
        'use strict';
        let socketClient;
        let host = '10.10.21.14';
        let port = 84;
        // PowerON
        on({id: 'fakeroku.0.lyngdorf.keys.Select', val: true}, async function (obj) {
            await Send_mesage_via_TCP('!POWERONMAIN\r');
        // PowerOFF
        on({id: 'fakeroku.0.lyngdorf.keys.Home', val: true}, async function (obj) {
            await Send_mesage_via_TCP('!POWEROFFMAIN\r');
        // Vol+
        on({id: 'fakeroku.0.lyngdorf.keys.Up', val: true}, async function (obj) {
            await Send_mesage_via_TCP('!VOL+\r!VOL+\r');
        // Vol-
        on({id: 'fakeroku.0.lyngdorf.keys.Down', val: true}, async function (obj) {
            await Send_mesage_via_TCP('!VOL-\r!VOL-\r');
        async function Send_mesage_via_TCP(message) {
                const net = require('net');
                // On disconnect
            // Send the message
        tschuess
        • OliverIO
          OliverIO @abcklaus last edited by
          Also meiner Meinung nach liegt es nicht an dem was @Sokomoto schreibt.
          Gemäß Stack trace passiert der Fehler bei der Verarbeitung der Rückmeldung per once (Zeile 12 des logs).
          Die Rückmeldung wird dann per JSON.stringify (Zeile 7) versucht in einen String umzuwandeln.
          Allerdings scheint das ein Objekt zu sein, welches auf sich selber verweist und daher nicht umgewandelt werden kann.
          Interessant wäre es, was da enthalten ist.
          Evtl könntest du die Rückmeldung mal in einen Buffer speichern und da mal reinschauen. Buffer sind meist ein Array mit 8bit Werten, die den jeweiligen zeichencode darstellen. etwas aufpassen muss man bei utf8 kodierten Zeichenketten
          die net-Bibliothek kann die daten als string und als Buffer zurückgeben
          https://nodejs.org/api/buffer.html
