    4. Node-Red
    5. Tages/Nachtlänge berechnen
      hpgo last edited by
      Hallo, ich würde mir gern berechnen, wie lange ist es tagsüber hell und wie lange es dunkel ist. Dazu hab ich die Sun positions Node die gewünschten Zeiten herausgesucht.
      Jetzt müsst das ganze noch berechnet werden - leider fehlt mir dazu der Ansatz.
      Vlt gibts auch schon fertige Lösungen?
              "id": "1d8c27aff840b27c",
              "type": "tab",
              "label": "TEST",
              "disabled": false,
              "info": "",
              "env": []
              "id": "858b441eaddacfd7",
              "type": "sun-position",
              "z": "1d8c27aff840b27c",
              "name": "",
              "positionConfig": "d836509a.67bc4",
              "rules": [],
              "onlyOnChange": "true",
              "topic": "",
              "outputs": 1,
              "start": "",
              "startType": "none",
              "startOffset": 0,
              "startOffsetType": "none",
              "startOffsetMultiplier": 60000,
              "end": "",
              "endType": "none",
              "endOffset": 0,
              "endOffsetType": "none",
              "endOffsetMultiplier": 60000,
              "x": 430,
              "y": 240,
              "wires": [
                      "69184b9a38db4f0b",
                      "e6e2c94479444efe",
                      "a76942cd4a4957a5"
              "id": "da350f3e507cd358",
              "type": "inject",
              "name": "Inject",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "",
              "payloadType": "date",
              "x": 270,
              "y": 240,
              "wires": [
                      "858b441eaddacfd7"
              "id": "69184b9a38db4f0b",
              "type": "change",
              "name": "Sonnenuntergang",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "payload.times.sunsetStart.value",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 690,
              "y": 260,
              "wires": [
                      "ee5148fbf0ef5947"
              "id": "e6e2c94479444efe",
              "type": "change",
              "name": "Sonneaunaufgang",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "payload.times.sunriseStart.value",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 690,
              "y": 220,
              "wires": [
                      "ee5148fbf0ef5947"
              "id": "a76942cd4a4957a5",
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "targetType": "full",
              "statusVal": "",
              "statusType": "auto",
              "x": 630,
              "y": 160,
              "wires": []
              "id": "ee5148fbf0ef5947",
              "type": "join",
              "name": "",
              "mode": "custom",
              "build": "array",
              "property": "payload",
              "propertyType": "msg",
              "key": "topic",
              "joiner": "\\n",
              "joinerType": "str",
              "accumulate": false,
              "timeout": "",
              "count": "2",
              "reduceRight": false,
              "reduceExp": "",
              "reduceInit": "",
              "reduceInitType": "",
              "reduceFixup": "",
              "x": 890,
              "y": 240,
              "wires": [
                      "4d86b7feb800bad5"
              "id": "4d86b7feb800bad5",
              "type": "debug",
              "name": "",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "false",
              "statusVal": "",
              "x": 1050,
              "y": 240,
              "wires": []
              "id": "d836509a.67bc4",
              "type": "position-config",
              "name": "Johnsdorf/Brunn",
              "isValide": "true",
              "longitude": "0",
              "latitude": "0",
              "angleType": "deg",
              "timeZoneOffset": 99,
              "timeZoneDST": 0,
              "stateTimeFormat": "3",
              "stateDateFormat": "3",
              "contextStore": ""
      Lg
      • mickym
        mickym Most Active @hpgo last edited by mickym
        @hpgo Wenn Du schon diese Nodes installiert hast, warum nutzt die dann nicht ?
        Diese Node ist doch super komfortabel - um solche Aufgaben - out of the box zu lösen:
        In der Hilfe zu der Node gibt es auch ein WIKI um Dir alles erklären zu lassen:
               "type": "debug",
               "z": "e07ec81bf2817d9a",
               "name": "",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 1050,
               "y": 340,
               "wires": []
               "id": "f70ba7449572c8a9",
               "type": "time-span",
               "outputs": 1,
               "name": "",
               "positionConfig": "",
               "operand1": "sunriseEnd",
               "operand1Type": "pdsTime",
               "operand1Format": "0",
               "operand1Offset": 0,
               "operand1OffsetType": "none",
               "operand1OffsetMultiplier": 60000,
               "operand2": "sunsetEnd",
               "operand2Type": "pdsTime",
               "operand2Format": "0",
               "operand2Offset": 0,
               "operand2OffsetType": "none",
               "operand2OffsetMultiplier": 60000,
               "rules": [],
               "checkall": "true",
               "results": [
                       "p": "",
                       "pt": "msgPayload",
                       "v": "",
                       "vt": "timespan",
                       "o": "",
                       "oT": "none",
                       "oM": "60000",
                       "fTs": 3,
                       "fTsS": 3,
                       "fTsT": "Stunden",
                       "fTsI": "3",
                       "f": 0,
                       "fS": 0,
                       "fT": "Millisekunden UNIX-Zeit",
                       "fI": "0",
                       "next": false,
                       "days": "*",
                       "months": "*",
                       "onlyEvenDays": false,
                       "onlyOddDays": false,
                       "onlyEvenWeeks": false,
                       "onlyOddWeeks": false
               "x": 540,
               "y": 280,
               "wires": [
                       "1daf54e19d778ac5"
               "id": "fbd738101ef48d85",
               "type": "inject",
               "name": "",
               "props": [
                       "p": "payload"
               "repeat": "",
               "crontab": "",
               "once": false,
               "onceDelay": 0.1,
               "topic": "",
               "payload": "true",
               "payloadType": "bool",
               "x": 230,
               "y": 300,
               "wires": [
                       "f70ba7449572c8a9",
                       "25fb26316449d50a"
               "id": "1daf54e19d778ac5",
               "type": "debug",
               "name": "",
               "active": false,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 830,
               "y": 280,
               "wires": []
               "id": "25fb26316449d50a",
               "outputs": 1,
               "name": "",
               "rules": [],
               "checkall": "true",
               "results": [
                       "p": "",
                       "pt": "msgPayload",
                       "v": "",
                       "vt": "timespan",
                       "o": "",
                       "oT": "none",
                       "oM": "60000",
                       "fTs": 2,
                       "fTsS": 2,
                       "fTsT": "Minuten",
                       "fTsI": "2",
                       "f": 0,
                       "fS": 0,
                       "fI": "0",
                       "next": false,
                       "days": "*",
                       "months": "*",
               "x": 540,
               "y": 340,
               "wires": [
                       "bf62f0ad31fc54e9"
               "id": "bf62f0ad31fc54e9",
               "type": "change",
               "name": "",
               "rules": [
                       "t": "set",
                       "p": "payload",
                       "pt": "msg",
                       "to": "{ \"tag\": $floor((payload *-1) / 60) & \" Stunden - \" & $round((payload *-1) % 60,0) & \" Minuten\",\t\"nacht\": $floor((1440- payload *-1) / 60) & \" Stunden - \" & $round((1440- payload *-1) % 60,0) & \" Minuten\"}",
                       "tot": "jsonata"
               "action": "",
               "property": "",
               "from": "",
               "to": "",
               "reg": false,
               "x": 850,
               "y": 340,
               "wires": [
                       "4d86b7feb800bad5"
        Ich habe zumindest mit dieser Bibliothek alle diese Nodes installiert bekommen:
          hpgo @mickym last edited by
          @mickym
          Vielen herzlichen Dank, ich hatte mir nur die Blind Control Node angeschaut.
          Lg
