    4. javascript.0 Fehlermeldung beim Starten der Instanz
      mguenther last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: PI4.
      Arbeitsspeicher: 8GB
      Festplattenart: SSD
      Betriebssystem: Debian
      Node-Version: 14.19.1
      Nodejs-Version: 14.19.1
      NPM-Version: 6.14.16
      Installationsart: Skript
      Image genutzt: Ja
      Hallo Zusammen,
      ich bekomme -wenn ich die Instanz javascript.0 stoppe und dann wieder starte- folgende LOG-Einträge:
      2022-03-21 02:04:10.373 - error: javascript.0 (4316) In file included from ../src/binding.cc:1:
      /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type]
      793 | (node::addon_register_func) (regfunc), \
      /home/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
      827 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
      ../src/binding.cc:153:1: note: in expansion of macro ‘NODE_MODULE’
      153 | NODE_MODULE(cpufeatures, init)
      und
      2022-03-21 02:04:15.210 - error: javascript.0 (4316) In file included from ../src/binding.cc:6:
      ../src/binding.cc:2003:1: note: in expansion of macro ‘NODE_MODULE’
      2003 | NODE_MODULE(sshcrypto, init)
      Log-File mit Meldungen davor und etwas danach:
      2022-03-21 02:03:37.992 - info: host.raspberrypi "system.adapter.javascript.0" enabled
      2022-03-21 02:03:38.468 - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 4316
      2022-03-21 02:03:42.717 - info: javascript.0 (4316) starting. Version 5.2.21 in /opt/iobroker/node_modules/iobroker.javascript, node: v14.19.1, js-controller: 4.0.21
      2022-03-21 02:03:42.773 - info: javascript.0 (4316) npm install dewpoint --production (System call)
      2022-03-21 02:04:03.275 - info: javascript.0 (4316)
      > cpu-features@0.0.2 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features
      > node-gyp rebuild
      2022-03-21 02:04:04.590 - info: javascript.0 (4316) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build“ wird betreten
      2022-03-21 02:04:04.595 - info: javascript.0 (4316) ACTION Configuring dependencies /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build/Makefile
      2022-03-21 02:04:04.851 - info: javascript.0 (4316) -- The C compiler identification is GNU 10.2.1
      2022-03-21 02:04:04.882 - info: javascript.0 (4316) -- Detecting C compiler ABI info
      2022-03-21 02:04:05.151 - info: javascript.0 (4316) -- Detecting C compiler ABI info - done
      2022-03-21 02:04:05.201 - info: javascript.0 (4316) -- Check for working C compiler: /usr/bin/cc - skipped
      2022-03-21 02:04:05.203 - info: javascript.0 (4316) -- Detecting C compile features
      2022-03-21 02:04:05.205 - info: javascript.0 (4316) -- Detecting C compile features - done
      2022-03-21 02:04:05.224 - info: javascript.0 (4316) -- Looking for dlfcn.h
      2022-03-21 02:04:05.537 - info: javascript.0 (4316) -- Looking for dlfcn.h - found
      2022-03-21 02:04:05.542 - info: javascript.0 (4316) -- Looking for getauxval
      2022-03-21 02:04:05.842 - info: javascript.0 (4316) -- Looking for getauxval - found
      2022-03-21 02:04:05.863 - info: javascript.0 (4316) -- Configuring done
      2022-03-21 02:04:05.887 - info: javascript.0 (4316) -- Generating done
      2022-03-21 02:04:05.892 - info: javascript.0 (4316) -- Build files have been written to: /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build
      2022-03-21 02:04:05.905 - info: javascript.0 (4316) TOUCH Release/obj.target/config_deps.stamp
      2022-03-21 02:04:05.917 - info: javascript.0 (4316) ACTION Building dependencies /opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build/libcpu_features.a
      2022-03-21 02:04:05.966 - info: javascript.0 (4316) gmake[1]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
      2022-03-21 02:04:06.037 - info: javascript.0 (4316) gmake[2]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
      2022-03-21 02:04:06.042 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
      2022-03-21 02:04:06.077 - info: javascript.0 (4316) Scanning dependencies of target utils
      2022-03-21 02:04:06.081 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
      2022-03-21 02:04:06.087 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
      2022-03-21 02:04:06.120 - info: javascript.0 (4316) [ 11%] Building C object CMakeFiles/utils.dir/src/filesystem.c.o
      2022-03-21 02:04:06.323 - info: javascript.0 (4316) [ 22%] Building C object CMakeFiles/utils.dir/src/stack_line_reader.c.o
      2022-03-21 02:04:06.561 - info: javascript.0 (4316) [ 33%] Building C object CMakeFiles/utils.dir/src/string_view.c.o
      2022-03-21 02:04:06.826 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
      2022-03-21 02:04:06.867 - info: javascript.0 (4316) [ 33%] Built target utils
      2022-03-21 02:04:06.882 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
      2022-03-21 02:04:06.919 - info: javascript.0 (4316) Scanning dependencies of target unix_based_hardware_detection
      2022-03-21 02:04:06.923 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
      2022-03-21 02:04:06.928 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
      2022-03-21 02:04:06.976 - info: javascript.0 (4316) [ 44%] Building C object CMakeFiles/unix_based_hardware_detection.dir/src/hwcaps.c.o
      2022-03-21 02:04:07.253 - info: javascript.0 (4316) [ 55%] Building C object CMakeFiles/unix_based_hardware_detection.dir/src/unix_features_aggregator.c.o
      2022-03-21 02:04:07.373 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
      2022-03-21 02:04:07.411 - info: javascript.0 (4316) [ 55%] Built target unix_based_hardware_detection
      2022-03-21 02:04:07.424 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
      2022-03-21 02:04:07.468 - info: javascript.0 (4316) Scanning dependencies of target cpu_features
      2022-03-21 02:04:07.474 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
      2022-03-21 02:04:07.480 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
      2022-03-21 02:04:07.530 - info: javascript.0 (4316) [ 66%] Building C object CMakeFiles/cpu_features.dir/src/cpuinfo_arm.c.o
      2022-03-21 02:04:08.014 - info: javascript.0 (4316) [ 77%] Linking C static library libcpu_features.a
      2022-03-21 02:04:08.103 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
      2022-03-21 02:04:08.137 - info: javascript.0 (4316) [ 77%] Built target cpu_features
      2022-03-21 02:04:08.145 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
      2022-03-21 02:04:08.180 - info: javascript.0 (4316) Scanning dependencies of target list_cpu_features
      2022-03-21 02:04:08.185 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
      2022-03-21 02:04:08.190 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird betreten
      2022-03-21 02:04:08.222 - info: javascript.0 (4316) [ 88%] Building C object CMakeFiles/list_cpu_features.dir/src/utils/list_cpu_features.c.o
      2022-03-21 02:04:08.547 - info: javascript.0 (4316) [100%] Linking C executable list_cpu_features
      2022-03-21 02:04:08.671 - info: javascript.0 (4316) gmake[3]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
      2022-03-21 02:04:08.707 - info: javascript.0 (4316) [100%] Built target list_cpu_features
      2022-03-21 02:04:08.713 - info: javascript.0 (4316) gmake[2]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
      2022-03-21 02:04:08.765 - info: javascript.0 (4316) gmake[1]: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/deps/cpu_features/build“ wird verlassen
      2022-03-21 02:04:08.774 - info: javascript.0 (4316) TOUCH Release/obj.target/build_deps.stamp
      2022-03-21 02:04:08.787 - info: javascript.0 (4316) CXX(target) Release/obj.target/cpufeatures/src/binding.o
      2022-03-21 02:04:10.987 - info: javascript.0 (4316) SOLINK_MODULE(target) Release/obj.target/cpufeatures.node
      2022-03-21 02:04:11.261 - info: javascript.0 (4316) COPY Release/cpufeatures.node
      2022-03-21 02:04:11.276 - info: javascript.0 (4316) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build“ wird verlassen
      2022-03-21 02:04:11.307 - info: javascript.0 (4316)
      > ssh2@1.6.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
      > node install.js
      2022-03-21 02:04:12.657 - info: unifi.0 (6404) State value to set for "unifi.0.default.clients.e4:5f:01:15:7d:62.satisfaction" has to be type "number" but received type "string"
      2022-03-21 02:04:13.015 - info: javascript.0 (4316) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build“ wird betreten
      2022-03-21 02:04:13.018 - info: javascript.0 (4316) CXX(target) Release/obj.target/sshcrypto/src/binding.o
      2022-03-21 02:04:13.498 - info: unifi.0 (6404) State value to set for "unifi.0.default.clients.b8:27:eb:3d:9e:da.satisfaction" has to be type "number" but received type "string"
      2022-03-21 02:04:13.655 - info: unifi.0 (6404) State value to set for "unifi.0.default.clients.e4:5f:01:27:f2:57.satisfaction" has to be type "number" but received type "string"
      2022-03-21 02:04:19.059 - info: javascript.0 (4316) SOLINK_MODULE(target) Release/obj.target/sshcrypto.node
      2022-03-21 02:04:19.346 - info: javascript.0 (4316) COPY Release/sshcrypto.node
      2022-03-21 02:04:19.362 - info: javascript.0 (4316) make: Verzeichnis „/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build“ wird verlassen
      2022-03-21 02:04:19.385 - info: javascript.0 (4316) Succeeded in building optional crypto binding
      2022-03-21 02:04:20.496 - info: javascript.0 (4316) + dewpoint@1.0.0
      added 109 packages from 199 contributors and audited 702 packages in 36.267s
      2022-03-21 02:04:21.645 - info: javascript.0 (4316)
      7 packages are looking for funding
      run `npm fund` for details
      2022-03-21 02:04:21.650 - info: javascript.0 (4316) found 2 high severity vulnerabilities
      run `npm audit fix` to fix them, or `npm audit` for details
      2022-03-21 02:04:21.767 - info: javascript.0 (4316) requesting all states
      2022-03-21 02:04:21.768 - info: javascript.0 (4316) requesting all objects
      2022-03-21 02:04:26.131 - info: javascript.0 (4316) received all objects
      2022-03-21 02:04:28.257 - info: javascript.0 (4316) received all states
      2022-03-21 02:04:28.487 - warn: host.raspberrypi-Server Cannot execute map: Cannot read property 'match' of undefined
      Danach werden die Skripte gestartet. Ich habe noch in der letzten Zeile ein Warning, was hin und wieder angezeigt wird.
      @liv-in-sky - das ist die Fehlermeldung, die ich dir zeigen wollte und wir es letztes Mal nicht mehr finden konnten. Auch jetzt war es wieder so, dass ein schedule nicht gestoppt werden konnte (daher die Instanz stoppen und wieder starten)
      2022-03-20 22:32:55.335 - error: javascript.0 (4990) Error by canceling scheduled job ""
        mguenther @mguenther last edited by mguenther
        Im Logfile steht ja noch:
        pi@raspberrypi:~ $ npm audit fix
        npm ERR! code EAUDITNOPJSON
        npm ERR! audit No package.json found: Cannot audit a project without a package.json
        npm ERR!     /home/pi/.npm/_logs/2022-03-21T17_24_43_439Z-debug.log
        pi@raspberrypi:~ $
        Und nun? Lösung?
        crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
        • crunchip
          crunchip Forum Testing Most Active @mguenther last edited by
          @mguenther das kannst du ignorieren, ist für die Entwickler
            Thomas Braun Most Active @mguenther last edited by
            @mguenther
            Das müsste im richtigen Verzeichnis ausgeführt werden.
            Aber lass die Finger von npm audit fix oder gar npm audit fix -force.
            Das macht mehr kaputt als das es was bringt.
              mguenther @Thomas Braun last edited by
              ok
              hast du ansonsten eine Idee, wieso die Fehlermeldung oben bei mir kommt?
                @mguenther
                Welche?
                  die 2 error Meldungen beim Starten der javascript Instanz - beide von oben aus dem ersten Beitrag
                    wodkab @mguenther last edited by
                    @mguenther
                    Ich habe bei mir die beiden gleichen Fehlermeldungen im Log, wenn ich javascript.0 restarte oder den Pi4 reboote:
                    2022-04-16 10:50:23.745 - info: javascript.0 (6665) AR(target) Release/obj.target/deps/cpu_features/cpu_features.a
                    2022-04-16 10:50:23.776 - info: javascript.0 (6665) COPY Release/cpu_features.a
                    2022-04-16 10:50:23.802 - info: javascript.0 (6665) CXX(target) Release/obj.target/cpufeatures/src/binding.o
                    2022-04-16 10:50:26.277 - error: javascript.0 (6665) In file included from ../src/binding.cc:1:
                    /opt/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:793:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type]
                    /opt/iobroker/.cache/node-gyp/14.19.1/include/node/node.h:827:3: note: in expansion of macro ‘NODE_MODULE_X’
                    ../src/binding.cc:152:1: note: in expansion of macro ‘NODE_MODULE’
                    152 | NODE_MODULE(cpufeatures, init)
                    2022-04-16 10:50:27.088 - info: javascript.0 (6665) SOLINK_MODULE(target) Release/obj.target/cpufeatures.node
                    2022-04-16 10:50:27.410 - info: javascript.0 (6665) COPY Release/cpufeatures.node
                    2022-04-16 10:50:27.428 - info: javascript.0 (6665) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/cpu-features/build'
                    2022-04-16 10:50:27.461 - info: javascript.0 (6665)
                    > ssh2@1.9.0 install /opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2
                    > node install.js
                    2022-04-16 10:50:29.372 - info: javascript.0 (6665) make: Entering directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
                    2022-04-16 10:50:29.374 - info: javascript.0 (6665) CXX(target) Release/obj.target/sshcrypto/src/binding.o
                    2022-04-16 10:50:31.325 - error: javascript.0 (6665) In file included from ../src/binding.cc:5:
                    ../src/binding.cc:2148:1: note: in expansion of macro ‘NODE_MODULE’
                    2148 | NODE_MODULE(sshcrypto, init)
                    2022-04-16 10:50:35.335 - info: javascript.0 (6665) SOLINK_MODULE(target) Release/obj.target/sshcrypto.node
                    2022-04-16 10:50:35.631 - info: javascript.0 (6665) COPY Release/sshcrypto.node
                    2022-04-16 10:50:35.649 - info: javascript.0 (6665) make: Leaving directory '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ssh2/lib/protocol/crypto/build'
                    2022-04-16 10:50:35.675 - info: javascript.0 (6665) Succeeded in building optional crypto binding
                    Gibt es Neuigkeiten, wie ich das wieder fixen kann?
                    M Thomas Braun 2 Replies Last reply Reply Quote 0
                      mguenther @wodkab last edited by
                      @wodkab
                      habe keine Lösung (bekommen)
                        @mguenther Ich habe eigentlich nichts geändert ... aber bei mir kommt die Fehlermeldung jetzt nicht mehr 😕 aber soll mir rechts sein. So oft restarte/reboote ich ja auch nicht. Zur Info ... bei mir läuft iobroker in einem Docker-Container.
                          Thomas Braun Most Active @wodkab last edited by
                          @wodkab sagte in javascript.0 Fehlermeldung beim Starten der Instanz:
                          ssh2@1.9.0
                          Wo hängt denn das Modul?
                          cd /opt/iobroker
                          npm ls ssh2
                            wodkab @Thomas Braun last edited by
                              Thomas Braun Most Active @wodkab last edited by Thomas Braun
                              @wodkab
                              Okay, also als manuelles Modul im javaskript-Adapter.
                              Brauchst du das wirklich? Ich würde das sonst rauswerfen.
                              Wenn wirklich benötigt, dann muss das vielleicht nochmal reinstalliert oder neugebaut werden.
                                @thomas-braun @thomas-braun Ok ... Danke, dann weiß ich schon mal woher der Fehler kommt. Brauchen tue ich es schon, ich führe damit ssh-Kommandos auf meinen LibreEelecs, NAS, RaspPis etc. aus.
                                  @wodkab
                                  Ich hab jetzt erst genauer geschaut... Mea culpa!
                                  Aber das sind gar keine 'Fehler', das sind ganz normale Meldungen, wenn Module neugebaut werden. Wird ja auch erfolgreich abgeschlossen:
                                    @thomas-braun Cool ... Danke, das erklärt auch, warum die "Fehler", die eigentlich Build-Warnings aus dem Modul-Build sind nicht mehr kommen ... Modul wird ja (denke ich) nicht dauernd neu gebaut 😉
                                    788
