    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер Discovery
    Драйвер Discovery
      Haus last edited by
      Version 0.2.2
      MegaESP на запрос 'http://' + ip + '/wrg/?cf=1' даёт ответ Try http://ip/pwd/
      Error megad, megadd, megaesp когда в сети
      host.ioBroker	2017-03-22 12:12:02.479	info	instance system.adapter.discovery.0 started with pid 2687
      host.ioBroker	2017-03-22 12:11:32.465	info	Restart adapter system.adapter.discovery.0 because enabled
      host.ioBroker	2017-03-22 12:11:32.465	error	instance system.adapter.discovery.0 terminated with code 0 (OK)
      discovery.0	2017-03-22 12:11:32.443	info	terminating
      discovery.0	2017-03-22 12:11:32.130	debug	Test 192.168.1.14 hm-rega
      discovery.0	2017-03-22 12:11:31.926	error	at process._tickCallback (node.js:425:17)
      discovery.0	2017-03-22 12:11:31.926	error	at nextTickCallbackWith2Args (node.js:511:9)
      discovery.0	2017-03-22 12:11:31.926	error	at endReadableNT (_stream_readable.js:923:12)
      discovery.0	2017-03-22 12:11:31.926	error	at IncomingMessage.emit (events.js:166:7)
      discovery.0	2017-03-22 12:11:31.926	error	at emitNone (events.js:72:20)
      discovery.0	2017-03-22 12:11:31.926	error	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.discovery/lib/tools.js:435:25)
      discovery.0	2017-03-22 12:11:31.926	error	at /opt/iobroker/node_modules/iobroker.discovery/lib/adapters/megad.js:57:21
      discovery.0	2017-03-22 12:11:31.926	error	at addMegaDDevice (/opt/iobroker/node_modules/iobroker.discovery/lib/adapters/megad.js:22:9)
      discovery.0	2017-03-22 12:11:31.926	error	TypeError: callback is not a function
      discovery.0	2017-03-22 12:11:31.923	error	uncaught exception: callback is not a function
      discovery.0	2017-03-22 12:11:31.618	debug	Test 192.168.1.14 upnp
      discovery.0	2017-03-22 12:11:31.615	debug	Test 192.168.1.14 tr-064
      discovery.0	2017-03-22 12:11:31.613	debug	Test 192.168.1.14 sql
      discovery.0	2017-03-22 12:11:31.612	debug	Test 192.168.1.14 sonos
      discovery.0	2017-03-22 12:11:31.611	debug	Test 192.168.1.14 ping
      discovery.0	2017-03-22 12:11:31.610	debug	Test 192.168.1.14 nut
      discovery.0	2017-03-22 12:11:31.609	debug	Test 192.168.1.14 megad
      discovery.0	2017-03-22 12:11:31.608	debug	Test 192.168.1.14 influxdb
      discovery.0	2017-03-22 12:11:31.607	debug	Test 192.168.1.14 hm-rpc
      discovery.0	2017-03-22 12:11:31.605	debug	Test 192.168.1.14 fronius
      discovery.0	2017-03-22 12:11:31.604	debug	Test 192.168.1.14 chromecast
      discovery.0	2017-03-22 12:11:31.597	debug	Test 192.168.1.10 hm-rega
      discovery.0	2017-03-22 12:11:31.581	debug	Test 192.168.1.10 upnp
      discovery.0	2017-03-22 12:11:31.579	debug	Test 192.168.1.10 tr-064
      discovery.0	2017-03-22 12:11:31.578	debug	Test 192.168.1.10 sql
      P.S. закомментировал в megad.js 22 и 24 строчки, начал работать только понятно MegaD-328 отличить от MegaD-2561 не может. Создал ещё в lib/ megadd.js, megaesp.js, вся работает как надо.
        Haus last edited by
        Version 0.3.0
        discovery.0	2017-03-28 07:21:03.095	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.10.1
        host.ioBroker	2017-03-28 07:21:01.422	info	instance system.adapter.discovery.0 started with pid 30385
        host.ioBroker	2017-03-28 07:20:31.392	info	Restart adapter system.adapter.discovery.0 because enabled
        host.ioBroker	2017-03-28 07:20:31.391	error	instance system.adapter.discovery.0 terminated with code 0 (OK)
        discovery.0	2017-03-28 07:20:31.366	info	terminating
        discovery.0	2017-03-28 07:20:30.851	error	at Timer.listOnTimeout (timers.js:214:5)
        discovery.0	2017-03-28 07:20:30.851	error	at tryOnTimeout (timers.js:244:5)
        discovery.0	2017-03-28 07:20:30.851	error	at ontimeout (timers.js:393:18)
        discovery.0	2017-03-28 07:20:30.851	error	at Timeout.testSerialPort [as _onTimeout] (/opt/iobroker/node_modules/iobroker.discovery/lib/tools.js:484:13)
        discovery.0	2017-03-28 07:20:30.851	error	at /opt/iobroker/node_modules/iobroker.discovery/lib/adapters/rflink.js:58:13
        discovery.0	2017-03-28 07:20:30.851	error	at /opt/iobroker/node_modules/iobroker.discovery/main.js:167:25
        discovery.0	2017-03-28 07:20:30.851	error	ReferenceError: callbacks is not defined
        discovery.0	2017-03-28 07:20:30.850	error	uncaught exception: callbacks is not defined
        discovery.0	2017-03-28 07:20:30.834	warn	Stop scan port undefined
        discovery.0	2017-03-28 07:20:30.832	error	Cannot open_ port /dev/ttyS0: Error: Module version mismatch. Expected 48, got 46.
        discovery.0	2017-03-28 07:20:30.724	warn	Open port /dev/ttyS0
        discovery.0	2017-03-28 07:20:30.723	warn	Call port /dev/ttyS0 57600
        discovery.0	2017-03-28 07:20:30.445	info	Found 11 addresses
        discovery.0	2017-03-28 07:20:14.133	info	Discover UPnP devices...
        discovery.0	2017-03-28 07:20:13.618	info	Received "browse" event
        discovery.0	2017-03-28 07:20:05.294	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v6.10.1
        host.ioBroker	2017-03-28 07:20:03.692	info	instance system.adapter.discovery.0 started with pid 30071
        host.ioBroker	2017-03-28 07:20:03.667	info	object change system.adapter.discovery.0
          @Haus:
          Version 0.2.2
          P.S. закомментировал в megad.js 22 и 24 строчки, начал работать только понятно MegaD-328 отличить от MegaD-2561 не может. Создал ещё в lib/ megadd.js, megaesp.js, вся работает как надо. `
          Ну их нельзя коментировать, т.к тогда процесс поиска никогда не закончится.
          Ну хоть встрой что ли опрос
          ` > if (typeof callback !== 'function') {
          options.log('typeof ' + typeof callback + ', ' + JSON.stringify(callback));
          } else {
          callback(null, true, ip);
            Haus last edited by
            @Bluefox:
            @Haus:
            Version 0.2.2
            } else {
            Version 0.2.3
            При первом поиске находит
            discovery.0	2017-03-28 22:04:24.529	debug	Test 192.168.1.65 fronius
            discovery.0	2017-03-28 22:04:24.528	debug	Test 192.168.1.65 chromecast
            discovery.0	2017-03-28 22:04:24.526	debug	Test 192.168.1.65
            discovery.0	2017-03-28 22:04:24.019	debug	Test 192.168.1.15 hm-rega
            discovery.0	2017-03-28 22:04:23.669	debug	typeof object, null
            discovery.0	2017-03-28 22:04:23.515	debug	Test 192.168.1.15 upnp
            discovery.0	2017-03-28 22:04:23.514	debug	Test 192.168.1.15 tr-064
            discovery.0	2017-03-28 22:04:23.513	debug	Test 192.168.1.15 sql
            discovery.0	2017-03-28 22:04:23.512	debug	Test 192.168.1.15 sonos
            discovery.0	2017-03-28 22:19:42.315	debug	Test 192.168.1.15 ping
            discovery.0	2017-03-28 22:19:42.314	debug	Test 192.168.1.15 nut
            discovery.0	2017-03-28 22:19:42.313	debug	Test 192.168.1.15 megad
            discovery.0	2017-03-28 22:19:42.312	debug	Test 192.168.1.15 influxdb
            discovery.0	2017-03-28 22:19:42.310	debug	Test 192.168.1.15 hm-rpc
            discovery.0	2017-03-28 22:19:42.309	debug	Test 192.168.1.15 fronius
            discovery.0	2017-03-28 22:19:42.308	debug	Test 192.168.1.15 chromecast
            discovery.0	2017-03-28 22:19:42.307	debug	Test 192.168.1.15
            discovery.0	2017-03-28 22:19:42.298	debug	Test 192.168.1.10 hm-rega
            установив megad.0, запускаю поиск ругается на второй (24 строчка) callback(null, false, ip);
            Применив
            options.log.debug('typeof ' + typeof callback + ', ' + JSON.stringify(callback));
            } else {
            ответ тот же
            P.S. Как я писал выше Megad (328, 2561) он не отличает и наращивает megad.0, megad.1…
            81.0k
