    4. NPM List Fehler "npm ERR! peer dep missing"
      sunny9999 last edited by sunny9999
      Servus in die Runde....
      Vorab : Mein System ( Master & 1 Slave) rennt super...
      Master System : Debian
      Node.js v14.19.0
      NPM 6.14.16
      Slave : Rpi-4
      Node.js v14.19.0
      NPM 6.14.16
      Grad im Zuge eines js-controller updates auf 14.19 ein "npm list" eingegeben....alles grün bis auf einen Fehler Block am Ende der Liste...
      npm ERR! peer dep missing: rollup@^1.20.0 || ^2.0.0, required by rollup-plugin-polyfill-node@0.8.0
      npm ERR! peer dep missing: rollup@^1.20.0 || ^2.0.0, required by @rollup/plugin-inject@4.0.4
      npm ERR! peer dep missing: rollup@^1.20.0||^2.0.0, required by @rollup/pluginutils@3.1.0
      npm ERR! peer dep missing: @material-ui/core@^4.0.0, required by @material-ui/pickers@3.3.10
      npm ERR! peer dep missing: react@^16.8.0 || ^17.0.0, required by @material-ui/pickers@3.3.10
      npm ERR! peer dep missing: react-dom@^16.8.0 || ^17.0.0, required by @material-ui/pickers@3.3.10
      npm ERR! peer dep missing: react@>=16.6.0, required by react-transition-group@4.4.2
      npm ERR! peer dep missing: react@>=16.8, required by rifm@0.7.0
      npm ERR! peer dep missing: react-dom@>=16.6.0, required by react-transition-group@4.4.2
      npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
      npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
      npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
      npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce
      npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
      npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
      npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz
      npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
      npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
      npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
      npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
      npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
      npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
      npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc
      npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
      npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
      npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
      npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typescript
      npm ERR! extraneous: eslint@8.9.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint
      npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google
      npm ERR! extraneous: eslint-plugin-jest@26.1.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest
      npm ERR! extraneous: jest@27.5.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest
      npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli
      npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
      Jemand eine Idee / Hinweis wo da das Problem liegt ?
      Danke und Grüße
      Sunny
      • AlCalzone
        AlCalzone Developer @sunny9999 last edited by
        @sunny9999 Das sind alles development dependencies (sowohl die missing als auch die extraneous), die haben auf einem Produktivsystem gar nix zu suchen. Vermutlich wurde irgendwann mal in /opt/iobroker/node_modules/zigbee-herdsman ein npm install (ohne das --production Flag) ausgeführt.
        Wenn alles läuft, würde ich das ehrlich gesagt ignorieren.
          sunny9999 @AlCalzone last edited by
          @alcalzone
          Vielen Dank für den Hinweis, da könntest du recht haben...irgendwann vor grauer Vorzeit....
          Mein System ist immer Safe...ich mach nen Snapshot vor uninstall und gut..
          Wie kann ich den deinstallieren ? Gibts nen Unterschied von dem Modul zigbee-herdsman zum zigbee Modul ?
          Danke für Deine Hilfe...
          Sunny
            arteck Developer Most Active @sunny9999 last edited by arteck
            @sunny9999 sagte in NPM List Fehler "npm ERR! peer dep missing":
            zigbee-herdsman ist das kommunikationspaket .. den brauchst du .. aber
            was du machen kannst
            zigbee adapter stop
            konsole auf
            rm -R /opt/iobroker/node_modules/zigbee-herdsman-converters
            dann adapter von GIT installeiren
            adapter starten
            danach sollte es wieder sauber sein
              sunny9999 @arteck last edited by
              @arteck
              @arteck
              Danke für deine Hinweise...
              Hat funktioniert , läuft ...ABER bei erneutem NPM List kommt
              │ ├─┬ UNMET DEPENDENCY zigbee-herdsman@0.14.16
              │ │ ├── UNMET DEPENDENCY @babel/cli@7.17.0
              │ │ ├── UNMET DEPENDENCY @babel/preset-env@7.16.11
              │ │ ├── UNMET DEPENDENCY @babel/preset-typescript@7.16.7
              │ │ ├── UNMET DEPENDENCY @types/debounce@1.2.1
              │ │ ├── UNMET DEPENDENCY @types/debug@4.1.7
              │ │ ├── UNMET DEPENDENCY @types/jest@27.4.0
              │ │ ├── UNMET DEPENDENCY @types/mz@2.7.4
              │ │ ├── UNMET DEPENDENCY @types/nedb@1.8.12
              │ │ ├── UNMET DEPENDENCY @types/serialport@8.0.2
              │ │ ├── UNMET DEPENDENCY @typescript-eslint/eslint-plugin@5.10.2
              │ │ ├── UNMET DEPENDENCY @typescript-eslint/parser@5.10.2
              │ │ ├── UNMET DEPENDENCY debounce@1.2.1
              │ │ ├─┬ UNMET DEPENDENCY debug@4.3.3
              │ │ │ └── UNMET DEPENDENCY ms@2.1.2
              │ │ ├── UNMET DEPENDENCY eslint@8.8.0
              │ │ ├── UNMET DEPENDENCY fast-deep-equal@3.1.3
              │ │ ├── UNMET DEPENDENCY jest@27.5.0
              │ │ ├── UNMET DEPENDENCY mixin-deep@2.0.1
              │ │ ├─┬ UNMET DEPENDENCY mz@2.7.0
              │ │ │ ├── UNMET DEPENDENCY any-promise@1.3.0
              │ │ │ ├── UNMET DEPENDENCY object-assign@4.1.1
              │ │ │ └─┬ UNMET DEPENDENCY thenify-all@1.6.0
              │ │ │   └─┬ UNMET DEPENDENCY thenify@3.3.1
              │ │ │     └── UNMET DEPENDENCY any-promise@1.3.0
              │ │ ├─┬ UNMET DEPENDENCY serialport@9.2.8
              │ │ │ ├─┬ UNMET DEPENDENCY @serialport/binding-mock@9.2.4
              │ │ │ │ ├─┬ UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
              │ │ │ │ │ └── UNMET DEPENDENCY debug@4.3.3
              │ │ │ ├─┬ UNMET DEPENDENCY @serialport/bindings@9.2.8
              │ │ │ │ ├── UNMET DEPENDENCY @serialport/binding-abstract@9.2.3
              │ │ │ │ ├── UNMET DEPENDENCY @serialport/parser-readline@9.2.4
              │ │ │ │ ├─┬ UNMET DEPENDENCY bindings@1.5.0
              │ │ │ │ │ └── UNMET DEPENDENCY file-uri-to-path@1.0.0
              │ │ │ │ ├── UNMET DEPENDENCY debug@4.3.3
              │ │ │ │ ├── UNMET DEPENDENCY nan@2.15.0
              │ │ │ │ └─┬ UNMET DEPENDENCY prebuild-install@7.0.1
              │ │ │ │   ├── UNMET DEPENDENCY detect-libc@2.0.0
              │ │ │ │   ├── UNMET DEPENDENCY expand-template@2.0.3
              │ │ │ │   ├── UNMET DEPENDENCY github-from-package@0.0.0
              │ │ │ │   ├── UNMET DEPENDENCY minimist@1.2.5
              │ │ │ │   ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
              │ │ │ │   ├── UNMET DEPENDENCY napi-build-utils@1.0.2
              │ │ │ │   ├─┬ UNMET DEPENDENCY node-abi@3.8.0
              │ │ │ │   │ └─┬ UNMET DEPENDENCY semver@7.3.5
              │ │ │ │   │   └─┬ UNMET DEPENDENCY lru-cache@6.0.0
              │ │ │ │   │     └── UNMET DEPENDENCY yallist@4.0.0
              │ │ │ │   ├─┬ UNMET DEPENDENCY npmlog@4.1.2
              │ │ │ │   │ ├─┬ UNMET DEPENDENCY are-we-there-yet@1.1.7
              │ │ │ │   │ │ ├── UNMET DEPENDENCY delegates@1.0.0
              │ │ │ │   │ │ └─┬ UNMET DEPENDENCY readable-stream@2.3.7
              │ │ │ │   │ │   ├── UNMET DEPENDENCY core-util-is@1.0.3
              │ │ │ │   │ │   ├── UNMET DEPENDENCY inherits@2.0.4
              │ │ │ │   │ │   ├── UNMET DEPENDENCY isarray@1.0.0
              │ │ │ │   │ │   ├── UNMET DEPENDENCY process-nextick-args@2.0.1
              │ │ │ │   │ │   ├── UNMET DEPENDENCY safe-buffer@5.1.2
              │ │ │ │   │ │   ├─┬ UNMET DEPENDENCY string_decoder@1.1.1
              │ │ │ │   │ │   │ └── UNMET DEPENDENCY safe-buffer@5.1.2
              │ │ │ │   │ │   └── UNMET DEPENDENCY util-deprecate@1.0.2
              │ │ │ │   │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
              │ │ │ │   │ ├─┬ UNMET DEPENDENCY gauge@2.7.4
              │ │ │ │   │ │ ├── UNMET DEPENDENCY aproba@1.2.0
              │ │ │ │   │ │ ├── UNMET DEPENDENCY console-control-strings@1.1.0
              │ │ │ │   │ │ ├── UNMET DEPENDENCY has-unicode@2.0.1
              │ │ │ │   │ │ ├── UNMET DEPENDENCY object-assign@4.1.1
              │ │ │ │   │ │ ├── UNMET DEPENDENCY signal-exit@3.0.7
              │ │ │ │   │ │ ├─┬ UNMET DEPENDENCY string-width@1.0.2
              │ │ │ │   │ │ │ ├── UNMET DEPENDENCY code-point-at@1.1.0
              │ │ │ │   │ │ │ ├─┬ UNMET DEPENDENCY is-fullwidth-code-point@1.0.0
              │ │ │ │   │ │ │ │ └── UNMET DEPENDENCY number-is-nan@1.0.1
              │ │ │ │   │ │ │ └── UNMET DEPENDENCY strip-ansi@3.0.1
              │ │ │ │   │ │ ├─┬ UNMET DEPENDENCY strip-ansi@3.0.1
              │ │ │ │   │ │ │ └── UNMET DEPENDENCY ansi-regex@2.1.1
              │ │ │ │   │ │ └─┬ UNMET DEPENDENCY wide-align@1.1.5
              │ │ │ │   │ │   └── UNMET DEPENDENCY string-width@1.0.2
              │ │ │ │   │ └── UNMET DEPENDENCY set-blocking@2.0.0
              │ │ │ │   ├─┬ UNMET DEPENDENCY pump@3.0.0
              │ │ │ │   │ ├─┬ UNMET DEPENDENCY end-of-stream@1.4.4
              │ │ │ │   │ │ └── UNMET DEPENDENCY once@1.4.0
              │ │ │ │   │ └─┬ UNMET DEPENDENCY once@1.4.0
              │ │ │ │   │   └── UNMET DEPENDENCY wrappy@1.0.2
              │ │ │ │   ├─┬ UNMET DEPENDENCY rc@1.2.8
              │ │ │ │   │ ├── UNMET DEPENDENCY deep-extend@0.6.0
              │ │ │ │   │ ├── UNMET DEPENDENCY ini@1.3.8
              │ │ │ │   │ ├── UNMET DEPENDENCY minimist@1.2.5
              │ │ │ │   │ └── UNMET DEPENDENCY strip-json-comments@2.0.1
              │ │ │ │   ├─┬ UNMET DEPENDENCY simple-get@4.0.1
              │ │ │ │   │ ├─┬ UNMET DEPENDENCY decompress-response@6.0.0
              │ │ │ │   │ │ └── UNMET DEPENDENCY mimic-response@3.1.0
              │ │ │ │   │ ├── UNMET DEPENDENCY once@1.4.0
              │ │ │ │   │ └── UNMET DEPENDENCY simple-concat@1.0.1
              │ │ │ │   ├─┬ UNMET DEPENDENCY tar-fs@2.1.1
              │ │ │ │   │ ├── UNMET DEPENDENCY chownr@1.1.4
              │ │ │ │   │ ├── UNMET DEPENDENCY mkdirp-classic@0.5.3
              │ │ │ │   │ ├── UNMET DEPENDENCY pump@3.0.0
              │ │ │ │   │ └─┬ UNMET DEPENDENCY tar-stream@2.2.0
              │ │ │ │   │   ├─┬ UNMET DEPENDENCY bl@4.1.0
              │ │ │ │   │   │ ├─┬ UNMET DEPENDENCY buffer@5.7.1
              │ │ │ │   │   │ │ ├── UNMET DEPENDENCY base64-js@1.5.1
              │ │ │ │   │   │ │ └── UNMET DEPENDENCY ieee754@1.2.1
              │ │ │ │   │   │ └─┬ UNMET DEPENDENCY readable-stream@3.6.0
              │ │ │ │   │   │   ├── UNMET DEPENDENCY string_decoder@1.1.1
              │ │ │ │   │   ├── UNMET DEPENDENCY end-of-stream@1.4.4
              │ │ │ │   │   ├── UNMET DEPENDENCY fs-constants@1.0.0
              │ │ │ │   └─┬ UNMET DEPENDENCY tunnel-agent@0.6.0
              │ │ │ ├── UNMET DEPENDENCY @serialport/parser-byte-length@9.2.4
              │ │ │ ├── UNMET DEPENDENCY @serialport/parser-cctalk@9.2.4
              │ │ │ ├── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
              │ │ │ ├── UNMET DEPENDENCY @serialport/parser-inter-byte-timeout@9.2.4
              │ │ │ ├─┬ UNMET DEPENDENCY @serialport/parser-readline@9.2.4
              │ │ │ │ └── UNMET DEPENDENCY @serialport/parser-delimiter@9.2.4
              │ │ │ ├── UNMET DEPENDENCY @serialport/parser-ready@9.2.4
              │ │ │ ├── UNMET DEPENDENCY @serialport/parser-regex@9.2.4
              │ │ │ ├─┬ UNMET DEPENDENCY @serialport/stream@9.2.4
              │ │ ├── UNMET DEPENDENCY slip@1.0.2
              │ │ ├── UNMET DEPENDENCY typedoc@0.22.11
              │ │ ├── UNMET DEPENDENCY typedoc-plugin-markdown@3.11.13
              │ │ ├── UNMET DEPENDENCY typedoc-plugin-no-inherit@1.3.1
              │ │ ├── UNMET DEPENDENCY typedoc-plugin-sourcefile-url@1.0.6
              │ │ └── UNMET DEPENDENCY typescript@4.5.5
              │ └─┬ UNMET DEPENDENCY zigbee-herdsman-converters@14.0.422
              │   ├─┬ UNMET DEPENDENCY axios@0.25.0
              │   │ └── UNMET DEPENDENCY follow-redirects@1.14.8
              │   ├── UNMET DEPENDENCY buffer-crc32@0.2.13
              │   ├── UNMET DEPENDENCY eslint@8.9.0
              │   ├── UNMET DEPENDENCY eslint-config-google@0.14.0
              │   ├── UNMET DEPENDENCY eslint-plugin-jest@26.1.0
              │   ├─┬ UNMET DEPENDENCY https-proxy-agent@5.0.0
              │   │ ├─┬ UNMET DEPENDENCY agent-base@6.0.2
              │   │ └─┬ UNMET DEPENDENCY debug@4.3.3
              │   ├── UNMET DEPENDENCY jest@27.5.1
              │   ├─┬ UNMET DEPENDENCY tar-stream@2.2.0
              │   │ │ └── UNMET DEPENDENCY readable-stream@3.6.0
              │   │   ├─┬ UNMET DEPENDENCY string_decoder@1.3.0
              │   │   │ └── UNMET DEPENDENCY safe-buffer@5.2.1
              │   └─┬ UNMET DEPENDENCY zigbee-herdsman@0.14.14
              └─┬ paesslerag-node-red-contrib-prtg@0.0.0-development (git+https://github.com/PaesslerAG/node-red-contrib-prtg.git#478eb5028e2cbc8d04cdab503874ecfc5fd7d2f6)
                └── mustache@4.2.0
              npm ERR! missing: zigbee-herdsman@0.14.16, required by iobroker.zigbee@1.6.16
              npm ERR! missing: zigbee-herdsman-converters@14.0.422, required by iobroker.zigbee@1.6.16
              npm ERR! missing: @babel/cli@7.17.0, required by zigbee-herdsman@0.14.16
              npm ERR! missing: @babel/preset-env@7.16.11, required by zigbee-herdsman@0.14.16
              npm ERR! missing: @babel/preset-typescript@7.16.7, required by zigbee-herdsman@0.14.16
              npm ERR! missing: @types/debounce@1.2.1, required by zigbee-herdsman@0.14.16
              npm ERR! missing: @types/debug@4.1.7, required by zigbee-herdsman@0.14.16
              npm ERR! missing: @types/jest@27.4.0, required by zigbee-herdsman@0.14.16
              npm ERR! missing: @types/mz@2.7.4, required by zigbee-herdsman@0.14.16
              npm ERR! missing: @types/nedb@1.8.12, required by zigbee-herdsman@0.14.16
              npm ERR! missing: @types/serialport@8.0.2, required by zigbee-herdsman@0.14.16
              npm ERR! missing: @typescript-eslint/eslint-plugin@5.10.2, required by zigbee-herdsman@0.14.16
              npm ERR! missing: @typescript-eslint/parser@5.10.2, required by zigbee-herdsman@0.14.16
              npm ERR! missing: eslint@8.8.0, required by zigbee-herdsman@0.14.16
              npm ERR! missing: jest@27.5.0, required by zigbee-herdsman@0.14.16
              npm ERR! missing: typedoc@0.22.11, required by zigbee-herdsman@0.14.16
              npm ERR! missing: typedoc-plugin-markdown@3.11.13, required by zigbee-herdsman@0.14.16
              npm ERR! missing: typedoc-plugin-no-inherit@1.3.1, required by zigbee-herdsman@0.14.16
              npm ERR! missing: typedoc-plugin-sourcefile-url@1.0.6, required by zigbee-herdsman@0.14.16
              npm ERR! missing: typescript@4.5.5, required by zigbee-herdsman@0.14.16
              npm ERR! missing: debounce@1.2.1, required by zigbee-herdsman@0.14.16
              npm ERR! missing: debug@4.3.3, required by zigbee-herdsman@0.14.16
              npm ERR! missing: fast-deep-equal@3.1.3, required by zigbee-herdsman@0.14.16
              npm ERR! missing: mixin-deep@2.0.1, required by zigbee-herdsman@0.14.16
              npm ERR! missing: mz@2.7.0, required by zigbee-herdsman@0.14.16
              npm ERR! missing: serialport@9.2.8, required by zigbee-herdsman@0.14.16
              npm ERR! missing: slip@1.0.2, required by zigbee-herdsman@0.14.16
              npm ERR! missing: ms@2.1.2, required by debug@4.3.3
              npm ERR! missing: any-promise@1.3.0, required by mz@2.7.0
              npm ERR! missing: object-assign@4.1.1, required by mz@2.7.0
              npm ERR! missing: thenify-all@1.6.0, required by mz@2.7.0
              npm ERR! missing: thenify@3.3.1, required by thenify-all@1.6.0
              npm ERR! missing: any-promise@1.3.0, required by thenify@3.3.1
              npm ERR! missing: @serialport/binding-mock@9.2.4, required by serialport@9.2.8
              npm ERR! missing: @serialport/bindings@9.2.8, required by serialport@9.2.8
              npm ERR! missing: @serialport/parser-byte-length@9.2.4, required by serialport@9.2.8
              npm ERR! missing: @serialport/parser-cctalk@9.2.4, required by serialport@9.2.8
              npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by serialport@9.2.8
              npm ERR! missing: @serialport/parser-inter-byte-timeout@9.2.4, required by serialport@9.2.8
              npm ERR! missing: @serialport/parser-readline@9.2.4, required by serialport@9.2.8
              npm ERR! missing: @serialport/parser-ready@9.2.4, required by serialport@9.2.8
              npm ERR! missing: @serialport/parser-regex@9.2.4, required by serialport@9.2.8
              npm ERR! missing: @serialport/stream@9.2.4, required by serialport@9.2.8
              npm ERR! missing: debug@4.3.3, required by serialport@9.2.8
              npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/binding-mock@9.2.4
              npm ERR! missing: debug@4.3.3, required by @serialport/binding-mock@9.2.4
              npm ERR! missing: debug@4.3.3, required by @serialport/binding-abstract@9.2.3
              npm ERR! missing: @serialport/binding-abstract@9.2.3, required by @serialport/bindings@9.2.8
              npm ERR! missing: @serialport/parser-readline@9.2.4, required by @serialport/bindings@9.2.8
              npm ERR! missing: bindings@1.5.0, required by @serialport/bindings@9.2.8
              npm ERR! missing: debug@4.3.3, required by @serialport/bindings@9.2.8
              npm ERR! missing: nan@2.15.0, required by @serialport/bindings@9.2.8
              npm ERR! missing: prebuild-install@7.0.1, required by @serialport/bindings@9.2.8
              npm ERR! missing: file-uri-to-path@1.0.0, required by bindings@1.5.0
              npm ERR! missing: detect-libc@2.0.0, required by prebuild-install@7.0.1
              npm ERR! missing: expand-template@2.0.3, required by prebuild-install@7.0.1
              npm ERR! missing: github-from-package@0.0.0, required by prebuild-install@7.0.1
              npm ERR! missing: minimist@1.2.5, required by prebuild-install@7.0.1
              npm ERR! missing: mkdirp-classic@0.5.3, required by prebuild-install@7.0.1
              npm ERR! missing: napi-build-utils@1.0.2, required by prebuild-install@7.0.1
              npm ERR! missing: node-abi@3.8.0, required by prebuild-install@7.0.1
              npm ERR! missing: npmlog@4.1.2, required by prebuild-install@7.0.1
              npm ERR! missing: pump@3.0.0, required by prebuild-install@7.0.1
              npm ERR! missing: rc@1.2.8, required by prebuild-install@7.0.1
              npm ERR! missing: simple-get@4.0.1, required by prebuild-install@7.0.1
              npm ERR! missing: tar-fs@2.1.1, required by prebuild-install@7.0.1
              npm ERR! missing: tunnel-agent@0.6.0, required by prebuild-install@7.0.1
              npm ERR! missing: semver@7.3.5, required by node-abi@3.8.0
              npm ERR! missing: lru-cache@6.0.0, required by semver@7.3.5
              npm ERR! missing: yallist@4.0.0, required by lru-cache@6.0.0
              npm ERR! missing: are-we-there-yet@1.1.7, required by npmlog@4.1.2
              npm ERR! missing: console-control-strings@1.1.0, required by npmlog@4.1.2
              npm ERR! missing: gauge@2.7.4, required by npmlog@4.1.2
              npm ERR! missing: set-blocking@2.0.0, required by npmlog@4.1.2
              npm ERR! missing: delegates@1.0.0, required by are-we-there-yet@1.1.7
              npm ERR! missing: readable-stream@2.3.7, required by are-we-there-yet@1.1.7
              npm ERR! missing: core-util-is@1.0.3, required by readable-stream@2.3.7
              npm ERR! missing: inherits@2.0.4, required by readable-stream@2.3.7
              npm ERR! missing: isarray@1.0.0, required by readable-stream@2.3.7
              npm ERR! missing: process-nextick-args@2.0.1, required by readable-stream@2.3.7
              npm ERR! missing: safe-buffer@5.1.2, required by readable-stream@2.3.7
              npm ERR! missing: string_decoder@1.1.1, required by readable-stream@2.3.7
              npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@2.3.7
              npm ERR! missing: safe-buffer@5.1.2, required by string_decoder@1.1.1
              npm ERR! missing: aproba@1.2.0, required by gauge@2.7.4
              npm ERR! missing: console-control-strings@1.1.0, required by gauge@2.7.4
              npm ERR! missing: has-unicode@2.0.1, required by gauge@2.7.4
              npm ERR! missing: object-assign@4.1.1, required by gauge@2.7.4
              npm ERR! missing: signal-exit@3.0.7, required by gauge@2.7.4
              npm ERR! missing: string-width@1.0.2, required by gauge@2.7.4
              npm ERR! missing: strip-ansi@3.0.1, required by gauge@2.7.4
              npm ERR! missing: wide-align@1.1.5, required by gauge@2.7.4
              npm ERR! missing: code-point-at@1.1.0, required by string-width@1.0.2
              npm ERR! missing: is-fullwidth-code-point@1.0.0, required by string-width@1.0.2
              npm ERR! missing: strip-ansi@3.0.1, required by string-width@1.0.2
              npm ERR! missing: number-is-nan@1.0.1, required by is-fullwidth-code-point@1.0.0
              npm ERR! missing: ansi-regex@2.1.1, required by strip-ansi@3.0.1
              npm ERR! missing: string-width@1.0.2, required by wide-align@1.1.5
              npm ERR! missing: end-of-stream@1.4.4, required by pump@3.0.0
              npm ERR! missing: once@1.4.0, required by pump@3.0.0
              npm ERR! missing: once@1.4.0, required by end-of-stream@1.4.4
              npm ERR! missing: wrappy@1.0.2, required by once@1.4.0
              npm ERR! missing: deep-extend@0.6.0, required by rc@1.2.8
              npm ERR! missing: ini@1.3.8, required by rc@1.2.8
              npm ERR! missing: minimist@1.2.5, required by rc@1.2.8
              npm ERR! missing: strip-json-comments@2.0.1, required by rc@1.2.8
              npm ERR! missing: decompress-response@6.0.0, required by simple-get@4.0.1
              npm ERR! missing: once@1.4.0, required by simple-get@4.0.1
              npm ERR! missing: simple-concat@1.0.1, required by simple-get@4.0.1
              npm ERR! missing: mimic-response@3.1.0, required by decompress-response@6.0.0
              npm ERR! missing: chownr@1.1.4, required by tar-fs@2.1.1
              npm ERR! missing: mkdirp-classic@0.5.3, required by tar-fs@2.1.1
              npm ERR! missing: pump@3.0.0, required by tar-fs@2.1.1
              npm ERR! missing: tar-stream@2.2.0, required by tar-fs@2.1.1
              npm ERR! missing: bl@4.1.0, required by tar-stream@2.2.0
              npm ERR! missing: end-of-stream@1.4.4, required by tar-stream@2.2.0
              npm ERR! missing: fs-constants@1.0.0, required by tar-stream@2.2.0
              npm ERR! missing: inherits@2.0.4, required by tar-stream@2.2.0
              npm ERR! missing: readable-stream@3.6.0, required by tar-stream@2.2.0
              npm ERR! missing: readable-stream@3.6.0, required by bl@4.1.0
              npm ERR! missing: buffer@5.7.1, required by bl@4.1.0
              npm ERR! missing: inherits@2.0.4, required by bl@4.1.0
              npm ERR! missing: inherits@2.0.4, required by readable-stream@3.6.0
              npm ERR! missing: string_decoder@1.1.1, required by readable-stream@3.6.0
              npm ERR! missing: util-deprecate@1.0.2, required by readable-stream@3.6.0
              npm ERR! missing: base64-js@1.5.1, required by buffer@5.7.1
              npm ERR! missing: ieee754@1.2.1, required by buffer@5.7.1
              npm ERR! missing: safe-buffer@5.1.2, required by tunnel-agent@0.6.0
              npm ERR! missing: @serialport/parser-delimiter@9.2.4, required by @serialport/parser-readline@9.2.4
              npm ERR! missing: debug@4.3.3, required by @serialport/stream@9.2.4
              npm ERR! missing: eslint@8.9.0, required by zigbee-herdsman-converters@14.0.422
              npm ERR! missing: eslint-config-google@0.14.0, required by zigbee-herdsman-converters@14.0.422
              npm ERR! missing: eslint-plugin-jest@26.1.0, required by zigbee-herdsman-converters@14.0.422
              npm ERR! missing: jest@27.5.1, required by zigbee-herdsman-converters@14.0.422
              npm ERR! missing: axios@0.25.0, required by zigbee-herdsman-converters@14.0.422
              npm ERR! missing: buffer-crc32@0.2.13, required by zigbee-herdsman-converters@14.0.422
              npm ERR! missing: https-proxy-agent@5.0.0, required by zigbee-herdsman-converters@14.0.422
              npm ERR! missing: tar-stream@2.2.0, required by zigbee-herdsman-converters@14.0.422
              npm ERR! missing: zigbee-herdsman@0.14.14, required by zigbee-herdsman-converters@14.0.422
              npm ERR! missing: follow-redirects@1.14.8, required by axios@0.25.0
              npm ERR! missing: agent-base@6.0.2, required by https-proxy-agent@5.0.0
              npm ERR! missing: debug@4.3.3, required by https-proxy-agent@5.0.0
              npm ERR! missing: debug@4.3.3, required by agent-base@6.0.2
              npm ERR! missing: string_decoder@1.3.0, required by readable-stream@3.6.0
              npm ERR! missing: safe-buffer@5.2.1, required by string_decoder@1.3.0
              npm ERR! missing: @babel/cli@7.17.0, required by zigbee-herdsman@0.14.14
              npm ERR! missing: @babel/preset-env@7.16.11, required by zigbee-herdsman@0.14.14
              npm ERR! missing: @babel/preset-typescript@7.16.7, required by zigbee-herdsman@0.14.14
              npm ERR! missing: @types/debounce@1.2.1, required by zigbee-herdsman@0.14.14
              npm ERR! missing: @types/debug@4.1.7, required by zigbee-herdsman@0.14.14
              npm ERR! missing: @types/jest@27.4.0, required by zigbee-herdsman@0.14.14
              npm ERR! missing: @types/mz@2.7.4, required by zigbee-herdsman@0.14.14
              npm ERR! missing: @types/nedb@1.8.12, required by zigbee-herdsman@0.14.14
              npm ERR! missing: @types/serialport@8.0.2, required by zigbee-herdsman@0.14.14
              npm ERR! missing: @typescript-eslint/eslint-plugin@5.10.2, required by zigbee-herdsman@0.14.14
              npm ERR! missing: @typescript-eslint/parser@5.10.2, required by zigbee-herdsman@0.14.14
              npm ERR! missing: eslint@8.8.0, required by zigbee-herdsman@0.14.14
              npm ERR! missing: jest@27.5.0, required by zigbee-herdsman@0.14.14
              npm ERR! missing: typedoc@0.22.11, required by zigbee-herdsman@0.14.14
              npm ERR! missing: typedoc-plugin-markdown@3.11.13, required by zigbee-herdsman@0.14.14
              npm ERR! missing: typedoc-plugin-no-inherit@1.3.1, required by zigbee-herdsman@0.14.14
              npm ERR! missing: typedoc-plugin-sourcefile-url@1.0.6, required by zigbee-herdsman@0.14.14
              npm ERR! missing: typescript@4.5.5, required by zigbee-herdsman@0.14.14
              npm ERR! missing: debounce@1.2.1, required by zigbee-herdsman@0.14.14
              npm ERR! missing: debug@4.3.3, required by zigbee-herdsman@0.14.14
              npm ERR! missing: fast-deep-equal@3.1.3, required by zigbee-herdsman@0.14.14
              npm ERR! missing: mixin-deep@2.0.1, required by zigbee-herdsman@0.14.14
              npm ERR! missing: mz@2.7.0, required by zigbee-herdsman@0.14.14
              npm ERR! missing: serialport@9.2.8, required by zigbee-herdsman@0.14.14
              npm ERR! missing: slip@1.0.2, required by zigbee-herdsman@0.14.14
              npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
              npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce
              npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug
              npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest
              npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz
              npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb
              npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport
              npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
              npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
              npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint
              npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest
              npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc
              npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
              npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
              npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
              npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typescript
              Noch nen Tip wie ich das noch weg bekomme ?
              Thx Sunny
                @sunny9999 was ist wenn du
                npm cache clean --force
                machst
                  @arteck sagte in NPM List Fehler "npm ERR! peer dep missing":
                  Top ! Danke für den Tip, die UNMET DEPENDENCY´s sind nun weg
                  Jetzt hab ich noch bei NPM list :
                  Hier noch ne Idee wie ich die noch weg bekomme ?
                  Danke und Grüße
                  Sunny
                    @sunny9999 ja lass die finger von npm list..
                      @arteck
                      Danke, hast ja recht, wenns läuft und das tut es......also lass ich es..
                      Sunny
                        Thomas Braun Most Active @sunny9999 last edited by
                        @sunny9999
                        Die extraneous Pakete kannst du per
                        npm prune
                        noch rauswerfen.
                        801
