    3. Cloud Dienste
    4. kann Google Home nicht mehr (re)connecten!
    • frankjoke
      frankjoke last edited by frankjoke
      Ich kann seit gestern mein Google home nicht mehr (re)connecten!
      Kriege in IOT solche Fehlermeldungen:
      2022-03-29 17:23:24.344	error	[GHOME] devices are unknown to google home
      iot.0
      2022-03-29 17:23:14.552	warn	[GHOME] Missing name, type or treat for: alias.0.Keller.BewegungKellerUnten. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.552	warn	[GHOME] Missing name, type or treat for: alias.0.Keller.BewegungKellerOben. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.551	warn	[GHOME] Missing name, type or treat for: alias.0.Keller.BewegungAbstellraum. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.549	warn	[GHOME] Missing name, type or treat for: alias.0.EG.Wassermelder. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.549	warn	[GHOME] Missing name, type or treat for: alias.0.EG.WCEingang. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.548	warn	[GHOME] Missing name, type or treat for: alias.0.EG.WCAusgang. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.547	warn	[GHOME] Missing name, type or treat for: alias.0.EG.VorzimmerBewegung. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.547	warn	[GHOME] Missing name, type or treat for: alias.0.EG.TorSchalter. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.545	warn	[GHOME] Missing name, type or treat for: alias.0.EG.BewegungWC. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.545	warn	[GHOME] Missing name, type or treat for: alias.0.AZF.BewegungInnen. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.544	warn	[GHOME] Missing name, type or treat for: alias.0.AZF.BewegungAZFS. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.544	warn	[GHOME] Missing name, type or treat for: alias.0.AZF.BewegungAZF2. Not added to GoogleHome
      iot.0
      2022-03-29 17:23:14.542	warn	[GHOME] Missing name, type or treat for: alias.0.1Stock.Klimaanlage. Not added to GoogleHome
      iot.0
      2022-03-29 17:22:55.222	error	[GHOME] device alias.0.1Stock.TemperaturFZ.ACTUAL is unknown to google home
      iot.0
      2022-03-29 17:20:05.565	error	[GHOME] device alias.0.EG.TerassenTemperatur.SECOND is unknown to google home
      iot.0
      2022-03-29 17:18:49.809	error	[GHOME] device alias.0.GartenPool.GartenTemperatur.ACTUAL is unknown to google home
      iot.0
      2022-03-29 17:18:49.805	error	[GHOME] device alias.0.WZ.TempWZ1.SECOND is unknown to google home
      iot.0
      2022-03-29 17:18:11.200	error	[GHOME] device alias.0.1Stock.TemperaturFZ.SECOND is unknown to google home
      iot.0
      2022-03-29 17:15:56.519	error	[GHOME] device alias.0.EG.TerassenTemperatur.ACTUAL is unknown to google home
      iot.0
      2022-03-29 17:14:18.660	error	[GHOME] device alias.0.EG.Tado.SECOND is unknown to google home
      iot.0
      2022-03-29 17:14:18.658	error	[GHOME] device alias.0.EG.Tado.ACTUAL is unknown to google home
      iot.0
      2022-03-29 17:14:01.909	error	[GHOME] device alias.0.Zentrale.GPUtemp.ACTUAL is unknown to google home
      iot.0
      2022-03-29 17:14:01.846	error	[GHOME] device alias.0.Zentrale.CPUtemp.ACTUAL is unknown to google home
      iot.0
      2022-03-29 17:12:40.791	error	[GHOME] device alias.0.GartenPool.GartenTemperatur.SECOND is unknown to google home
      iot.0
      2022-03-29 17:12:40.607	error	[GHOME] device alias.0.WZ.TempWZ1.ACTUAL is unknown to google home
      iot.0
      2022-03-29 17:09:28.112	error	[GHOME] device alias.0.1Stock.TemperaturSZ.ACTUAL is unknown to google home
      Bis gestern hat's funktioniert, nur mit warnings.
      Übrigens: Wie kann ich geräte aus dem Google-interface ausblenden? Wenn ich das Gerät in der Liste mit dem Mistkübel lösche taucht es immer wieder auf!
      Ich will nur 5-6 meiner Geräte für Google assistant nutzbar machen aber nicht alles (z.B. den Teil der oben Fehler macht)!
        holofury @frankjoke last edited by
        @frankjoke
        Gibt es hierfür jetzt eine Lösung?
        Habe das gleiche Problem - ioBroker aus Google Home entfernt, neu verbinden funktioniert nicht, ebenfalls mit u.a. dieser Meldung im Log:
        • crunchip
          crunchip Forum Testing Most Active last edited by crunchip
          Info:
          Habe gestern ein Update der Google Home App gemacht, seither wurden alle Geräte entfernt, keine Verbindung mehr zu iobroker möglich.
          • crunchip
            Gibt es bezüglich google home Update noch andere mit diesem Problem?
            Marius Schäfer 1 Reply Last reply Reply Quote 0
            • Marius Schäfer
              Marius Schäfer @crunchip last edited by
              Habe heute upgedated und meine Geräte sind auch alle weg.
              • crunchip
                crunchip Forum Testing Most Active @Marius Schäfer last edited by
                @marius-schäfer dann bin ich schon mal nicht alleine, wundert mich allerdings das aktuell nicht noch mehr von diesem Problem zu lesen ist, nutzen ja doch einige google/iobroker
                • Marius Schäfer
                  @crunchip Ja..
                  [GHOME] No devices defined. Did you add no sensors or indicate states to rooms and enums?
                  • crunchip
                    @marius-schäfer ich habe jetzt im iot google ausgeschaltet und gespeichert, anschliessend google wieder aktiviert, jetzt konnte ich iobroker wieder in der home App zufügen
                    • Marius Schäfer
                      @crunchip Ich habe ein downgrade auf 1.11.5 gemacht und es geht.
