    4. [Gelöst] HM HM-CC-RT-DN Xiaomi Fensterkontakt
      seppel786 last edited by seppel786
      ich versuche gerade mittels einfachem JS Script meine Heizungsaktoren zu schalten:
      on({id: 'zigbee.0.00158d0002b52ab1.opened', change: "ne"}, function(obj) {
          if (obj.state.val == true) {
              setState('hm-rpc.0.PEQ1191283.4.AUTO_MODE', 12);
              log('Fenster auf - Heizung aus');
          } else {
              setState('hm-rpc.0.PEQ1191283.4.AUTO_MODE', true);
              log('Fenster zu - Heizung an')
      Im Log bekomme ich folgende Fehlermeldung:
      javascript.0
      	2022-04-20 17:43:47.440	info	Stop script script.js.Skripte.Klima.Koppelung_Heizung_Fenster
      javascript.0
      	2022-04-20 17:37:27.124	info	script.js.Skripte.Klima.Koppelung_Heizung_Fenster: Fenster zu - Heizung an
      hm-rpc.0
      	2022-04-20 17:37:18.710	error	Cannot call setValue: XML-RPC fault: Failure
      hm-rpc.0
      	2022-04-20 17:37:18.710	error	xmlrpc -> setValue ["PEQ1191283:4","AUTO_MODE",12] ACTION
      javascript.0
      	2022-04-20 17:37:18.702	info	State value to set for "hm-rpc.0.PEQ1191283.4.AUTO_MODE" has to be type "boolean" but received type "number"
      javascript.0
      	2022-04-20 17:37:18.684	info	script.js.Skripte.Klima.Koppelung_Heizung_Fenster: Fenster auf - Heizung aus
      javascript.0
      	2022-04-20 17:37:18.683	warn	at processImmediate (internal/timers.js:464:21)
      javascript.0
      	2022-04-20 17:37:18.683	warn	at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5909:56)
      javascript.0
      	2022-04-20 17:37:18.683	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:530:29)
      javascript.0
      	2022-04-20 17:37:18.683	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1082:38)
      javascript.0
      	2022-04-20 17:37:18.683	warn	at Object.<anonymous> (script.js.Skripte.Klima.Koppelung_Heizung_Fenster:7:9)
      javascript.0
      	2022-04-20 17:37:18.682	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1437:20)
      javascript.0
      	2022-04-20 17:37:18.678	warn	You are assigning a number to the state "hm-rpc.0.PEQ1191283.4.AUTO_MODE" which expects a boolean. Please fix your code to use a boolean or change the state type to number. This warning might become an error in future versions.
      javascript.0
      	2022-04-20 17:37:03.485	info	script.js.Skripte.Klima.Koppelung_Heizung_Fenster: registered 1 subscription and 0 schedules
      javascript.0
      	2022-04-20 17:37:03.470	info	Start javascript script.js.Skripte.Klima.Koppelung_Heizung_Fenster
      javascript.0
      	2022-04-20 17:37:02.576	info	Stop script script.js.Skripte.Klima.Koppelung_Heizung_Fenster
      Hätte jemand für mich einen Rat, warum ich die Fehlermeldung erhalte?
      Dsnke und Grüße,
      Seppel
        paul53 @seppel786 last edited by
        @seppel786
        Die Fenster-Offen-Temperatur (12) muss in "MANU_MODE" geschrieben werden.
          seppel786 @paul53 last edited by
          Tja wie so oft liegt das Problem 30 cm vor dem Bildschirm 🙂
          Skript ist nun angepasst:
          on({id: 'zigbee.0.00158d0002b52da0.opened', change: "ne"}, function(obj) {
                  setState('hm-rpc.0.REQ0841908.4.MANU_MODE', 12);
              } else {
                  setState('hm-rpc.0.REQ0841908.4.AUTO_MODE', true);
                  log('Fenster zu - Heizung an');
          Allerdings bekomme ich immer noch eine Fehlermeldung:
          hm-rpc.0
          	2022-04-21 18:49:04.100	error	Cannot call setValue: XML-RPC fault: Failure
          hm-rpc.0
          	2022-04-21 18:49:04.099	error	xmlrpc -> setValue ["REQ0841908:4","AUTO_MODE",true] ACTION
          javascript.0
          	2022-04-21 18:49:01.562	info	script.js.Skripte.Klima.Koppelung_Heizung_Fenster: Fenster zu - Heizung an
          hm-rpc.0
          	2022-04-21 18:49:00.117	error	Cannot call setValue: XML-RPC fault: Failure
          hm-rpc.0
          	2022-04-21 18:49:00.109	error	xmlrpc -> setValue ["REQ0841908:4","MANU_MODE",12] FLOAT
          javascript.0
          	2022-04-21 18:48:57.563	info	script.js.Skripte.Klima.Koppelung_Heizung_Fenster: Fenster auf - Heizung aus
            paul53 @seppel786 last edited by paul53
            @seppel786 sagte: bekomme ich immer noch eine Fehlermeldung:
            Das liegt sicherlich nicht am Skript, wenn die SN stimmt. Lassen sich die Datenpunkt-Werte im Tab "Objekte" ändern?
              @paul53 Das Problem lag tatsächlich an meinen HM Aktoren. Nach neuem Anlernen hat das Skript funktioniert.
              Danke und Gruß,
              Seppel
