    4. Zigbee mal wieder kaputt
      mpl1338 last edited by
      Zigbee Adapter startet mal wieder nicht korrekt. Kann jemand das problem lösen?
      iobroker
      Plattform
      linux
      Betriebssystem
      linux
      Architektur
      x64
      CPUs
      Geschwindigkeit
      3600 MHz
      Modell
      Intel(R) Core(TM) i3-8109U CPU @ 3.00GHz
      RAM
      4 GB
      System-Betriebszeit
      00:27:25
      Node.js
      v14.19.1
      time
      1650651619032
      timeOffset
      -120
      Anzahl der Adapter
      490
      NPM
      6.14.16
      Datenträgergröße
      12 GB
      freier Festplattenspeicher
      5.85 GB
      Betriebszeit
      00:22:23
      Aktive Instanzen
      27
      Weg
      /opt/iobroker/
      Hostname
      iobroker
      zigbee.0
      2022-04-22 20:22:57.873	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1650651777869,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651377248}
      zigbee.0
      2022-04-22 20:22:57.872	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'\". undefined","ack":true,"ts":1650651777869,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651553035}
      zigbee.0
      2022-04-22 20:22:57.863	error	Error herdsman start
      zigbee.0
      2022-04-22 20:22:57.863	error	Failed to start Zigbee
      zigbee.0
      2022-04-22 20:22:57.861	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'"
      zigbee.0
      2022-04-22 20:22:57.765	info	Installed Version: iobroker.zigbee@1.6.18
      zigbee.0
      2022-04-22 20:22:57.744	debug	Starting zigbee-herdsman...
      zigbee.0
      2022-04-22 20:22:57.744	info	Starting Zigbee npm ...
      zigbee.0
      2022-04-22 20:22:57.744	info	Try to reconnect. 1 attempts left
      zigbee.0
      2022-04-22 20:22:47.773	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1650651767751,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651377248}
      zigbee.0
      2022-04-22 20:22:47.773	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'\". undefined","ack":true,"ts":1650651767751,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651553035}
      zigbee.0
      2022-04-22 20:22:47.753	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_04_22-20_22_47.tar.gz success
      zigbee.0
      2022-04-22 20:22:47.751	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1650651767750,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651377248}
      zigbee.0
      2022-04-22 20:22:47.748	info	Installed Version: iobroker.zigbee@1.6.18
      zigbee.0
      2022-04-22 20:22:47.742	error	Error herdsman start
      zigbee.0
      2022-04-22 20:22:47.742	error	Failed to start Zigbee
      zigbee.0
      2022-04-22 20:22:47.741	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'"
      zigbee.0
      2022-04-22 20:22:47.710	silly	States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1650651767587,"q":0,"from":"system.adapter.zigbee.0","lc":1650651674279}
      zigbee.0
      2022-04-22 20:22:47.524	debug	Starting zigbee-herdsman...
      zigbee.0
      2022-04-22 20:22:47.523	info	Starting Zigbee npm ...
      zigbee.0
      2022-04-22 20:22:47.505	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[x],"extenedPanID":[x]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":true}}
      zigbee.0
      2022-04-22 20:22:47.492	info	starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.23
      zigbee.0
      2022-04-22 20:22:47.366	debug	Plugin sentry Initialize Plugin (enabled=true)
      zigbee.0
      2022-04-22 20:22:47.310	silly	statesDB connected
      zigbee.0
      2022-04-22 20:22:47.310	debug	States connected to redis: 127.0.0.1:9000
      zigbee.0
      2022-04-22 20:22:47.300	debug	States create User PubSub Client
      zigbee.0
      2022-04-22 20:22:47.300	debug	States create System PubSub Client
      zigbee.0
      2022-04-22 20:22:47.294	debug	Redis States: Use Redis connection: 127.0.0.1:9000
      zigbee.0
      2022-04-22 20:22:47.293	silly	objectDB connected
      zigbee.0
      2022-04-22 20:22:47.291	silly	redis psubscribe cfg.o.enum.*
      zigbee.0
      2022-04-22 20:22:47.281	silly	redis psubscribe cfg.o.system.user.*
      zigbee.0
      2022-04-22 20:22:47.280	debug	Objects connected to redis: 127.0.0.1:9001
      zigbee.0
      2022-04-22 20:22:47.278	debug	Objects client initialize lua scripts
      zigbee.0
      2022-04-22 20:22:47.260	debug	Objects create User PubSub Client
      zigbee.0
      2022-04-22 20:22:47.259	debug	Objects create System PubSub Client
      zigbee.0
      2022-04-22 20:22:47.259	debug	Objects client ready ... initialize now
      zigbee.0
      2022-04-22 20:22:47.239	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
      host.iobroker
      2022-04-22 20:22:46.398	info	instance system.adapter.zigbee.0 started with pid 2867
      host.iobroker
      2022-04-22 20:22:44.053	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      zigbee.0
      2022-04-22 20:22:43.602	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0005816448.link_quality:{"val":0,"ack":true,"ts":1650651763583,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471794}
      zigbee.0
      2022-04-22 20:22:43.601	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0005816448.available:{"val":false,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.599	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000577ed85.link_quality:{"val":0,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.598	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000577ed85.available:{"val":false,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.598	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000581710d.link_quality:{"val":0,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.596	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000581710d.available:{"val":false,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.595	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006954782.link_quality:{"val":0,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.594	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006954782.available:{"val":false,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.593	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b36df2.link_quality:{"val":0,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.592	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b36df2.available:{"val":false,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.592	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b3f166.link_quality:{"val":0,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.590	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b3f166.available:{"val":false,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.589	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400e524.link_quality:{"val":0,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
      zigbee.0
      2022-04-22 20:22:43.588	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400e524.available:{"val":false,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471697}
      zigbee.0
      2022-04-22 20:22:43.587	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400c2e0.link_quality:{"val":0,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471695}
      zigbee.0
      2022-04-22 20:22:43.586	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400c2e0.available:{"val":false,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471695}
      zigbee.0
      2022-04-22 20:22:43.585	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000416c1e5.link_quality:{"val":0,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471695}
      zigbee.0
      2022-04-22 20:22:43.583	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000416c1e5.available:{"val":false,"ack":true,"ts":1650651763582,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471694}
      zigbee.0
      2022-04-22 20:22:43.571	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.undefinedDevices:{"val":"{}","ack":true,"ts":1650651763563,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651435076}
      zigbee.0
      2022-04-22 20:22:43.517	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      zigbee.0
      2022-04-22 20:22:43.516	debug	Plugin sentry destroyed
      zigbee.0
      2022-04-22 20:22:43.516	info	terminating
      zigbee.0
      2022-04-22 20:22:43.516	warn	Failed to stop zigbee during startup
      zigbee.0
      2022-04-22 20:22:43.404	info	Zigbee: disabling joining new devices.
      zigbee.0
      2022-04-22 20:22:43.401	debug	onDeviceStatusUpdate: 00158d0005816448: false
      zigbee.0
      2022-04-22 20:22:43.400	debug	DeviceAvailability:Publish LQ for 0x00158d0005816448 = 0
      zigbee.0
      2022-04-22 20:22:43.399	debug	DeviceAvailability:Publish available for 0x00158d0005816448 = false
      zigbee.0
      2022-04-22 20:22:43.399	debug	onDeviceStatusUpdate: 00158d000577ed85: false
      zigbee.0
      2022-04-22 20:22:43.399	debug	DeviceAvailability:Publish LQ for 0x00158d000577ed85 = 0
      zigbee.0
      2022-04-22 20:22:43.397	debug	DeviceAvailability:Publish available for 0x00158d000577ed85 = false
      zigbee.0
      2022-04-22 20:22:43.397	debug	onDeviceStatusUpdate: 00158d000581710d: false
      zigbee.0
      2022-04-22 20:22:43.396	debug	DeviceAvailability:Publish LQ for 0x00158d000581710d = 0
      zigbee.0
      2022-04-22 20:22:43.395	debug	DeviceAvailability:Publish available for 0x00158d000581710d = false
      zigbee.0
      2022-04-22 20:22:43.395	debug	onDeviceStatusUpdate: 00158d0006954782: false
      zigbee.0
      2022-04-22 20:22:43.394	debug	DeviceAvailability:Publish LQ for 0x00158d0006954782 = 0
      zigbee.0
      2022-04-22 20:22:43.390	debug	DeviceAvailability:Publish available for 0x00158d0006954782 = false
      zigbee.0
      2022-04-22 20:22:43.390	debug	onDeviceStatusUpdate: 00158d0006b36df2: false
      zigbee.0
      2022-04-22 20:22:43.389	debug	DeviceAvailability:Publish LQ for 0x00158d0006b36df2 = 0
      zigbee.0
      2022-04-22 20:22:43.388	debug	DeviceAvailability:Publish available for 0x00158d0006b36df2 = false
      zigbee.0
      2022-04-22 20:22:43.388	debug	onDeviceStatusUpdate: 00158d0006b3f166: false
      zigbee.0
      2022-04-22 20:22:43.387	debug	DeviceAvailability:Publish LQ for 0x00158d0006b3f166 = 0
      zigbee.0
      2022-04-22 20:22:43.386	debug	DeviceAvailability:Publish available for 0x00158d0006b3f166 = false
      zigbee.0
      2022-04-22 20:22:43.386	debug	onDeviceStatusUpdate: 00158d000400e524: false
      zigbee.0
      2022-04-22 20:22:43.385	debug	DeviceAvailability:Publish LQ for 0x00158d000400e524 = 0
      zigbee.0
      2022-04-22 20:22:43.384	debug	DeviceAvailability:Publish available for 0x00158d000400e524 = false
      zigbee.0
      2022-04-22 20:22:43.384	debug	onDeviceStatusUpdate: 00158d000400c2e0: false
      zigbee.0
      2022-04-22 20:22:43.383	debug	DeviceAvailability:Publish LQ for 0x00158d000400c2e0 = 0
      zigbee.0
      2022-04-22 20:22:43.382	debug	DeviceAvailability:Publish available for 0x00158d000400c2e0 = false
      zigbee.0
      2022-04-22 20:22:43.381	debug	onDeviceStatusUpdate: 00158d000416c1e5: false
      zigbee.0
      2022-04-22 20:22:43.375	debug	DeviceAvailability:Publish LQ for 0x00158d000416c1e5 = 0
      zigbee.0
      2022-04-22 20:22:43.370	debug	DeviceAvailability:Publish available for 0x00158d000416c1e5 = false
      zigbee.0
      2022-04-22 20:22:43.368	info	cleaned everything up...
      zigbee.0
      2022-04-22 20:22:43.367	info	Got terminate signal TERMINATE_YOURSELF
      zigbee.0
      2022-04-22 20:22:43.367	silly	States system redis pmessage system.adapter.zigbee.0.sigKill/system.adapter.zigbee.0.sigKill:{"val":-1,"ack":false,"ts":1650651763364,"q":0,"from":"system.host.iobroker","lc":1650651763364}
      host.iobroker
      2022-04-22 20:22:43.365	info	stopInstance system.adapter.zigbee.0 send kill signal
      Thomas Braun Asgothian 3 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @mpl1338 last edited by Thomas Braun
        @mpl1338 sagte in Zigbee mal wieder kaputt:
        /dev/ttyACM0
        Sicher das /dev/ttyACM0 dar richtige Device ist?
        Stell den Device Link aus
        ls -l /dev/serial/by-id/
        ein. Der ändert sich für den Stick nie.
        Ist das mal wieder Proxmox oder ähnliches Virtuelles Zeuch?
          Schalt das mal aus, damit man sieht was da ggf. noch im Argen liegt.
          • Asgothian
            Asgothian Developer @Thomas Braun last edited by
            • Asgothian
              Asgothian Developer @mpl1338 last edited by
              @mpl1338 du hast ein Problem mit deiner seriellen Schnittstelle:
              da stimmt etwas mit der Hardware oder dem OS nicht.
              A.
                Thomas Braun Most Active @Asgothian last edited by
                @asgothian sagte in Zigbee mal wieder kaputt:
                Ja, deswegen die Frage ob das ein Container oder VM oder sowas ist.
                  ok hier nochgmal:
                  zigbee.0
                  2022-04-23 09:47:35.471	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1650700055469,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651377248}
                  zigbee.0
                  2022-04-23 09:47:35.471	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'\". undefined","ack":true,"ts":1650700055469,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651553035}
                  zigbee.0
                  2022-04-23 09:47:35.465	error	Error herdsman start
                  zigbee.0
                  2022-04-23 09:47:35.465	error	Failed to start Zigbee
                  zigbee.0
                  2022-04-23 09:47:35.465	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'"
                  zigbee.0
                  2022-04-23 09:47:35.374	info	Installed Version: iobroker.zigbee@1.6.18
                  zigbee.0
                  2022-04-23 09:47:35.366	debug	Starting zigbee-herdsman...
                  zigbee.0
                  2022-04-23 09:47:35.366	info	Starting Zigbee npm ...
                  zigbee.0
                  2022-04-23 09:47:35.365	info	Try to reconnect. 1 attempts left
                  zigbee.0
                  2022-04-23 09:47:25.396	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1650700045378,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651377248}
                  zigbee.0
                  2022-04-23 09:47:25.396	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.pairingMessage:{"val":"Error: Starting zigbee-herdsman problem : \"Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'\". undefined","ack":true,"ts":1650700045377,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651553035}
                  zigbee.0
                  2022-04-23 09:47:25.377	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.connection:{"val":false,"ack":true,"ts":1650700045373,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651377248}
                  zigbee.0
                  2022-04-23 09:47:25.375	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2022_04_23-09_47_25.tar.gz success
                  zigbee.0
                  2022-04-23 09:47:25.365	error	Error herdsman start
                  zigbee.0
                  2022-04-23 09:47:25.365	error	Failed to start Zigbee
                  zigbee.0
                  2022-04-23 09:47:25.364	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200'"
                  zigbee.0
                  2022-04-23 09:47:25.332	info	Installed Version: iobroker.zigbee@1.6.18
                  zigbee.0
                  2022-04-23 09:47:25.292	silly	States system redis pmessage system.adapter.zigbee.0.logLevel/system.adapter.zigbee.0.logLevel:{"val":"silly","ack":true,"ts":1650700045210,"q":0,"from":"system.adapter.zigbee.0","lc":1650651674279}
                  zigbee.0
                  2022-04-23 09:47:25.152	debug	Starting zigbee-herdsman...
                  zigbee.0
                  2022-04-23 09:47:25.152	info	Starting Zigbee npm ...
                  zigbee.0
                  2022-04-23 09:47:25.134	debug	Using zigbee-herdsman with settings: {"network":{"panID":6754,"channelList":[11],"networkKey":[x],"extenedPanID":[x]},"databasePath":"/opt/iobroker/iobroker-data/zigbee_0/shepherd.db","backupPath":"/opt/iobroker/iobroker-data/zigbee_0/nvbackup.json","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"adapter":{"forceStartWithInconsistentAdapterConfiguration":false}}
                  zigbee.0
                  2022-04-23 09:47:25.120	info	starting. Version 1.6.18 in /opt/iobroker/node_modules/iobroker.zigbee, node: v14.19.1, js-controller: 4.0.23
                  zigbee.0
                  2022-04-23 09:47:25.003	debug	Plugin sentry Initialize Plugin (enabled=true)
                  zigbee.0
                  2022-04-23 09:47:24.949	silly	statesDB connected
                  zigbee.0
                  2022-04-23 09:47:24.949	debug	States connected to redis: 127.0.0.1:9000
                  zigbee.0
                  2022-04-23 09:47:24.939	debug	States create User PubSub Client
                  zigbee.0
                  2022-04-23 09:47:24.938	debug	States create System PubSub Client
                  zigbee.0
                  2022-04-23 09:47:24.932	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                  zigbee.0
                  2022-04-23 09:47:24.931	silly	objectDB connected
                  zigbee.0
                  2022-04-23 09:47:24.929	silly	redis psubscribe cfg.o.enum.*
                  zigbee.0
                  2022-04-23 09:47:24.920	silly	redis psubscribe cfg.o.system.user.*
                  zigbee.0
                  2022-04-23 09:47:24.919	debug	Objects connected to redis: 127.0.0.1:9001
                  zigbee.0
                  2022-04-23 09:47:24.917	debug	Objects client initialize lua scripts
                  zigbee.0
                  2022-04-23 09:47:24.900	debug	Objects create User PubSub Client
                  zigbee.0
                  2022-04-23 09:47:24.900	debug	Objects create System PubSub Client
                  zigbee.0
                  2022-04-23 09:47:24.899	debug	Objects client ready ... initialize now
                  zigbee.0
                  2022-04-23 09:47:24.878	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                  host.iobroker
                  2022-04-23 09:47:24.050	info	instance system.adapter.zigbee.0 started with pid 46805
                  host.iobroker
                  2022-04-23 09:47:21.631	info	instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  zigbee.0
                  2022-04-23 09:47:21.170	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0005816448.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471794}
                  zigbee.0
                  2022-04-23 09:47:21.169	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0005816448.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.169	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000577ed85.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.167	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000577ed85.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.165	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000581710d.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.165	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000581710d.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.165	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006954782.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.156	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006954782.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.156	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b36df2.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.155	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b36df2.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.154	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b3f166.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.153	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d0006b3f166.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.153	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400e524.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471739}
                  zigbee.0
                  2022-04-23 09:47:21.151	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400e524.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471697}
                  zigbee.0
                  2022-04-23 09:47:21.146	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400c2e0.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471695}
                  zigbee.0
                  2022-04-23 09:47:21.141	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000400c2e0.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471695}
                  zigbee.0
                  2022-04-23 09:47:21.140	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000416c1e5.link_quality:{"val":0,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471695}
                  zigbee.0
                  2022-04-23 09:47:21.139	silly	States user redis pmessage zigbee.0.*/zigbee.0.00158d000416c1e5.available:{"val":false,"ack":true,"ts":1650700041137,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651471694}
                  zigbee.0
                  2022-04-23 09:47:21.128	silly	States user redis pmessage zigbee.0.*/zigbee.0.info.undefinedDevices:{"val":"{}","ack":true,"ts":1650700041107,"q":0,"from":"system.adapter.zigbee.0","user":"system.user.admin","lc":1650651435076}
                  zigbee.0
                  2022-04-23 09:47:21.091	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  zigbee.0
                  2022-04-23 09:47:21.090	debug	Plugin sentry destroyed
                  zigbee.0
                  2022-04-23 09:47:21.090	info	terminating
                  zigbee.0
                  2022-04-23 09:47:21.088	warn	Failed to stop zigbee during startup
                  zigbee.0
                  2022-04-23 09:47:21.039	info	Zigbee: disabling joining new devices.
                  zigbee.0
                  2022-04-23 09:47:21.037	debug	onDeviceStatusUpdate: 00158d0005816448: false
                  zigbee.0
                  2022-04-23 09:47:21.036	debug	DeviceAvailability:Publish LQ for 0x00158d0005816448 = 0
                  zigbee.0
                  2022-04-23 09:47:21.036	debug	onDeviceStatusUpdate: 00158d000577ed85: false
                  zigbee.0
                  2022-04-23 09:47:21.035	debug	DeviceAvailability:Publish LQ for 0x00158d000577ed85 = 0
                  zigbee.0
                  2022-04-23 09:47:21.036	debug	DeviceAvailability:Publish available for 0x00158d0005816448 = false
                  zigbee.0
                  2022-04-23 09:47:21.034	debug	DeviceAvailability:Publish available for 0x00158d000577ed85 = false
                  zigbee.0
                  2022-04-23 09:47:21.034	debug	onDeviceStatusUpdate: 00158d000581710d: false
                  zigbee.0
                  2022-04-23 09:47:21.033	debug	DeviceAvailability:Publish available for 0x00158d000581710d = false
                  zigbee.0
                  2022-04-23 09:47:21.033	debug	onDeviceStatusUpdate: 00158d0006954782: false
                  zigbee.0
                  2022-04-23 09:47:21.033	debug	DeviceAvailability:Publish LQ for 0x00158d000581710d = 0
                  zigbee.0
                  2022-04-23 09:47:21.032	debug	DeviceAvailability:Publish LQ for 0x00158d0006954782 = 0
                  zigbee.0
                  2022-04-23 09:47:21.031	debug	DeviceAvailability:Publish available for 0x00158d0006954782 = false
                  zigbee.0
                  2022-04-23 09:47:21.031	debug	onDeviceStatusUpdate: 00158d0006b36df2: false
                  zigbee.0
                  2022-04-23 09:47:21.030	debug	DeviceAvailability:Publish LQ for 0x00158d0006b36df2 = 0
                  zigbee.0
                  2022-04-23 09:47:21.030	debug	DeviceAvailability:Publish available for 0x00158d0006b36df2 = false
                  zigbee.0
                  2022-04-23 09:47:21.030	debug	onDeviceStatusUpdate: 00158d0006b3f166: false
                  zigbee.0
                  2022-04-23 09:47:21.029	debug	DeviceAvailability:Publish LQ for 0x00158d0006b3f166 = 0
                  zigbee.0
                  2022-04-23 09:47:21.028	debug	DeviceAvailability:Publish available for 0x00158d0006b3f166 = false
                  zigbee.0
                  2022-04-23 09:47:21.028	debug	onDeviceStatusUpdate: 00158d000400e524: false
                  zigbee.0
                  2022-04-23 09:47:21.027	debug	DeviceAvailability:Publish LQ for 0x00158d000400e524 = 0
                  zigbee.0
                  2022-04-23 09:47:21.026	debug	DeviceAvailability:Publish available for 0x00158d000400e524 = false
                  zigbee.0
                  2022-04-23 09:47:21.026	debug	onDeviceStatusUpdate: 00158d000400c2e0: false
                  zigbee.0
                  2022-04-23 09:47:21.025	debug	DeviceAvailability:Publish LQ for 0x00158d000400c2e0 = 0
                  zigbee.0
                  2022-04-23 09:47:21.023	debug	DeviceAvailability:Publish available for 0x00158d000400c2e0 = false
                  zigbee.0
                  2022-04-23 09:47:21.022	debug	onDeviceStatusUpdate: 00158d000416c1e5: false
                  zigbee.0
                  2022-04-23 09:47:21.019	debug	DeviceAvailability:Publish LQ for 0x00158d000416c1e5 = 0
                  zigbee.0
                  2022-04-23 09:47:21.016	debug	DeviceAvailability:Publish available for 0x00158d000416c1e5 = false
                  zigbee.0
                  2022-04-23 09:47:21.014	info	cleaned everything up...
                  host.iobroker
                  2022-04-23 09:47:21.015	info	stopInstance system.adapter.zigbee.0 send kill signal
                  zigbee.0
                  2022-04-23 09:47:21.014	silly	States system redis pmessage system.adapter.zigbee.0.sigKill/system.adapter.zigbee.0.sigKill:{"val":-1,"ack":false,"ts":1650700041013,"q":0,"from":"system.host.iobroker","lc":1650700041013}
                  zigbee.0
                  2022-04-23 09:47:21.014	info	Got terminate signal TERMINATE_YOURSELF
                  IOB läuft auf einem Proxmox Container
                  ls -l /dev/ttyACM0
                  -------rw- 1 root root 0 Apr 22 19:53 /dev/ttyACM0
                    @mpl1338
                    Gut, Container also...
                    Auf einem nativen System schaut das jedenfalls so aus:
                    ls -l /dev/ttyAMA0
                    crw-rw---- 1 root dialout 204, 64 Apr 23 01:04 /dev/ttyAMA0
                    Mein zigbee-Stick wird aber auch woanders (nämlich /dev/ttyUSB0) eingehängt:
                    ls -la /dev/serial/by-id/
                    total 0
                    drwxr-xr-x 2 root root 60 Apr 23 01:04 .
                    drwxr-xr-x 4 root root 80 Apr 23 01:04 ..
                    lrwxrwxrwx 1 root root 13 Apr 23 01:04 usb-Silicon_Labs_slae.sh_cc2652rb_stick_-_slaesh_s_iot_stuff_00_12_4B_00_23_93_2C_A8-if00-port0 -> ../../ttyUSB0
                    ls -l /dev/ttyUSB0
                    crw-rw---- 1 root dialout 188, 0 Apr 23 09:25 /dev/ttyUSB0
                      Ich weiß jetzt nicht warum, es geht jedoch wieder.
                      lsusb
                      Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                      Bus 001 Device 002: ID 0451:16c8 Texas Instruments, Inc.
                      Bus 001 Device 003: ID 8087:0aaa Intel Corp.
                      Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                      ls -l /dev/ttyACM0
                      crw-rw---- 1 root dialout 166, 0 Apr 23 10:21 /dev/ttyACM0
                      habe gestern 100te mal neu gestartet und nichts ist passiert. Eben nochmal neu gestartet und er findet ihn wieder
                        @mpl1338
                        Dann stell den Link aus /dev/serial/by-id ein. Der ist robuster bei Neustarts.
                          gibts nicht
                          ls: cannot access '/dev/serial/by-id/': No such file or directory
                          Thomas Braun S G 3 Replies Last reply Reply Quote 0
                            @mpl1338
                            Gut, liegt vielleicht an dem Container-Gedöns.
                            Ich weiß schon, warum ich das nicht verwende.
                              Snopy_16 @mpl1338 last edited by
                              @mpl1338 Ich hatte auch mal den Fehler, Iobroker lief aber auf einem Raspi PI 4.
                              da war die serielle Schnittstelle nicht aktiviert.
                              • G
                                guergen @mpl1338 last edited by guergen
                                Normal geht der Befehl unter Proxmox!
                                Hast Du den Stick auch richtig an den Container weitergegeben? Als VM ist das wesendlich entspannter!
                                Schau Dir das mal an : https://coldcorner.de/2018/07/12/proxmox-usb-passthrough-fuer-lxc-container-z-wave-uzb1/
                                  ich habe die USB weitergabe nach der von dir geposteten Anleitung vor nem Jahr eingerichtet. Ohne dies ging Garnichts
                                  • G
                                    @mpl1338 Und das heisst jetzt?
                                    Geht das nicht mehr?
                                      Diamand2k22 @guergen last edited by
                                      ich hab das Problem, dass die Rechte bei dem Sonoff Zigbee Stick nicht passen.
                                      Wie kann ich dem Stick die nötigen Rechte verpassen?
                                      Bei mir sieht das ganze so aus:
                                      proxmox@zigbee2mqtt:/opt/zigbee2mqtt$ ls -la /dev/serial/by-id/
                                      total 0
                                      drwxr-xr-x 2 root root 60 Feb 21 18:54 .
                                      drwxr-xr-x 3 root root 60 Feb 21 18:54 ..
                                      ---------- 1 root root  0 Feb 21 18:54 usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
                                      aktuell bekomme ich beim start von zigbee den Fehler:
                                      Starting Zigbee2MQTT without watchdog.
                                      [2025-02-21 19:03:02] error:    z2m: Error while starting zigbee-herdsman
                                      [2025-02-21 19:03:02] error:    z2m: Failed to start zigbee-herdsman
                                      [2025-02-21 19:03:02] error:    z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
                                      [2025-02-21 19:03:02] error:    z2m: Exiting...
                                      [2025-02-21 19:03:02] error:    z2m: Error: Error: Inappropriate ioctl for device setting custom baud rate of 115200
                                       ELIFECYCLE  Command failed with exit code 1.
                                      1404
