    5. [gelöst]nodejs net server beenden
      stoffel67 last edited by stoffel67
      ich versuche gerade einen TCP Server aufzusetzen.
      das funktioniert auch, aber wie beende ich den Server?
      Beim Stoppen des Scripts und Neustart bekomme ich
      Error: listen EADDRINUSE: address already in use :::85
      hier mal mein script:
      var net = require('net');
      // Configuration parameters
      var HOST = 'localhost';
      var PORT = 85;
      // Create Server instance
      var server = net.createServer(onClientConnected);
      server.listen(PORT,  function() {
        console.log('server listening on '+ server.address(0));
      server.on('error', function (e) {
        if (e.code == 'EADDRINUSE') {
          console.log('Address in use, retrying...');
          setTimeout(function () {
            server.close();
            console.log(server.connections)
            server.listen(PORT, HOST);
          }, 1000);
      function onClientConnected(sock) {
        var remoteAddress = sock.remoteAddress + ':' + sock.remotePort;
        console.log('new client connected:'+ remoteAddress);
        sock.on('data', function(data) {
          console.log('Says:'+ data);
          //sock.write(data);
          setze_Input_state(data);
          //sock.write(' exit');
        sock.on('close',  function () {
          console.log('connection from %s closed'+ remoteAddress);
        sock.on('error', function (err) {
          console.log('Connection %s error: %s'+ remoteAddress+ err.message);
          // close connection if script stopped
        onStop(function (callback) {
         // if (client) {
              // close connection
              sock.end();
              //sock.unref();
              //server.destroy();
                  console.log('Connection DESTROYED');
          callback();
         }, 2000 /*ms*/);
      wie kann ich den Server beenden und neu Starten??
        stoffel67 @stoffel67 last edited by
        @stoffel67 said in nodejs net server beenden:
        Fehler gefunden:
              // close connection
                server.close();
                //sock.unref();
        ich muss den Server beenden, nicht den "socket"😌
        javascript
