    4. [erledigt]jarvis: Failed connecting to http://192.168.2....
      Stmiko last edited by Stmiko
      habe seit ein paar Tagen Probleme mit jarvis. Es kommt keine Verbindung mehr zustande.
      Die Entwickler-Console sagt folgendes:
      app.d3faf308.js:1 App Welcome to jarvis v3.0.11
      app.d3faf308.js:1 App Using instance 0.
      app.d3faf308.js:1 App Time - Router Ready: 161.00ms
      app.d3faf308.js:1 19:08:50 | INFO | CONNECTION | Connecting to http://192.168.2.102:8400 (#1)...
      translate_content.js:1 -- Adding event listener for "initpopup" in content script
      translate_content.js:1 -- Adding event listener for "translateGoogleContent" in content script
      translate_content.js:1 -- Adding event listener for "translateGmailContent" in content script
      pdf_content.js:1 -- Adding event listener document event "to-content-script-event-start-pdf-compression-pdf2go"
      pdf_content.js:1 -- Adding event listener for "injectContentCss" in content script
      pdf_content.js:1 -> sending event to service worker from content script: to-service-worker-is-allowed-file-access-pdf2go
      pdf_injected.js:2 -- Adding event listener document event "to-injected-script-event-pdf-init-injected-main-pdf2go"
      pdf_injected.js:2 -- Adding event listener document event "to-injected-script-event-pdf-close-tool-pdf2go"
      pdf_injected.js:2 -- Adding event listener document event "to-injected-script-event-local-compress-fail-pdf2go"
      pdf_injected.js:2 -- Adding event listener for "setProgressBar" in injected script
      pdf_content.js:1 SENDING CONFIG
      pdf_content.js:1 -> Sending docment event "to-injected-script-event-pdf-init-injected-main-pdf2go"
      pdf_injected.js:2 <- Received document event "to-injected-script-event-pdf-init-injected-main-pdf2go"
      app.d3faf308.js:1 19:08:55 | ERROR | CONNECTION | Failed connecting to http://192.168.2.102:8400 (#1)!
      _message @ app.d3faf308.js:1
      app.d3faf308.js:1 19:08:55 | INFO | CONNECTION | Connecting to https://192.168.2.102:8400 (#2)...
      app.d3faf308.js:1 19:09:00 | ERROR | CONNECTION | Failed connecting to https://192.168.2.102:8400 (#2)!
      error @ app.d3faf308.js:1
      (anonym) @ app.d3faf308.js:1
      app.d3faf308.js:1 App-hGejAmgnwn Connection delayed Error: Connection delayed
          at app.d3faf308.js:1:563144
      index.html#/status0:1 Failed to decode downloaded font: http://192.168.2.102:8082/jarvis/fonts/materialdesignicons-webfont.606b1642.woff2
      index.html#/status0:1 OTS parsing error: Failed to convert WOFF 2.0 font to SFNT
      :8400/jarvis-socket/?EIO=4&transport=polling&t=O3TIpMU:1          Failed to load resource: net::ERR_SSL_PROTOCOL_ERROR
      Wann ist das Problem zum 1.mal aufgetreten: Tja, kann ich nicht so genau sagen 😞
      Ich bin auf dem beta-Repository. Meine Vermutung ist, das das mit irgendeinem Update kaputt gegangen ist. Leider hört hier mein Halbwissen auf.
      Kann mir evtl. jmd einen Tipp geben, woran das liegen könnte?
      Cache habe ich natürlich schon gelöscht. IP und Port sind richtig!
      js-controller: 4.0.23
      admin: 5.4.9
      jarvis: 3.0.11
      Vielen Dank im Voraus!
      Lg,
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: 16GB
      Festplattenart: SSD/HDD
      Betriebssystem: Debian11
      Node-Version: v14.19.3
      Nodejs-Version: v14.19.3
      NPM-Version: 6.14.17
      Installationsart: Manuell
      Image genutzt: Nein
        MCU @Stmiko last edited by
        @stmiko
        Wenn möglich bei neuen Fragen im jarvis Thread stellen:
        v3 -> https://forum.iobroker.net/topic/49776/jarvis-v3-0-0-just-another-remarkable-vis
        Web-Adapter-Version?
        https://mcuiobroker.gitbook.io/jarvis-infos/jarvis/besonderheiten-v3/fehler-hinweise-v3#error-timeout-oefter-bei-unterschiedlichen-geraeten
          @mcu sagte in jarvis: Failed connecting to http://192.168.2.102:8400 (#1)!:
          @stmiko
          Ok, Danke für den Hinweis... Lg
            Stmiko @Stmiko last edited by
            Falls es jmd interessiert: Dank proxmox habe ich einen alten snapshot eingespielt und die Updates nach-und-nach wieder eingespielt.......und jetzt läuft jarvis.
            Also k.A. woran das letztendlich gelegen hat 😞
            Lg
            connection error jarvis
