    4. Decoonz unter Zigbee Adapter funktioniert nicht (gelöst)
      lustig29 last edited by lustig29
      Ich probiere gerade einen Decoonz Conbee 2 Stick unter dem Zigbee Adapter zum laufen zu bringen. Leider wird die Instanz nicht grün.
      zigbee.0
      2022-05-20 19:42:08.020	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      2022-05-20 19:42:08.018	info	terminating
      zigbee.0
      2022-05-20 19:42:08.011	info	Zigbee: disabling joining new devices.
      zigbee.0
      2022-05-20 19:42:08.001	info	cleaned everything up...
      zigbee.0
      2022-05-20 19:42:07.973	error	Error while opening serialport 'Error: Error: No such file or directory, cannot open usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00'
      zigbee.0
      2022-05-20 19:42:07.972	error	Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00' at SerialPort.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:182:28) at SerialPort._error (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:198:14) at /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/stream/lib/index.js:242:12
      zigbee.0
      2022-05-20 19:42:07.970	error	unhandled promise rejection: Error while opening serialport 'Error: Error: No such file or directory, cannot open usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00'
      zigbee.0
      2022-05-20 19:42:07.969	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      2022-05-20 19:41:48.395	error	Error herdsman start
      zigbee.0
      2022-05-20 19:41:48.395	error	Failed to start Zigbee
      zigbee.0
      2022-05-20 19:41:48.393	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00'"
        Thomas Braun Most Active @lustig29 last edited by Thomas Braun
        @lustig29
        ls -l /dev/serial/by-id
        anschauen ob der Geräte-Link wirklich so lautet.
        In den Einstellungen des Adapters steht der komplette Pfad drin?
        Müsste sowas wie
        /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00
        dann sein.
          lustig29 @Thomas Braun last edited by lustig29
          @thomas-braun said in Decoonz unter Zigbee Adapter funktioniert nicht:
          /dev/serial/by-id/
          Pfad hab ich angepasst.
          Leider immer noch der Fehler.
          Hatte vorher den Decoonz Adapter laufen. Muss ich da eventuell noch was deinstallieren, oder spielt das keine Rolle?
          Thomas Braun 3 Replies Last reply Reply Quote 0
            @lustig29
            Und was sagt nun
            Und wie sieht ein Neustart des Adapters jetzt im Log aus?
              @lustig29 sagte in Decoonz unter Zigbee Adapter funktioniert nicht:
              Läuft der deconz-Kram noch?
              systemctl status deconz deconz-gui
                 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00 -> ../../ttyACM0
                zigbee.0
                2022-05-20 20:26:23.483	error	Error herdsman start
                zigbee.0
                2022-05-20 20:26:23.482	error	Failed to start Zigbee
                zigbee.0
                2022-05-20 20:26:23.479	error	Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: Device or resource busy, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2435893-if00'"
                   ^[[200~systemctl status deconz deconz-gui
                  -bash: $'\E[200~systemctl': Kommando nicht gefunden.
                    Nein, es ist nicht 'der Fehler'. Die Meldung ist nun eine andere.
                      @thomas-braun Wie kann ich das Problem lösen?
                        @lustig29
                        Bitte genau abtippen oder kopieren...
                          Warning: The unit file, source configuration file or drop-ins of deconz.service>
                          Unit deconz-gui.service could not be found.
                          ● deconz.service - deCONZ: ZigBee gateway -- REST API
                               Loaded: loaded (/lib/systemd/system/deconz.service; bad; vendor preset: en>
                               Active: active (running) since Tue 2022-03-29 19:18:27 CEST; 1 months 21 d>
                             Main PID: 346 (deCONZ)
                                Tasks: 4 (limit: 4915)
                                  CPU: 7h 55min 5.049s
                               CGroup: /system.slice/deconz.service
                                       └─346 /usr/bin/deCONZ -platform minimal --http-port=80
                          Mär 29 19:18:27 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST >
                          Mär 29 19:18:29 raspberrypi deCONZ[346]: QStandardPaths: XDG_RUNTIME_DIR not se>
                          Mär 29 19:18:30 raspberrypi deCONZ[346]: libpng warning: iCCP: known incorrect >
                          Mär 29 19:18:31 raspberrypi deCONZ[346]: This plugin does not support propagate>
                          Mär 29 19:18:34 raspberrypi deCONZ[346]: This plugin does not support propagate>
                          lines 1-17/17 (END)...skipping...
                          Warning: The unit file, source configuration file or drop-ins of deconz.service changed on disk. Run 'systemctl daemon-reload' to reload units.
                               Loaded: loaded (/lib/systemd/system/deconz.service; bad; vendor preset: enabled)
                               Active: active (running) since Tue 2022-03-29 19:18:27 CEST; 1 months 21 days ago
                          Mär 29 19:18:27 raspberrypi systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
                          Mär 29 19:18:29 raspberrypi deCONZ[346]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
                          Mär 29 19:18:30 raspberrypi deCONZ[346]: libpng warning: iCCP: known incorrect sRGB profile
                          Mär 29 19:18:31 raspberrypi deCONZ[346]: This plugin does not support propagateSizeHints()
                          Mär 29 19:18:34 raspberrypi deCONZ[346]: This plugin does not support propagateSizeHints()
                            @lustig29
                            sudo systemctl stop deconz
                            sudo systemctl disable deconz
                            Dann sollte ein Neustart auch 'grün' werden.
                              Super. Hat funktioniert. Besten Dank
                              422
