    4. Proxmox
    5. Fehler bei gnupg Installation
      Fridolin last edited by
      Moin
      brauche mal wieder eure Hilfe
      Habe einen neuen Container in proxxmox.
      Es soll gnupg installiert werden.
      Es läuft Ubuntu 20.04
      sudo apt-get update
      sudo apt-get -y install gnupg
      Es kommt folgende Fehlermeldung:
      Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
      Was genau läuft schief?
      Hatte sowas schonmal. Hing irgendwie mit den Berechtigungen zusammen wenn ich mich recht erinnere.
      Need Help 🙂
      Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Fridolin last edited by Thomas Braun
        @fridolin
        sudo apt update
        sudo apt full-upgrade
        anschauen. Und bitte vollständige Ein- wie Ausgaben in CodeTags posten.
        F 2 Replies Last reply Reply Quote 0
          Fridolin01 @Thomas Braun last edited by
          @thomas-braun said in Fehler bei gnupg Installation:
          sudo apt update
          sudo apt update
          sudo: setrlimit(RLIMIT_CORE): Operation not permitted
          Err:1 http://archive.ubuntu.com/ubuntu focal InRelease
            Temporary failure resolving 'archive.ubuntu.com'
          Err:2 http://archive.ubuntu.com/ubuntu focal-updates InRelease
          Err:3 http://archive.ubuntu.com/ubuntu focal-security InRelease
          Reading package lists... Done
          Building dependency tree... Done
          All packages are up to date.
          W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal/InRelease  Temporary failure resolving 'archive.ubuntu.com'
          W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-updates/InRelease  Temporary failure resolving 'archive.ubuntu.com'
          W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/focal-security/InRelease  Temporary failure resolving 'archive.ubuntu.com'
          W: Some index files failed to download. They have been ignored, or old ones used instead.
            Calculating upgrade... Done
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Thomas Braun Most Active @Fridolin01 last edited by Thomas Braun
              @fridolin01 sagte in Fehler bei gnupg Installation:
              Dann wirst du entweder dein Netzwerk/DNS reparieren müssen oder darauf warten müssen, bis der host wieder erreichbar ist.
              Ist wohl wieder so'n Container-Ding...
              Mir wären die Kübel ja echt zu anstrengend.
              • Meister Mopper
                Meister Mopper @Fridolin last edited by
                @fridolin
                Wie sieht die Netzwerkkonfiguration des Containers aus?
                  @fridolin01
                  Und das ist die vollständige, ungekürzte Ausgabe?
                  Wenn nein, bitte vollständige, ungekürzte Ein- und Ausgaben inkl. login prompt posten, wenn ja fehlt das nodesource-Repository.
                    @thomas-braun Ja Vollständig und ungekürzt
                    • crunchip
                      crunchip Forum Testing Most Active @Fridolin01 last edited by
                      @fridolin01
                      @thomas-braun sagte in Fehler bei gnupg Installation:
                        Fridolin01 @crunchip last edited by
                        @crunchip
                        Ubuntu 20.04 LTS Grafana tty1
                        Grafana login: root
                        Password:
                        Welcome to Ubuntu 20.04 LTS (GNU/Linux 5.4.34-1-pve x86_64)
                         * Documentation:  https://help.ubuntu.com
                         * Management:     https://landscape.canonical.com
                         * Support:        https://ubuntu.com/advantage
                        Failed to connect to https://changelogs.ubuntu.com/meta-release-lts. Check your Internet connection or proxy settings
                        Last login: Sun May 22 18:45:38 UTC 2022 on tty1
                        root@Grafana:~# sudo apt update
                        root@Grafana:~#
                        crunchip Meister Mopper 2 Replies Last reply Reply Quote 0
                        • crunchip
                          crunchip Forum Testing Most Active @Fridolin01 last edited by crunchip
                          Grafana login: root
                          https://www.iobroker.net/#de/documentation/install/proxmox.md
                            Homoran Global Moderator Administrators @crunchip last edited by Homoran
                            @crunchip sagte in Fehler bei gnupg Installation:
                            Grafana login: root
                            und dann auch noch:
                            • Meister Mopper
                              Meister Mopper @Fridolin01 last edited by
                              @fridolin01
                              Was man Dir mit präattentiver Visualisierung sagen möchte:
                              • Leg Dir für den Container einen User an und arbeite nicht als root.
                              • Gib die Kommandos mit sudo ein, wenn Du root-Rechte benötigst.
                              *duckundwech
                                Homoran Global Moderator Administrators @Meister Mopper last edited by
                                @meister-mopper sagte in Fehler bei gnupg Installation:
                                aber nicht wenn du schon root bist!
                                  Thomas Braun Most Active @Homoran last edited by Thomas Braun
                                  Dann bist du superroot: Neu, jetzt noch rootiger.
                                  @Fridolin01: Verfummel das System nicht! Bei Ubuntu gibt es keinen root-account. Hat es noch nie, wird es auch nie geben. Hier wird immer mit einem Standarduser hantiert, der Fallweise per sudo kurz die erforderlichen Rechte erlangen kann.
                                  Und kümmer dich um das Netzwerk, das scheint grundsätzlich falsch aufgesetzt zu sein. Also kein Problem mit den Repos sondern bei dir lokal.
                                  Meister Mopper 1 Reply Last reply Reply Quote 1
                                  • crunchip
                                    @homoran sagte in Fehler bei gnupg Installation:
                                    und dann auch noch:
                                    soweit hab ich gar nimmer gelesen😁
                                    • Meister Mopper
                                      Meister Mopper @Thomas Braun last edited by
                                      Da ist es wieder, das Container-Problem. Gibbet doch!
                                      Ubuntu 20.04.4 LTS pihole tty1
                                      pihole login: root
                                      Password:
                                      Welcome to Ubuntu 20.04.4 LTS (GNU/Linux 5.15.35-1-pve x86_64)
                                      Last login: Mi Sep 15 07:51:29 CEST 2021 on tty1
                                      root@pihole:~# lsb_release -a
                                      No LSB modules are available.
                                      Distributor ID: Ubuntu
                                      Description:    Ubuntu 20.04.4 LTS
                                      Release:        20.04
                                      Codename:       focal
                                        Thomas Braun Most Active @Meister Mopper last edited by Thomas Braun
                                        @meister-mopper
                                        Es wird trotzdem als Standarduser über das System gerutscht und nicht als root. In einer Standard-Installation von Ubuntu ist das auch immer der Fall. Bei den Müll-Containern sollte das auch Standard sein.
                                        Aber das ist offenbar ja nicht die einzige Fehlkonfiguration hier.
                                        Edit:
                                        Wenn ich mir anschaue, dass lt. Statistik Docker nicht mal 8% Anteil an den Installationen hat kommt es da zumindest gefühlt überproportional zu Problemen:
                                        Meister Mopper 2 Replies Last reply Reply Quote 1
                                        • Meister Mopper
                                          Ja natürlich! @Fridolin01 benötigt vielleicht eine Hilfe, wie er den normalen User anlegt?
                                          @Fridolin01 : Hier könntest Du jetzt was schreiben 🤷‍♂️
                                          • Meister Mopper
                                            Edit:
                                            Hast Du Dich verirrt? Docker?
                                            81.1k
                                            2340
