    4. Smartgarden - Keine Verbindung zu Gerät / Dienst
      SebastianF200 last edited by
      Hallo Zusammen,
      Ich scheitere wohlmöglich nur an einer Kleinigkeit.
      Mein Smartgarden Adapter Verbindet sich zum "Host" und auch die "Lebenszeichen" Anzeigen sind Grün, bzw. Verbunden.
      Bei der Verbindung mit Gerät oder Dienst bekomme Ich keine Verbindung zu Stande.
      Mail Adresse und Passwort habe Ich mehrfach Kontrolliert.
      Den API Key habe Ich mir auch generiert. (https://developer.husqvarnagroup.cloud/)
      Wo kann da noch ein Fehler begraben sein?
      smartgarden.0
      2022-05-27 11:53:57.214	info	1/ getConnection: trying to connect again in 300 seconds
      smartgarden.0
      2022-05-27 11:53:57.213	info	1/ getConnection: returned connection error: request returned 403 Forbidden
      smartgarden.0
      2022-05-27 11:53:57.211	error	Error: request returned 403 Forbidden
      smartgarden.0
      2022-05-27 11:53:57.210	info	1/ get_locations failure:..return with error
      smartgarden.0
      2022-05-27 11:53:57.209	info	1/ get_locations failure: response.statusCode/Message=403/Forbidden
      smartgarden.0
      2022-05-27 11:53:57.024	info	1/ get_locations ...
      smartgarden.0
      2022-05-27 11:53:57.022	info	1/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX-XXXXXXXXXXXX-XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
      smartgarden.0
      2022-05-27 11:53:57.020	info	1/ Connection: expires_in/timeout/factor:86399 / 86485 / 1.001
      smartgarden.0
      2022-05-27 11:53:57.019	info	1/ Connection: successful: response.statusCode / statusMessage=200 / OK
      smartgarden.0
      2022-05-27 11:53:56.619	info	1/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev/v1 authentication_host: https://api.authentication.husqvarnagroup.dev
      smartgarden.0
      2022-05-27 11:53:56.618	info	1/ connecting to Gardena Smart System Service ...
      smartgarden.0
      2022-05-27 11:53:56.615	info	1/ connectToGardena...
      smartgarden.0
      2022-05-27 11:53:56.614	info	1/ getConnection...
      smartgarden.0
      2022-05-27 11:53:56.549	info	starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v14.19.0, js-controller: 4.0.23
      host.raspberrypi-iob
      2022-05-27 11:53:54.731	info	instance system.adapter.smartgarden.0 started with pid 27117
      2022-05-27 11:53:52.259	info	instance system.adapter.smartgarden.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        // Erledigt
        Ich musste nur noch auf (https://developer.husqvarnagroup.cloud/) die API Verbinden.
        Läuft!!
